can this be updated with @nateG 's addition pls?
I updated app and driver code but still get lots of debug logging
@Angus_M i think roberts driver and app rewrite were so in the device you can toggle the logging on and off.
No, I don't think so. You edit the app code directly to turn the logging on or off. I don't see anything in the device page to allow me to toggle the logging status.
I'm wondering if there is anything I have to do after updating the driver and app code. I tried re-running the app initialisation. I did a refresh in the device pages. I resaved the devices. Still I seem to get copious logging.
3+ pages like this every minute...
@robert1 code reduced message traffic substantially for me. My post was about an error code I was getting that I would have gotten when I used @blink code as well. Your image looks like it is not using @robert1 code. I would suggest uninstalling device and then run @robert1 app again.
The App code is where the majority of the logging noise comes from.
Th code, as provided, has the logging turned off.
There is code in the device handler too, but isn't the source of much noise. This is done through the UI (for each device) - the default will be off anyway, because the variables don't exist.
However, I just checked the code, and the 'parseEventData' function in the driver has the logging in your screen shot.
So, go in to each Sensibo device, under the Preferences section, turn off the debug and info toggles, and save the preferences. This should make a massive difference.
Then you're not running the right Driver.
Copy from post #38 above
I noticed when looking at the driver code again there are a lot of log.trace lines of code. However, it only generates 3 rows every 5 minutes or so. I might go fix this later, but it's not noisy enough for me to bother right now.
Ah it seems ok now. I don't think the devices refreshed properly after updating the driver. Now they seem fine, the preferences have appeared and the logging is much reduced! Cheers.
yeah, this is what i get too, but it's not so obtrusive...
New device code that adds @nateG request and also adds traceLogging wrapper so save those few extra lines.
* Sensibo
* Copyright 2015 Eric Gosselin
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
preferences {
//Logging Message Config
input name: "infoLogging", type: "bool", title: "Enable info message logging", description: ""
input name: "debugLogging", type: "bool", title: "Enable debug message logging", description: ""
input name: "traceLogging", type: "bool", title: "Enable trace message logging", description: ""
metadata {
definition (name: "SensiboPod", namespace: "EricG66", author: "Eric Gosselin", oauth: false) {
capability "Relative Humidity Measurement"
capability "Temperature Measurement"
capability "Polling"
capability "Refresh"
capability "Switch"
capability "Thermostat"
capability "Battery"
capability "Actuator"
capability "Sensor"
capability "Health Check"
capability "Power Source"
capability "Voltage Measurement"
attribute "swing", "String"
attribute "temperatureUnit","String"
attribute "productModel","String"
attribute "firmwareVersion","String"
attribute "Climate","String"
attribute "targetTemperature","Double"
attribute "statusText","String"
attribute "currentmode","String"
attribute "fanLevel","String"
attribute "on","String" // Added by request of NateG
command "setAll"
command "switchFanLevel"
command "switchMode"
command "raiseCoolSetpoint"
command "lowerCoolSetpoint"
command "raiseHeatSetpoint"
command "lowerHeatSetpoint"
command "voltage"
command "raiseTemperature"
command "lowerTemperature"
command "switchSwing"
command "setThermostatMode"
command "modeHeat"
command "modeCool"
command "modeDry"
command "modeFan"
command "modeAuto"
command "lowfan"
command "mediumfan"
command "highfan"
command "quietfan"
command "strongfan"
command "autofan"
command "fullswing"
command "setAirConditionerMode"
command "toggleClimateReact"
command "setClimateReact"
command "configureClimateReact"
simulator {
tiles(scale: 2) {
multiAttributeTile(name:"thermostatMulti", type:"thermostat",, width:6, height:4,canChangeIcon: false) {
tileAttribute("device.temperature", key: "PRIMARY_CONTROL") {
attributeState ("default", label:'${currentValue}°')//,
//backgroundColors:[
// [value: 15, color: "#153591"],
// [value: 18, color: "#1e9cbb"],
// [value: 21, color: "#90d2a7"],
// [value: 24, color: "#44b621"],
// [value: 27, color: "#f1d801"],
// [value: 30, color: "#d04e00"],
// [value: 33, color: "#bc2323"],
// [value: 59, color: "#153591"],
// [value: 64, color: "#1e9cbb"],
// [value: 70, color: "#90d2a7"],
// [value: 75, color: "#44b621"],
// [value: 81, color: "#f1d801"],
// [value: 86, color: "#d04e00"],
// [value: 91, color: "#bc2323"]
tileAttribute("device.targetTemperature", key: "VALUE_CONTROL") {
attributeState("VALUE_UP", action: "raiseTemperature")
attributeState("VALUE_DOWN", action: "lowerTemperature")
tileAttribute("device.humidity", key: "SECONDARY_CONTROL") {
attributeState("default", label:'${currentValue}%', unit:"%")
tileAttribute("device.thermostatOperatingState", key: "OPERATING_STATE") {
attributeState("idle", backgroundColor:"#a9a9a9")
attributeState("heating", backgroundColor:"#e86d13")
attributeState("cooling", backgroundColor:"#00a0dc")
attributeState("fan only", backgroundColor:"#44b621")
attributeState("Dry", backgroundColor:"#A1E5E5")
tileAttribute("device.thermostatMode", key: "THERMOSTAT_MODE") {
attributeState("off", label:'${name}')
attributeState("heat", label:'${name}')
attributeState("cool", label:'${name}')
attributeState("fan", label:'${name}')
attributeState("dry", label:'${name}')
attributeState("auto", label:'${name}')
tileAttribute("device.heatingSetpoint", key: "HEATING_SETPOINT") {
attributeState("default", label:'${currentValue}')
tileAttribute("device.coolingSetpoint", key: "COOLING_SETPOINT") {
valueTile("temperature", "device.temperature", width: 2, height: 2) {
state("temperature", label:'Temp: ${currentValue}',backgroundColors:[])
valueTile("humidity", "device.humidity", width: 2, height: 2) {
state("humidity", label:'Humidity: ${currentValue} %',
backgroundColors:[
valueTile("voltage", "device.voltage", width: 1, height: 1) {
state("voltage", label:'${currentValue}',
backgroundColors:[
[value: 2700, color: "#CC0000"],
[value: 2800, color: "#FFFF00"],
[value: 2900, color: "#00FF00"]
valueTile("firmwareVersion", "device.firmwareVersion", width: 1, height: 1) {
state("version", label:'Firmware: ${currentValue}',backgroundColors:[])
valueTile("productModel", "device.productModel", width: 1, height: 1) {
state("mains", label:'Model: ${currentValue}',backgroundColors:[])
valueTile("powerSource", "device.powerSource", width: 1, height: 1) {
state("mains", icon:"https://image.ibb.co/inKcN5/cable_power_cord_plug_circle_512.png", label:'Source: ${currentValue}',backgroundColors:[])
state("battery", icon:"https://image.ibb.co/gFUNpk/battery.jpg", label:'Source: ${currentValue}',backgroundColors:[])
standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true) {
state "on", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#00a0dc"
state "off", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff"
standardTile("fanLevel", "device.fanLevel", width: 2, height: 2) {
state "low", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/gZxHpk/fan_low_2.png", nextState:"medium"
state "medium", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/cUa3Uk/fan_medium_2.png", nextState:"high"
state "high", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/fcfFaQ/fan_high_2.png", nextState:"auto"
state "auto", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/m8oq9k/fan_auto_2.png" , nextState:"quiet"
state "quiet", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/mC74wb/fan_quiet2.png" , nextState:"medium_high"
state "medium_high", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/j62DXR/fan_medium_3.png" , nextState:"medium_low"
state "medium_low", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/etX296/fan_low_3.png" , nextState:"strong"
state "strong", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/eaLeUw/fan_strong2.png" , nextState:"low"
standardTile("currentmode", "device.thermostatMode", width: 2, height: 2) {
state "heat", action:"switchMode", backgroundColor:"#e86d13", icon:"https://image.ibb.co/c7Grh5/sun.png", nextState:"cool"
state "cool", action:"switchMode", backgroundColor:"#00a0dc", icon:"https://image.ibb.co/bZ56FQ/cold.png", nextState:"fan"
state "fan", action:"switchMode", backgroundColor:"#e8e3d8", icon:"https://image.ibb.co/n1dhpk/status_message_fan.png", nextState:"dry"
state "dry", action:"switchMode", backgroundColor:"#e8e3d8", icon:"https://image.ibb.co/k2ZNpk/dry_mode.png", nextState:"auto"
state "auto", action:"switchMode", backgroundColor:"#e8e3d8", icon:"https://image.ibb.co/dwaRh5/auto_mode.png", nextState:"heat"
standardTile("upCoolButtonControl", "device.targetTemperature", inactiveLabel: false, decoration: "flat", width: 1, height: 2) {
state "setpoint", action:"raiseCoolSetpoint", icon:"st.thermostat.thermostat-up",label :"Up"
standardTile("downCoolButtonControl", "device.targetTemperature", inactiveLabel: false, decoration: "flat", width: 1, height: 2) {
state "setpoint", action:"lowerCoolSetpoint", icon:"st.thermostat.thermostat-down", label :"Down"
standardTile("swing", "device.swing", width: 2, height: 2) {
state "stopped", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/iWhvaQ/stopped.png", nextState:"fixedTop"
state "fixedTop", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/nbV3Uk/fixedTop.png", nextState:"fixedMiddleTop"
state "fixedMiddleTop", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/chbcpk/fixed_Middle_Top.png", nextState:"fixedMiddle"
state "fixedMiddle", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/dxDe25/fixed_Middle.png", nextState:"fixedMiddleBottom"
state "fixedMiddleBottom", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/ebZmh5/fixed_Middle_Bottom.png", nextState:"fixedBottom"
state "fixedBottom", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/n2tCN5/fixed_Bottom.png", nextState:"rangeTop"
state "rangeTop", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/gYQsN5/rangeTop.png", nextState:"rangeMiddle"
state "rangeMiddle", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/dC1XN5/range_Middle.png", nextState:"rangeBottom"
state "rangeBottom", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/csTOUk/range_Bottom.png", nextState:"rangeFull"
