Anybody using a Sensibo?
Hi there @blink, unfortunately I am getting the same error message as @blanghor:
dev:142019-04-26 12:42:38.815 errorjava.lang.NullPointerException: Cannot get property 'value' on null object on line 649 (on)
My reverse cycle unit does support swing settings (toggle button on the remote), but the Sensibo itself does not seem to - no options for such control in the App or the web interface.
I have looked into your firmware suggestion, and there doesn't appear to be a method for updating the Sensibo Firmware that I can see in their knowledge base or the App itself.
I have also tried hardcoding "stopped" into line 665 of your App code, although I'm not sure I have done this correctly. Currently I have substituted
tData.data.swing = swingM
for
tData.data.swing = stopped
Is this correct? Apologies but I'm not much of a coder. Keen to learn more though!
Any other potential solutions if this code adjustment has been done correctly?
I was never able to get it working even with hardcoding swing to stop. I had contacted Sensibo about a firmware upgrade and they told me mine was up to date.
My Sensibo works fine in SmartThings with the integration, which this code is based on. I believe in the ST logs I also see SwingM being null, but the integration works properly.
what happens if you remove the line completely?
You need to specify stopped a string, so probably:
tData.data.swing = "stopped"
I didn't write the code for this app/device handler - It's just a port of EricG's implementation for the ST Hub. Mostly just removing some imports and statements, or defining variables that Hubitat needs to function in a similar manner. I noticed some small issues with the code I previously pasted, and EricG has posted an update for the app and DTH. Here's an updated version that I'm using in Hubitat. I've added in a statement to try to catch the null swing modes. Not sure if that solves your problem, but it's worth a try.
Device Handler
 *  Sensibo
 *  Copyright 2015 Eric Gosselin
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
preferences {
metadata {
	definition (name: "SensiboPod", namespace: "EricG66", author: "Eric Gosselin", oauth: false) {
		capability "Relative Humidity Measurement"
		capability "Temperature Measurement"
		capability "Polling"
        capability "Refresh"
        capability "Switch"
        capability "Thermostat"
        capability "Battery"
        capability "Actuator"
        capability "Sensor"
        capability "Health Check"
        capability "Power Source"
        capability "Voltage Measurement"
        attribute "swing", "String"
        attribute "temperatureUnit","String"
        attribute "productModel","String"
        attribute "firmwareVersion","String"
        attribute "Climate","String"
		attribute "targetTemperature","Double"
        attribute "statusText","String"
        attribute "currentmode","String"
        attribute "fanLevel","String"
        command "setAll"
        command "switchFanLevel"
        command "switchMode"
        command "raiseCoolSetpoint"
        command "lowerCoolSetpoint"
        command "raiseHeatSetpoint"
        command "lowerHeatSetpoint"
        command "voltage"
        command "raiseTemperature"
        command "lowerTemperature"
        command "switchSwing"
        command "setThermostatMode"
        command "modeHeat"
        command "modeCool"
        command "modeDry"
        command "modeFan"
        command "modeAuto"
        command "lowfan"
        command "mediumfan"
        command "highfan"
        command "quietfan"
        command "strongfan"
        command "autofan"
        command "fullswing"
        command "setAirConditionerMode"
        command "toggleClimateReact"
        command "setClimateReact"
        command "configureClimateReact"
	simulator {
	tiles(scale: 2) {
    	multiAttributeTile(name:"thermostatMulti", type:"thermostat",, width:6, height:4,canChangeIcon: false) {
   			tileAttribute("device.temperature", key: "PRIMARY_CONTROL") {
            	attributeState ("default", label:'${currentValue}°')//,
                //backgroundColors:[
				//	[value: 15, color: "#153591"],
				//	[value: 18, color: "#1e9cbb"],
				//	[value: 21, color: "#90d2a7"],
				//	[value: 24, color: "#44b621"],
				//	[value: 27, color: "#f1d801"],
				//	[value: 30, color: "#d04e00"],
				//	[value: 33, color: "#bc2323"],
                //    [value: 59, color: "#153591"],
				//	[value: 64, color: "#1e9cbb"],
				//	[value: 70, color: "#90d2a7"],
				//	[value: 75, color: "#44b621"],
				//	[value: 81, color: "#f1d801"],
				//	[value: 86, color: "#d04e00"],
				//	[value: 91, color: "#bc2323"]
            tileAttribute("device.targetTemperature", key: "VALUE_CONTROL") {
                attributeState("VALUE_UP", action: "raiseTemperature")
                attributeState("VALUE_DOWN", action: "lowerTemperature")
            tileAttribute("device.humidity", key: "SECONDARY_CONTROL") {
   				attributeState("default", label:'${currentValue}%', unit:"%")
            tileAttribute("device.thermostatOperatingState", key: "OPERATING_STATE") {
    			attributeState("idle", backgroundColor:"#a9a9a9")
    			attributeState("heating", backgroundColor:"#e86d13")
    			attributeState("cooling", backgroundColor:"#00a0dc")
                attributeState("fan only", backgroundColor:"#44b621")
                attributeState("Dry", backgroundColor:"#A1E5E5")
  			tileAttribute("device.thermostatMode", key: "THERMOSTAT_MODE") {
    			attributeState("off", label:'${name}')
                attributeState("heat", label:'${name}')
                attributeState("cool", label:'${name}')
                attributeState("fan", label:'${name}')
                attributeState("dry", label:'${name}')
    			attributeState("auto", label:'${name}')
  			tileAttribute("device.heatingSetpoint", key: "HEATING_SETPOINT") {
    			attributeState("default", label:'${currentValue}')
  			tileAttribute("device.coolingSetpoint", key: "COOLING_SETPOINT") {
		valueTile("temperature", "device.temperature", width: 2, height: 2) {
			state("temperature", label:'Temp: ${currentValue}',backgroundColors:[])
		valueTile("humidity", "device.humidity", width: 2, height: 2) {
			state("humidity", label:'Humidity: ${currentValue} %',
				backgroundColors:[
        valueTile("voltage", "device.voltage", width: 1, height: 1) {
			state("voltage", label:'${currentValue}',
				backgroundColors:[
					[value: 2700, color: "#CC0000"],
					[value: 2800, color: "#FFFF00"],
					[value: 2900, color: "#00FF00"]
        valueTile("firmwareVersion", "device.firmwareVersion", width: 1, height: 1) {
			state("version", label:'Firmware: ${currentValue}',backgroundColors:[])
        valueTile("productModel", "device.productModel", width: 1, height: 1) {
			state("mains", label:'Model: ${currentValue}',backgroundColors:[])
        valueTile("powerSource", "device.powerSource", width: 1, height: 1) {
			state("mains", icon:"https://image.ibb.co/inKcN5/cable_power_cord_plug_circle_512.png", label:'Source: ${currentValue}',backgroundColors:[])
            state("battery", icon:"https://image.ibb.co/gFUNpk/battery.jpg", label:'Source: ${currentValue}',backgroundColors:[])
        standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true) {
			state "on", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#00a0dc"
			state "off", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff"
        standardTile("fanLevel", "device.fanLevel", width: 2, height: 2) {
            state "low", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/gZxHpk/fan_low_2.png", nextState:"medium"
            state "medium", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/cUa3Uk/fan_medium_2.png", nextState:"high"
            state "high", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/fcfFaQ/fan_high_2.png", nextState:"auto"
            state "auto", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/m8oq9k/fan_auto_2.png" , nextState:"quiet"
            state "quiet", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/mC74wb/fan_quiet2.png" , nextState:"medium_high"
            state "medium_high", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/j62DXR/fan_medium_3.png" , nextState:"medium_low"
            state "medium_low", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/etX296/fan_low_3.png" , nextState:"strong"
            state "strong", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/eaLeUw/fan_strong2.png" , nextState:"low"
        standardTile("currentmode", "device.thermostatMode",  width: 2, height: 2) {
            state "heat", action:"switchMode", backgroundColor:"#e86d13", icon:"https://image.ibb.co/c7Grh5/sun.png", nextState:"cool"
            state "cool", action:"switchMode", backgroundColor:"#00a0dc", icon:"https://image.ibb.co/bZ56FQ/cold.png", nextState:"fan"
            state "fan", action:"switchMode", backgroundColor:"#e8e3d8", icon:"https://image.ibb.co/n1dhpk/status_message_fan.png", nextState:"dry"
            state "dry", action:"switchMode", backgroundColor:"#e8e3d8", icon:"https://image.ibb.co/k2ZNpk/dry_mode.png", nextState:"auto"
            state "auto", action:"switchMode", backgroundColor:"#e8e3d8", icon:"https://image.ibb.co/dwaRh5/auto_mode.png", nextState:"heat"
        standardTile("upCoolButtonControl", "device.targetTemperature", inactiveLabel: false, decoration: "flat", width: 1, height: 2) {
			state "setpoint", action:"raiseCoolSetpoint", icon:"st.thermostat.thermostat-up",label :"Up"
        standardTile("downCoolButtonControl", "device.targetTemperature", inactiveLabel: false, decoration: "flat", width: 1, height: 2) {
			state "setpoint", action:"lowerCoolSetpoint", icon:"st.thermostat.thermostat-down", label :"Down"
        standardTile("swing", "device.swing",  width: 2, height: 2) {
            state "stopped", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/iWhvaQ/stopped.png", nextState:"fixedTop"
            state "fixedTop", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/nbV3Uk/fixedTop.png", nextState:"fixedMiddleTop"
            state "fixedMiddleTop", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/chbcpk/fixed_Middle_Top.png", nextState:"fixedMiddle"
            state "fixedMiddle", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/dxDe25/fixed_Middle.png", nextState:"fixedMiddleBottom"
            state "fixedMiddleBottom", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/ebZmh5/fixed_Middle_Bottom.png", nextState:"fixedBottom"
            state "fixedBottom", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/n2tCN5/fixed_Bottom.png", nextState:"rangeTop"
            state "rangeTop", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/gYQsN5/rangeTop.png", nextState:"rangeMiddle"
            state "rangeMiddle", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/dC1XN5/range_Middle.png", nextState:"rangeBottom"
            state "rangeBottom", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/csTOUk/range_Bottom.png", nextState:"rangeFull"
            state "rangeFull", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/hHK8vQ/range_Full.png", nextState:"horizontal"
            state "horizontal", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/cAGQ2G/range_Horizontal2.png", nextState:"both"
            state "both", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/dLUOpw/range_Both2.png", nextState:"stopped"
        standardTile("Climate", "device.Climate", width: 2, height: 2) {
			state "on", label:'${name}', action:"toggleClimateReact", icon:"https://i.ibb.co/Z8ZzcHR/auto-fix-2.png", backgroundColor:"#00a0dc"
			state "off", label:'${name}', action:"toggleClimateReact", icon:"https://i.ibb.co/Z8ZzcHR/auto-fix-2.png", backgroundColor:"#ffffff"
            state "notdefined", label:'N/A', action:"toggleClimateReact", icon:"https://i.ibb.co/Z8ZzcHR/auto-fix-2.png", backgroundColor:"#e86d13"
        standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
			state "default", label:"Refresh", action:"refresh.refresh", icon:"st.secondary.refresh"
        standardTile("coolmode", "device.thermostatMode",  width: 1, height: 1) {
       		state "cool", action:"modeCool", backgroundColor:"#00a0dc", icon:"https://image.ibb.co/bZ56FQ/cold.png"
        standardTile("heatmode", "device.thermostatMode",  width: 1, height: 1) {
       		state "heat", action:"modeHeat", backgroundColor:"#e86d13", icon:"https://image.ibb.co/c7Grh5/sun.png"
        standardTile("drymode", "device.thermostatMode",  width: 1, height: 1) {
       		state "dry", action:"modeDry", backgroundColor:"#e8e3d8", icon:"https://image.ibb.co/k2ZNpk/dry_mode.png"
        standardTile("fanmode", "device.thermostatMode",  width: 1, height: 1) {
       		state "fan", action:"modeFan", backgroundColor:"#e8e3d8", icon:"https://image.ibb.co/n1dhpk/status_message_fan.png"
        standardTile("highfan", "device.fanLevel",  width: 1, height: 1) {
       		state "high", action:"highfan", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/fcfFaQ/fan_high_2.png"
        standardTile("autofan", "device.fanLevel",  width: 1, height: 1) {
       		state "auto", action:"autofan", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/m8oq9k/fan_auto_2.png"
        standardTile("fullswing", "device.swing",  width: 1, height: 1) {
       		state "rangeFull", action:"fullswing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/hHK8vQ/range_Full.png"
		main (["switch"])
		details (["thermostatMulti","switch","fanLevel","currentmode","swing","Climate","refresh","coolmode","heatmode","fanmode","drymode","highfan","autofan","fullswing","firmwareVersion","productModel","powerSource","voltage"])
def setAll(newMode,temp,fan)
	log.trace "setAll() called with " + newMode + "," + temp + "," + fan
    def Setpoint = temp.toInteger()
    def LevelBefore = fan
    def capabilities = parent.getCapabilities(device.deviceNetworkId,newMode)
    def Level = LevelBefore
    if (capabilities.remoteCapabilities != null) {
    	def fanLevels = capabilities.remoteCapabilities.fanLevels
    	log.debug "Fan levels capabilities : " + capabilities.remoteCapabilities.fanLevels
        Level = GetNextFanLevel(LevelBefore,capabilities.remoteCapabilities.fanLevels)
        log.debug "Fan : " + Level
        def result = parent.setACStates(this, device.deviceNetworkId, "on", newMode, Setpoint, Level, device.currentState("swing").value, device.currentState("temperatureUnit").value)
        if (result) {
        	if (LevelBefore != Level) {
                generatefanLevelEvent(Level)
            sendEvent(name: 'thermostatMode', value: newMode, displayed: false,isStateChange: true)
            if (device.currentState("on").value == "off") { generateSwitchEvent("on") }
            generateModeEvent(newMode)
            generateStatusEvent()
            refresh()
        else {
            generateErrorEvent()
    else {
def lowfan()
	log.trace "lowfan() called"
	dfanLevel("low")
def mediumfan()
	log.trace "mediumfan() called"
	dfanLevel("medium")
def highfan()
	log.trace "highfan() called"
	dfanLevel("high")
def quietfan()
	log.trace "quietfan() called"
	dfanLevel("quiet")
def strongfan()
	log.trace "strongfan() called"
	dfanLevel("strong")
def autofan()
	log.trace "autofan() called"
	dfanLevel("auto")
def fullswing()
	log.trace "fullswing() called"
	modeSwing("rangeFull")
def temperatureDown(temp)
	log.trace "temperatureDown() called with "+ temp
	def sunit = device.currentValue("temperatureUnit")
    def capabilities = parent.getCapabilities(device.deviceNetworkId, device.currentState("currentmode").value)
    def values
    if (sunit == "F") {
    	if (capabilities.remoteCapabilities.temperatures.F == null) {
       		return -1
    	values = capabilities.remoteCapabilities.temperatures.F.values
    else {
    	if (capabilities.remoteCapabilities.temperatures.C == null) {
       		return -1
    	values = capabilities.remoteCapabilities.temperatures.C.values
    def found = values.findAll{number -> number < temp}
	log.debug "Values retrieved : " + found
    if (found == null || found.empty) found = values.first()
    else found = found.last()
    log.debug "Temp before : " + temp
    log.debug "Temp after : " + found
    temp = found
    return temp
def temperatureUp(temp)
	log.trace "temperatureUp() called with "+ temp
    def values
    if (sunit == "F") {
       		return -1
    else {
       		return -1
    def found = values.findAll{number -> number > temp}
    if (found == null || found.empty) found = values.last()
    else found = found.first()
    temp = found
    return temp
void raiseTemperature() {
	log.trace "raiseTemperature() called"
	def operMode = device.currentState("currentmode").value
    def Setpoint = device.currentValue("targetTemperature").toInteger()
    def theTemp = device.currentValue("temperatureUnit")
    log.debug "Current target temperature = ${Setpoint}"
	Setpoint = temperatureUp(Setpoint)
    if (Setpoint == -1) {
      return
    switch (operMode) {
    	case "heat":
        	setHeatingSetpoint(Setpoint)
            break;
        case "cool":
        	setCoolingSetpoint(Setpoint)
            break;
        case "fan":
        	setFanSetpoint(Setpoint)
        	break;
         case "dry":
            setDrySetpoint(Setpoint)
        	break;
        case "auto":
        	break;
        default:
        	break;
void lowerTemperature() {
	log.trace "lowerTemperature() called"
	Setpoint = temperatureDown(Setpoint)
      return
    switch (operMode) {
    	case "heat":
            break;
        case "cool":
            break;
        case "fan":
        	break;
         case "dry":
        	break;
        case "auto":
        	break;
        default:
        	break;
void lowerCoolSetpoint() {
   	log.trace "lowerCoolSetpoint() called"
    def result = parent.setACStates(this, device.deviceNetworkId , "on", device.currentState("currentmode").value, Setpoint, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
    if (result) {
    	log.info "Cooling temperature changed to " + Setpoint + " for " + device.deviceNetworkId
        sendEvent(name: 'coolingSetpoint', value: Setpoint,  displayed: false)
        sendEvent(name: 'thermostatSetpoint', value: Setpoint,  displayed: false)
        generateSetTempEvent(Setpoint)
    	log.debug "New target Temperature = ${Setpoint}"
    	refresh()
	else {
    	log.debug "error"
void setThermostatMode(modes)
	log.trace "setThermostatMode() called"
  	def currentMode = device.currentState("currentmode").value
  	log.debug "switching AC mode from current mode: $currentMode"
  	switch (modes) {
		case "cool":
			modeCool()
			break
		//case "fan":
		//	returnCommand = modeFan()
		//	break
		//case "dry":
		//	returnCommand = modeDry()
		//	break
        case "auto":
	        modeAuto()
			break
        case "heat":
			modeHeat()
			break
        case "off":
            off()
            break
void setAirConditionerMode(modes)
	log.trace "setAirConditionerMode() called"
  	switch (modes) {
		case "cool":
			modeCool()
			break
		case "fanOnly":
        case "fan":
			modeFan()
			break
		case "dry":
			modeDry()
			break
        case "auto":
	        modeAuto()
			break
        case "heat":
			modeHeat()
			break
void raiseCoolSetpoint() {
   	log.trace "raiseCoolSetpoint() called"
    if (result) {
    	refresh()
	else {
void raiseHeatSetpoint() {
	log.trace "raiseHeatSetpoint() called"
    if (result) {
    	log.info "Heating temperature changed to " + Setpoint + " for " + device.deviceNetworkId
        sendEvent(name: 'heatingSetpoint', value: Setpoint, displayed: false)
    	refresh()
	else {
void lowerHeatSetpoint() {
	log.trace "lowerHeatSetpoint() called"
    if (result) {
    	refresh()
	else {
def refresh()
  log.trace "refresh() called"
  poll()
  log.trace "refresh() ended"
// Set Temperature
def setFanSetpoint(temp) {
	log.trace "setFanSetpoint() called"
	temp = temp.toInteger()
	log.debug "setTemperature : " + temp
    def result = parent.setACStates(this, device.deviceNetworkId , "on", "fan", temp, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
    if (result) {
    	log.info "Fan temperature changed to " + temp + " for " + device.deviceNetworkId
  		generateModeEvent("fan")
        sendEvent(name: 'thermostatSetpoint', value: temp, displayed: false)
    	generateSetTempEvent(temp)
    	refresh()
    else {
// Set Temperature
def setDrySetpoint(temp) {
	log.trace "setDrySetpoint() called"
    def result = parent.setACStates(this, device.deviceNetworkId , "on", "dry", temp, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
    if (result) {
    	log.info "Dry temperature changed to " + temp + " for " + device.deviceNetworkId
  		generateModeEvent("dry")
    	refresh()
    else {
// Set Temperature
def setCoolingSetpoint(temp) {
	log.trace "setCoolingSetpoint() called"
    def result = parent.setACStates(this, device.deviceNetworkId , "on", "cool", temp, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
    if (result) {
    	log.info "Cooling temperature changed to " + temp + " for " + device.deviceNetworkId
  		generateModeEvent("cool")
    	sendEvent(name: 'coolingSetpoint', value: temp, displayed: false)
    	//sendEvent(name: 'heatingSetpoint', value: temp, displayed: false)
    	refresh()
    else {
def setHeatingSetpoint(temp) {
	log.trace "setHeatingSetpoint() called"
    def result = parent.setACStates(this, device.deviceNetworkId , "on", "heat", temp, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
    if (result) {
    	log.info "Heating temperature changed to " + temp + " for " + device.deviceNetworkId
    	generateModeEvent("heat")
    	//sendEvent(name: 'coolingSetpoint', value: temp, displayed: false)
    	refresh()
    else {
def generateSetTempEvent(temp) {
   sendEvent(name: "targetTemperature", value: temp, descriptionText: "$device.displayName set temperature is now ${temp}", displayed: true, isStateChange: true)
// Turn off or Turn on the AC
def on() {
	log.trace "on called"
    log.debug "Temp Unit : " + device.currentState("temperatureUnit").value
    def result = parent.setACStates(this, device.deviceNetworkId, "on", device.currentState("currentmode").value, Setpoint, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
    log.debug "Result : " + result
    if (result) {
    	log.info "AC turned ON for " + device.deviceNetworkId
    	sendEvent(name: 'thermostatMode', value: device.currentState("currentmode").value, displayed: false,isStateChange: true)
        //sendEvent(name: 'thermostatOperatingState', value: "idle",isStateChange: true)
    	refresh()
    else {
def off() {
	log.trace "off called"
    def result = parent.setACStates(this, device.deviceNetworkId, "off", device.currentState("currentmode").value, Setpoint, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
    if (result) {
    	log.info "AC turned OFF for " + device.deviceNetworkId
    	sendEvent(name: 'thermostatMode', value: "off", displayed: false,isStateChange: true)
        generateSwitchEvent("off")
    	refresh()
    else {
def generateSwitchEvent(mode) {
   sendEvent(name: "on", value: mode, descriptionText: "$device.displayName is now ${mode}", displayed: false, isStateChange: true)
   sendEvent(name: "switch", value: mode, descriptionText: "$device.displayName is now ${mode}", displayed: true, isStateChange: true)
   //refresh()
def dfanLevel(String newLevel){
	log.trace "dfanLevel called with fan = " + newLevel
        Level = GetNextFanLevel(newLevel,capabilities.remoteCapabilities.fanLevels)
        //log.debug "Fan : " + Level
        def result = parent.setACStates(this, device.deviceNetworkId,"on", device.currentState("currentmode").value, Setpoint, Level, device.currentState("swing").value, device.currentState("temperatureUnit").value)
        if (result) {
        	log.info "Fan level changed to " + Level + " for " + device.deviceNetworkId
            if (Level == "low") {
            	sendEvent(name: 'thermostatFanMode', value: "circulate", displayed: false)
            else {
                sendEvent(name: 'thermostatFanMode', value: "on", displayed: false)
        	refresh()
        else {
    else {
    	//TODO when the mode do not exist
def generatefanLevelEvent(mode) {
   sendEvent(name: "fanLevel", value: mode, descriptionText: "$device.displayName fan level is now ${mode}", displayed: true, isStateChange: true)
// toggle Climate React
def toggleClimateReact()
  	log.trace "toggleClimateReact() called"
	def currentClimateMode = device.currentState("Climate")?.value
    def returnCommand
    switch (currentClimateMode) {
    	case "off":
        	returnCommand = setClimateReact("on")
            break
        case "on":
        	returnCommand = setClimateReact("off")
            break
    if (!returnCommand) { returnCommand }
// Set Climate React
def setClimateReact(ClimateState) {
    /// Parameter ClimateState : "on" or "off"
	log.trace "setClimateReact() called"
	log.debug "Climate : " + ClimateState
    def result = parent.setClimateReact(this, device.deviceNetworkId, ClimateState)
    if (result) {
    	log.info "Climate React changed to " + ClimateState + " for " + device.deviceNetworkId
        sendEvent(name: 'Climate', value: ClimateState, displayed: false)
    	//generateSetTempEvent(temp)
    	refresh()
    else {
def configureClimateReact(lowThres, highThres,stype,lowState,highState, on_off, ThresUnit)
    // lowThres and highThres - Integer parameters
	// stype : possible values are "temperature", "humidity" or "feelsLike"
    // lowState and highState :
    //    on, fanLevel, temperatureUnit, targetTemperature, mode
    //    like  "[true,'auto','C',21,'heat']"
    //    to turn off AC,first parameters = false : "[false,'auto','C',21,'heat']"
    // one_off : boolean value to enable/disable the Climate React
    // unit : Passing F for Farenheit or C for Celcius
    // Some examples:
    // Range 19-24 Celcius, start to heat to 22 at auto fan if the temp is lower than 19 and stop the AC when higher than 24
    // configureClimateReact(19, 24, ‘temperature’, ‘[true, ‘auto’, ‘C’, 22, ‘heat’]’, ‘[false, ‘auto’, ‘C’, 22, ‘heat’]’, true, ‘C’);
    // Range 67-68 Farenheit, start to heat to 68 at auto fan if the temp is lower than 67 and stop the AC when higher than 68
    // configureClimateReact(67, 68, ‘temperature’, ‘[true, ‘auto’, ‘F’, 68, ‘heat’]’, ‘[false, ‘auto’, ‘F’, 68, ‘heat’]’, true, ‘F’);
	log.trace "configureClimateReact() called"
    if (ThresUnit.toUpperCase() == "F")
    	lowThres = fToc(lowThres).round(1)
    	highThres = fToc(highThres).round(1)
    def json = new groovy.json.JsonBuilder()
    def lowStateMap = evaluate(lowState)
    def highStateMap = evaluate(highState)
    def lowStateJson
    def highStateJson
    if (lowStateMap) {
        lowStateJson = json {
            on lowStateMap[0]
            fanLevel lowStateMap[1]
            temperatureUnit lowStateMap[2]
            targetTemperature lowStateMap[3]
            mode lowStateMap[4]
    else { lowStateJson = null }
    if (highStateMap) {
        highStateJson = json {
            on highStateMap[0]
            fanLevel highStateMap[1]
            temperatureUnit highStateMap[2]
            targetTemperature highStateMap[3]
            mode highStateMap[4]
    else { highStateJson = null }
    def root = json {
    	deviceUid device.deviceNetworkId
        highTemperatureWebhook null
        highTemperatureThreshold highThres
        lowTemperatureWebhook null
        type stype
        lowTemperatureState lowStateJson
        enabled on_off
        highTemperatureState highStateJson
        lowTemperatureThreshold lowThres
    log.debug "CLIMATE REACT STRING : " + JsonOutput.prettyPrint(json.toString())
    def result = parent.configureClimateReact(this, device.deviceNetworkId, json.toString())
    if (result) {
    	log.info "Climate React settings changed for " + device.deviceNetworkId
        sendEvent(name: 'Climate', value: on_off, displayed: false)
    	refresh()
    else {
def switchFanLevel() {
	log.trace "switchFanLevel() called"
	def currentFanMode = device.currentState("fanLevel")?.value
	log.debug "switching fan level from current mode: $currentFanMode"
	def returnCommand
	switch (currentFanMode) {
		case "low":
			returnCommand = dfanLevel("medium")
			break
		case "medium":
			returnCommand = dfanLevel("high")
			break
		case "high":
			returnCommand = dfanLevel("auto")
			break
        case "auto":
			returnCommand = dfanLevel("quiet")
			break
        case "quiet":
			returnCommand = dfanLevel("medium_high")
			break
         case "medium_high":
			returnCommand = dfanLevel("medium_low")
			break
         case "medium_low":
			returnCommand = dfanLevel("strong")
			break
          case "strong":
			returnCommand = dfanLevel("low")
			break
	returnCommand
def modeHeat()
	log.trace "modeHeat() called"
	modeMode("heat")
def modeCool()
	log.trace "modeCool() called"
	modeMode("cool")
def modeDry()
	log.trace "modeDry() called"
	modeMode("dry")
def modeFan()
	log.trace "modeFan() called"
	modeMode("fan")
def modeAuto()
	log.trace "modeAuto() called"
	modeMode("auto")
// To change the AC mode
def switchMode() {
	log.trace "switchMode() called"
	def currentMode = device.currentState("currentmode")?.value
	def returnCommand
	switch (currentMode) {
		case "heat":
			returnCommand = modeMode("cool")
			break
		case "cool":
			returnCommand = modeMode("fan")
			break
		case "fan":
			returnCommand = modeMode("dry")
			break
        case "dry":
            returnCommand = modeMode("auto")
			break
        case "auto":
			returnCommand = modeMode("heat")
			break
	returnCommand
def modeMode(String newMode){
    log.trace "modeMode() called with " + newMode
    def LevelBefore = device.currentState("fanLevel").value
        if (result) {
        	log.info "Mode changed to " + newMode + " for " + device.deviceNetworkId
        	refresh()
        else {
    else {
       def themodes = parent.getCapabilities(device.deviceNetworkId,"modes")
       def sMode = GetNextMode(newMode,themodes)
	   NextMode(sMode)
def generateModeEvent(mode) {
   sendEvent(name: "thermostatMode", value: mode, descriptionText: "$device.displayName Thermostat mode is now ${mode}", displayed: true, isStateChange: true)
def returnNext(liste1, liste2, val) throws Exception
    try {
    	def index = liste2.indexOf(val)
        if (index == -1) throw new Exception()
        else return liste2[liste2.indexOf(val)]
    catch(Exception e) {
    	if (liste1.indexOf(val)+ 1 == liste1.size()) {
           val = liste1[0]
         else {
           val = liste1[liste1.indexOf(val) + 1]
def GetNextFanLevel(fanLevel, fanLevels)
	log.trace "GetNextFanLevel called with " + fanLevel
    if (fanLevels == null || fanLevels == "null") {
      return null
	def listFanLevel = ['low','medium','high','auto','quiet','medium_high','medium_low','strong']
    def newFanLevel = returnNext(listFanLevel, fanLevels,fanLevel)
    log.debug "Next fanLevel = " + newFanLevel
    return newFanLevel
def GetNextMode(mode, modes)
	log.trace "GetNextMode called with " + mode
	def listMode = ['heat','cool','fan','dry','auto']
    def newMode = returnNext(listMode, modes,mode)
    log.debug "Next Mode = " + newMode
	return newMode
def NextMode(sMode)
	log.trace "NextMode called()"
	if (sMode != null) {
    	switch (sMode)
         	case "heat":
            	modeHeat()
            	break
            case "cool":
            	modeCool()
            	break
            case "fan":
            	modeFan()
            	break
            case "dry":
            	modeDry()
            	break
            case "auto":
            	modeAuto()
            	break
    else
    	return null
def GetNextSwingMode(swingMode, swingModes){
	log.trace "GetNextSwingMode() called with " + swingMode
    if (swingModes == null || swingModes == "null") {
    	return null
	def listSwingMode = ['stopped','fixedTop','fixedMiddleTop','fixedMiddle','fixedMiddleBottom','fixedBottom','rangeTop','rangeMiddle','rangeBottom','rangeFull','horizontal','both']
    def newSwingMode = returnNext(listSwingMode, swingModes,swingMode)
    log.debug "Next Swing Mode = " + newSwingMode
	return newSwingMode
def switchSwing() {
	log.trace "switchSwing() called"
	def currentMode = device.currentState("swing")?.value
	log.debug "switching Swing mode from current mode: $currentMode"
	def returnCommand
		case "stopped":
			returnCommand = modeSwing("fixedTop")
			break
		case "fixedTop":
			returnCommand = modeSwing("fixedMiddleTop")
			break
        case "fixedMiddleTop":
			returnCommand = modeSwing("fixedMiddle")
			break
        case "fixedMiddle":
			returnCommand = modeSwing("fixedMiddleBottom")
			break
        case "fixedMiddleBottom":
			returnCommand = modeSwing("fixedBottom")
			break
		case "fixedBottom":
			returnCommand = modeSwing("rangeTop")
			break
        case "rangeTop":
            returnCommand = modeSwing("rangeMiddle")
			break
        case "rangeMiddle":
			returnCommand = modeSwing("rangeBottom")
			break
         case "rangeBottom":
			returnCommand = modeSwing("rangeFull")
			break
        case "rangeFull":
			returnCommand = modeSwing("horizontal")
			break
        case "horizontal":
			returnCommand = modeSwing("both")
			break
         case "both":
			returnCommand = modeSwing("stopped")
			break
	returnCommand
def modeSwing(String newSwing)
    log.trace "modeSwing() called with " + newSwing
    def SwingBefore = device.currentState("swing").value
    def Swing = SwingBefore
    	def Swings = capabilities.remoteCapabilities.swing
        log.debug "Swing capabilities : " + capabilities.remoteCapabilities.swing
        Swing = GetNextSwingMode(newSwing,capabilities.remoteCapabilities.swing)
        //log.debug "Swing : " + Swing
        def result = parent.setACStates(this, device.deviceNetworkId, "on", device.currentState("currentmode").value, Setpoint, device.currentState("fanLevel").value, Swing, device.currentState("temperatureUnit").value)
        if (result) {
        	log.info "Swing mode changed to " + Swing + " for " + device.deviceNetworkId
            sendEvent(name: 'swing', value: Swing, displayed: false,isStateChange: true)
            generateSwingModeEvent(Swing)
        	refresh()
        else {
    else
      //TODO
def generateSwingModeEvent(mode) {
   sendEvent(name: "swing", value: mode, descriptionText: "$device.displayName swing mode is now ${mode}", displayed: true, isStateChange: true)
def generateErrorEvent() {
   log.debug "$device.displayName FAILED to set the AC State"
   sendEvent(name: "Error", value: "Error", descriptionText: "$device.displayName FAILED to set or get the AC State", displayed: true, isStateChange: true)
void poll() {
	log.trace "Executing 'poll' using parent SmartApp"
	def results = parent.pollChild(this)
    def linkText = getLinkText(device)
    parseTempUnitEventData(results)
    parseEventData(results)
def parseTempUnitEventData(Map results)
    log.debug "parsing data $results"
	if(results)
		results.each { name, value ->
        	if (name=="temperatureUnit") {
                def isChange = true
                def isDisplayed = false
				sendEvent(
					value: value,
                    //unit: value,
					linkText: linkText,
					descriptionText: "${name} = ${value}",
					handlerName: "temperatureUnit",
					isStateChange: isChange,
					displayed: isDisplayed)
def parseEventData(Map results)
	log.debug "parsing Event data $results"
	if(results)
 			log.debug "name :" + name + " value :" + value
            def isChange = false
            def isDisplayed = true
            if (name=="voltage") {
                isChange = true //isTemperatureStateChange(device, name, value.toString())
                isDisplayed = false
				sendEvent(
					value: value,
                    unit: "mA",
					linkText: linkText,
					descriptionText: getThermostatDescriptionText(name, value, linkText),
					handlerName: name,
            else if (name== "battery") {
                isDisplayed = false
				sendEvent(
					value: value,
                    //unit: "V",
