Anyone close to Henderson KY?
Hi everyone. Is there anyone close to Henderson KY who could guide me along?
Thanks in advance.
‘bout 3 hours down river from me, so probably not stopping by, but what are you having issues with?
Close in spirit... :wink: Plenty here from all kinds of time zones happy to help, all you need do is ask.
Not nearby but I can do remote support, if interested send me PM.
Ok, so far, 3 takers. Lol. Well, I will take what help I can get. As you can tell, I am new to hubitat. Duh. I have worked with smart life devices but most of them were wifi. I am starting to get some more zigbee devices. So, let me guess, not much out there for use with tuya wifi devices. I will get back with you guys in a bit after a nap. Lol.
Thanks for responding with positive replies.
What devices do you have already? Tuya or Zigbee? Or others....
Tuya does sell a Matter capable hub, which I believe can be integrated with Hubitat. @kkossev would be able to answer you better.
Tuya Matter Bridges will bring only the Tuya Zigbee devices to Huitat.
For Tuya WiFi devices integration - [BETA] Tuya Cloud Driver (Limited device support).
Well, this page won't let me answer to an individual post, but that's ok.
As for equipment, I have tuya zigbee hub
Amazon.com Not sure if it can mesh with hubitat
THIRDREALITY ZigBee Smart Plug 4 Pack -working fine on hubitat in repeater mode. https://www.amazon.com/gp/aw/d/B0BPY5D1KC?psc=1&ref=ppx_pop_mob_b_asin_title
2 kmc 4 way outlet
Amazon.com a pair of these that are wifi
I have 5 of these
Amazon.com these are also wifi
One of these QMQJIA SmartHomeControls Tool Zigbee Wireless Scene Switches Push button https://www.amazon.com/QIACHIP-Wireless-Control-Supports-Requires/dp/B0BRZZCV94/ref=mp_s_a_1_6?dib=eyJ2IjoiMSJ9.jU-TSAygDOKQrxc8Zp7ANzZANW7Be1EG4fM9oaibZGjhRSJqSALKA_Q-2kv-qVKmLy8jFuKHCwE8iFjYHFqnL5Gh7EN1sVJ_3Sukq4nnrs2VCVEEzLCjR3swYNDCNQFBhuuJqTc0LqrtnoatwTv0nfR2wV-Op_5Xk0n10_BbfdM6cjg_EtQX61edWJdBkTXd3fFjrPcmk8xODxaUOVgXcg.ZPQzY0RUhGS_PoM8TCo2qQF_8-Bkb7dnQteXUJ_DaO0&dib_tag=se&keywords=QMQJIA+SmartHomeControls+Tool+Zigbee+Wireless+Scene+Switches+Push+button&qid=1725583028&sr=8-6
4 KMC Smart plug model 30154 wifi w/o power monitoring
4 KMC Smart plug model 70011 w/power monitoring
2 tuya smart fingerbots both zigbee and sort of working in hubitat. Mine has the extra activate button on top. I can't seem to get the controls to work correctly. I can push the on button in the interface and it comes on. If you press the on button again it does nothing. I have to press the off before the on a second time. I have not yet tried to pair an tuya energy meter. I have another ordered and I will try when it comes in.
I have 3 of this power meter
https://www.aliexpress.us/item/3256806006840605.html?spm=a2g0n.order_detail.order_detail_item.3.cf72f19c7nbA4n&gatewayAdapt=glo2usa
One 120a and 2 80a and it is wifi
One of these tuya Hose timers Smart Garden wifi Watering Timer Remote Automatic Drip Irrigation Controller | eBay it says it is zigbee but I can't get it to pair with hubitat.
Now for the extras. Lol
Can anything ooma be used in hubitat? I have a ooma voip phone and security system.i would like to get away from it and strictly have it local.
Oh, and I have 3 fiet bulbs that are connected to smart life app and I have not tried to put them on hubitat. I think they are wifi bulbs though.
I think that is all for now. I have my work cut out for me, that's for sure.
Thanks for the assist.by the time I am done (hopefully a few weeks learning curve), I will either be CRAZY or I will be in a position to help others.
Paul
I may end up having to drive a few hours to get with someone. I am not afraid to drive a bit. Lol
With all of that tuya and other nonstandard gear, I’m gonna guess Crazy, unless you are a computer wiz and have an extra linux box lying around waiting to install Home Assistant on so you can bring everything into Hubitat.
You should have a look at the supported devices list.
Most of the Tuya gadgets that you have could be used in Hubitat.
The first app to install should be the Hubitat Package Manager (HPM) - you will use it to install the rest of the custom drivers needed for these devices that are not natively supported in HE.
This is not the Matter bridge model, but will be discovered by the Tuya Cloud Driver and it will bring to HE these Zigbee devices that may remain paired to the Tuya hub via the cloud integration.
The KMC Smart Tap 4-Outlet Wall Mounted Plugs should be exposed via the Tuya Cloud Driver.
The WiFi Humidity Temperature sensors should be exposed via the Tuya Cloud Driver.
Install the Tuya Scene Switch TS004F driver via HPM, then pair directly to your Hubitat hub.
Via Tuya Cloud Driver.
Use HPM to install Tuya Zigbee Fingerbot driver.
Try again the Tuya Cloud Driver.
If it is Zigbee, could be supported by this driver : Tuya Zigbee Valve driver.
If WiFi - simple on/off control should be possible via the Cloud driver.
Obviously @kkossev has already been there and come out the other side.... :slight_smile:
That would not surprise me one bit. Lol
@kkossev wow, thank you for the breakdown. I just read it today, I do not know how I missed it before.
You really went through a bit there for me. It seems i need to get this tuya cloud wifi crap pulled into HE.
By the way, I believe I got the info on the tuya side done, now I need to get better instructions for the HE side. On the tuya side, I can see all devices on the tuya iot platform.
Thanks again.
@rob9 what's on your mind? Why delete your post?
I had a question then went another direction
Oh, gotcha.
Near Maysville, KY, but on the ohio side.
@user5224
That is not to far, but I would definitely need to make a day of it with 2 hour there and 2 hours back.
I see your a beta tester. So you either know hubitat pretty well or you love the latest and greatest even if it does not work out of the gate. Lol. Looking on the community board, it looks like you joined the hubitat system in April of 2023. So, you have been working with hubitat way longer than me. I imagine you could share loads of info in person. Questions and ideas flow best that way. I sooooo hate this messaging back and forth. Sometimes it is ok, but most of the time, it is excruciating slow waiting for replies.
So, what is your first name, I am Paul. Thanks for messaging me back.
