Aeotec Siren 6 is FINALLY here
Understood. I'm not in a huge hurry.
If you need the new 1.4 firmware, I know Kevin has it (he posted such on the ST forum).
Bizarre that they changed so much between firmware 1.2 and 1.4... But it is Aeotec, so not THAT surprising.. They do weird crap sometimes.
I think aeotec needs to hear from us users. Are they asleep at the wheel or what? They get Kevin to test and code for 1.2, then release 1.4, are you kidding me ?? If we ever did this at the health system where I manage pharmacy applications, we all be escorted out by security before lunch!
With firmware 1.2, you could specify the tone, volume, light effect, sound intercept, sound repeat delay, and repeat count and play that the sound using those settings by sending a single Configuration Set command. (I'll admit that it took several hours to figure out how to do the bit shifting to fit 7 pieces of information into a 4 byte value, but once I was able to figure that out, everything worked great and it was the most reliable siren I've ever worked with.)
With firmware 1.4, you have to specify the light effect, sound intercept, sound repeat delay, and repeat count by sending a Configuration Set command. Then you have to send a Sound Switch Configuration Set command to a specific endpoint to set the volume and then send Sound Switch Tone Play Set to a specific endpoint to play the sound using all those settings.
You have no idea how much I hate Aeotec right now...
I just posted a new version of my Aeotec Siren 6 handler so the device is now fully functional with SmartThings...
We don't care about SmartThings :wink: :smile: :smile: :wink:
You do if Kevin is going to work on a user driver for the Siren/Doorbell 6 after he gets done with ST.... :slight_smile:
Although I would guess that he will be stuck until the pairing issue w/HE gets resolved anyway.
It will all get working eventually, though. No fear.
You might not, but some users haven't completely transferred over yet so I'm sure they'd be interested to know that they can at least use it on that platform while waiting for Hubitat support.
Also, if Hubitat releases an update that fixes the inclusion issue, but doesn't have a built-in driver ready for it yet then the device will still be supported using a ported version of my ST handler...
Yeah, I know. I also have a SmartThings hub. So this is a solution for me. But still I have no interest in SmartThings since finding Hubitat :smile:
The driver ported and saved by just changing physicalgraph to hubitat. Now, it just saved correctly. I obviously don't have a device to test with but figured this would be a good starting point for someone to run with it.
 *  Aeotec Siren 6 v1.1.1
 *  (Model: ZW164-A)
 *  Author:
 *    Kevin LaFramboise (krlaframboise)
 *	URL to Documentation:  https://community.smartthings.com/t/release-aeotec-siren-6/164654?u=krlaframboise
 *  Changelog:
 *    1.1.1 (06/01/2019)
 *      - Fixed setting ranges for firmware 1.4.
 *      - Misc code cleanup
 *    1.1 (06/01/2019)
 *      - Rewrote a lot of the handler because of changes in the 1.4 firmware.
 *    1.0.1 (05/17/2019)
 *      - Initial Release
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
import groovy.transform.Field
@Field LinkedHashMap VOLUME = [mute:0]
@Field LinkedHashMap TONE = [longest:22, shortest:29, tamper:17]
@Field LinkedHashMap INTERVAL_BETWEEN = [notStopping:0]
@Field LinkedHashMap LIGHT_EFFECT = [off:1, on:2, flash:32, strobe:64]
@Field LinkedHashMap CONTINUOUS_PLAY_COUNT = [continuous:0]
@Field LinkedHashMap INTERCEPT_LENGTH = [actualToneLength:0]
@Field LinkedHashMap PLAY_ASSOC = [groupId:7, endpoint:6]
@Field LinkedHashMap TAMPER_ASSOC = [groupId:3, endpoint:2]
metadata {
	definition (
		name: "Aeotec Siren 6",
		namespace: "krlaframboise",
		author: "Kevin LaFramboise",
		ocfDeviceType: "x.com.st.d.siren",
		vid:"generic-siren"
		capability "Actuator"
		capability "Alarm"