					linkText: linkText,
					handlerName: name,
            else if (name== "powerSource") {
                isDisplayed = false
				sendEvent(
					value: value,
					linkText: linkText,
					handlerName: name,
            else if (name== "Climate") {
                isChange = true
                isDisplayed = false
				sendEvent(
					value: value,
					linkText: linkText,
					handlerName: name,
            else if (name=="on") {
                isChange = true
                isDisplayed = false
				sendEvent(
					value: value,
					linkText: linkText,
					handlerName: name,
                sendEvent(name: "switch", value: value)
            else if (name=="thermostatMode") {
                isDisplayed = false
				if (value=="cool") {
                	sendEvent(name: 'airConditionerMode', value: "cool",
                    sendEvent(name: 'thermostatOperatingState', value: "cooling",
				} else if (value=="heat") {
					sendEvent(name: 'airConditionerMode', value: "heat",
                    sendEvent(name: 'thermostatOperatingState', value: "heating",
				} else if (value=="fan") {
             		sendEvent(name: 'airConditionerMode', value: "fanOnly",
					sendEvent(name: 'thermostatOperatingState', value: "fan only",
                } else if (value=="dry") {
                    sendEvent(name: 'airConditionerMode', value: "dry",
					sendEvent(name: 'thermostatOperatingState', value: "dry",
                 } else if (value=="auto") {
                    sendEvent(name: 'airConditionerMode', value: "auto",
					sendEvent(name: 'thermostatOperatingState', value: "auto",
				} else {
				sendEvent(
					value: value,
					linkText: linkText,
					handlerName: name,
            else if (name=="coolingSetpoint" || name== "heatingSetpoint" || name == "thermostatSetpoint") {
                isDisplayed = false
				sendEvent(
					value: value,
                    //unit : device.currentValue("temperatureUnit"),
					linkText: linkText,
					handlerName: name,
            else if (name=="temperatureUnit") {
                isChange = true
                isDisplayed = false
				sendEvent(
					value: value,
                    //unit: value,
					linkText: linkText,
					handlerName: name,
            else if (name=="thermostatFanMode") {
            	def mode = (value.toString() == "high" || value.toString() == "medium") ? "on" : value.toString()
                mode = (mode == "low") ? "circulate" : mode
                isDisplayed = false
				sendEvent(
					value: value,
					linkText: linkText,
					handlerName: name,
 			else if (name=="swing") {
                isDisplayed = false
				sendEvent(
					value: value,
					linkText: linkText,
					handlerName: name,
            else if (name=="temperature" || name== "lastTemperaturePush" || name== "lastHumidityPush") {
                isDisplayed = false
				sendEvent(
					value: value,
					//unit: device.currentValue("temperatureUnit"),
					linkText: linkText,
					handlerName: name,
            else if (name=="humidity") {
                isDisplayed = false
				sendEvent(
					value: value,
					linkText: linkText,
					handlerName: name,
            else {
            	isChange = true//isStateChange(device, name, value.toString())
                isDisplayed = false//isChange
                sendEvent(
					value: value.toString(),
					linkText: linkText,
					handlerName: name,
        generateStatusEvent ()
private getThermostatDescriptionText(name, value, linkText)
	if(name == "temperature")
		return "$name was $value " + device.currentState("temperatureUnit").value
    else if(name == "humidity")
		return "$name was $value %"
    else if(name == "targetTemperature")
		return "latest temperature setpoint was $value " + device.currentState("temperatureUnit").value
	else if(name == "fanLevel")
		return "latest fan level was $value"
	else if(name == "on")
		return "latest switch was $value"
    else if (name == "mode")
        return "thermostat mode was ${value}"
    else if (name == "currentmode")
    else if (name == "powerSource")
        return "power source mode was ${value}"
    else if (name == "Climate")
        return "Climate React was ${value}"
    else if (name == "thermostatMode")
    else if (name == "temperatureUnit")
    	return "thermostat unit was ${value}"
    else if (name == "voltage")
    	return "Battery voltage was ${value}"
    else if (name == "battery")
    	return "Battery was ${value}"
    else if (name == "voltage" || name== "battery")
    else if (name == "swing")
    	return "Swing mode was ${value}"
    else if (name == "Error")
    	def str = (value == "Failed") ? "failed" : "success"
        return "Last setACState was ${str}"
    else
        return "${name} = ${value}"
// parse events into attributes
	log.debug "Parsing '${description}'"
    def name = null
	def value = null
    def statusTextmsg = ""
    def msg = parseLanMessage(description)
    def headersAsString = msg.header // => headers as a string
    def headerMap = msg.headers      // => headers as a Map
    def body = msg.body              // => request body as a string
    def status = msg.status          // => http status code of the response
    def json = msg.json              // => any JSON included in response body, as a data structure of lists and maps
    def xml = msg.xml                // => any XML included in response body, as a document tree structure
    def data = msg.data              // => either JSON or XML in response body (whichever is specified by content-type header in response)
	if (description?.startsWith("on/off:")) {
		log.debug "Switch command"
		name = "switch"
		value = description?.endsWith(" 1") ? "on" : "off"
   else if (description?.startsWith("temperature")) {
    	log.debug "Temperature"
        name = "temperature"
		value = device.currentValue("temperature")
    else if (description?.startsWith("humidity")) {
    	log.debug "Humidity"
        name = "humidity"
		value = device.currentValue("humidity")
    else if (description?.startsWith("targetTemperature")) {
    	log.debug "targetTemperature"
        name = "targetTemperature"
		value = device.currentValue("targetTemperature")
    else if (description?.startsWith("fanLevel")) {
    	log.debug "fanLevel"
        name = "fanLevel"
		value = device.currentValue("fanLevel")
    else if (description?.startsWith("currentmode")) {
    	log.debug "mode"
        name = "currentmode"
		value = device.currentValue("currentmode")
    else if (description?.startsWith("on")) {
    	log.debug "on"
        name = "on"
        value = device.currentValue("on")
    else if (description?.startsWith("switch")) {
    	log.debug "switch"
        name = "switch"
    else if (description?.startsWith("temperatureUnit")) {
    	log.debug "temperatureUnit"
        name = "temperatureUnit"
        value = device.currentValue("temperatureUnit")
    else if (description?.startsWith("Error")) {
    	log.debug "Error"
        name = "Error"
        value = device.currentValue("Error")
    else if (description?.startsWith("voltage")) {
    	log.debug "voltage"
        name = "voltage"
		value = device.currentValue("voltage")
    else if (description?.startsWith("battery")) {
    	log.debug "battery"
        name = "battery"
		value = device.currentValue("battery")
    else if (description?.startsWith("swing")) {
    	log.debug "swing"
        name = "swing"
		value = device.currentValue("swing")
    def result = createEvent(name: name, value: value)
	log.debug "Parse returned ${result?.descriptionText}"
	return result
def generateStatusEvent() {
    def temperature = device.currentValue("temperature").toDouble()
    def humidity = device.currentValue("humidity").toDouble()
    def targetTemperature = device.currentValue("targetTemperature").split(' ')[0].toDouble()
    def fanLevel = device.currentValue("fanLevel")
    def mode = device.currentValue("currentmode")
    def on = device.currentValue("on")
    def swing = device.currentValue("swing")
    def ClimateReact = device.currentValue("Climate")
	def error = device.currentValue("Error")
    def sUnit = device.currentValue("temperatureUnit")
    statusTextmsg = "${humidity}%"
    sendEvent("name":"statusText", "value":statusTextmsg, "description":"", displayed: false, isStateChange: true)
def fToc(temp) {
	return ((temp - 32) / 1.8).toDouble()
def ping(){
	log.trace "calling parent ping()"
	return parent.ping()
Application
 *  Sensibo Integration for Hubitat
definition(
    name: "Sensibo Integration",
    description: "Connect your Sensibo Pod to Hubitat.",
    category: "Green Living",
    iconUrl: "https://image.ibb.co/j7qAPT/Sensibo_1x.png",
    iconX2Url: "https://image.ibb.co/coZtdo/Sensibo_2x.png",
    iconX3Url: "https://image.ibb.co/cBwTB8/Sensibo_3x.png",
    singleInstance: true)
    appSetting "apikey"
preferences {
	page(name: "SelectAPIKey", title: "API Key", content: "setAPIKey", nextPage: "deviceList", install: false, uninstall: true)
	page(name: "deviceList", title: "Sensibo", content:"SensiboPodList", install:true, uninstall: true)
    page(name: "timePage")
    page(name: "timePageEvent")
def getServerUrl() { "https://home.sensibo.com" }
def getapikey() { apiKey }
//def version() { "SmartThingsv1.5" }
public static String version() { return "SmartThingsv1.6" }
def setAPIKey()
	log.trace "setAPIKey()"
	if(appSettings)
    	def pod = appSettings.apikey
    else {
        def pod = ""
    def p = dynamicPage(name: "SelectAPIKey", title: "Enter your API Key", uninstall: true) {
		section(""){
			paragraph "Please enter your API Key provided by Sensibo \n\nAvailable at: \nhttps://home.sensibo.com/me/api"
			input(name: "apiKey", title:"", type: "text", required:true, multiple:false, description: "", defaultValue: pod)
    return p
def SensiboPodList()
	log.trace "SensiboPodList()"
	def stats = getSensiboPodList()
	log.debug "device list: $stats"
	def p = dynamicPage(name: "deviceList", title: "Select Your Sensibo Pod", uninstall: true) {
		section(""){
			paragraph "Tap below to see the list of Sensibo Pods available in your Sensibo account and select the ones you want to connect to SmartThings."
			input(name: "SelectedSensiboPods", title:"Pods", type: "enum", required:true, multiple:true, description: "Tap to choose",  options: stats)
        section("Refresh") {
        	input(name:"refreshinminutes", title: "Refresh rates in minutes", type: "enum", required:false, multiple: false, options: ["1", "5", "10","15","30"])
	 	// No push notifications on Hubitat
        section("Receive Pod sensors infos") {
        	input "boolnotifevery", "bool",submitOnChange: true, required: false, title: "Receive temperature, humidity and battery level notification every hour?"
            href(name: "toTimePageEvent",
                     page: "timePageEvent", title:"Only during a certain time", require: false)
        section("Alert on sensors (threshold)") {
        	input "sendPushNotif", "bool",submitOnChange: true, required: false, title: "Receive alert on Sensibo Pod sensors based on threshold?"
		if (sendPushNotif) {
           section("Select the temperature threshold",hideable: true) {
            	input "minTemperature", "decimal", title: "Min Temperature",required:false
            	input "maxTemperature", "decimal", title: "Max Temperature",required:false }
            section("Select the humidity threshold",hideable: true) {
            	input "minHumidity", "decimal", title: "Min Humidity level",required:false
            	input "maxHumidity", "decimal", title: "Max Humidity level",required:false }
        	section("How frequently?") {
        		input(name:"days", title: "Only on certain days of the week", type: "enum", required:false, multiple: true, options: ["Monday", "Tuesday", "Wednesday","Thursday","Friday","Saturday","Sunday"])
        	section("") {
        		href(name: "toTimePage",
                	 page: "timePage", title:"Only during a certain time", require: false)
	return p
// page def must include a parameter for the params map!
