@blink Is it possible for you to create a set of device and driver code with no debug logging?
I found that they flood my log every 10 seconds or so and it is not ideal.
Or maybe someone can suggest an easy way for me to turn the debugging off?
I have the same. Agree would be great to suppress all the unnecessary logging.or have an easy option for this.
@Angus_M I haven't encountered any problem yet, all commands seems to be functional and my aircon responded accordingly
same here with my 2 gen1's - no issues
I've got Sky v2, (three of them), and no problem with performance.
But, for the lolz, I've just taken the App and Driver and wrapped the Logging functions so you can turn on/off logging.
In the driver code, you can switch it off per device on the device screen (info and debug), but this generally doesn't generate much in the way of messages.
See below for App code (which is very noisy), and you can turn on/off logging (This code has logging turned off by default)
NOTE: I'm a total novice at this, but it seems to work for me, and has made the logs way cleaner, so enjoy!
Driver Code
(Revised - see post #54)
App Code
Change Lines 44-46 from false to true if you want to turn logging on.
* Sensibo Integration for Hubitat
* Copyright 2015 Eric Gosselin
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
name: "Sensibo Integration",
namespace: "EricG66",
author: "Eric Gosselin",
description: "Connect your Sensibo Pod to Hubitat.",
category: "Green Living",
iconUrl: "https://image.ibb.co/j7qAPT/Sensibo_1x.png",
iconX2Url: "https://image.ibb.co/coZtdo/Sensibo_2x.png",
iconX3Url: "https://image.ibb.co/cBwTB8/Sensibo_3x.png",
singleInstance: true)
appSetting "apikey"
preferences {
page(name: "SelectAPIKey", title: "API Key", content: "setAPIKey", nextPage: "deviceList", install: false, uninstall: true)
page(name: "deviceList", title: "Sensibo", content:"SensiboPodList", install:true, uninstall: true)
page(name: "timePage")
page(name: "timePageEvent")
def getServerUrl() { "https://home.sensibo.com" }
def getapikey() { apiKey }
//def version() { "SmartThingsv1.5" }
// if you want logging, set these true, else false
def debugLog() { return false }
def traceLog() { return false }
public static String version() { return "SmartThingsv1.6" }
private def displayDebugLog(message) {
if (debugLog() == true) log.debug "${message}"
private def displayTraceLog(message) {
if (traceLog() == true) log.trace "${message}"
def setAPIKey()
displayTraceLog( "setAPIKey()")
if(appSettings)
def pod = appSettings.apikey
else {
def pod = ""
def p = dynamicPage(name: "SelectAPIKey", title: "Enter your API Key", uninstall: true) {
section(""){
paragraph "Please enter your API Key provided by Sensibo \n\nAvailable at: \nhttps://home.sensibo.com/me/api"
input(name: "apiKey", title:"", type: "text", required:true, multiple:false, description: "", defaultValue: pod)
return p
def SensiboPodList()
displayTraceLog( "SensiboPodList()")
def stats = getSensiboPodList()
displayDebugLog( "device list: $stats")
def p = dynamicPage(name: "deviceList", title: "Select Your Sensibo Pod", uninstall: true) {
section(""){
paragraph "Tap below to see the list of Sensibo Pods available in your Sensibo account and select the ones you want to connect to SmartThings."
input(name: "SelectedSensiboPods", title:"Pods", type: "enum", required:true, multiple:true, description: "Tap to choose", options: stats)
section("Refresh") {
input(name:"refreshinminutes", title: "Refresh rates in minutes", type: "enum", required:false, multiple: false, options: ["1", "5", "10","15","30"])
// No push notifications on Hubitat
section("Receive Pod sensors infos") {
input "boolnotifevery", "bool",submitOnChange: true, required: false, title: "Receive temperature, humidity and battery level notification every hour?"
href(name: "toTimePageEvent",
page: "timePageEvent", title:"Only during a certain time", require: false)
section("Alert on sensors (threshold)") {
input "sendPushNotif", "bool",submitOnChange: true, required: false, title: "Receive alert on Sensibo Pod sensors based on threshold?"
if (sendPushNotif) {
section("Select the temperature threshold",hideable: true) {
input "minTemperature", "decimal", title: "Min Temperature",required:false
input "maxTemperature", "decimal", title: "Max Temperature",required:false }
section("Select the humidity threshold",hideable: true) {
input "minHumidity", "decimal", title: "Min Humidity level",required:false
input "maxHumidity", "decimal", title: "Max Humidity level",required:false }
section("How frequently?") {
input(name:"days", title: "Only on certain days of the week", type: "enum", required:false, multiple: true, options: ["Monday", "Tuesday", "Wednesday","Thursday","Friday","Saturday","Sunday"])
section("") {
href(name: "toTimePage",
page: "timePage", title:"Only during a certain time", require: false)
return p
// page def must include a parameter for the params map!
