Any easy way to get several attributes on the same dashboard tile?
You'd think there'd be a way. There's plenty of room.
Thanks.
@velvetfoot Tile master in Hubitat Package Manager
You can also achieve this by layering tiles. The order you create the tiles can produce the layering naturally, but if you need to adjust it you will need to adjust the dashboard using CSS to force the ordering of the tiles. You will likely want to adjust the default tile sizing to reduce the default width and height to give you more control
I've done that, but I'd like to get several attributes on the tile, but they naturally like to hang out in the middle of the tile. I'll try some stuff later tonight.
You might want to check out Tile Master from BPTWorld.
I use it for displaying multiple atributes.
Nice and compact.
big fan of Tile Master 2!! I also use templates - a new for me way to customize attributes.
If you are looking for a potential test tool for multi values- try my Date/Time parser with 45 variables!!!
I haven't gotten to Tile Master yet, but I did mess around with @thebearmay 's Hub Information app and the html template for attributes. No idea what I'm doing, but got this:
