[BETA] Hubitat File Driver (HFD)
For you, an user that can't wait to explore the latest awesome local files feature, I present a "provisory" solution for file access:
With HFD you can read/write/append to files directly from your apps and drivers, almost like if you were using a File API.
This is a BETA version. Bugs are expected, suggestions are welcome, even complaints too ... part of the business, of course.
I hope it is useful for the community.
Marco Felicio
Interesting.... Examples of use?
With HFD you can read/write/rewrite a file.
One example that I think of and use case for HFD is creating an user log - first create the file then append information to it.
As I said, there are some tradeoffs: it is necessary to create a virtual device for each file that you want to use.
In you case - if I'm not mistaken .. - you'd need a file to duplicate a tile definition. If you can live with a single file for that - a plain workfile - I think HFD can be useful for you.
I warn you that it that seems to be a file size limitation due to Hubitat's current implementation of the local files. This is expected, since it is a beta feature.
Marco
Just dropping this here as a "PSA" because I couldn't find this info very easily
To easily read the contents of a file from local storage see example below replacing filename.txt with your filename.
String fileText = "http://${location.hub.localIP}:8080/local/filename.txt".toURL().getText();
H
Interesting …
Could you explain this a bit further. Where does that line go?
In your device handler code where you need to get something out of a file. The entire file contents are in the variable fileText. Clear?