def timePage() {
dynamicPage(name: "timePage", uninstall: false, install: false, title: "Only during a certain time") {
section("") {
input(name: "startTime", title: "Starting at : ", required:false, multiple: false, type:"time",)
input(name: "endTime", title: "Ending at : ", required:false, multiple: false, type:"time")
def timePageEvent() {
dynamicPage(name: "timePageEvent", uninstall: false, install: false, title: "Only during a certain time") {
section("") {
input(name: "startTimeEvent", title: "Starting at : ", required:false, multiple: false, type:"time",)
input(name: "endTimeEvent", title: "Ending at : ", required:false, multiple: false, type:"time")
def getSensiboPodList()
displayTraceLog( "getSensiboPodList called")
def deviceListParams = [
uri: "${getServerUrl()}",
path: "/api/v2/users/me/pods",
requestContentType: "application/json",
query: [apiKey:"${getapikey()}", integration:"${version()}", type:"json",fields:"id,room" ]]
def pods = [:]
try {
httpGet(deviceListParams) { resp ->
if(resp.status == 200)
resp.data.result.each { pod ->
def key = pod.id
def value = pod.room.name
pods[key] = value
state.pods = pods
catch(Exception e)
displayDebugLog( "Exception Get Json: " + e)
debugEvent ("Exception get JSON: " + e)
displayDebugLog( "Sensibo Pods: $pods" )
return pods
def installed() {
displayTraceLog( "Installed() called with settings: ${settings}")
state.lastTemperaturePush = null
state.lastHumidityPush = null
initialize()
def d = getChildDevices()
if (boolnotifevery) {
//runEvery1Hour("hournotification")
schedule("0 0 * * * ?", "hournotification")
displayDebugLog( "Configured health checkInterval when installed()")
sendEvent(name: "checkInterval", value: 2 * 60 * 60 + 2 * 60, displayed: true)
//subscribe(d,"temperatureUnit",eTempUnitHandler)
subscribe(d, "temperature", eTemperatureHandler)
subscribe(d, "humidity", eHumidityHandler)
def updated() {
displayTraceLog( "Updated() called with settings: ${settings}")
unschedule()
unsubscribe()
initialize()
def ping() {
displayTraceLog( "ping called")
def returnStatus = true
try {
returnStatus = true
catch(Exception e)
returnStatus = false
return returnStatus
def hournotification() {
displayTraceLog( "hournotification() called")
def hour = new Date()
def curHour = hour.format("HH:mm",location.timeZone)
def curDay = hour.format("EEEE",location.timeZone)
// Check the time Threshold
def stext = ""
if (startTimeEvent && endTimeEvent) {
def minHour = new Date().parse(smartThingsDateFormat(), startTimeEvent)
def endHour = new Date().parse(smartThingsDateFormat(), endTimeEvent)
def minHourstr = minHour.format("HH:mm",location.timeZone)
def maxHourstr = endHour.format("HH:mm",location.timeZone)
if (curHour >= minHourstr && curHour <= maxHourstr)
def devices = getChildDevices()
devices.each { d ->
displayTraceLog( "Notification every hour for device: ${d.id}")
def currentPod = d.displayName
def currentTemperature = d.currentState("temperature").value
def currentHumidity = d.currentState("humidity").value
def currentBattery = d.currentState("voltage").value
def sunit = d.currentState("temperatureUnit").value
stext = "${currentPod} - Temperature: ${currentTemperature} ${sunit} Humidity: ${currentHumidity}% Battery: ${currentBattery}"
sendPush(stext)
else {
devices.each { d ->
sendPush(stext)
//def switchesHandler(evt)
// if (evt.value == "on") {
// displayDebugLog( "switch turned on!")
// } else if (evt.value == "off") {
// displayDebugLog( "switch turned off!")
