Success! Thanks @stephack. I now have one less dependency on ST. I actually wrote a new Hubitat Virtual Motion Driver (with Switch Capability) to make the Ring Motion events show up as a Hubitat Motion/Switch device. It automatically turns off the 'switch' and sets 'motion' to inactive after 3 seconds.
BTW - in my Alexa Routine, I was able to select which Alexa devices I wanted a spoken phrase played on. Doing so, I was able to have Alexa to say "There is someone at the front door" on just a single Echo device.
Here's the driver code in case anyone is interested. It is really pretty trivial.
 *  Virtual Motion with Switch
 *  Copyright 2018 Daniel Ogorchock
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 *  Change History:
 *    Date        Who            What
 *    2018-11-03  Dan Ogorchock  Original Creation
metadata {
	definition (name: "Virtual Motion with Switch", namespace: "ogiewon", author: "Daniel Ogorchock") {
		capability "Sensor"
		capability "Motion Sensor"
        capability "Switch"
def on() {
    sendEvent(name: "motion", value: "active")
    sendEvent(name: "switch", value: "on")
    runIn(3, off)
def off() {
    sendEvent(name: "motion", value: "inactive")
    sendEvent(name: "switch", value: "off")
def installed() {