state "rangeFull", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/hHK8vQ/range_Full.png", nextState:"horizontal"
state "horizontal", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/cAGQ2G/range_Horizontal2.png", nextState:"both"
state "both", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/dLUOpw/range_Both2.png", nextState:"stopped"
standardTile("Climate", "device.Climate", width: 2, height: 2) {
state "on", label:'${name}', action:"toggleClimateReact", icon:"https://i.ibb.co/Z8ZzcHR/auto-fix-2.png", backgroundColor:"#00a0dc"
state "off", label:'${name}', action:"toggleClimateReact", icon:"https://i.ibb.co/Z8ZzcHR/auto-fix-2.png", backgroundColor:"#ffffff"
state "notdefined", label:'N/A', action:"toggleClimateReact", icon:"https://i.ibb.co/Z8ZzcHR/auto-fix-2.png", backgroundColor:"#e86d13"
standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", label:"Refresh", action:"refresh.refresh", icon:"st.secondary.refresh"
standardTile("coolmode", "device.thermostatMode", width: 1, height: 1) {
state "cool", action:"modeCool", backgroundColor:"#00a0dc", icon:"https://image.ibb.co/bZ56FQ/cold.png"
standardTile("heatmode", "device.thermostatMode", width: 1, height: 1) {
state "heat", action:"modeHeat", backgroundColor:"#e86d13", icon:"https://image.ibb.co/c7Grh5/sun.png"
standardTile("drymode", "device.thermostatMode", width: 1, height: 1) {
state "dry", action:"modeDry", backgroundColor:"#e8e3d8", icon:"https://image.ibb.co/k2ZNpk/dry_mode.png"
standardTile("fanmode", "device.thermostatMode", width: 1, height: 1) {
state "fan", action:"modeFan", backgroundColor:"#e8e3d8", icon:"https://image.ibb.co/n1dhpk/status_message_fan.png"
standardTile("highfan", "device.fanLevel", width: 1, height: 1) {
state "high", action:"highfan", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/fcfFaQ/fan_high_2.png"
standardTile("autofan", "device.fanLevel", width: 1, height: 1) {
state "auto", action:"autofan", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/m8oq9k/fan_auto_2.png"
standardTile("fullswing", "device.swing", width: 1, height: 1) {
state "rangeFull", action:"fullswing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/hHK8vQ/range_Full.png"
main (["switch"])
details (["thermostatMulti","switch","fanLevel","currentmode","swing","Climate","refresh","coolmode","heatmode","fanmode","drymode","highfan","autofan","fullswing","firmwareVersion","productModel","powerSource","voltage"])
private def displayDebugLog(message) {
if (debugLogging) log.debug "${device.displayName}: ${message}"
private def displayTraceLog(message) {
if (traceLogging) log.trace "${device.displayName}: ${message}"
private def displayInfoLog(message) {
if (infoLogging || state.prefsSetCount != 1)
log.info "${device.displayName}: ${message}"
def setAll(newMode,temp,fan)
displayTraceLog( "setAll() called with " + newMode + "," + temp + "," + fan )
def Setpoint = temp.toInteger()
def LevelBefore = fan
def capabilities = parent.getCapabilities(device.deviceNetworkId,newMode)
def Level = LevelBefore
if (capabilities.remoteCapabilities != null) {
def fanLevels = capabilities.remoteCapabilities.fanLevels
displayDebugLog("Fan levels capabilities : " + capabilities.remoteCapabilities.fanLevels)
Level = GetNextFanLevel(LevelBefore,capabilities.remoteCapabilities.fanLevels)
displayDebugLog("Fan : " + Level)
def result = parent.setACStates(this, device.deviceNetworkId, "on", newMode, Setpoint, Level, device.currentState("swing").value, device.currentState("temperatureUnit").value)
if (result) {
if (LevelBefore != Level) {
generatefanLevelEvent(Level)
sendEvent(name: 'thermostatMode', value: newMode, displayed: false,isStateChange: true)
if (device.currentState("on").value == "off") { generateSwitchEvent("on") }
generateModeEvent(newMode)
generateStatusEvent()
refresh()
else {
generateErrorEvent()
else {
def lowfan()
displayTraceLog( "lowfan() called")
dfanLevel("low")
def mediumfan()
displayTraceLog( "mediumfan() called")
dfanLevel("medium")
def highfan()
displayTraceLog( "highfan() called")
dfanLevel("high")
def quietfan()
displayTraceLog( "quietfan() called")
dfanLevel("quiet")
def strongfan()
displayTraceLog( "strongfan() called")
dfanLevel("strong")
def autofan()
displayTraceLog( "autofan() called")
dfanLevel("auto")
def fullswing()
displayTraceLog( "fullswing() called")
modeSwing("rangeFull")
def temperatureDown(temp)
displayTraceLog( "temperatureDown() called with "+ temp)
def sunit = device.currentValue("temperatureUnit")
def capabilities = parent.getCapabilities(device.deviceNetworkId, device.currentState("currentmode").value)
def values
if (sunit == "F") {
if (capabilities.remoteCapabilities.temperatures.F == null) {
return -1
values = capabilities.remoteCapabilities.temperatures.F.values
else {
if (capabilities.remoteCapabilities.temperatures.C == null) {
return -1
values = capabilities.remoteCapabilities.temperatures.C.values
def found = values.findAll{number -> number < temp}
displayDebugLog("Values retrieved : " + found)
if (found == null || found.empty) found = values.first()
else found = found.last()
displayDebugLog("Temp before : " + temp )
displayDebugLog("Temp after : " + found)
temp = found
return temp