def timePage() {
    dynamicPage(name: "timePage", uninstall: false, install: false, title: "Only during a certain time") {
      section("") {
        input(name: "startTime", title: "Starting at : ", required:false, multiple: false, type:"time",)
        input(name: "endTime", title: "Ending at : ", required:false, multiple: false, type:"time")
def timePageEvent() {
    dynamicPage(name: "timePageEvent", uninstall: false, install: false, title: "Only during a certain time") {
      section("") {
        input(name: "startTimeEvent", title: "Starting at : ", required:false, multiple: false, type:"time",)
        input(name: "endTimeEvent", title: "Ending at : ", required:false, multiple: false, type:"time")
def getSensiboPodList()
	log.trace "getSensiboPodList called"
    def deviceListParams = [
    uri: "${getServerUrl()}",
    path: "/api/v2/users/me/pods",
    requestContentType: "application/json",
    query: [apiKey:"${getapikey()}", integration:"${version()}", type:"json",fields:"id,room" ]]
	def pods = [:]
    try {
      httpGet(deviceListParams) { resp ->
    	if(resp.status == 200)
				resp.data.result.each { pod ->
                    def key = pod.id
                    def value = pod.room.name
					pods[key] = value
                state.pods = pods
    catch(Exception e)
		log.debug "Exception Get Json: " + e
		debugEvent ("Exception get JSON: " + e)
    log.debug "Sensibo Pods: $pods"
    return pods
def installed() {
	log.trace "Installed() called with settings: ${settings}"
	state.lastTemperaturePush = null
    state.lastHumidityPush = null
	initialize()
    def d = getChildDevices()
	if (boolnotifevery) {
    	//runEvery1Hour("hournotification")
        schedule("0 0 * * * ?", "hournotification")
    log.debug "Configured health checkInterval when installed()"
	sendEvent(name: "checkInterval", value: 2 * 60 * 60 + 2 * 60, displayed: true)
    //subscribe(d,"temperatureUnit",eTempUnitHandler)
    	subscribe(d, "temperature", eTemperatureHandler)
        subscribe(d, "humidity", eHumidityHandler)
def updated() {
	log.trace "Updated() called with settings: ${settings}"
	unschedule()
    unsubscribe()
    initialize()
def ping() {
	log.trace "ping called"
    def returnStatus = true
    try {
				returnStatus = true
    catch(Exception e)
		returnStatus = false
    return returnStatus
def hournotification() {
	log.trace "hournotification() called"
	def hour = new Date()
	def curHour = hour.format("HH:mm",location.timeZone)
	def curDay = hour.format("EEEE",location.timeZone)
	// Check the time Threshold
    def stext = ""
	if (startTimeEvent && endTimeEvent) {
 		def minHour = new Date().parse(smartThingsDateFormat(), startTimeEvent)
    	def endHour = new Date().parse(smartThingsDateFormat(), endTimeEvent)
    	def minHourstr = minHour.format("HH:mm",location.timeZone)
    	def maxHourstr = endHour.format("HH:mm",location.timeZone)
    	if (curHour >= minHourstr && curHour <= maxHourstr)
    		def devices = getChildDevices()
            devices.each { d ->
                log.trace "Notification every hour for device: ${d.id}"
                def currentPod = d.displayName
                def currentTemperature = d.currentState("temperature").value
                def currentHumidity = d.currentState("humidity").value
                def currentBattery = d.currentState("voltage").value
                def sunit = d.currentState("temperatureUnit").value
                stext = "${currentPod} - Temperature: ${currentTemperature} ${sunit} Humidity: ${currentHumidity}% Battery: ${currentBattery}"
                sendPush(stext)
    else {
            devices.each { d ->
                sendPush(stext)
//def switchesHandler(evt)
//  if (evt.value == "on") {
//        log.debug "switch turned on!"
//    } else if (evt.value == "off") {
//        log.debug "switch turned off!"
def eTempUnitHandler(evt)
	//refreshOneDevice(evt.device.displayName)
def eTemperatureHandler(evt){
	def currentTemperature = evt.device.currentState("temperature").value
    def currentPod = evt.device.displayName
    if (inDateThreshold(evt,"temperature") == true) {
        if(maxTemperature != null){
            if(currentTemperature.toDouble() > maxTemperature)
            	def stext = "Temperature level is too high at ${currentPod} : ${currentTemperature}"
				sendEvent(name: "lastTemperaturePush", value: "${stext}",  displayed : "true", descriptionText:"${stext}")
                sendPush(stext)
                state.lastTemperaturePush = hour
        if(minTemperature != null) {
            if(currentTemperature.toDouble() < minTemperature)
            	def stext = "Temperature level is too low at ${currentPod} : ${currentTemperature}"
                sendPush(stext)
def eHumidityHandler(evt){
	def currentHumidity = evt.device.currentState("humidity").value
    if (inDateThreshold(evt,"humidity") == true) {
        if(maxHumidity != null){
            if(currentHumidity.toDouble() > maxHumidity)
            	def stext = "Humidity level is too high at ${currentPod} : ${currentHumidity}"
                sendEvent(name: "lastHumidityPush", value: "${stext}", displayed : "true", descriptionText:"${stext}")
                sendPush(stext)
                state.lastHumidityPush = hour
        if(minHumidity != null) {
            if(currentHumidity.toDouble() < minHumidity)
            	def stext = "Humidity level is too low at ${currentPod} : ${currentHumidity}"
                sendPush(stext)
public smartThingsDateFormat() { "yyyy-MM-dd'T'HH:mm:ss.SSSZ" }
public smartThingsDateFormatNoMilli() { "yyyy-MM-dd'T'HH:mm:ssZ" }
def canPushNotification(currentPod, hour,sType) {
    // Check if the client already received a push
    if (sType == "temperature") {
        if (sfrequency.toString().isInteger()) {
            if (state.lastTemperaturePush != null) {
                long unxNow = hour.time
                def before = new Date().parse(smartThingsDateFormatNoMilli(),state.lastTemperaturePush)
                long unxEnd = before.time
                unxNow = unxNow/1000
                unxEnd = unxEnd/1000
                def timeDiff = Math.abs(unxNow-unxEnd)
                timeDiff = timeDiff/60
                if (timeDiff <= sfrequency)
                    return false
    else {
            if (state.lastHumidityPush != null) {
                def before = new Date().parse(smartThingsDateFormatNoMilli(),state.lastHumidityPush)
                    return false
    return true
def inDateThreshold(evt,sType) {
    def result = canPushNotification(currentPod,hour, sType)
    if (!result) {
        return false
    // Check the day of the week
    if (days != null && !days.contains(curDay)) {
    	return false
	if (startTime && endTime) {
 		def minHour = new Date().parse(smartThingsDateFormat(), startTime)
    	def endHour = new Date().parse(smartThingsDateFormat(), endTime)
    	if (curHour >= minHourstr && curHour < maxHourstr)
    		return true
    	else
	    	return false
    return true
def refresh() {
	log.trace "refresh() called with rate of " + refreshinminutes + " minutes"
    unschedule()
	refreshDevices()
    if (refreshinminutes == "1")
    	runEvery1Minute("refreshDevices")
    else if (refreshinminutes == "5")
    	runEvery5Minutes("refreshDevices")
    else if (refreshinminutes == "10")
    	runEvery10Minutes("refreshDevices")
    else if (refreshinminutes == "15")
    	runEvery15Minutes("refreshDevices")
    else if (refreshinminutes == "30")
    	runEvery30Minutes("refreshDevices")
    else
def refreshOneDevice(dni) {
	log.trace "refreshOneDevice() called"
	def d = getChildDevice(dni)
	d.refresh()
def refreshDevices() {
	log.trace "refreshDevices() called"
	devices.each { d ->
		log.debug "Calling refresh() on device: ${d.id}"
		d.refresh()
def getChildNamespace() { "EricG66" }
def getChildTypeName() { "SensiboPod" }
def initialize() {
    log.trace "initialize() called"
    log.trace "key "+ getapikey()
    state.apikey = getapikey()
	def devices = SelectedSensiboPods.collect { dni ->
		log.debug dni
		if(!d)
            	def name = getSensiboPodList().find( {key,value -> key == dni })
				log.debug "Pod : ${name.value} - Hub : ${location.hubs[0].name} - Type : " +  getChildTypeName() + " - Namespace : " + getChildNamespace()
				d = addChildDevice(getChildNamespace(), getChildTypeName(), dni, location.hubs[0].id, [
                	"label" : "Pod ${name.value}",
                    "name" : "Pod ${name.value}"
                d.setIcon("on","on","https://image.ibb.co/jgAMW8/sensibo-sky-off.png")
                d.setIcon("off","on","https://image.ibb.co/jgAMW8/sensibo-sky-off.png")
                d.save()
				log.trace "created ${d.displayName} with id $dni"
			else
				log.trace "found ${d.displayName} with id $dni already exists"
			return d
	log.trace "created ${devices.size()} Sensibo Pod"
	def delete
	// Delete any that are no longer in settings
	if(!SelectedSensiboPods)
		log.debug "delete Sensibo"
		delete = getChildDevices()
	else
		delete = getChildDevices().findAll { !SelectedSensiboPods.contains(it.deviceNetworkId) }
	log.trace "deleting ${delete.size()} Sensibo"
	delete.each { deleteChildDevice(it.deviceNetworkId) }
	def PodList = getChildDevices()
    pollHandler()
    refreshDevices()
    else
// Subscribe functions
def OnOffHandler(evt) {
	log.trace "on off handler activated"
    debugEvent(evt.value)
	//def name = evt.device.displayName
    if (sendPush) {
            //sendPush("The ${name} is turned on!")
            //sendPush("The ${name} is turned off!")
def getPollRateMillis() { return 45 * 1000 }
def getCapabilitiesRateMillis() {return 60 * 1000 }
// Poll Child is invoked from the Child Device itself as part of the Poll Capability
def pollChild( child )
	log.trace "pollChild() called"
	debugEvent ("poll child")
	def now = new Date().time
	debugEvent ("Last Poll Millis = ${state.lastPollMillis}")
	def last = state.lastPollMillis ?: 0
	def next = last + pollRateMillis
	log.debug "pollChild( ${child.device.deviceNetworkId} ): $now > $next ?? w/ current state: ${state.sensibo}"
	debugEvent ("pollChild( ${child.device.deviceNetworkId} ): $now > $next ?? w/ current state: ${state.sensibo}")
	//if( now > next )
	if( true ) // for now let's always poll/refresh
		log.debug "polling children because $now > $next"
		debugEvent("polling children because $now > $next")
		pollChildren(child.device.deviceNetworkId)
		log.debug "polled children and looking for ${child.device.deviceNetworkId} from ${state.sensibo}"
		debugEvent ("polled children and looking for ${child.device.deviceNetworkId} from ${state.sensibo}")
		def currentTime = new Date().time
		debugEvent ("Current Time = ${currentTime}")
		state.lastPollMillis = currentTime
		def tData = state.sensibo[child.device.deviceNetworkId]
        if (tData == null) return
        log.debug  "DEBUG - TDATA" + tData
        debugEvent ("Error in Poll ${tData.data.Error}",false)
        //tData.Error = false
        //tData.data.Error = "Failed"
		if(tData.data.Error != "Success")
			log.error "ERROR: Device connection removed? no data for ${child.device.deviceNetworkId} after polling"
			// TODO: flag device as in error state
			// child.errorState = true
			return null
		tData.updated = currentTime
		return tData.data
	else if(state.sensibo[child.device.deviceNetworkId] != null)
		log.debug "not polling children, found child ${child.device.deviceNetworkId} "
		if(!tData.updated)
			// we have pulled new data for this thermostat, but it has not asked us for it
			// track it and return the data
			tData.updated = new Date().time
			return tData.data
		return null
	else if(state.sensibo[child.device.deviceNetworkId] == null)
		log.error "ERROR: Device connection removed? no data for ${child.device.deviceNetworkId}"
		return null
	else
		// it's not time to poll again and this thermostat already has its latest values
	return null
def configureClimateReact(child,String PodUid,String JsonString)
	log.trace "configureClimateReact() called for $PodUid with settings : $JsonString"
    def result = sendPostJsonClimate(PodUid, JsonString)
    if (result) {
        if (tData == null) {
        //tData.data.Climate = ClimateState
        tData.data.Error = "Success"
    else {
        if (tData == null) return false
    return(result)
def setClimateReact(child,String PodUid, ClimateState)
	log.trace "setClimateReact() called for $PodUid Climate React: $ClimateState"
    def ClimateReact = getClimateReact(PodUid)
    log.debug "DEBUG " + ClimateReact.Climate + " " + ClimateState
    if (ClimateReact.Climate == "notdefined") {
        tData.data.Climate = ClimateReact.Climate
        return true
    def jsonRequestBody
    if (ClimateState == "on") {
    	jsonRequestBody = '{"enabled": true}'
    else {
    	jsonRequestBody = '{"enabled": false}'
    log.debug "Mode Request Body = ${jsonRequestBody}"
    def result = sendPutJson(PodUid, jsonRequestBody)
    if (result) {
    else {
    return(result)
def setACStates(child,String PodUid, on, mode, targetTemperature, fanLevel, swingM, sUnit)
	log.trace "setACStates() called for $PodUid ON: $on - MODE: $mode - Temp : $targetTemperature - FAN : $fanLevel - SWING MODE : $swingM - UNIT : $sUnit"
    //Return false if no values was read from Sensibo API
    if (on == "--") { return false }
    def OnOff = (on == "on") ? true : false
    //if (swingM == null) swingM = "stopped"
    log.trace "Target Temperature :" + targetTemperature
	def jsonRequestBody = '{"acState":{"on": ' + OnOff.toString() + ',"mode": "' + mode + '"'
    log.debug "Fan Level is :$fanLevel"
    log.debug "Swing is :$swingM"
    log.debug "Target Temperature is :$targetTemperature"
    if (fanLevel != null) {
       log.debug "Fan Level info is present"
       jsonRequestBody += ',"fanLevel": "' + fanLevel + '"'
    if (targetTemperature != 0) {
    	jsonRequestBody += ',"targetTemperature": '+ targetTemperature + ',"temperatureUnit": "' + sUnit + '"'
    if (swingM)
        jsonRequestBody += ',"swing": "' + swingM + '"'
    jsonRequestBody += '}}'