		capability "Switch"
		capability "Audio Notification"
		capability "Music Player"
		capability "Speech Synthesis"
		capability "Switch Level"
		capability "Tamper Alert"
		capability "Tone"
		capability "Configuration"
		capability "Refresh"
		capability "Health Check"
		attribute "lastCheckIn", "string"
		attribute "primaryStatus", "string"
		attribute "secondaryStatus", "string"
		attribute "firmwareVersion", "string"
		// Music Player commands used by some apps
		command "playSoundAndTrack"
		command "playTrackAtVolume"
		command "playText"
		command "playSound"
		fingerprint mfr:"0371", prod:"0103", model:"00A4", deviceJoinName:"Aeotec Siren 6"
	simulator { }
	tiles(scale: 2) {
		multiAttributeTile(name:"primaryStatus", type: "generic", width: 6, height: 4){
			tileAttribute ("device.primaryStatus", key: "PRIMARY_CONTROL") {
				attributeState "off", label: 'OFF', action: "switch.on", icon: "st.alarm.alarm.alarm", backgroundColor: "#ffffff"
				attributeState "alarm", label: 'ALARM', action: "alarm.off", icon: "st.alarm.alarm.alarm", backgroundColor: "#e86d13"
				attributeState "chime", label: 'CHIME', action: "switch.off", icon: "st.alarm.beep.beep", backgroundColor: "#00a0dc"
				attributeState "on", label: 'ON', action: "switch.off", icon:"st.lights.philips.hue-single", backgroundColor:"#00a0dc"
			tileAttribute ("device.secondaryStatus", key: "SECONDARY_CONTROL") {
				attributeState "default", label:'${currentValue}'
		standardTile("sliderText", "generic", width: 2, height: 2) {
			state "default", label:'Play Sound #'
		controlTile("slider", "device.level", "slider",	height: 2, width: 4) {
			state "level", action:"switch level.setLevel"
		standardTile("off", "device.alarm", width: 2, height: 2) {
			state "default", label:'Off', action: "alarm.off"
		standardTile("on", "device.switch", width: 2, height: 2) {
			state "default", label:'On', action: "switch.on"
		standardTile("beep", "device.tone", width: 2, height: 2) {
			state "default", label:'Chime', action: "tone.beep"
		standardTile("siren", "device.alarm", width: 2, height: 2) {
			state "default", label:'Siren', action: "alarm.siren"
		standardTile("strobe", "device.alarm", width: 2, height: 2) {
			state "default", label:'Strobe', action: "alarm.strobe"
		standardTile("both", "device.alarm", width: 2, height: 2) {
			state "default", label:'Both', action: "alarm.both"
		standardTile("refresh", "device.refresh", width: 2, height: 2) {
			state "default", label:'Refresh', action: "refresh.refresh", icon:"st.secondary.refresh-icon"
		standardTile("configure", "device.configure", width: 2, height: 2) {
			state "default", label:'Sync', action: "configuration.configure", icon:"st.secondary.tools"
		valueTile("syncStatus", "device.syncStatus", decoration:"flat", width:2, height: 2) {
			state "syncStatus", label:'${currentValue}'
		valueTile("firmwareVersion", "device.firmwareVersion", decoration:"flat", width:3, height: 1) {
			state "firmwareVersion", label:'Firmware ${currentValue}'
		main "primaryStatus"
		details(["primaryStatus", "sliderText", "slider", "off", "on", "beep", "siren", "strobe", "both", "refresh", "syncStatus", "configure", "firmwareVersion"])
	preferences {
		getParamInput(manualSilenceParam)
		getOptionsInput("tamperVolume", "Tamper Volume", defaultTamperVolume, setDefaultOption(volumeOptions, defaultTamperVolume))
		getOptionsInput("switchOnAction", "Switch On Action", 0, setDefaultOption(switchOnActionOptions, "0"))
		getOptionsInput("sirenTone", "Siren Sound", defaultSirenTone, setDefaultOption(toneOptions, defaultSirenTone))
		getOptionsInput("sirenVolume", "Siren Volume", defaultSirenVolume, setDefaultOption(volumeOptions, defaultSirenVolume))
		getOptionsInput("strobeLightEffect", "Strobe Light Effect", defaultStrobeLightEffect, setDefaultOption(lightEffectOptions, defaultStrobeLightEffect))