def eTempUnitHandler(evt)
//refreshOneDevice(evt.device.displayName)
def eTemperatureHandler(evt){
def currentTemperature = evt.device.currentState("temperature").value
def currentPod = evt.device.displayName
if (inDateThreshold(evt,"temperature") == true) {
if(maxTemperature != null){
if(currentTemperature.toDouble() > maxTemperature)
def stext = "Temperature level is too high at ${currentPod} : ${currentTemperature}"
sendEvent(name: "lastTemperaturePush", value: "${stext}", displayed : "true", descriptionText:"${stext}")
sendPush(stext)
state.lastTemperaturePush = hour
if(minTemperature != null) {
if(currentTemperature.toDouble() < minTemperature)
def stext = "Temperature level is too low at ${currentPod} : ${currentTemperature}"
sendPush(stext)
def eHumidityHandler(evt){
def currentHumidity = evt.device.currentState("humidity").value
if (inDateThreshold(evt,"humidity") == true) {
if(maxHumidity != null){
if(currentHumidity.toDouble() > maxHumidity)
def stext = "Humidity level is too high at ${currentPod} : ${currentHumidity}"
sendEvent(name: "lastHumidityPush", value: "${stext}", displayed : "true", descriptionText:"${stext}")
sendPush(stext)
state.lastHumidityPush = hour
if(minHumidity != null) {
if(currentHumidity.toDouble() < minHumidity)
def stext = "Humidity level is too low at ${currentPod} : ${currentHumidity}"
sendPush(stext)
public smartThingsDateFormat() { "yyyy-MM-dd'T'HH:mm:ss.SSSZ" }
public smartThingsDateFormatNoMilli() { "yyyy-MM-dd'T'HH:mm:ssZ" }
def canPushNotification(currentPod, hour,sType) {
// Check if the client already received a push
if (sType == "temperature") {
if (sfrequency.toString().isInteger()) {
if (state.lastTemperaturePush != null) {
long unxNow = hour.time
def before = new Date().parse(smartThingsDateFormatNoMilli(),state.lastTemperaturePush)
long unxEnd = before.time
unxNow = unxNow/1000
unxEnd = unxEnd/1000
def timeDiff = Math.abs(unxNow-unxEnd)
timeDiff = timeDiff/60
if (timeDiff <= sfrequency)
return false
else {
if (state.lastHumidityPush != null) {
def before = new Date().parse(smartThingsDateFormatNoMilli(),state.lastHumidityPush)
return false
return true
def inDateThreshold(evt,sType) {
def result = canPushNotification(currentPod,hour, sType)
if (!result) {
return false
// Check the day of the week
if (days != null && !days.contains(curDay)) {
return false
if (startTime && endTime) {
def minHour = new Date().parse(smartThingsDateFormat(), startTime)
def endHour = new Date().parse(smartThingsDateFormat(), endTime)
if (curHour >= minHourstr && curHour < maxHourstr)
return true
else
return false
return true
def refresh() {
displayTraceLog( "refresh() called with rate of " + refreshinminutes + " minutes")
unschedule()
refreshDevices()
if (refreshinminutes == "1")
runEvery1Minute("refreshDevices")
else if (refreshinminutes == "5")
runEvery5Minutes("refreshDevices")
else if (refreshinminutes == "10")
runEvery10Minutes("refreshDevices")
else if (refreshinminutes == "15")
runEvery15Minutes("refreshDevices")
else if (refreshinminutes == "30")
runEvery30Minutes("refreshDevices")
else
def refreshOneDevice(dni) {
displayTraceLog( "refreshOneDevice() called")
def d = getChildDevice(dni)
d.refresh()
def refreshDevices() {
displayTraceLog( "refreshDevices() called")
devices.each { d ->
displayDebugLog( "Calling refresh() on device: ${d.id}")
d.refresh()
def getChildNamespace() { "EricG66" }
def getChildTypeName() { "SensiboPod" }
def initialize() {
displayTraceLog( "initialize() called")
displayTraceLog( "key "+ getapikey())
state.apikey = getapikey()
def devices = SelectedSensiboPods.collect { dni ->
displayDebugLog( dni)
if(!d)
def name = getSensiboPodList().find( {key,value -> key == dni })
displayDebugLog( "Pod : ${name.value} - Hub : ${location.hubs[0].name} - Type : " + getChildTypeName() + " - Namespace : " + getChildNamespace())
d = addChildDevice(getChildNamespace(), getChildTypeName(), dni, location.hubs[0].id, [
"label" : "Pod ${name.value}",
"name" : "Pod ${name.value}"
d.setIcon("on","on","https://image.ibb.co/jgAMW8/sensibo-sky-off.png")
d.setIcon("off","on","https://image.ibb.co/jgAMW8/sensibo-sky-off.png")
d.save()
displayTraceLog( "created ${d.displayName} with id $dni")
else
displayTraceLog( "found ${d.displayName} with id $dni already exists")
return d
displayTraceLog( "created ${devices.size()} Sensibo Pod")
def delete
// Delete any that are no longer in settings
if(!SelectedSensiboPods)
displayDebugLog( "delete Sensibo")
delete = getChildDevices()
else
delete = getChildDevices().findAll { !SelectedSensiboPods.contains(it.deviceNetworkId) }
displayTraceLog( "deleting ${delete.size()} Sensibo")
delete.each { deleteChildDevice(it.deviceNetworkId) }
def PodList = getChildDevices()
pollHandler()
refreshDevices()
else
// Subscribe functions
def OnOffHandler(evt) {
displayTraceLog( "on off handler activated")
debugEvent(evt.value)
//def name = evt.device.displayName
if (sendPush) {
//sendPush("The ${name} is turned on!")