def temperatureUp(temp)
displayTraceLog( "temperatureUp() called with "+ temp)
def values
if (sunit == "F") {
return -1
else {
return -1
def found = values.findAll{number -> number > temp}
if (found == null || found.empty) found = values.last()
else found = found.first()
temp = found
return temp
void raiseTemperature() {
displayTraceLog( "raiseTemperature() called" )
def operMode = device.currentState("currentmode").value
def Setpoint = device.currentValue("targetTemperature").toInteger()
def theTemp = device.currentValue("temperatureUnit")
displayDebugLog("Current target temperature = ${Setpoint}")
Setpoint = temperatureUp(Setpoint)
if (Setpoint == -1) {
return
switch (operMode) {
case "heat":
setHeatingSetpoint(Setpoint)
break;
case "cool":
setCoolingSetpoint(Setpoint)
break;
case "fan":
setFanSetpoint(Setpoint)
break;
case "dry":
setDrySetpoint(Setpoint)
break;
case "auto":
break;
default:
break;
void lowerTemperature() {
displayTraceLog( "lowerTemperature() called")
Setpoint = temperatureDown(Setpoint)
return
switch (operMode) {
case "heat":
break;
case "cool":
break;
case "fan":
break;
case "dry":
break;
case "auto":
break;
default:
break;
void lowerCoolSetpoint() {
displayTraceLog( "lowerCoolSetpoint() called")
def result = parent.setACStates(this, device.deviceNetworkId , "on", device.currentState("currentmode").value, Setpoint, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
if (result) {
displayInfoLog( "Cooling temperature changed to " + Setpoint + " for " + device.deviceNetworkId)
sendEvent(name: 'coolingSetpoint', value: Setpoint, displayed: false)
sendEvent(name: 'thermostatSetpoint', value: Setpoint, displayed: false)
generateSetTempEvent(Setpoint)
displayDebugLog("New target Temperature = ${Setpoint}")
refresh()
else {
displayDebugLog("error")
void setThermostatMode(modes)
displayTraceLog( "setThermostatMode() called")
def currentMode = device.currentState("currentmode").value
displayDebugLog("switching AC mode from current mode: $currentMode")
switch (modes) {
case "cool":
modeCool()
break
//case "fan":
// returnCommand = modeFan()
// break
//case "dry":
// returnCommand = modeDry()
// break
case "auto":
modeAuto()
break
case "heat":
modeHeat()
break
case "off":
off()
break
void setAirConditionerMode(modes)
displayTraceLog( "setAirConditionerMode() called")
switch (modes) {
case "cool":
modeCool()
break
case "fanOnly":
case "fan":
modeFan()
break
case "dry":
modeDry()
break
case "auto":
modeAuto()
break
case "heat":
modeHeat()
break
void raiseCoolSetpoint() {
displayTraceLog( "raiseCoolSetpoint() called")
if (result) {
refresh()
else {
void raiseHeatSetpoint() {
displayTraceLog( "raiseHeatSetpoint() called")
if (result) {
displayInfoLog( "Heating temperature changed to " + Setpoint + " for " + device.deviceNetworkId)
sendEvent(name: 'heatingSetpoint', value: Setpoint, displayed: false)
refresh()
else {
void lowerHeatSetpoint() {
displayTraceLog( "lowerHeatSetpoint() called")
if (result) {
refresh()
else {
def refresh()
displayTraceLog( "refresh() called")
poll()
displayTraceLog( "refresh() ended")
// Set Temperature
def setFanSetpoint(temp) {
displayTraceLog( "setFanSetpoint() called")
temp = temp.toInteger()
displayDebugLog("setTemperature : " + temp )
def result = parent.setACStates(this, device.deviceNetworkId , "on", "fan", temp, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
if (result) {
displayInfoLog( "Fan temperature changed to " + temp + " for " + device.deviceNetworkId)
generateModeEvent("fan")
sendEvent(name: 'thermostatSetpoint', value: temp, displayed: false)
generateSetTempEvent(temp)
refresh()
else {
// Set Temperature
def setDrySetpoint(temp) {
displayTraceLog( "setDrySetpoint() called")
def result = parent.setACStates(this, device.deviceNetworkId , "on", "dry", temp, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
if (result) {
displayInfoLog( "Dry temperature changed to " + temp + " for " + device.deviceNetworkId)
generateModeEvent("dry")
refresh()
else {
// Set Temperature
def setCoolingSetpoint(temp) {
displayTraceLog( "setCoolingSetpoint() called")
def result = parent.setACStates(this, device.deviceNetworkId , "on", "cool", temp, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
if (result) {
displayInfoLog( "Cooling temperature changed to " + temp + " for " + device.deviceNetworkId)
generateModeEvent("cool")
sendEvent(name: 'coolingSetpoint', value: temp, displayed: false)
//sendEvent(name: 'heatingSetpoint', value: temp, displayed: false)
refresh()
else {
def setHeatingSetpoint(temp) {
displayTraceLog( "setHeatingSetpoint() called")
displayDebugLog("setTemperature : " + temp)
def result = parent.setACStates(this, device.deviceNetworkId , "on", "heat", temp, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
if (result) {
displayInfoLog( "Heating temperature changed to " + temp + " for " + device.deviceNetworkId)
generateModeEvent("heat")
//sendEvent(name: 'coolingSetpoint', value: temp, displayed: false)
refresh()
else {
def generateSetTempEvent(temp) {
sendEvent(name: "targetTemperature", value: temp, descriptionText: "$device.displayName set temperature is now ${temp}", displayed: true, isStateChange: true)
// Turn off or Turn on the AC
def on() {
displayTraceLog( "on called")