	debugEvent ("Mode Request Body = ${jsonRequestBody}")
	boolean result = true
	if(!sendJson(PodUid, jsonRequestBody))
	{ result = false }
	if (result) {
        log.debug "Device : " + child.device.deviceNetworkId + " state : " + tData
		tData.data.fanLevel = fanLevel
        tData.data.thermostatFanMode = fanLevel
        tData.data.on = on
        tData.data.currentmode = mode
        log.debug "Thermostat mode " + on
        if (on=="off") {
        	tData.data.thermostatMode = "off"
        else {
        	 tData.data.thermostatMode = mode
        tData.data.targetTemperature = targetTemperature
        tData.data.coolingSetpoint = targetTemperature
        tData.data.heatingSetpoint = targetTemperature
        tData.data.thermostatSetpoint = targetTemperature
        tData.data.temperatureUnit = sUnit
    else {
	return(result)
//Get the capabilities of the A/C Unit
def getCapabilities(PodUid, mode)
	log.trace "getCapabilities() called"
    def last = state.lastPollCapabilitiesMillis ?: 0
	def next = last + getCapabilitiesRateMillis()
    def data = [:]
    if (state.capabilities == null || state.capabilities.$PodUid == null || now > next)
    //if (true)
    	log.debug "Now : " + now + " Next : " + next
    	//def data = [:]
		def pollParams = [
    	path: "/api/v2/pods/${PodUid}",
    	query: [apiKey:"${getapikey()}", integration:"${version()}", type:"json", fields:"remoteCapabilities,productModel"]]
     	try {
			log.trace "getCapabilities() called - Request sent to Sensibo API(remoteCapabilities) for PODUid : $PodUid - ${version()}"
     		httpGet(pollParams) { resp ->
                if (resp.data) {
                    log.debug "Status : " + resp.status
                    if(resp.status == 200) {
                        //resp.data = [result: [remoteCapabilities: [modes: [heat: [swing: ["stopped", "fixedTop", "fixedMiddleTop", "fixedMiddle", "fixedMiddleBottom", "fixedBottom", "rangeTop", "rangeMiddle", "rangeBottom", "rangeFull"], temperatures: [C: ["isNative": true, "values": [16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]], F: ["isNative": false, "values": [61, 63, 64, 66, 68, 70, 72, 73, 75, 77, 79, 81, 82, 84, 86]]], fanLevels: ["low", "medium", "high", "auto"]], fan: [swing: ["stopped", "fixedMiddleTop", "fixedMiddle", "fixedMiddleBottom", "fixedBottom", "rangeTop", "rangeMiddle", "rangeBottom", "rangeFull"], temperatures: [C: ["isNative": true, "values": [16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]], F: ["isNative": false, "values": [61, 63, 64, 66, 68, 70, 72, 73, 75, 77, 79, 81, 82, 84, 86]]], fanLevels: ["low", "medium", "high", "auto"]], cool: [swing: ["stopped", "fixedTop", "fixedMiddleTop", "fixedMiddle", "fixedMiddleBottom", "fixedBottom", "rangeTop", "rangeMiddle", "rangeBottom", "rangeFull"], temperatures: ["C": ["isNative": true, "values": [16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]], F: ["isNative": false, "values": [61, 63, 64, 66, 68, 70, 72, 73, 75, 77, 79, 81, 82, 84, 86]]], fanLevels: ["low", "high", "auto"]]]]]]
                        //resp.data = ["result": ["productModel": "skyv2", "remoteCapabilities": ["modes": ["dry": ["temperatures": ["C": ["isNative": false, "values": [17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]], "F": ["isNative": true, "values": [62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86]]], "swing": ["stopped", "rangeFull"]], "auto": ["temperatures": ["C": ["isNative": false, "values": [17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]], "F": ["isNative": true, "values": [62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86]]], "swing": ["stopped", "rangeFull"]], "heat": ["swing": ["stopped", "rangeFull"], "temperatures": ["C": ["isNative": false, "values": [17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]], "F": ["isNative": true, "values": [62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86]]], "fanLevels": ["low", "medium", "high", "auto"]], "fan": ["swing": ["stopped", "rangeFull"], "temperatures": [], "fanLevels": ["low", "medium", "high", "auto"]], "cool": ["swing": ["stopped", "rangeFull"], "temperatures": ["C": ["isNative": false, "values": [17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]], "F": ["isNative": true, "values": [62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86]]], "fanLevels": ["low", "medium", "high", "auto"]]]]]]
                        log.debug resp.data
                        if (state.capabilities == null) { state.capabilities = [:] }
                        state.capabilities.$PodUid = resp.data
                        log.debug "Succes read from Sensibo"
                        log.trace "Capabilities from Sensibo for ${PodUid} : " + state.capabilities.$PodUid
						state.lastPollCapabilitiesMillis = currentTime
                        switch (mode){
                            case "dry":
                                data = [
                                    remoteCapabilities : resp.data.result.remoteCapabilities.modes.dry,
                                    productModel :  resp.data.result.productModel
                                break
                            case "cool":
                                data = [
                                    remoteCapabilities : resp.data.result.remoteCapabilities.modes.cool,
                                break
                            case "heat":
                                data = [
                                    remoteCapabilities : resp.data.result.remoteCapabilities.modes.heat,
                                break
                            case "fan":
                                data = [
                                    remoteCapabilities : resp.data.result.remoteCapabilities.modes.fan,
                                break
                            case "auto":
                                data = [
                                    remoteCapabilities : resp.data.result.remoteCapabilities.modes.auto,
                                break
                            case "modes":
                                data = [
                                    remoteCapabilities : resp.data.result.remoteCapabilities.modes,
                                break
                        log.trace "Returning remoteCapabilities from Sensibo"
                        return data
                    else {
                        log.debug "get remoteCapabilities Failed"
                        data = [
                            remoteCapabilities : "",
                            productModel : ""
                        return data
        	return data
        	data = [
            	productModel : ""
     		return data
    else {
    	log.trace "Capabilities from local for ${PodUid} : " + state.capabilities.$PodUid
        //return
    	switch (mode){
            case "dry":
            data = [
                remoteCapabilities : state.capabilities.$PodUid.result.remoteCapabilities.modes.dry,
                productModel : state.capabilities.$PodUid.result.productModel
            break
            case "cool":
            data = [
                remoteCapabilities : state.capabilities.$PodUid.result.remoteCapabilities.modes.cool,
            break
            case "heat":
            data = [
                remoteCapabilities :state.capabilities.$PodUid.result.remoteCapabilities.modes.heat,
            break
            case "fan":
            data = [
                remoteCapabilities : state.capabilities.$PodUid.result.remoteCapabilities.modes.fan,
            break
            case "auto":
            data = [
                remoteCapabilities : state.capabilities.$PodUid.result.remoteCapabilities.modes.auto,
            break
            case "modes":
            data = [
                remoteCapabilities : state.capabilities.$PodUid.result.remoteCapabilities.modes,
            break
        log.trace "Returning remoteCapabilities from local"
        return data
// Get Climate React settings
def getClimateReact(PodUid)
	log.trace "getClimateReact() called - ${version()}"
	def data = [:]
	def pollParams = [
    	path: "/api/v2/pods/${PodUid}/smartmode",
    	query: [apiKey:"${getapikey()}", integration:"${version()}", type:"json", fields:"*"]]
    try {
			if (resp.data) {
				debugEvent ("Response from Sensibo GET = ${resp.data}")
				debugEvent ("Response Status = ${resp.status}")
            log.trace "Get ClimateReact " + resp.data.result
                if (!resp.data.result) {
                	data = [
                 		Climate : "notdefined",
                 		Error : "Success"]
                 	log.debug "Returning Climate React (not configured)"
                 	return data
            	resp.data.result.any { stat ->
                    log.trace "get ClimateReact Success"
                    log.debug "PodUID : $PodUid : " + PodUid
                    def OnOff = "off"
                    if (resp.data.result.enabled != null) {
                    	OnOff = resp.data.result.enabled ? "on" : "off"
                    data = [
                        Climate : OnOff.toString(),
                        Error : "Success"
                    log.debug "Climate: ${data.Climate}"
                    log.trace "Returning Climate React"
                    return data
            else {
           	     data = [
                 	Error : "Failed"]
                 log.debug "get ClimateReact Failed"
                 return data
       return data
    catch(Exception e)
        data = [
            Error : "Failed"
        return data
// Get the latest state from the Sensibo Pod
def getACState(PodUid)
	log.trace "getACState() called - ${version()}"
	def data = [:]
	def pollParams = [
    	path: "/api/v2/pods/${PodUid}/acStates",
    	query: [apiKey:"${getapikey()}", integration:"${version()}", type:"json", limit:1, fields:"status,acState,device"]]
    try {
			if (resp.data) {
                	if (stat.status == "Success") {
                        log.trace "get ACState Success"
                        log.debug "PodUID : $PodUid : " + stat.acState
                        def OnOff = stat.acState.on ? "on" : "off"
                        stat.acState.on = OnOff
						def stemp
                        if (stat.acState.targetTemperature == null) {
                          stemp = stat.device.measurements.temperature.toInteger()
                        else {
                          stemp = stat.acState.targetTemperature.toInteger()
                        def tempUnit
                        if (stat.acState.temperatureUnit == null) {
                          tempUnit = stat.device.temperatureUnit
                        else {
                          tempUnit = stat.acState.temperatureUnit
                        def tMode
                        if (OnOff=="off") {
        					tMode = "off"
				        else {
        	 				tMode = stat.acState.mode
						def sMode
						if (stat.acState.swing == null) {
                          sMode = "stopped"
                        else {
                          sMode = stat.acState.swing
                        log.debug "product Model : " + stat.device.productModel
                        def battery = stat.device.productModel == "skyv1" ? "battery" : "mains"
                        log.debug "swing Mode :" + stat.acState.swing
                        data = [
                            targetTemperature : stemp,
                            fanLevel : stat.acState.fanLevel,
                            currentmode : stat.acState.mode,
                            on : OnOff.toString(),
                            switch: OnOff.toString(),
                            thermostatMode: tMode,
                            thermostatFanMode : stat.acState.fanLevel,
                            coolingSetpoint : stemp,
                            heatingSetpoint : stemp,
                            thermostatSetpoint : stemp,
                            temperatureUnit : tempUnit,
                            swing : sMode,
                            powerSource : battery,
                            productModel : stat.device.productModel,
                            firmwareVersion : stat.device.firmwareVersion,
                            Error : "Success"
                        log.debug "On: ${data.on} targetTemp: ${data.targetTemperature} fanLevel: ${data.fanLevel} Thermostat mode: ${data.mode} swing: ${data.swing}"
                        log.trace "Returning ACState"
                        return data
                    else { log.debug "get ACState Failed"}
           else {
           	  data = [
                 targetTemperature : "0",
                 fanLevel : "--",
                 currentmode : "--",
                 on : "--",
                 switch : "--",
                 thermostatMode: "--",
                 thermostatFanMode : "--",
                 coolingSetpoint : "0",
                 heatingSetpoint : "0",
                 thermostatSetpoint : "0",
                 temperatureUnit : "",
                 swing : "--",
                 powerSource : "",
                 productModel : "",
                 firmwareVersion : "",
                 Error : "Failed"
              return data
       return data
    catch(Exception e)
        data = [
            fanLevel : "--",
            currentmode : "--",
            on : "--",
            switch : "--",
            swing : "--",
            powerSource : "",
            productModel : "",
            Error : "Failed"
        return data
def sendPutJson(String PodUid, String jsonBody)
 	log.trace "sendPutJson() called - Request sent to Sensibo API(smartmode) for PODUid : $PodUid - ${version()} - $jsonBody"
	def cmdParams = [
		headers: ["Content-Type": "application/json"],
        query: [apiKey:"${getapikey()}", integration:"${version()}", type:"json"],
		body: jsonBody]
    try{
       httpPut(cmdParams) { resp ->
                log.debug "updated ${resp.data}"
				debugEvent("updated ${resp.data}")
                log.trace "Successful call to Sensibo API."