//sendPush("The ${name} is turned off!")
def getPollRateMillis() { return 45 * 1000 }
def getCapabilitiesRateMillis() {return 60 * 1000 }
// Poll Child is invoked from the Child Device itself as part of the Poll Capability
def pollChild( child )
displayTraceLog( "pollChild() called")
debugEvent ("poll child")
def now = new Date().time
debugEvent ("Last Poll Millis = ${state.lastPollMillis}")
def last = state.lastPollMillis ?: 0
def next = last + pollRateMillis
displayDebugLog( "pollChild( ${child.device.deviceNetworkId} ): $now > $next ?? w/ current state: ${state.sensibo}")
debugEvent ("pollChild( ${child.device.deviceNetworkId} ): $now > $next ?? w/ current state: ${state.sensibo}")
//if( now > next )
if( true ) // for now let's always poll/refresh
displayDebugLog( "polling children because $now > $next")
debugEvent("polling children because $now > $next")
pollChildren(child.device.deviceNetworkId)
displayDebugLog( "polled children and looking for ${child.device.deviceNetworkId} from ${state.sensibo}")
debugEvent ("polled children and looking for ${child.device.deviceNetworkId} from ${state.sensibo}")
def currentTime = new Date().time
debugEvent ("Current Time = ${currentTime}")
state.lastPollMillis = currentTime
def tData = state.sensibo[child.device.deviceNetworkId]
if (tData == null) return
displayDebugLog( "DEBUG - TDATA" + tData)
debugEvent ("Error in Poll ${tData.data.Error}",false)
//tData.Error = false
//tData.data.Error = "Failed"
if(tData.data.Error != "Success")
log.error "ERROR: Device connection removed? no data for ${child.device.deviceNetworkId} after polling"
// TODO: flag device as in error state
// child.errorState = true
return null
tData.updated = currentTime
return tData.data
else if(state.sensibo[child.device.deviceNetworkId] != null)
displayDebugLog( "not polling children, found child ${child.device.deviceNetworkId} ")
if(!tData.updated)
// we have pulled new data for this thermostat, but it has not asked us for it
// track it and return the data
tData.updated = new Date().time
return tData.data
return null
else if(state.sensibo[child.device.deviceNetworkId] == null)
log.error "ERROR: Device connection removed? no data for ${child.device.deviceNetworkId}"
return null
else
// it's not time to poll again and this thermostat already has its latest values
return null
def configureClimateReact(child,String PodUid,String JsonString)
displayTraceLog( "configureClimateReact() called for $PodUid with settings : $JsonString" )
def result = sendPostJsonClimate(PodUid, JsonString)
if (result) {
if (tData == null) {
//tData.data.Climate = ClimateState
tData.data.Error = "Success"
else {
if (tData == null) return false
return(result)
def setClimateReact(child,String PodUid, ClimateState)
displayTraceLog( "setClimateReact() called for $PodUid Climate React: $ClimateState" )
def ClimateReact = getClimateReact(PodUid)
displayDebugLog( "DEBUG " + ClimateReact.Climate + " " + ClimateState)
if (ClimateReact.Climate == "notdefined") {
tData.data.Climate = ClimateReact.Climate
return true
def jsonRequestBody
if (ClimateState == "on") {
jsonRequestBody = '{"enabled": true}'
else {
jsonRequestBody = '{"enabled": false}'
displayDebugLog( "Mode Request Body = ${jsonRequestBody}")
def result = sendPutJson(PodUid, jsonRequestBody)
if (result) {
else {
return(result)
def setACStates(child,String PodUid, on, mode, targetTemperature, fanLevel, swingM, sUnit)
displayTraceLog( "setACStates() called for $PodUid ON: $on - MODE: $mode - Temp : $targetTemperature - FAN : $fanLevel - SWING MODE : $swingM - UNIT : $sUnit")
//Return false if no values was read from Sensibo API
if (on == "--") { return false }
def OnOff = (on == "on") ? true : false
//if (swingM == null) swingM = "stopped"
displayTraceLog( "Target Temperature :" + targetTemperature)
def jsonRequestBody = '{"acState":{"on": ' + OnOff.toString() + ',"mode": "' + mode + '"'
displayDebugLog( "Fan Level is :$fanLevel")
displayDebugLog( "Swing is :$swingM")
displayDebugLog( "Target Temperature is :$targetTemperature")
if (fanLevel != null) {