displayDebugLog("Temp Unit : " + device.currentState("temperatureUnit").value)
def result = parent.setACStates(this, device.deviceNetworkId, "on", device.currentState("currentmode").value, Setpoint, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
displayDebugLog("Result : " + result)
if (result) {
displayInfoLog( "AC turned ON for " + device.deviceNetworkId)
sendEvent(name: 'thermostatMode', value: device.currentState("currentmode").value, displayed: false,isStateChange: true)
//sendEvent(name: 'thermostatOperatingState', value: "idle",isStateChange: true)
refresh()
else {
def off() {
displayTraceLog( "off called")
def result = parent.setACStates(this, device.deviceNetworkId, "off", device.currentState("currentmode").value, Setpoint, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
if (result) {
displayInfoLog( "AC turned OFF for " + device.deviceNetworkId)
sendEvent(name: 'thermostatMode', value: "off", displayed: false,isStateChange: true)
generateSwitchEvent("off")
refresh()
else {
def generateSwitchEvent(mode) {
sendEvent(name: "on", value: mode, descriptionText: "$device.displayName is now ${mode}", displayed: false, isStateChange: true)
sendEvent(name: "switch", value: mode, descriptionText: "$device.displayName is now ${mode}", displayed: true, isStateChange: true)
//refresh()
def dfanLevel(String newLevel){
displayTraceLog( "dfanLevel called with fan = " + newLevel)
Level = GetNextFanLevel(newLevel,capabilities.remoteCapabilities.fanLevels)
//displayDebugLog("Fan : " + Level)
def result = parent.setACStates(this, device.deviceNetworkId,"on", device.currentState("currentmode").value, Setpoint, Level, device.currentState("swing").value, device.currentState("temperatureUnit").value)
if (result) {
displayInfoLog( "Fan level changed to " + Level + " for " + device.deviceNetworkId)
if (Level == "low") {
sendEvent(name: 'thermostatFanMode', value: "circulate", displayed: false)
else {
sendEvent(name: 'thermostatFanMode', value: "on", displayed: false)
refresh()
else {
else {
//TODO when the mode do not exist
def generatefanLevelEvent(mode) {
sendEvent(name: "fanLevel", value: mode, descriptionText: "$device.displayName fan level is now ${mode}", displayed: true, isStateChange: true)
// toggle Climate React
def toggleClimateReact()
displayTraceLog( "toggleClimateReact() called")
def currentClimateMode = device.currentState("Climate")?.value
def returnCommand
switch (currentClimateMode) {
case "off":
returnCommand = setClimateReact("on")
break
case "on":
returnCommand = setClimateReact("off")
break
if (!returnCommand) { returnCommand }
// Set Climate React
def setClimateReact(ClimateState) {
/// Parameter ClimateState : "on" or "off"
displayTraceLog( "setClimateReact() called")
displayDebugLog("Climate : " + ClimateState )
def result = parent.setClimateReact(this, device.deviceNetworkId, ClimateState)
if (result) {
displayInfoLog( "Climate React changed to " + ClimateState + " for " + device.deviceNetworkId)
sendEvent(name: 'Climate', value: ClimateState, displayed: false)
//generateSetTempEvent(temp)
refresh()
else {
def configureClimateReact(lowThres, highThres,stype,lowState,highState, on_off, ThresUnit)
// lowThres and highThres - Integer parameters
// stype : possible values are "temperature", "humidity" or "feelsLike"
// lowState and highState :
// on, fanLevel, temperatureUnit, targetTemperature, mode
// like "[true,'auto','C',21,'heat']"
// to turn off AC,first parameters = false : "[false,'auto','C',21,'heat']"
// one_off : boolean value to enable/disable the Climate React
// unit : Passing F for Farenheit or C for Celcius
// Some examples:
// Range 19-24 Celcius, start to heat to 22 at auto fan if the temp is lower than 19 and stop the AC when higher than 24
// configureClimateReact(19, 24, ‘temperature’, ‘[true, ‘auto’, ‘C’, 22, ‘heat’]’, ‘[false, ‘auto’, ‘C’, 22, ‘heat’]’, true, ‘C’);
// Range 67-68 Farenheit, start to heat to 68 at auto fan if the temp is lower than 67 and stop the AC when higher than 68
// configureClimateReact(67, 68, ‘temperature’, ‘[true, ‘auto’, ‘F’, 68, ‘heat’]’, ‘[false, ‘auto’, ‘F’, 68, ‘heat’]’, true, ‘F’);
displayTraceLog( "configureClimateReact() called")
if (ThresUnit.toUpperCase() == "F")
lowThres = fToc(lowThres).round(1)
highThres = fToc(highThres).round(1)
def json = new groovy.json.JsonBuilder()
def lowStateMap = evaluate(lowState)
def highStateMap = evaluate(highState)
def lowStateJson
def highStateJson
if (lowStateMap) {
lowStateJson = json {
on lowStateMap[0]
fanLevel lowStateMap[1]
temperatureUnit lowStateMap[2]
targetTemperature lowStateMap[3]
mode lowStateMap[4]
else { lowStateJson = null }
if (highStateMap) {
highStateJson = json {
on highStateMap[0]
fanLevel highStateMap[1]
temperatureUnit highStateMap[2]
targetTemperature highStateMap[3]
mode highStateMap[4]
else { highStateJson = null }
def root = json {
deviceUid device.deviceNetworkId
highTemperatureWebhook null
highTemperatureThreshold highThres
lowTemperatureWebhook null
type stype
lowTemperatureState lowStateJson
enabled on_off
highTemperatureState highStateJson
lowTemperatureThreshold lowThres
displayDebugLog("CLIMATE REACT STRING : " + JsonOutput.prettyPrint(json.toString()))
def result = parent.configureClimateReact(this, device.deviceNetworkId, json.toString())