                log.debug "Returning True"
				return true
           	else {
            	log.trace "Failed call to Sensibo API."
                return false
    catch(Exception e)
		log.debug "Exception Sending Json: " + e
		debugEvent ("Exception Sending JSON: " + e)
		return false
def sendPostJsonClimate(String PodUid, String jsonBody)
 	log.trace "sendPostJsonClimate() called - Request sent to Sensibo API(smartmode) for PODUid : $PodUid - ${version()} - $jsonBody"
	def cmdParams = [
		body: jsonBody]
    try{
       httpPost(cmdParams) { resp ->
				return true
           	else {
                return false
    catch(Exception e)
		return false
// Send state to the Sensibo Pod
def sendJson(String PodUid, String jsonBody)
    log.trace "sendJson() called - Request sent to Sensibo API(acStates) for PODUid : $PodUid - ${version()} - $jsonBody"
	def cmdParams = [
        query: [apiKey:"${getapikey()}", integration:"${version()}", type:"json", fields:"acState"],
		body: jsonBody]
	def returnStatus = false
    try{
                //returnStatus = resp.status
				returnStatus = true
           	else {
    catch(Exception e)
	log.debug "Return Status: ${returnStatus}"
	return returnStatus
def pollChildren(PodUid)
    log.trace "pollChildren() called"
    def thermostatIdsString = PodUid
	log.trace "polling children: $thermostatIdsString"
	def pollParams = [
    	path: "/api/v2/pods/${thermostatIdsString}/measurements",
    	query: [apiKey:"${getapikey()}", integration:"${version()}", type:"json", fields:"batteryVoltage,temperature,humidity,time"]]
	debugEvent ("Before HTTPGET to Sensibo.")
	try{
			if (resp.data) {
				log.trace "poll results returned"
                log.debug "DEBUG DATA RESULT" + resp.data.result
                if (resp.data.result == null || resp.data.result.empty)
                	log.debug "Cannot get measurement from the API, should ask Sensibo Support Team"
                	debugEvent ("Cannot get measurement from the API, should ask Sensibo Support Team",true)
                def setTemp = getACState(thermostatIdsString)
                def ClimateReact = getClimateReact(thermostatIdsString)
                if (setTemp.Error != "Failed") {
				 state.sensibo = resp.data.result.inject([:]) { collector, stat ->
					def dni = thermostatIdsString
					log.debug "updating dni $dni"
                    def stemp = stat.temperature ? stat.temperature.toDouble().round(1) : 0
                    def shumidify = stat.humidity ? stat.humidity.toDouble().round() : 0
                    if (setTemp.temperatureUnit == "F") {
                        stemp = cToF(stemp).round(1)
					def tMode
                    if (setTemp.on=="off") {
        				tMode = "off"
				    else {
        	 			tMode = setTemp.currentmode
					def battpourcentage = 100
                    def battVoltage = stat.batteryVoltage
					if (battVoltage == null)
                    	battVoltage = 3000
                    if (battVoltage < 2850) battpourcentage = 10
                    if (battVoltage > 2850 && battVoltage < 2950) battpourcentage = 50
					def data = [
						temperature: stemp,
						humidity: shumidify,
                        targetTemperature: setTemp.targetTemperature,
                        fanLevel: setTemp.fanLevel,
                        currentmode: setTemp.currentmode,
                        on: setTemp.on,
                        switch : setTemp.on,
                        thermostatFanMode: setTemp.fanLevel,
                        coolingSetpoint: setTemp.targetTemperature,
                        heatingSetpoint: setTemp.targetTemperature,
                        thermostatSetpoint: setTemp.targetTemperature,
                        temperatureUnit : setTemp.temperatureUnit,
                        voltage : battVoltage,
                        swing : setTemp.swing,
                        battery : battpourcentage,
                        powerSource : setTemp.powerSource,
                        productModel : setTemp.productModel,
                        firmwareVersion : setTemp.firmwareVersion,
                        Climate : ClimateReact.Climate,
                        Error: setTemp.Error
					debugEvent ("Event Data = ${data}",false)
					collector[dni] = [data:data]
					return collector
				log.debug "updated ${state.sensibo[thermostatIdsString].size()} stats: ${state.sensibo[thermostatIdsString]}"
                debugEvent ("updated ${state.sensibo[thermostatIdsString]}",false)
			else
				log.error "polling children & got http status ${resp.status}"
	catch(Exception e)
		log.debug "___exception polling children: " + e
		debugEvent ("${e}")
def pollHandler() {
	debugEvent ("in Poll() method.")
    // Hit the Sensibo API for update on all the Pod
    log.debug PodList
    PodList.each {
    	log.debug "polling " + it.deviceNetworkId
        pollChildren(it.deviceNetworkId) }
    state.sensibo.each {stat ->
		def dni = stat.key
		log.debug ("DNI = ${dni}")
		debugEvent ("DNI = ${dni}")
		if(d)
			log.debug ("Found Child Device.")
			debugEvent ("Found Child Device.")
			debugEvent("Event Data before generate event call = ${stat}")
			log.debug state.sensibo[dni]
			d.generateEvent(state.sensibo[dni].data)
def debugEvent(message, displayEvent = false) {
	def results = [
		descriptionText: message,
		displayed: displayEvent
	log.debug "Generating AppDebug Event: ${results}"
	sendEvent (results)
def cToF(temp) {
	return (temp * 1.8 + 32).toDouble()
def fToC(temp) {
Thanks so much @blink. Unfortunately the updated code hasn't worked either although it seems to have moved on to other issues.
When I first tried to turn the sensibo on the logs showed the following:
dev:142019-04-28 01:55:55.204 errorjava.lang.NullPointerException: Cannot get property 'value' on null object on line 806 (on)
dev:142019-04-28 01:55:55.173 debugTemp Unit : C
dev:142019-04-28 01:55:55.162 debugon called
I then tried a Refresh, which returned no errors in the logs:
dev:142019-04-28 01:57:06.781 debugrefresh() ended
dev:142019-04-28 01:57:06.580 debugname :Error value :Success
dev:142019-04-28 01:57:06.579 debugname :Climate value :notdefined
dev:142019-04-28 01:57:06.578 debugname :firmwareVersion value :SKY30036
dev:142019-04-28 01:57:06.577 debugname :productModel value :skyv2
dev:142019-04-28 01:57:06.552 debugname :powerSource value :mains
dev:142019-04-28 01:57:06.549 debugname :battery value :100
dev:142019-04-28 01:57:06.547 debugname :swing value :stopped
dev:142019-04-28 01:57:06.546 debugname :voltage value :3000
dev:142019-04-28 01:57:06.545 debugname :temperatureUnit value :C
dev:142019-04-28 01:57:06.544 debugname :thermostatSetpoint value :18
dev:142019-04-28 01:57:06.543 debugname :heatingSetpoint value :18
dev:142019-04-28 01:57:06.537 debugname :coolingSetpoint value :18
dev:142019-04-28 01:57:06.536 debugname :thermostatFanMode value :null
dev:142019-04-28 01:57:06.535 debugname :thermostatMode value :off
dev:142019-04-28 01:57:06.534 debugname :switch value :off
dev:142019-04-28 01:57:06.533 debugname :on value :off
dev:142019-04-28 01:57:06.532 debugname :currentmode value :null
dev:142019-04-28 01:57:06.531 debugname :fanLevel value :null
dev:142019-04-28 01:57:06.529 debugname :targetTemperature value :18
dev:142019-04-28 01:57:06.514 debugname :humidity value :64
dev:142019-04-28 01:57:06.503 debugname :temperature value :18.9
dev:142019-04-28 01:57:06.494 debugparsing Event data [temperature:18.9, humidity:64, targetTemperature:18, fanLevel:null, currentmode:null, on:off, switch:off, thermostatMode:off, thermostatFanMode:null, coolingSetpoint:18, heatingSetpoint:18, thermostatSetpoint:18, temperatureUnit:C, voltage:3000, swing:stopped, battery:100, powerSource:mains, productModel:skyv2, firmwareVersion:SKY30036, Climate:notdefined, Error:Success]
dev:142019-04-28 01:57:06.419 debugparsing data [temperature:18.9, humidity:64, targetTemperature:18, fanLevel:null, currentmode:null, on:off, switch:off, thermostatMode:off, thermostatFanMode:null, coolingSetpoint:18, heatingSetpoint:18, thermostatSetpoint:18, temperatureUnit:C, voltage:3000, swing:stopped, battery:100, powerSource:mains, productModel:skyv2, firmwareVersion:SKY30036, Climate:notdefined, Error:Success]
dev:142019-04-28 01:57:01.889 debugExecuting 'poll' using parent SmartApp
dev:142019-04-28 01:57:01.881 debugrefresh() called
Although after the refresh, no further errors were reported when I tried to switch on again, but still no action from the Sensibo:
dev:142019-04-28 01:57:16.117 debugSensibo Pod Living Room A/C FAILED to set the AC State
dev:142019-04-28 01:57:16.115 debugResult : false
dev:142019-04-28 01:57:14.349 debugTemp Unit : C
dev:142019-04-28 01:57:14.337 debugon called
Not sure if you can help any further, and can't see EricG's username in these forums?
I'm not sure that he uses Hubitat - this code is posted over in SmartThings. It looks like a bunch of fan related status' are also null for you at this point: fanLevel, currentMode, and thermostatFanMode. Could you try turning on your sensibo and running a refresh to see if those values get populated or if they're still null?
Thank you, @blink, for your work on this. I just tried out your code for the first time, and it seems to be working fine for me straight away. There are a few errors showing in the logs, which might indicate a little bit of cleanup necessary in the code, but my AC is being successfully controlled from my Hubitat.
One thing I would love to see is a switch to enable/disable debug logging, like most other devices seem to have. Once the integration has been setup and tested, I don't really want to have all the debug log entries populating my logs.
I also want to thank @blink for his work and @Angus_M for describing the steps simply enough for me to follow. It seems to be working for me too.
thank you, I setup the driver, then the app, then added the app with API and found my 2 V1 sensibo devices. Love it.
How r u guys finding performance? I'm still finding its slow at times due to the Cloud I guess. Same with interaction using Google Home too. Wish we had a direct integration.
@blink Is it possible for you to create a set of device and driver code with no debug logging?
I found that they flood my log every 10 seconds or so and it is not ideal.
Or maybe someone can suggest an easy way for me to turn the debugging off?
I have the same. Agree would be great to suppress all the unnecessary logging.or have an easy option for this.
@tonysosw how is the performance for you. Do you find they respond ok? I have patchy response.
@Angus_M I haven't encountered any problem yet, all commands seems to be functional and my aircon responded accordingly
same here with my 2 gen1's - no issues
I've got Sky v2, (three of them), and no problem with performance.
But, for the lolz, I've just taken the App and Driver and wrapped the Logging functions so you can turn on/off logging.
In the driver code, you can switch it off per device on the device screen (info and debug), but this generally doesn't generate much in the way of messages.
See below for App code (which is very noisy), and you can turn on/off logging (This code has logging turned off by default)
NOTE: I'm a total novice at this, but it seems to work for me, and has made the logs way cleaner, so enjoy!