		getOptionsInput("sirenRepeat", "Siren Repeat", defaultSirenRepeat, setDefaultOption(getRepeatOptions(true), defaultSirenRepeat))
		getOptionsInput("sirenRepeatDelay", "Siren Repeat Delay", defaultSirenRepeatDelay, setDefaultOption(repeatDelayOptions, defaultSirenRepeatDelay))
		getOptionsInput("sirenToneIntercept", "Siren Tone Intercept Length", defaultSirenToneIntercept, setDefaultOption(toneInterceptOptions, defaultSirenToneIntercept))
		getOptionsInput("chimeTone", "Default Chime Sound", defaultChimeTone, setDefaultOption(toneOptions, defaultChimeTone))
		getOptionsInput("chimeVolume", "Default Chime Volume", defaultChimeVolume, setDefaultOption(volumeOptions, defaultChimeVolume))
		getOptionsInput("chimeLightEffect", "Chime Light Effect", defaultChimeLightEffect, setDefaultOption(lightEffectOptions, defaultChimeLightEffect))
		getOptionsInput("chimeRepeat", "Chime Repeat", defaultChimeRepeat, setDefaultOption(getRepeatOptions(false), defaultChimeRepeat))
		getOptionsInput("chimeRepeatDelay", "Chime Repeat Delay", defaultChimeRepeatDelay, setDefaultOption(repeatDelayOptions, defaultChimeRepeatDelay))
		getOptionsInput("chimeToneIntercept", "Chime Tone Intercept Length", defaultChimeToneIntercept, setDefaultOption(toneInterceptOptions, defaultChimeToneIntercept))
		input "debugOutput", "bool",
			title: "Enable Debug Logging?",
			defaultValue: true,
			required: false
private getParamInput(param) {
	getOptionsInput("configParam${param.num}", param.name, param.value, param.options)
private getOptionsInput(name, title, defaultVal, options) {
	input "${name}", "enum",
		title: "${title}:",
		required: false,
		defaultValue: defaultValue,
		displayDuringSetup: true,
		options: options
private getTamperVolumeSetting() {
	return safeToInt(settings?.tamperVolume, defaultTamperVolume)
private getSirenVolumeSetting() {
	return safeToInt(settings?.sirenVolume, defaultSirenVolume)
private getSirenToneSetting() {
	return safeToInt(settings?.sirenTone, defaultSirenTone)
private getStrobeLightEffectSetting() {
	return safeToInt(settings?.strobeLightEffect, defaultStrobeLightEffect)
private getSirenRepeatSetting() {
	return safeToInt(settings?.sirenRepeat, defaultSirenRepeat)
private getSirenRepeatDelaySetting() {
	return safeToInt(settings?.sirenRepeatDelay, defaultSirenRepeatDelay)
private getSirenToneInterceptSetting() {
	return safeToInt(settings?.sirenToneIntercept, defaultSirenToneIntercept)
private getChimeVolumeSetting() {
	return safeToInt(settings?.chimeVolume, defaultChimeVolume)
private getChimeToneSetting() {
	return safeToInt(settings?.chimeTone, defaultChimeTone)
private getChimeLightEffectSetting() {
	return safeToInt(settings?.chimeLightEffect, defaultChimeLightEffect)
private getChimeRepeatSetting() {
	return safeToInt(settings?.chimeRepeat, defaultChimeRepeat)
private getChimeRepeatDelaySetting() {
	return safeToInt(settings?.chimeRepeatDelay, defaultChimeRepeatDelay)
private getChimeToneInterceptSetting() {
	return safeToInt(settings?.chimeToneIntercept, defaultChimeToneIntercept)
private getDefaultTamperVolume() { return 10 }
private getDefaultSirenTone() { return 10 }
private getDefaultSirenVolume() { return 50 }
private getDefaultStrobeLightEffect() { return LIGHT_EFFECT.strobe }
private getDefaultSirenRepeat() { return 0 }
private getDefaultSirenRepeatDelay() { return 0 }
private getDefaultSirenToneIntercept() { return 0 }
private getDefaultChimeTone() { return 1 }
private getDefaultChimeVolume() { return 10 }
private getDefaultChimeLightEffect() { return LIGHT_EFFECT.flash }
private getDefaultChimeRepeat() { return 1 }
private getDefaultChimeRepeatDelay() { return 0 }
private getDefaultChimeToneIntercept() { return 0 }
def installed() {
	state.syncAll = true
def updated() {
	if (!isDuplicateCommand(state.lastUpdated, 2000)) {
		state.lastUpdated = new Date().time
		runIn(2, updateSyncStatus)
		def cmds = getConfigureCmds()
		return cmds ? response(cmds) : []
def configure() {
	logDebug "configure()..."
