Nope, did you see above that I said that C7 has this built in, and for C5 and older there is a community app. No need for other hardware, you just need the firmware file.
I also listed the other driver that I would try above. The Centralscene switch driver.
Oh, sorry if I missed that. I have the C5. How do I get this community App? Also, I'll try the driver you mentioned and get back to you. If the driver thing doesn't work I'll try the firmware update via the COmmunity App. BTW, I really don't know anything about downloading/working community apps. But... I'm learning!
Read this linked thread very thoroughly, a couple times if needed until you understand what to do. There are two versions of this app, so please read through understand which you need. It isn't hard to do this, but there are very particular steps to follow.
Far as installing apps/drivers, it is very easy, it is basically pointing the hub to a Github folder, and it imports the code for you. You then just save what it imports. https://docs.hubitat.com/index.php?title=Drivers_Code
So I tried the "Generic Z-Wave CentralScene Switch" under "Type" and then saved it. Basically, I get the same problems - incorrect status report, button hanging when commands are given, but commands still usually go through.
It looks like a firmware update is all I have left to try. Before I do this, I am wondering... some users suggested I get an additional hub to shoulder the burden of the many devices I have. Since I have a C5 and the newer C7 hub apparently has this firmware updating process built it, would it make more sense for me to just buy a new hub and try the firmware update that way? Or.... are we sure that one hub handling 50-60 devices is reasonable?
Oddly enough, I had search my order history on Amazon to find the Hubitat Elevation. That history indicates that the hub I ordered on May of 2020 Is the C-7... (and is not available, ugh!), but under Settings/Hub Details/Hardware Version it definitely says "Rev C-5"
I have seen where products were updated and the listing reused and it looks like you purchased a different product. If you go to your orders, and pull up the invoice it will show what you actually purchased.
But either way, if it says C5 in the details, there is no way it is a C7.
One hub should be able to have much more than that. I have over 50 Zwave devices alone, plus about that many Zigbee, and then the Lutron stuff and whatever else. I think I was getting close to 250 devices (including virtual ones) the last time I counted.
If you want the C7, then go for it. But the only difference between the C5 and C7 is the Zwave side of things, otherwise, the hardware and software are identical. You might be able to use a couple of the tools in the Zwave settings to do some diagnosis, but I am not sure that will solve this issue.
Try one more. Use the "Generic Zwave Switch" driver and see if that is any different.
Looks like that didn't work either, unfortunately.
I'm not sure if this helps, but I was able to (sort of) reproduce the problem with one of the Philips Light strips in the same room by repeatedly turning on/off the device. Eventually the hang occurred.... except that, the hang was temporary and the command ultimately went through. So I think I can say that the Philips devices don't seem to have this issue as often or as badly as the Leviton devices.
Could this be Wi-Fi issue? The iPad has to send a signal through Wi-Fi to the Hub, right? Except that it mostly is a problem with the Leviton devices so... I guess maybe it is a Leviton specific issue.
I'm not sure if this makes a difference, but in the App on my iPad, on the dashboard screen, there are two icons in the top right corner whose significance I don't understand. One looks like a square target reticle and tapping on that opens the same Dashboard on cloud.hubitat.com. The other one, oddly enough, looks like a cloud, and when I tap on it, the cloud is replaced with a home icon and a plus sign. Tapping on the plus sign allows me to add a dashboard while tapping on the home icon gives me back the cloud icon.
Does it matter whether I operate my dashboards through the local URL or the cloud.hubitat.com? I seem to be having the same problem either way....
Neon, I have one other it of information to add for troubleshooting this. When I go to the device details page in the Hubitat interface and select the exact same device, I notice that the commands do through more easily, but it's not showing the correct device status. For example, the lights were on when it read as follows:
So it seems that the send command hangs in dashboard only, while the command still goes through in Dashboard and Device details page, but the correct device status is not being shown either in Dashboard or in Device details page.
So.... that points to a firmware issue then? Since Generic Z-Wave Switch and Central Scene Generic Z-wave Switch did not work under "type:"
Lots of different causes for devices not responding in a timely manner. Mesh saturation, weak mesh, bad drivers, ghost devices. Maybe post a screenshot of your zwave details page and lets see what's going on.
Z-Wave Mesh Tool provides additional useful info as well:
I'm investigating options to upgrade from my master/slave setup with 2x HC2 (that's 2x Home Centre 2's for those of you not familiar with Fibaro) and I stumbled across this post.
I started my HA journey a decade ago, so have probably made every mistake in the book.
Some of you might find this post useful: [I've had to remove the link - pls PM me if you want it] So my first concern with Hubitat, why can't you post links on this forum?
Update: looks like access is restricted until after your first post. Here's the link:
In many ways, it is relevant to any zwave setup despite being title a guide for the HC2.
Following the steps in the guide made the difference between having a "broken" system to an almost rock solid setup.
I do have exactly 200 zwave devices (as of writing) across 2x HC2, so problems become exacerbated with so many devices, however it's possible to "break" your system with a medium sized number of modules not configured correctly and/or bad coding practices - although I can't comment on bad coding for the hubitat as I know almost nothing about it, however I expect there are many parallels across different HA controllers.
In short, if you are having issues that you just can't get to the bottom of, buy a zwave zniffer, the details (and links) around what to do are in the post above.
I know it's a hassle to buy a usb stick, flash it and install the software, but living with a zwave system that doesn't work is a bigger hassle in the long run.
BTW, I can only comment on zwave networks as that all I use for my HA setup.
