@Royski give the new zip on Dropbox a try. Much better error handling, it should tell us what's going on.
Copy everything to your HubVoiceSat folder, reflash and run HubVoiceSatSetup.exe
hubvoice-sat-2026.04.03.1-release.zip
Just tried again, not much more info for you though ![]()
The light lights up when I say the wake word, then it just spins and doesn't stop.
| Time | Level | Tag | Message |
| 17:30:37 | [W] | [component:422] | debug set Warning flag: unspecified |
| 17:30:38 | [E] | [voice_assistant:548] | No API client connected |
| 17:30:38 | [W] | [component:462] | debug cleared Warning flag |
| 17:30:41 | [I] | [safe_mode:071] | Boot seems successful; resetting boot loop counter |
| 17:30:56 | [E] | [voice_assistant:548] | No API client connected |
On the HubVoice PC, test API port reachability:
PowerShell: Test-NetConnection 192.168.1.96 -Port 6054
Also, show me what this gives you:
http://127.0.0.1:8080/health
Here you go matey
{"ok": true, "status": "online", "queue_depth": 0, "voice_assistant": {}, "scheduler": {"timers": [], "alarms": [], "timer_count": 0, "alarm_count": 0}}
Please run these commands in PowerShell on the HubVoice PC and send me the output:
whoamiInvoke-WebRequest -UseBasicParsing http://127.0.0.1:8080/health | Select-Object -ExpandProperty ContentInvoke-WebRequest -UseBasicParsing http://127.0.0.1:8080/satellites | Select-Object -ExpandProperty ContentGet-Content "$env:LOCALAPPDATA\HubVoiceSat\satellites.csv"powershell -NoProfile -ExecutionPolicy Bypass -File "C:\HubVoice\restart-runtime.ps1" -ShutdownAllInvoke-WebRequest -UseBasicParsing http://127.0.0.1:8080/health | Select-Object -ExpandProperty ContentHere you go
@Royski , thanks for the info! I think I got it now. Try the new zip on Dropbox... hubvoice-sat-2026.04.05.1-release.zip
Could you advise on what the recommended specification is for the always on Windows machine.?
I'd prefer a Ubuntu solution as I already have a headless server up and working for my Chanels DVR.
Doesn't need much, for specifics I'd have no idea. I use a no name mini-pc off of Amazon for about $300 that also runs my Blue-iris server.
This is the second request for a Linux port. Definitely something to look into I guess.
Hey @bptworld ,
Ok so I updated but now have a different issue, the device is still not getting registered.
As a just in case, I made sure the required ports were opened on my UDM Pro firewall settings, but sadly no change, and there is no device being entered in the satellites.csv ![]()
BTW, just to be 100%, I take it this is my PCs IP which go in these fields right? Obs not the Hubitat one though ![]()
First thing that I see in your screenshot... you're not on the latest version.
Should be:
Thats just a screenshot from above, unrelated.
I am on the right one I was just being lazy with screenshots ![]()
One thing I did notice, as I have ChatGPT was there wasn't any settings in the app, after I had updated. So I removed and reinstalled on HE< hence the change in App ID
So now I have CGPT - ACE!!
Click 'open' and show me what you get
"ok": true,
"service": "HubVoiceSat runtime",
"port": 8080,
"queue_depth": 0,
"last_action": "idle",
"last_error": "",
"last_transcript": "",
"command_mode": "fast",
"scheduler": {
"timers": [],
"alarms": [],
"timer_count": 0,
"alarm_count": 0
Is there any reason it shows 8080 instead of 6054?
@Royski , I was able to reproduce it here. I think I finally fixed it.
New build on Dropbox...
hubvoice-sat-2026.04.06.2-release.zip
Will give it a go as soon as I can ![]()
Thanks , I'll keep my fingers crossed for a future Linux port...I don't really want another always on PC running. I'm trying to reduce my hub count ![]()