Driver Code
(Revised - see post #54)
App Code
Change Lines 44-46 from false to true if you want to turn logging on.
 *  Copyright 2015 Eric Gosselin
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
definition(
    namespace: "EricG66",
    author: "Eric Gosselin",
    appSetting "apikey"
preferences {
// if you want logging, set these true, else false
def debugLog() { return false }
def traceLog() { return false }
private def displayDebugLog(message) {
	if (debugLog() == true) log.debug "${message}"
private def displayTraceLog(message) {
	if (traceLog() == true) log.trace  "${message}"
def setAPIKey()
	displayTraceLog( "setAPIKey()")
	if(appSettings)
    else {
        def pod = ""
		section(""){
    return p
	displayTraceLog( "SensiboPodList()")
	displayDebugLog( "device list: $stats")
		section(""){
        	section("") {
	return p
def timePage() {
      section("") {
      section("") {
	displayTraceLog( "getSensiboPodList called")
	def pods = [:]
    try {
                    def key = pod.id
					pods[key] = value
                state.pods = pods
    catch(Exception e)
		displayDebugLog( "Exception Get Json: " + e)
    displayDebugLog( "Sensibo Pods: $pods"  )
    return pods
def installed() {
	displayTraceLog( "Installed() called with settings: ${settings}")
	initialize()
    displayDebugLog( "Configured health checkInterval when installed()")
def updated() {
	displayTraceLog( "Updated() called with settings: ${settings}")
	unschedule()
    unsubscribe()
    initialize()
def ping() {
	displayTraceLog( "ping called")
    try {
				returnStatus = true
    catch(Exception e)
    return returnStatus
	displayTraceLog( "hournotification() called")
    def stext = ""
            devices.each { d ->
                displayTraceLog( "Notification every hour for device: ${d.id}")
                sendPush(stext)
    else {
            devices.each { d ->
                sendPush(stext)
//        displayDebugLog( "switch turned on!")
//        displayDebugLog( "switch turned off!")
                sendPush(stext)
                sendPush(stext)
                sendPush(stext)
                sendPush(stext)
                    return false
    else {
                    return false
    return true
    if (!result) {
        return false
    	return false
    		return true
    	else
	    	return false
    return true
def refresh() {
	displayTraceLog( "refresh() called with rate of " + refreshinminutes + " minutes")
    unschedule()
	refreshDevices()
    else
	displayTraceLog( "refreshOneDevice() called")
	d.refresh()
	displayTraceLog( "refreshDevices() called")
	devices.each { d ->
		displayDebugLog( "Calling refresh() on device: ${d.id}")
		d.refresh()
def initialize() {
    displayTraceLog( "initialize() called")
    displayTraceLog( "key "+ getapikey())
		displayDebugLog( dni)
		if(!d)
				displayDebugLog( "Pod : ${name.value} - Hub : ${location.hubs[0].name} - Type : " +  getChildTypeName() + " - Namespace : " + getChildNamespace())
                d.save()
				displayTraceLog( "created ${d.displayName} with id $dni")
			else
				displayTraceLog( "found ${d.displayName} with id $dni already exists")
			return d
	displayTraceLog( "created ${devices.size()} Sensibo Pod")
	def delete
		displayDebugLog( "delete Sensibo")
	else
	displayTraceLog( "deleting ${delete.size()} Sensibo")
    pollHandler()
    refreshDevices()
    else
	displayTraceLog( "on off handler activated")
    if (sendPush) {
	displayTraceLog( "pollChild() called")
	displayDebugLog( "pollChild( ${child.device.deviceNetworkId} ): $now > $next ?? w/ current state: ${state.sensibo}")
	//if( now > next )
		displayDebugLog( "polling children because $now > $next")
		displayDebugLog( "polled children and looking for ${child.device.deviceNetworkId} from ${state.sensibo}")
        displayDebugLog(  "DEBUG - TDATA" + tData)
			return null
		return tData.data
		displayDebugLog( "not polling children, found child ${child.device.deviceNetworkId} ")
		if(!tData.updated)
			return tData.data
		return null
		return null
	else
	return null
	displayTraceLog( "configureClimateReact() called for $PodUid with settings : $JsonString"  )
    if (result) {
    else {
    return(result)
	displayTraceLog( "setClimateReact() called for $PodUid Climate React: $ClimateState"   )
    displayDebugLog( "DEBUG " + ClimateReact.Climate + " " + ClimateState)
        return true
    def jsonRequestBody
    else {
    displayDebugLog( "Mode Request Body = ${jsonRequestBody}")
    if (result) {
    else {
    return(result)
	displayTraceLog( "setACStates() called for $PodUid ON: $on - MODE: $mode - Temp : $targetTemperature - FAN : $fanLevel - SWING MODE : $swingM - UNIT : $sUnit")
    displayTraceLog( "Target Temperature :" + targetTemperature)
    displayDebugLog( "Fan Level is :$fanLevel")
    displayDebugLog( "Swing is :$swingM")
    displayDebugLog( "Target Temperature is :$targetTemperature")
       displayDebugLog( "Fan Level info is present")
    if (swingM)
	{ result = false }
	if (result) {
        displayDebugLog( "Device : " + child.device.deviceNetworkId + " state : " + tData)
        tData.data.on = on
        displayDebugLog( "Thermostat mode " + on)
        if (on=="off") {
        else {
        tData.data.swing = swingM
    else {
	return(result)
	displayTraceLog( "getCapabilities() called")
    def data = [:]
    //if (true)
    	displayDebugLog( "Now : " + now + " Next : " + next    	)
    	//def data = [:]
		def pollParams = [
     	try {
			displayTraceLog( "getCapabilities() called - Request sent to Sensibo API(remoteCapabilities) for PODUid : $PodUid - ${version()}")
                if (resp.data) {
                    displayDebugLog( "Status : " + resp.status)
                        displayDebugLog( resp.data)
                        displayDebugLog( "Succes read from Sensibo")
                        displayTraceLog( "Capabilities from Sensibo for ${PodUid} : " + state.capabilities.$PodUid	)
                        switch (mode){
                            case "dry":
                                data = [
                                break
                            case "cool":
                                data = [
                                break
                            case "heat":
                                data = [
                                break
                            case "fan":
                                data = [
                                break
                            case "auto":
                                data = [
                                break
                            case "modes":
                                data = [
                                break
                        displayTraceLog( "Returning remoteCapabilities from Sensibo")
                        return data
                    else {
                        displayDebugLog( "get remoteCapabilities Failed")
                        data = [
                            productModel : ""
                        return data
        	return data
        	data = [
            	productModel : ""
     		return data
    else {
    	displayTraceLog( "Capabilities from local for ${PodUid} : " + state.capabilities.$PodUid)
        //return
    	switch (mode){
            case "dry":
            data = [
            break
            case "cool":
            data = [
            break
            case "heat":
            data = [
            break
            case "fan":
            data = [
            break
            case "auto":
            data = [
            break
            case "modes":
            data = [
            break
        displayTraceLog( "Returning remoteCapabilities from local")
        return data
	displayTraceLog( "getClimateReact() called - ${version()}")
	def data = [:]
	def pollParams = [
    try {
			if (resp.data) {
            displayTraceLog( "Get ClimateReact " + resp.data.result)
                	data = [
                 		Error : "Success"]
                 	displayDebugLog( "Returning Climate React (not configured)")
                 	return data
                    displayTraceLog( "get ClimateReact Success")
                    displayDebugLog( "PodUID : $PodUid : " + PodUid			)
                    def OnOff = "off"
                    data = [
                        Error : "Success"
                    displayDebugLog( "Climate: ${data.Climate}")
                    displayTraceLog( "Returning Climate React"   )
                    return data
            else {
           	     data = [
                 	Error : "Failed"]
                 displayDebugLog( "get ClimateReact Failed")
                 return data
       return data
    catch(Exception e)
        data = [
            Error : "Failed"
        return data
	displayTraceLog( "getACState() called - ${version()}")
	def data = [:]
	def pollParams = [
    try {
			if (resp.data) {
                        displayTraceLog( "get ACState Success")
                        displayDebugLog( "PodUID : $PodUid : " + stat.acState)
						def stemp
                        else {
                        def tempUnit
                        else {
                        def tMode
                        if (OnOff=="off") {
        					tMode = "off"
				        else {
						def sMode
                          sMode = "stopped"
                        else {
                        displayDebugLog( "product Model : " + stat.device.productModel)
                        displayDebugLog( "swing Mode :" + stat.acState.swing)
                        data = [
                            swing : sMode,
                            Error : "Success"
                        displayDebugLog( "On: ${data.on} targetTemp: ${data.targetTemperature} fanLevel: ${data.fanLevel} Thermostat mode: ${data.mode} swing: ${data.swing}")
                        displayTraceLog( "Returning ACState")
                        return data
                    else { displayDebugLog( "get ACState Failed") }
           else {
           	  data = [
                 fanLevel : "--",
                 currentmode : "--",
                 on : "--",
                 switch : "--",
                 swing : "--",
                 powerSource : "",
                 productModel : "",
                 Error : "Failed"
              return data
       return data
    catch(Exception e)
        data = [
            fanLevel : "--",
            currentmode : "--",
            on : "--",
            switch : "--",
            swing : "--",
            powerSource : "",
            productModel : "",
            Error : "Failed"
        return data
 	displayTraceLog( "sendPutJson() called - Request sent to Sensibo API(smartmode) for PODUid : $PodUid - ${version()} - $jsonBody")
	def cmdParams = [
		body: jsonBody]
    try{
                displayDebugLog( "updated ${resp.data}")
                displayTraceLog( "Successful call to Sensibo API.")
                displayDebugLog( "Returning True")
				return true
           	else {
            	displayTraceLog( "Failed call to Sensibo API.")
                return false
    catch(Exception e)
		displayDebugLog( "Exception Sending Json: " + e)
		return false
 	displayTraceLog( "sendPostJsonClimate() called - Request sent to Sensibo API(smartmode) for PODUid : $PodUid - ${version()} - $jsonBody")
	def cmdParams = [
		body: jsonBody]
    try{
				return true
           	else {
                return false
    catch(Exception e)
		return false
    displayTraceLog( "sendJson() called - Request sent to Sensibo API(acStates) for PODUid : $PodUid - ${version()} - $jsonBody")
	def cmdParams = [
		body: jsonBody]
    try{
				returnStatus = true
           	else {
    catch(Exception e)
	displayDebugLog( "Return Status: ${returnStatus}")
	return returnStatus
    displayTraceLog( "pollChildren() called")
	displayTraceLog( "polling children: $thermostatIdsString")
	def pollParams = [
	try{
			if (resp.data) {
				displayTraceLog( "poll results returned"     )
                displayDebugLog( "DEBUG DATA RESULT" + resp.data.result)
                	displayDebugLog( "Cannot get measurement from the API, should ask Sensibo Support Team")
					displayDebugLog( "updating dni $dni")
					def tMode
        				tMode = "off"
				    else {
                    	battVoltage = 3000
					def data = [
						temperature: stemp,
                        on: setTemp.on,
					return collector
				displayDebugLog( "updated ${state.sensibo[thermostatIdsString].size()} stats: ${state.sensibo[thermostatIdsString]}")
			else
	catch(Exception e)
		displayDebugLog( "___exception polling children: " + e)
		debugEvent ("${e}")
def pollHandler() {
    displayDebugLog( PodList)
    PodList.each {
    	displayDebugLog( "polling " + it.deviceNetworkId)
		def dni = stat.key
		displayDebugLog( ("DNI = ${dni}"))
		if(d)
			displayDebugLog( ("Found Child Device."))
			displayDebugLog( state.sensibo[dni])
	def results = [
	displayDebugLog( "Generating AppDebug Event: ${results}")
	sendEvent (results)
def cToF(temp) {
def fToC(temp) {
@robert1 Thanks a lot for the code Robert, my logs are now much much cleaner!!
Add to driver metadeta definition to get rid of some errors:
    attribute "on","String"