displayDebugLog( "Fan Level info is present")
jsonRequestBody += ',"fanLevel": "' + fanLevel + '"'
if (targetTemperature != 0) {
jsonRequestBody += ',"targetTemperature": '+ targetTemperature + ',"temperatureUnit": "' + sUnit + '"'
if (swingM)
jsonRequestBody += ',"swing": "' + swingM + '"'
jsonRequestBody += '}}'
debugEvent ("Mode Request Body = ${jsonRequestBody}")
boolean result = true
if(!sendJson(PodUid, jsonRequestBody))
{ result = false }
if (result) {
displayDebugLog( "Device : " + child.device.deviceNetworkId + " state : " + tData)
tData.data.fanLevel = fanLevel
tData.data.thermostatFanMode = fanLevel
tData.data.on = on
tData.data.currentmode = mode
displayDebugLog( "Thermostat mode " + on)
if (on=="off") {
tData.data.thermostatMode = "off"
else {
tData.data.thermostatMode = mode
tData.data.targetTemperature = targetTemperature
tData.data.coolingSetpoint = targetTemperature
tData.data.heatingSetpoint = targetTemperature
tData.data.thermostatSetpoint = targetTemperature
tData.data.temperatureUnit = sUnit
tData.data.swing = swingM
else {
return(result)
//Get the capabilities of the A/C Unit
def getCapabilities(PodUid, mode)
displayTraceLog( "getCapabilities() called")
def last = state.lastPollCapabilitiesMillis ?: 0
def next = last + getCapabilitiesRateMillis()
def data = [:]
if (state.capabilities == null || state.capabilities.$PodUid == null || now > next)
//if (true)
displayDebugLog( "Now : " + now + " Next : " + next )
//def data = [:]
def pollParams = [
path: "/api/v2/pods/${PodUid}",
query: [apiKey:"${getapikey()}", integration:"${version()}", type:"json", fields:"remoteCapabilities,productModel"]]
try {
displayTraceLog( "getCapabilities() called - Request sent to Sensibo API(remoteCapabilities) for PODUid : $PodUid - ${version()}")
httpGet(pollParams) { resp ->
if (resp.data) {
displayDebugLog( "Status : " + resp.status)
if(resp.status == 200) {
//resp.data = [result: [remoteCapabilities: [modes: [heat: [swing: ["stopped", "fixedTop", "fixedMiddleTop", "fixedMiddle", "fixedMiddleBottom", "fixedBottom", "rangeTop", "rangeMiddle", "rangeBottom", "rangeFull"], temperatures: [C: ["isNative": true, "values": [16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]], F: ["isNative": false, "values": [61, 63, 64, 66, 68, 70, 72, 73, 75, 77, 79, 81, 82, 84, 86]]], fanLevels: ["low", "medium", "high", "auto"]], fan: [swing: ["stopped", "fixedMiddleTop", "fixedMiddle", "fixedMiddleBottom", "fixedBottom", "rangeTop", "rangeMiddle", "rangeBottom", "rangeFull"], temperatures: [C: ["isNative": true, "values": [16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]], F: ["isNative": false, "values": [61, 63, 64, 66, 68, 70, 72, 73, 75, 77, 79, 81, 82, 84, 86]]], fanLevels: ["low", "medium", "high", "auto"]], cool: [swing: ["stopped", "fixedTop", "fixedMiddleTop", "fixedMiddle", "fixedMiddleBottom", "fixedBottom", "rangeTop", "rangeMiddle", "rangeBottom", "rangeFull"], temperatures: ["C": ["isNative": true, "values": [16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]], F: ["isNative": false, "values": [61, 63, 64, 66, 68, 70, 72, 73, 75, 77, 79, 81, 82, 84, 86]]], fanLevels: ["low", "high", "auto"]]]]]]
//resp.data = ["result": ["productModel": "skyv2", "remoteCapabilities": ["modes": ["dry": ["temperatures": ["C": ["isNative": false, "values": [17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]], "F": ["isNative": true, "values": [62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86]]], "swing": ["stopped", "rangeFull"]], "auto": ["temperatures": ["C": ["isNative": false, "values": [17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]], "F": ["isNative": true, "values": [62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86]]], "swing": ["stopped", "rangeFull"]], "heat": ["swing": ["stopped", "rangeFull"], "temperatures": ["C": ["isNative": false, "values": [17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]], "F": ["isNative": true, "values": [62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86]]], "fanLevels": ["low", "medium", "high", "auto"]], "fan": ["swing": ["stopped", "rangeFull"], "temperatures": [], "fanLevels": ["low", "medium", "high", "auto"]], "cool": ["swing": ["stopped", "rangeFull"], "temperatures": ["C": ["isNative": false, "values": [17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]], "F": ["isNative": true, "values": [62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86]]], "fanLevels": ["low", "medium", "high", "auto"]]]]]]
