I renamed my Echo's in my Amazon account, but it does not reflect the changes in Hubitat, "
Speak this message"
Is there an update function?
Speak this message"
You can just go into the device property page and change the label, I believe. I don't think there's any mechanism for updating it automatically once the virtual devices are created.
Ahh, Ok.. In the Echo Speaks APP
The Tonesto App actually reflect the changes..
Odd, I just checked my devices and it shows the old names.. Echo Speaks Device
But when i goto the APP. It shows the correct names.
AThe app is getting a live pick list. But once the devices are created it no longer updates them.
Got it.. I see.. Thanks. That makes alot of sense..
That's not an issue.. The Tonesto App is sweet integration! I don't mind setting it up it again.
Or Maybe this is an opportunity for Tonesto to update the devices in real-time as well.
It's supposed to update the labels. It does in ST.
With that said i've made changes to try and get it working on Hubitat in v2.3.0
When is Hubitat v2.3.0 available ?
Just now
That worked... I uninstalled the app and did a fresh install. I then went into my rules and the renamed echos were there!
Great Job!
Just an FYI for the future you should never need to do a fresh install unless it's suggested ![]()
You are correct.. Will remember if there is a next time...
Excuse me... I should have said... I installed the update first with current settings and i did not see the re-named echos... So i did a fresh installed and it showed up immediately..