if (result) {
displayInfoLog( "Climate React settings changed for " + device.deviceNetworkId)
sendEvent(name: 'Climate', value: on_off, displayed: false)
refresh()
else {
def switchFanLevel() {
displayTraceLog( "switchFanLevel() called")
def currentFanMode = device.currentState("fanLevel")?.value
displayDebugLog("switching fan level from current mode: $currentFanMode")
def returnCommand
switch (currentFanMode) {
case "low":
returnCommand = dfanLevel("medium")
break
case "medium":
returnCommand = dfanLevel("high")
break
case "high":
returnCommand = dfanLevel("auto")
break
case "auto":
returnCommand = dfanLevel("quiet")
break
case "quiet":
returnCommand = dfanLevel("medium_high")
break
case "medium_high":
returnCommand = dfanLevel("medium_low")
break
case "medium_low":
returnCommand = dfanLevel("strong")
break
case "strong":
returnCommand = dfanLevel("low")
break
returnCommand
def modeHeat()
displayTraceLog( "modeHeat() called")
modeMode("heat")
def modeCool()
displayTraceLog( "modeCool() called")
modeMode("cool")
def modeDry()
displayTraceLog( "modeDry() called")
modeMode("dry")
def modeFan()
displayTraceLog( "modeFan() called")
modeMode("fan")
def modeAuto()
displayTraceLog( "modeAuto() called")
modeMode("auto")
// To change the AC mode
def switchMode() {
displayTraceLog( "switchMode() called")
def currentMode = device.currentState("currentmode")?.value
def returnCommand
switch (currentMode) {
case "heat":
returnCommand = modeMode("cool")
break
case "cool":
returnCommand = modeMode("fan")
break
case "fan":
returnCommand = modeMode("dry")
break
case "dry":
returnCommand = modeMode("auto")
break
case "auto":
returnCommand = modeMode("heat")
break
returnCommand
def modeMode(String newMode){
displayTraceLog( "modeMode() called with " + newMode)
def LevelBefore = device.currentState("fanLevel").value
if (result) {
displayInfoLog( "Mode changed to " + newMode + " for " + device.deviceNetworkId)
refresh()
else {
else {
def themodes = parent.getCapabilities(device.deviceNetworkId,"modes")
def sMode = GetNextMode(newMode,themodes)
NextMode(sMode)
def generateModeEvent(mode) {
sendEvent(name: "thermostatMode", value: mode, descriptionText: "$device.displayName Thermostat mode is now ${mode}", displayed: true, isStateChange: true)
def returnNext(liste1, liste2, val) throws Exception
try {
def index = liste2.indexOf(val)
if (index == -1) throw new Exception()
else return liste2[liste2.indexOf(val)]
catch(Exception e) {
if (liste1.indexOf(val)+ 1 == liste1.size()) {
val = liste1[0]
else {
val = liste1[liste1.indexOf(val) + 1]
def GetNextFanLevel(fanLevel, fanLevels)
displayTraceLog( "GetNextFanLevel called with " + fanLevel)
if (fanLevels == null || fanLevels == "null") {
return null
def listFanLevel = ['low','medium','high','auto','quiet','medium_high','medium_low','strong']
def newFanLevel = returnNext(listFanLevel, fanLevels,fanLevel)
displayDebugLog("Next fanLevel = " + newFanLevel)
return newFanLevel
def GetNextMode(mode, modes)
displayTraceLog( "GetNextMode called with " + mode)
def listMode = ['heat','cool','fan','dry','auto']
def newMode = returnNext(listMode, modes,mode)
displayDebugLog("Next Mode = " + newMode)
return newMode
def NextMode(sMode)
displayTraceLog( "NextMode called()")
if (sMode != null) {
switch (sMode)
case "heat":
modeHeat()
break
case "cool":
modeCool()
break
case "fan":
modeFan()
break
case "dry":
modeDry()
break
case "auto":
modeAuto()
break
else
return null
def GetNextSwingMode(swingMode, swingModes){
displayTraceLog( "GetNextSwingMode() called with " + swingMode)
if (swingModes == null || swingModes == "null") {
return null
def listSwingMode = ['stopped','fixedTop','fixedMiddleTop','fixedMiddle','fixedMiddleBottom','fixedBottom','rangeTop','rangeMiddle','rangeBottom','rangeFull','horizontal','both']
def newSwingMode = returnNext(listSwingMode, swingModes,swingMode)
displayDebugLog("Next Swing Mode = " + newSwingMode)
return newSwingMode
def switchSwing() {
displayTraceLog( "switchSwing() called")
def currentMode = device.currentState("swing")?.value
displayDebugLog("switching Swing mode from current mode: $currentMode")
def returnCommand
case "stopped":
returnCommand = modeSwing("fixedTop")
break
case "fixedTop":
returnCommand = modeSwing("fixedMiddleTop")
break
case "fixedMiddleTop":
returnCommand = modeSwing("fixedMiddle")
break
case "fixedMiddle":
returnCommand = modeSwing("fixedMiddleBottom")
break
case "fixedMiddleBottom":
returnCommand = modeSwing("fixedBottom")
break
case "fixedBottom":
returnCommand = modeSwing("rangeTop")
break
case "rangeTop":
returnCommand = modeSwing("rangeMiddle")
break
case "rangeMiddle":
returnCommand = modeSwing("rangeBottom")
break
case "rangeBottom":
returnCommand = modeSwing("rangeFull")
break
case "rangeFull":
returnCommand = modeSwing("horizontal")
break
case "horizontal":
returnCommand = modeSwing("both")
break
case "both":
returnCommand = modeSwing("stopped")
break
returnCommand
def modeSwing(String newSwing)
displayTraceLog( "modeSwing() called with " + newSwing)
def SwingBefore = device.currentState("swing").value
def Swing = SwingBefore
def Swings = capabilities.remoteCapabilities.swing
displayDebugLog("Swing capabilities : " + capabilities.remoteCapabilities.swing)