displayDebugLog( resp.data)
if (state.capabilities == null) { state.capabilities = [:] }
state.capabilities.$PodUid = resp.data
displayDebugLog( "Succes read from Sensibo")
displayTraceLog( "Capabilities from Sensibo for ${PodUid} : " + state.capabilities.$PodUid )
state.lastPollCapabilitiesMillis = currentTime
switch (mode){
case "dry":
data = [
remoteCapabilities : resp.data.result.remoteCapabilities.modes.dry,
productModel : resp.data.result.productModel
break
case "cool":
data = [
remoteCapabilities : resp.data.result.remoteCapabilities.modes.cool,
break
case "heat":
data = [
remoteCapabilities : resp.data.result.remoteCapabilities.modes.heat,
break
case "fan":
data = [
remoteCapabilities : resp.data.result.remoteCapabilities.modes.fan,
break
case "auto":
data = [
remoteCapabilities : resp.data.result.remoteCapabilities.modes.auto,
break
case "modes":
data = [
remoteCapabilities : resp.data.result.remoteCapabilities.modes,
break
displayTraceLog( "Returning remoteCapabilities from Sensibo")
return data
else {
displayDebugLog( "get remoteCapabilities Failed")
data = [
remoteCapabilities : "",
productModel : ""
return data
return data
catch(Exception e) {
data = [
productModel : ""
return data
else {
displayTraceLog( "Capabilities from local for ${PodUid} : " + state.capabilities.$PodUid)
//return
switch (mode){
case "dry":
data = [
remoteCapabilities : state.capabilities.$PodUid.result.remoteCapabilities.modes.dry,
productModel : state.capabilities.$PodUid.result.productModel
break
case "cool":
data = [
remoteCapabilities : state.capabilities.$PodUid.result.remoteCapabilities.modes.cool,
break
case "heat":
data = [
remoteCapabilities :state.capabilities.$PodUid.result.remoteCapabilities.modes.heat,
break
case "fan":
data = [
remoteCapabilities : state.capabilities.$PodUid.result.remoteCapabilities.modes.fan,
break
case "auto":
data = [
remoteCapabilities : state.capabilities.$PodUid.result.remoteCapabilities.modes.auto,
break
case "modes":
data = [
remoteCapabilities : state.capabilities.$PodUid.result.remoteCapabilities.modes,
break
displayTraceLog( "Returning remoteCapabilities from local")
return data
// Get Climate React settings
def getClimateReact(PodUid)
displayTraceLog( "getClimateReact() called - ${version()}")
def data = [:]
def pollParams = [
path: "/api/v2/pods/${PodUid}/smartmode",
query: [apiKey:"${getapikey()}", integration:"${version()}", type:"json", fields:"*"]]
try {
if (resp.data) {
debugEvent ("Response from Sensibo GET = ${resp.data}")
debugEvent ("Response Status = ${resp.status}")
displayTraceLog( "Get ClimateReact " + resp.data.result)
if (!resp.data.result) {
data = [
Climate : "notdefined",
Error : "Success"]
displayDebugLog( "Returning Climate React (not configured)")
return data
resp.data.result.any { stat ->
displayTraceLog( "get ClimateReact Success")
displayDebugLog( "PodUID : $PodUid : " + PodUid )
def OnOff = "off"
if (resp.data.result.enabled != null) {
OnOff = resp.data.result.enabled ? "on" : "off"
data = [
Climate : OnOff.toString(),
Error : "Success"
displayDebugLog( "Climate: ${data.Climate}")
displayTraceLog( "Returning Climate React" )
return data
else {
data = [
Error : "Failed"]
displayDebugLog( "get ClimateReact Failed")
return data
return data
catch(Exception e)
data = [
Error : "Failed"
return data
// Get the latest state from the Sensibo Pod
def getACState(PodUid)
displayTraceLog( "getACState() called - ${version()}")
def data = [:]
def pollParams = [
path: "/api/v2/pods/${PodUid}/acStates",
query: [apiKey:"${getapikey()}", integration:"${version()}", type:"json", limit:1, fields:"status,acState,device"]]
try {
if (resp.data) {
if (stat.status == "Success") {