	runIn(5, updateSyncStatus)
	if (!device.currentValue("switch")) {
		sendEvent(getEventMap("tamper", "clear"))
		sendEvent(getEventMap("alarm", "off"))
		sendEvent(getEventMap("switch", "off"))
		sendEvent(getEventMap("level", 0))
	if (!device.currentValue("checkInterval")) {
		initializeCheckin()
	return cmds ? delayBetween(cmds, 250) : []
private initializeCheckin() {
	def checkInterval = (6 * 60 * 60) + (5 * 60)
	sendEvent(name: "checkInterval", value: checkInterval, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
	startHealthPollSchedule()
def ping() {
	if (!isDuplicateCommand(state.lastCheckInTime, 60000)) {
		logDebug "ping()"
		// Restart the polling schedule in case that's the reason why it's gone too long without checking in.
		return [versionGetCmd()]
private startHealthPollSchedule() {
	unschedule(healthPoll)
	runEvery3Hours(healthPoll)
def healthPoll() {
	logDebug "healthPoll()"
	sendHubCommand([new hubitat.device.HubAction(versionGetCmd())])
private getConfigureCmds() {
	def cmds = []
	if (state.syncAll || !state.playAssocSet) {
		cmds << associationSetCmd(PLAY_ASSOC.groupId)
		cmds << associationGetCmd(PLAY_ASSOC.groupId)
	if (state.syncAll || !device.currentValue("firmwareVersion")) {
		cmds << versionGetCmd()
	if (state.syncAll || tamperVolumeSetting != state.tamperVolume) {
		cmds << soundSwitchConfigSetCmd(tamperVolumeSetting, TONE.tamper, TAMPER_ASSOC.endpoint)
		cmds << soundSwitchConfigGetCmd(TAMPER_ASSOC.endpoint)
	configParams.each {
		def storedVal = getParamStoredValue(it.num)
		if (state.syncAll || "${it.value}" != "${storedVal}") {
			logDebug "CHANGING ${it.name}(#${it.num}) from ${storedVal} to ${it.value}"
			cmds << configSetCmd(it, it.value)
			cmds << configGetCmd(it)
	state.syncAll = false
	return cmds
// Music Player Commands
def play() {
	return playSound(chimeToneSetting)
def pause() {
	return off()
def stop() {
	return off()
def mute() {
	logUnsupportedCommand("mute()")
def unmute() {
	logUnsupportedCommand("unmute()")
def nextTrack() {
	logUnsupportedCommand("nextTrack()")
def previousTrack() {
	logUnsupportedCommand("previousTrack()")
private logUnsupportedCommand(cmdName) {
	logTrace "This device does not support the ${cmdName} command."
// Audio Notification Capability Commands
def playSoundAndTrack(URI, duration=null, track, volume=null) {
	playTrack(URI, volume)
def playTrackAtVolume(URI, volume) {
def playTrackAndResume(URI, volume=null, otherVolume=null) {
	if (otherVolume) {
		// Fix for Speaker Notify w/ Sound not using command as documented.
		volume = otherVolume
def playTrackAndRestore(URI, volume=null, otherVolume=null) {
	if (otherVolume) {
def playTextAndResume(message, volume=null) {
	playText(message, volume)
def playTextAndRestore(message, volume=null) {
def speak(message) {
	// Using playTrack in case url is passed in.
	playTrack("$message", null)
def playTrack(URI, volume=null) {
	def text = getTextFromTTSUrl(URI)
	playText(!text ? URI : text, volume)
private getTextFromTTSUrl(URI) {
	if (URI?.toString()?.contains("/")) {
		def startIndex = URI.lastIndexOf("/") + 1
		return URI.substring(startIndex, URI.size())?.toLowerCase()?.replace(".mp3","")
	return null
def playText(message, volume=null) {
	playSound(message)
def setLevel(level, duration=null) {
	playSound(level)
def playSound(soundNumber, volume=null) {
	logDebug "playSound(${soundNumber}" + (volume ? ", ${volume}" : "") + ")"
	def cmds = []
	if (canPlaySound("playSound(${soundNumber})")) {
		def tone = validateTone(soundNumber)
		if (tone) {
			state.lastAction = "chime"
			def configVal = getGroupConfigVal(chimeLightEffectSetting, chimeToneInterceptSetting, chimeRepeatDelaySetting, chimeRepeatSetting)
			cmds << configSetCmd(siren1GroupParam, configVal)
			volume = (volume == null) ? chimeVolumeSetting : validateVolume(volume)
			cmds << soundSwitchConfigSetCmd(volume, tone, PLAY_ASSOC.endpoint)
			cmds << soundSwitchTonePlaySetCmd(tone, PLAY_ASSOC.endpoint)
		else {
			log.warn "Ignoring playSound(${soundNumber}) because soundNumber must be between 1 and 30."