Swing = GetNextSwingMode(newSwing,capabilities.remoteCapabilities.swing)
//displayDebugLog("Swing : " + Swing)
def result = parent.setACStates(this, device.deviceNetworkId, "on", device.currentState("currentmode").value, Setpoint, device.currentState("fanLevel").value, Swing, device.currentState("temperatureUnit").value)
if (result) {
displayInfoLog( "Swing mode changed to " + Swing + " for " + device.deviceNetworkId)
sendEvent(name: 'swing', value: Swing, displayed: false,isStateChange: true)
generateSwingModeEvent(Swing)
refresh()
else {
else
//TODO
def generateSwingModeEvent(mode) {
sendEvent(name: "swing", value: mode, descriptionText: "$device.displayName swing mode is now ${mode}", displayed: true, isStateChange: true)
def generateErrorEvent() {
displayDebugLog("$device.displayName FAILED to set the AC State")
sendEvent(name: "Error", value: "Error", descriptionText: "$device.displayName FAILED to set or get the AC State", displayed: true, isStateChange: true)
void poll() {
displayTraceLog( "Executing 'poll' using parent SmartApp")
def results = parent.pollChild(this)
def linkText = getLinkText(device)
parseTempUnitEventData(results)
parseEventData(results)
def parseTempUnitEventData(Map results)
displayDebugLog("parsing data $results")
if(results)
results.each { name, value ->
if (name=="temperatureUnit") {
def isChange = true
def isDisplayed = false
sendEvent(
value: value,
//unit: value,
linkText: linkText,
descriptionText: "${name} = ${value}",
handlerName: "temperatureUnit",
isStateChange: isChange,
displayed: isDisplayed)
def parseEventData(Map results)
displayDebugLog("parsing Event data $results")
if(results)
displayDebugLog("name :" + name + " value :" + value)
def isChange = false
def isDisplayed = true
if (name=="voltage") {
isChange = true //isTemperatureStateChange(device, name, value.toString())
isDisplayed = false
sendEvent(
value: value,
unit: "mA",
linkText: linkText,
descriptionText: getThermostatDescriptionText(name, value, linkText),
handlerName: name,
else if (name== "battery") {
isDisplayed = false
sendEvent(
value: value,
//unit: "V",
linkText: linkText,
handlerName: name,
else if (name== "powerSource") {
isDisplayed = false
sendEvent(
value: value,
linkText: linkText,
handlerName: name,
else if (name== "Climate") {
isChange = true
isDisplayed = false
sendEvent(
value: value,
linkText: linkText,
handlerName: name,
else if (name=="on") {
isChange = true
isDisplayed = false
sendEvent(
value: value,
linkText: linkText,
handlerName: name,
sendEvent(name: "switch", value: value)
else if (name=="thermostatMode") {
isDisplayed = false
if (value=="cool") {
sendEvent(name: 'airConditionerMode', value: "cool",
sendEvent(name: 'thermostatOperatingState', value: "cooling",
} else if (value=="heat") {
sendEvent(name: 'airConditionerMode', value: "heat",
sendEvent(name: 'thermostatOperatingState', value: "heating",
} else if (value=="fan") {
sendEvent(name: 'airConditionerMode', value: "fanOnly",
sendEvent(name: 'thermostatOperatingState', value: "fan only",
} else if (value=="dry") {
sendEvent(name: 'airConditionerMode', value: "dry",
sendEvent(name: 'thermostatOperatingState', value: "dry",
} else if (value=="auto") {
sendEvent(name: 'airConditionerMode', value: "auto",
sendEvent(name: 'thermostatOperatingState', value: "auto",
} else {
sendEvent(
value: value,
linkText: linkText,
handlerName: name,
else if (name=="coolingSetpoint" || name== "heatingSetpoint" || name == "thermostatSetpoint") {
isDisplayed = false
sendEvent(
value: value,
//unit : device.currentValue("temperatureUnit"),
linkText: linkText,
handlerName: name,
else if (name=="temperatureUnit") {
isChange = true
isDisplayed = false
sendEvent(
value: value,
//unit: value,
linkText: linkText,
handlerName: name,
else if (name=="thermostatFanMode") {
def mode = (value.toString() == "high" || value.toString() == "medium") ? "on" : value.toString()
mode = (mode == "low") ? "circulate" : mode
isDisplayed = false
sendEvent(
value: value,
linkText: linkText,
handlerName: name,
else if (name=="swing") {
isDisplayed = false
sendEvent(
value: value,
linkText: linkText,
handlerName: name,
else if (name=="temperature" || name== "lastTemperaturePush" || name== "lastHumidityPush") {
isDisplayed = false
sendEvent(
value: value,
//unit: device.currentValue("temperatureUnit"),
linkText: linkText,
handlerName: name,
else if (name=="humidity") {
isDisplayed = false
sendEvent(
value: value,
linkText: linkText,
handlerName: name,
else {
isChange = true//isStateChange(device, name, value.toString())
isDisplayed = false//isChange
sendEvent(
value: value.toString(),
linkText: linkText,
handlerName: name,
generateStatusEvent ()
private getThermostatDescriptionText(name, value, linkText)
if(name == "temperature")
return "$name was $value " + device.currentState("temperatureUnit").value
else if(name == "humidity")
return "$name was $value %"
else if(name == "targetTemperature")
return "latest temperature setpoint was $value " + device.currentState("temperatureUnit").value
else if(name == "fanLevel")
return "latest fan level was $value"
else if(name == "on")
return "latest switch was $value"
else if (name == "mode")
return "thermostat mode was ${value}"
