Alfred DB2-B inclusion - miserably fails
Yes, those are ghosts and they will prevent you from adding the lock and will be destructive to your mesh. They need to be removed. As @jtp10181 says hit refresh then remove (remove power to the lock first). If that doesn't work you will need a z-wave stick to remove them. Please have a look at this post. It will help avoid gotchas like this