displayTraceLog( "get ACState Success")
displayDebugLog( "PodUID : $PodUid : " + stat.acState)
def OnOff = stat.acState.on ? "on" : "off"
stat.acState.on = OnOff
def stemp
if (stat.acState.targetTemperature == null) {
stemp = stat.device.measurements.temperature.toInteger()
else {
stemp = stat.acState.targetTemperature.toInteger()
def tempUnit
if (stat.acState.temperatureUnit == null) {
tempUnit = stat.device.temperatureUnit
else {
tempUnit = stat.acState.temperatureUnit
def tMode
if (OnOff=="off") {
tMode = "off"
else {
tMode = stat.acState.mode
def sMode
if (stat.acState.swing == null) {
sMode = "stopped"
else {
sMode = stat.acState.swing
displayDebugLog( "product Model : " + stat.device.productModel)
def battery = stat.device.productModel == "skyv1" ? "battery" : "mains"
displayDebugLog( "swing Mode :" + stat.acState.swing)
data = [
targetTemperature : stemp,
fanLevel : stat.acState.fanLevel,
currentmode : stat.acState.mode,
on : OnOff.toString(),
switch: OnOff.toString(),
thermostatMode: tMode,
thermostatFanMode : stat.acState.fanLevel,
coolingSetpoint : stemp,
heatingSetpoint : stemp,
thermostatSetpoint : stemp,
temperatureUnit : tempUnit,
swing : sMode,
powerSource : battery,
productModel : stat.device.productModel,
firmwareVersion : stat.device.firmwareVersion,
Error : "Success"
displayDebugLog( "On: ${data.on} targetTemp: ${data.targetTemperature} fanLevel: ${data.fanLevel} Thermostat mode: ${data.mode} swing: ${data.swing}")
displayTraceLog( "Returning ACState")
return data
else { displayDebugLog( "get ACState Failed") }
else {
data = [
targetTemperature : "0",
fanLevel : "--",
currentmode : "--",
on : "--",
switch : "--",
thermostatMode: "--",
thermostatFanMode : "--",
coolingSetpoint : "0",
heatingSetpoint : "0",
thermostatSetpoint : "0",
temperatureUnit : "",
swing : "--",
powerSource : "",
productModel : "",
firmwareVersion : "",
Error : "Failed"
return data
return data
catch(Exception e)
data = [
fanLevel : "--",
currentmode : "--",
on : "--",
switch : "--",
swing : "--",
powerSource : "",
productModel : "",
Error : "Failed"
return data
def sendPutJson(String PodUid, String jsonBody)
displayTraceLog( "sendPutJson() called - Request sent to Sensibo API(smartmode) for PODUid : $PodUid - ${version()} - $jsonBody")
def cmdParams = [
headers: ["Content-Type": "application/json"],
query: [apiKey:"${getapikey()}", integration:"${version()}", type:"json"],
body: jsonBody]
try{
httpPut(cmdParams) { resp ->
displayDebugLog( "updated ${resp.data}")
debugEvent("updated ${resp.data}")
displayTraceLog( "Successful call to Sensibo API.")
displayDebugLog( "Returning True")
return true
else {
displayTraceLog( "Failed call to Sensibo API.")
return false
catch(Exception e)
displayDebugLog( "Exception Sending Json: " + e)
debugEvent ("Exception Sending JSON: " + e)
return false
def sendPostJsonClimate(String PodUid, String jsonBody)
displayTraceLog( "sendPostJsonClimate() called - Request sent to Sensibo API(smartmode) for PODUid : $PodUid - ${version()} - $jsonBody")
def cmdParams = [
body: jsonBody]
try{
httpPost(cmdParams) { resp ->
return true
else {
return false
catch(Exception e)
return false
// Send state to the Sensibo Pod
def sendJson(String PodUid, String jsonBody)
displayTraceLog( "sendJson() called - Request sent to Sensibo API(acStates) for PODUid : $PodUid - ${version()} - $jsonBody")
def cmdParams = [
query: [apiKey:"${getapikey()}", integration:"${version()}", type:"json", fields:"acState"],
body: jsonBody]
def returnStatus = false
try{
//returnStatus = resp.status
returnStatus = true
else {
catch(Exception e)
displayDebugLog( "Return Status: ${returnStatus}")
return returnStatus
def pollChildren(PodUid)
displayTraceLog( "pollChildren() called")
def thermostatIdsString = PodUid
displayTraceLog( "polling children: $thermostatIdsString")
def pollParams = [
path: "/api/v2/pods/${thermostatIdsString}/measurements",
query: [apiKey:"${getapikey()}", integration:"${version()}", type:"json", fields:"batteryVoltage,temperature,humidity,time"]]
debugEvent ("Before HTTPGET to Sensibo.")
