Good afternoon Tom, I think I'm almost reaching the finish line, first of all thank you so much for your suggestion, I could realize that I had to reinstall the HPM and everything is working correctly. As I had told you on my previous post my intention to integrate Broadlink to Hubitat is to control the Hurricane Shutters and some Windows Shade too. I was able to capture and save the code (RF) from one of my "Shutters" and then i create a Virtual Device "Virtual shade" type, and labeled as "SHUTTER 1".
Then using the BSM I imported the "saved code" to Hubitat but unfortunately when i tried to "Sync" the code to my Virtual Device "SHUTTER 1" it is not populated on the list, only the "Hubitat Remote" is populating. I am new on Hubitat and these are the only missing devices to complete my Dashboard and home automation and I feel really frustrated. I am sharing some captures and appreciate the help that can provide me. Thank you.
Hey Tom, thank you for your quick response I truly appreciated, believe me i read your article multiple times and you did an amazing job, I do not want to sound annoying but based on my ADHD and watching already a couple of videos on how to use the Rule machine i think i will go with the second option to use either "push" or "sendsavedcode". based on the information provided before what is the correct sentence or command to write to either "push or Sendsavedcode" to my desired device? Thank you again.
So, I have the RM4 Mini, and I tried unsuccessfully to do a RF sweep and learn, and then I read the box more closely and I think this device only supports IR. Is that right? It's the RM4 Mini, not the Pro.
Tom's work is based on the python-broadlink, which supports RM4C mini, but makes no mention of RM4C Pro. If you're in the EU or Australia, then 315 MHz isn't included in those versions.
Hello @tomw. I too am a newbie to Hubitat.
I am trying to control a light with IR remote via the braodlink rm4 mini. I can get things to work in the app but i want to control it in Hubitat.
I tried to enter the bundle zip file but i cant seem to get it to work. I also tried to use the driver code but couldn't manage that either. I am sure that it is something silly that I am not doing right but I just cant get it figured out. Thanks in advnace.
The easiest way to install most community apps & drivers is Hubitat Package Manager (HPM) which is also a community app itself.
HPM greatly simplifies installations and also provides easy access to any future updates, and has a great serach tool for finding new things -- it's a big win.
Not every community app/driver out there is available in HPM, but most of the most popular ones are -- and this one is.
I agree with the recommendation to use HPM. It really simplifies the installation process.
You can also use the readme on my GitHub page for this component (link is in first post of this thread) for detailed installation and configuration instructions. Please post back if that info doesn't clear things up.
So I have been able to connect the broadlink rm4 mini to the app. I have been able to add the driver to Hubitat.
Now I am having trouble adding the device to hubitat. Do i add it manually as a virtual device? If so, do i then make the "type" be broadband remote and the "device name" be anything that i want?