else if (name == "currentmode")
else if (name == "powerSource")
return "power source mode was ${value}"
else if (name == "Climate")
return "Climate React was ${value}"
else if (name == "thermostatMode")
else if (name == "temperatureUnit")
return "thermostat unit was ${value}"
else if (name == "voltage")
return "Battery voltage was ${value}"
else if (name == "battery")
return "Battery was ${value}"
else if (name == "voltage" || name== "battery")
else if (name == "swing")
return "Swing mode was ${value}"
else if (name == "Error")
def str = (value == "Failed") ? "failed" : "success"
return "Last setACState was ${str}"
else
return "${name} = ${value}"
// parse events into attributes
displayDebugLog("Parsing '${description}'")
def name = null
def value = null
def statusTextmsg = ""
def msg = parseLanMessage(description)
def headersAsString = msg.header // => headers as a string
def headerMap = msg.headers // => headers as a Map
def body = msg.body // => request body as a string
def status = msg.status // => http status code of the response
def json = msg.json // => any JSON included in response body, as a data structure of lists and maps
def xml = msg.xml // => any XML included in response body, as a document tree structure
def data = msg.data // => either JSON or XML in response body (whichever is specified by content-type header in response)
if (description?.startsWith("on/off:")) {
displayDebugLog("Switch command")
name = "switch"
value = description?.endsWith(" 1") ? "on" : "off"
else if (description?.startsWith("temperature")) {
displayDebugLog("Temperature")
name = "temperature"
value = device.currentValue("temperature")
else if (description?.startsWith("humidity")) {
displayDebugLog("Humidity")
name = "humidity"
value = device.currentValue("humidity")
else if (description?.startsWith("targetTemperature")) {
displayDebugLog("targetTemperature")
name = "targetTemperature"
value = device.currentValue("targetTemperature")
else if (description?.startsWith("fanLevel")) {
displayDebugLog("fanLevel")
name = "fanLevel"
value = device.currentValue("fanLevel")
else if (description?.startsWith("currentmode")) {
displayDebugLog("mode")
name = "currentmode"
value = device.currentValue("currentmode")
else if (description?.startsWith("on")) {
displayDebugLog("on")
name = "on"
value = device.currentValue("on")
else if (description?.startsWith("switch")) {
displayDebugLog("switch")
name = "switch"
else if (description?.startsWith("temperatureUnit")) {
displayDebugLog("temperatureUnit")
name = "temperatureUnit"
value = device.currentValue("temperatureUnit")
else if (description?.startsWith("Error")) {
displayDebugLog("Error")
name = "Error"
value = device.currentValue("Error")
else if (description?.startsWith("voltage")) {
displayDebugLog("voltage")
name = "voltage"
value = device.currentValue("voltage")
else if (description?.startsWith("battery")) {
displayDebugLog("battery")
name = "battery"
value = device.currentValue("battery")
else if (description?.startsWith("swing")) {
displayDebugLog("swing")
name = "swing"
value = device.currentValue("swing")
def result = createEvent(name: name, value: value)
displayDebugLog("Parse returned ${result?.descriptionText}")
return result
def generateStatusEvent() {
def temperature = device.currentValue("temperature").toDouble()
def humidity = device.currentValue("humidity").toDouble()
def targetTemperature = device.currentValue("targetTemperature").split(' ')[0].toDouble()
def fanLevel = device.currentValue("fanLevel")
def mode = device.currentValue("currentmode")
def on = device.currentValue("on")
def swing = device.currentValue("swing")
def ClimateReact = device.currentValue("Climate")
def error = device.currentValue("Error")
def sUnit = device.currentValue("temperatureUnit")
statusTextmsg = "${humidity}%"
sendEvent("name":"statusText", "value":statusTextmsg, "description":"", displayed: false, isStateChange: true)
def fToc(temp) {
return ((temp - 32) / 1.8).toDouble()
def ping(){
displayTraceLog( "calling parent ping()")
return parent.ping()
has anyone been able to get their sensibos connected to alexa to control directly ?
I have tried all the versions of this app/driver - and the alexa skill is exposing them both to alexa discovery but it just doesn't migrate.
Why not use the Sensibo Alexa skill?
I have that and it works, but it doesnt push the status through to HE / i'd prefer HE to be controlling as much as possible and not Alexa.
I'm getting this error trying to install the app...
Cannot get property 'input' on null object on line 19
id delete the app and driver. Try using the original ones in post 24 before upgrading to the other one.
Given Line 19 of the DEVICE code has the word 'input' in it, I suspect you are trying to load the device in to the app instead of the app code.
Added debug level preference to the app instead of having to modify code. Started uploading some of my smarthome code to GitHub, so included this one at:
Hopefully, this makes things easier to find instead of scrolling through all the code pasting in this tread.
Hi, @blink. It looks like there is a problem with the namespaces in the GitHub code. Driver and App using the different namespaces, so I get exception.
And anyway, thank you for you work!