try{
if (resp.data) {
displayTraceLog( "poll results returned" )
displayDebugLog( "DEBUG DATA RESULT" + resp.data.result)
if (resp.data.result == null || resp.data.result.empty)
displayDebugLog( "Cannot get measurement from the API, should ask Sensibo Support Team")
debugEvent ("Cannot get measurement from the API, should ask Sensibo Support Team",true)
def setTemp = getACState(thermostatIdsString)
def ClimateReact = getClimateReact(thermostatIdsString)
if (setTemp.Error != "Failed") {
state.sensibo = resp.data.result.inject([:]) { collector, stat ->
def dni = thermostatIdsString
displayDebugLog( "updating dni $dni")
def stemp = stat.temperature ? stat.temperature.toDouble().round(1) : 0
def shumidify = stat.humidity ? stat.humidity.toDouble().round() : 0
if (setTemp.temperatureUnit == "F") {
stemp = cToF(stemp).round(1)
def tMode
if (setTemp.on=="off") {
tMode = "off"
else {
tMode = setTemp.currentmode
def battpourcentage = 100
def battVoltage = stat.batteryVoltage
if (battVoltage == null)
battVoltage = 3000
if (battVoltage < 2850) battpourcentage = 10
if (battVoltage > 2850 && battVoltage < 2950) battpourcentage = 50
def data = [
temperature: stemp,
humidity: shumidify,
targetTemperature: setTemp.targetTemperature,
fanLevel: setTemp.fanLevel,
currentmode: setTemp.currentmode,
on: setTemp.on,
switch : setTemp.on,
thermostatFanMode: setTemp.fanLevel,
coolingSetpoint: setTemp.targetTemperature,
heatingSetpoint: setTemp.targetTemperature,
thermostatSetpoint: setTemp.targetTemperature,
temperatureUnit : setTemp.temperatureUnit,
voltage : battVoltage,
swing : setTemp.swing,
battery : battpourcentage,
powerSource : setTemp.powerSource,
productModel : setTemp.productModel,
firmwareVersion : setTemp.firmwareVersion,
Climate : ClimateReact.Climate,
Error: setTemp.Error
debugEvent ("Event Data = ${data}",false)
collector[dni] = [data:data]
return collector
displayDebugLog( "updated ${state.sensibo[thermostatIdsString].size()} stats: ${state.sensibo[thermostatIdsString]}")
debugEvent ("updated ${state.sensibo[thermostatIdsString]}",false)
else
log.error "polling children & got http status ${resp.status}"
catch(Exception e)
displayDebugLog( "___exception polling children: " + e)
debugEvent ("${e}")
def pollHandler() {
debugEvent ("in Poll() method.")
// Hit the Sensibo API for update on all the Pod
displayDebugLog( PodList)
PodList.each {
displayDebugLog( "polling " + it.deviceNetworkId)
pollChildren(it.deviceNetworkId) }
state.sensibo.each {stat ->
def dni = stat.key
displayDebugLog( ("DNI = ${dni}"))
debugEvent ("DNI = ${dni}")
if(d)
displayDebugLog( ("Found Child Device."))
debugEvent ("Found Child Device.")
debugEvent("Event Data before generate event call = ${stat}")
displayDebugLog( state.sensibo[dni])
d.generateEvent(state.sensibo[dni].data)
def debugEvent(message, displayEvent = false) {
def results = [
descriptionText: message,
displayed: displayEvent
displayDebugLog( "Generating AppDebug Event: ${results}")
sendEvent (results)
def cToF(temp) {
return (temp * 1.8 + 32).toDouble()
def fToC(temp) {
return ((temp - 32) / 1.8).toDouble()
Add to driver metadeta definition to get rid of some errors:
attribute "on","String"
I updated app and driver code but still get lots of debug logging
@Angus_M i think roberts driver and app rewrite were so in the device you can toggle the logging on and off.
No, I don't think so. You edit the app code directly to turn the logging on or off. I don't see anything in the device page to allow me to toggle the logging status.
I'm wondering if there is anything I have to do after updating the driver and app code. I tried re-running the app initialisation. I did a refresh in the device pages. I resaved the devices. Still I seem to get copious logging.
3+ pages like this every minute...
@robert1 code reduced message traffic substantially for me. My post was about an error code I was getting that I would have gotten when I used @blink code as well. Your image looks like it is not using @robert1 code. I would suggest uninstalling device and then run @robert1 app again.
The App code is where the majority of the logging noise comes from.
Th code, as provided, has the logging turned off.
There is code in the device handler too, but isn't the source of much noise. This is done through the UI (for each device) - the default will be off anyway, because the variables don't exist.
However, I just checked the code, and the 'parseEventData' function in the driver has the logging in your screen shot.
So, go in to each Sensibo device, under the Preferences section, turn off the debug and info toggles, and save the preferences. This should make a massive difference.
Then you're not running the right Driver.
Copy from post #38 above
I noticed when looking at the driver code again there are a lot of log.trace lines of code. However, it only generates 3 rows every 5 minutes or so. I might go fix this later, but it's not noisy enough for me to bother right now.
Ah it seems ok now. I don't think the devices refreshed properly after updating the driver. Now they seem fine, the preferences have appeared and the logging is much reduced! Cheers.
yeah, this is what i get too, but it's not so obtrusive...