private canPlaySound(cmd) {
	def alarm = device.currentValue("alarm")
	if (alarm == "off") {
		return true
	else {
		log.warn "Ignoring ${cmd} because alarm is ${alarm}"
		return false
private validateTone(val) {
	def tone = safeToInt(val)
	if (tone < 1 || tone > 30) tone = 0
	return tone
private validateVolume(volume) {
	def vol = safeToInt(volume, 50)
	if (vol > 100) vol = 100
	if (vol < 0) vol = 0
	return vol
def beep() {
def on() {
	logDebug "on()..."
	def cmds = []
	if (canPlaySound("on()")) {
		def switchAction
		switch (settings?.switchOnAction) {
			case "led":
				switchAction = "on"
				state.lastAction = "on"
				cmds = getSirenStrobeCmds(VOLUME.mute, LIGHT_EFFECT.on, TONE.longest, CONTINUOUS_PLAY_COUNT.continuous) // Using a tone that's over a minute long reduces the frequency of it flashing when the tone starts over.
				break
			case "chime":
				switchAction = "chime"
				cmds = playSound(chimeToneSetting)
				break
			case "siren":
				switchAction = "siren"
				cmds = siren()
				break
			case "strobe":
				cmds = strobe()
				break
			case "both":
				cmds = both()
				break
			default:
				def sound = safeToInt(settings?.switchOnAction, 0)
				if (sound) {
					cmds = playSound(sound)
				else {
					log.warn "Ignoring 'on' command because the Switch On Action setting is set to 'Do Nothing'"
		state.switchAction = switchAction
	return cmds
def siren() {
	logDebug "siren()..."
	state.lastAction = "siren"
	return getSirenStrobeCmds(sirenVolumeSetting, LIGHT_EFFECT.off)
def strobe() {
	logDebug "strobe()..."
	state.lastAction = "strobe"
	return getSirenStrobeCmds(VOLUME.mute, strobeLightEffectSetting)
def both() {
	logDebug "both()..."
	state.lastAction = "both"
	return getSirenStrobeCmds(sirenVolumeSetting, strobeLightEffectSetting)
private getSirenStrobeCmds(volume, lightEffect, tone=sirenToneSetting, continuousPlayCount=sirenRepeatSetting) {
	def configVal = getGroupConfigVal(lightEffect, sirenToneInterceptSetting, sirenRepeatDelaySetting, continuousPlayCount)
	return delayBetween([
		configSetCmd(siren1GroupParam, configVal),
		soundSwitchConfigSetCmd(volume, tone, PLAY_ASSOC.endpoint),
	], 200)
def off() {
	logDebug "off()..."
	return [ soundSwitchTonePlaySetCmd(0, PLAY_ASSOC.endpoint) ]
def refresh() {
	logDebug "refresh()..."
