Setting up on a secondary hub.
First, installed Hub Information Driver v3 from HPM.
Second, installed Hub Detailed Information Display from HPM.
Third, Error loading Hub Detailed Information Display App
2025-04-04 03:04:36.402 PM error java.lang.NullPointerException: Cannot invoke method div() on null object on line 360 (method pageRender)
Because I forgot to enable attribute polling on Hub Information Driver v3.
Set CPU/Memory polling, then loading Hub Detailed Information Display App produced a really nice display just like you'd expect.
Fourth, went into settings and thought "Hmm what would happen if I select a Temp sensor?"
Answer: Back to error and App not loading.
So, I'm about to delete Hub Detailed Information Display App and re-install it but thought I'd ask if there was another option to get to the device select setting?