	updateSyncStatus()
	resetTamper()
	return [ basicGetCmd() ]
private versionGetCmd() {
	return secureCmd(zwave.versionV1.versionGet())
private associationSetCmd(group) {
	return secureCmd(zwave.associationV2.associationSet(groupingIdentifier:group, nodeId:[zwaveHubNodeId]))
private associationGetCmd(group) {
	return secureCmd(zwave.associationV2.associationGet(groupingIdentifier:group))
private basicGetCmd(endpoint=null) {
	return multiChannelCmdEncapCmd(zwave.basicV1.basicGet(), endpoint)
private basicSetCmd(value, endpoint=null) {
	return multiChannelCmdEncapCmd(zwave.basicV1.basicSet(value: value), endpoint)
private soundSwitchConfigGetCmd(endpoint) {
	return soundSwitchCmd("06", endpoint)
private soundSwitchConfigSetCmd(volume, tone, endpoint) {
	return soundSwitchCmd("05${convertToHex(volume)}${convertToHex(tone)}", endpoint)
private soundSwitchTonePlayGetCmd(endpoint) {
	return soundSwitchCmd("09", endpoint)
private soundSwitchTonePlaySetCmd(tone, endpoint) {
	return soundSwitchCmd("08${convertToHex(tone)}", endpoint)
private soundSwitchCmd(cmd, endpoint=null) {
	cmd = "79${cmd}"
	if (endpoint) {
		cmd = "600D00${convertToHex(endpoint)}${cmd}"
	return secureRawCmd(cmd)
private multiChannelCmdEncapCmd(cmd, endpoint) {
	if (endpoint) {
		return secureCmd(zwave.multiChannelV3.multiChannelCmdEncap(destinationEndPoint:endpoint).encapsulate(cmd))
	else {
		return secureCmd(cmd)
private configSetCmd(param, value) {
	if ("${value}".isInteger()) {
		return secureCmd(zwave.configurationV1.configurationSet(parameterNumber: param.num, size: param.size, scaledConfigurationValue: value))
	else {
		return secureCmd(zwave.configurationV1.configurationSet(parameterNumber: param.num, size: param.size, configurationValue: value))
private configGetCmd(param) {
	return secureCmd(zwave.configurationV2.configurationGet(parameterNumber: param.num))
private secureCmd(cmd) {
	if (isSecurityEnabled()) {
		return zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
	else {
		return cmd.format()
private secureRawCmd(cmd) {
		return "988100${cmd}"
	else {
		return cmd
private isSecurityEnabled() {
	return zwaveInfo?.zw?.contains("s") || ("0x98" in device.rawDescription?.split(" "))
private getCommandClassVersions() {
		0x20: 1,	// Basic
		0x59: 1,	// AssociationGrpInfo
		0x55: 1,	// Transport Service (V2)
		0x5A: 1,	// DeviceResetLocally
		0x5E: 2,	// ZwaveplusInfo
		0x60: 3,	// MultiChannel (v)
		0x6C: 1,	// Supervision
		0x70: 1,	// Configuration
		0x71: 3,	// Notification (v4)
		0x72: 2,	// ManufacturerSpecific
		0x73: 1,	// Powerlevel
		0x79: 1,	// Sound Switch
		0x7A: 2,	// Firmware Update Md
		0x85: 2,	// Association
		0x86: 1,	// Version (2)
		0x8E: 2,	// Multi Channel Association
		0x98: 1,	// Security 0
		0x9F: 1		// Security 2
// private getLightEffectConfigVal(brightenTime, dimTime, onTime, offTime) {
	// return [brightenTime, dimTime, onTime, offTime]
private getGroupConfigVal(lightEffect, intercept, intervalBetween, continuousPlayCount) {
	def configVal = [lightEffect, intercept, intervalBetween, continuousPlayCount]
	logTrace "getGroupConfigVal(lightEffect:${lightEffect}, intercept:${intercept}, intervalBetween:${intervalBetween}, continuousPlayCount:${continuousPlayCount}) = ${configVal}"
	return configVal
	def result = []
	try {
		if ("${description}".startsWith("Err 106")) {
			log.warn "secure inclusion failed"
		else if ("${description}".contains("command: 9881, payload: 00 79") || "${description}".contains("command: 79")) {
			logTrace "soundSwitchEvent(${description})"
		else {
			def cmd = zwave.parse(description, commandClassVersions)
			if (cmd) {
				result += zwaveEvent(cmd)
			else {
				log.warn "Unable to parse: $description"
		if (!isDuplicateCommand(state.lastCheckInTime, 59000)) {
			state.lastCheckInTime = new Date().time
			sendEvent(getEventMap("lastCheckIn", convertToLocalTimeString(new Date())))
	catch (e) {
		log.error "${e}"
	return result
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
	def encapsulatedCmd = cmd.encapsulatedCommand(commandClassVersions)
	def result = []
	if (encapsulatedCmd) {
		result += zwaveEvent(encapsulatedCmd)
	else {
		log.warn "Unable to extract encapsulated cmd from $cmd"
	return result
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
	def encapsulatedCommand = cmd.encapsulatedCommand([0x31: 3])
	if (encapsulatedCommand) {
		return zwaveEvent(encapsulatedCommand, cmd.sourceEndPoint)
	else if (cmd.commandClass == 121) {
		return soundSwitchEvent(cmd)
	else {
		logDebug "Unable to get encapsulated command: $cmd"
		return []
def zwaveEvent(hubitat.zwave.commands.notificationv3.NotificationReport cmd) {
	logTrace "NotificationReport: $cmd"
	switch(cmd.notificationType) {
		case 7:
			handleTamperEvent(cmd.event == 9 ? "detected" : "clear")
			break
		case 8:
			// Ignore button battery notifications
			break
		case 0x0E:
			// Ignore siren notifications
			break
		default:
			logTrace "Unknown Notification Type: ${cmd}"
	return []
private handleTamperEvent(value) {
	sendEventIfNew("tamper", value, true)
	sendEventIfNew("secondaryStatus", value == "detected" ? "TAMPERING" : "")
	if (value == "detected") {
		runIn(5, resetTamper)
def resetTamper() {
	sendEventIfNew("tamper", "clear", true)
	sendEventIfNew("secondaryStatus", "")
def zwaveEvent(hubitat.zwave.commands.associationv2.AssociationReport cmd) {
	logTrace "AssociationReport: ${cmd}"
	if (cmd.groupingIdentifier == PLAY_ASSOC.groupId && zwaveHubNodeId in cmd.nodeId) {
		updateSyncStatus("Syncing...")
		state.playAssocSet = true
	return []
def zwaveEvent(hubitat.zwave.commands.versionv1.VersionReport cmd) {
	logTrace "VersionReport: ${cmd}"
	def version = "${cmd.applicationVersion}.${cmd.applicationSubVersion}"
	logDebug "Firmware: ${version}"
	sendEventIfNew("firmwareVersion", version)
	return []
def zwaveEvent(hubitat.zwave.commands.configurationv1.ConfigurationReport cmd) {
	logTrace "ConfigurationReport: ${cmd}"
	def param = allConfigParams.find { it.num == cmd.parameterNumber }
	if (param) {
		def val = cmd.size == 1 ? cmd.configurationValue[0] : cmd.scaledConfigurationValue
		logDebug "${param.name}(#${param.num}) = ${val} ${cmd.size == 4 ? cmd.configurationValue : ''}"
		setParamStoredValue(param.num, val)
	else {
		logTrace "Unknown Parameter #${cmd.parameterNumber} = ${val}"
	return []
def updateSyncStatus(status=null) {
	if (status == null) {
		def changes = getPendingChanges()
		if (changes > 0) {
			status = "${changes} Pending Change" + ((changes > 1) ? "s" : "")
		else {
			status = "Synced"
	if ("${syncStatus}" != "${status}") {
		sendEvent(getEventMap("syncStatus", status))
private getSyncStatus() {
	return device.currentValue("syncStatus")
private getPendingChanges() {
	def pendingConfigParams = configParams.count { isConfigParamSynced(it) ? 0 : 1 }
	def pendingTamper = (tamperVolumeSetting != state.tamperVolume) ? 1 : 0
	def pendingPlayAssoc = !state.playAssocSet ? 1 : 0
	return (pendingConfigParams + pendingTamper + pendingPlayAssoc)
private isConfigParamSynced(param) {
	return ("${param.value}" == "${getParamStoredValue(param.num)}")
private getParamStoredValue(paramNum) {
	return state["configVal${paramNum}"]
private setParamStoredValue(paramNum, value) {
	state["configVal${paramNum}"] = value
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd) {
	logTrace "BasicReport: ${cmd}"
	handleBasicEvent(cmd.value)
	return []
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd, endpoint=null) {
	logTrace "BasicSet: ${cmd}"
	return []
private handleBasicEvent(rawVal) {
	def lastAction = state.lastAction
	def statusVal = "off"
	def switchVal = "off"
	def alarmVal = "off"
	if (rawVal) {
		switch (lastAction) {
			case "on":
				statusVal = "on"
				switchVal = "on"
				break
			case "chime":
				statusVal = "chime"
				if (state.switchAction == "chime") {
					switchVal = "on"
				break
			case { it in ["siren", "strobe", "both"] }:
				alarmVal = lastAction
				statusVal = "alarm"
				if (state.switchAction == "siren") {
					switchVal = "on"
				break
	else {
		state.lastAction = null
		state.switchAction = null
	sendEventIfNew("alarm", alarmVal, true)
	sendEventIfNew("switch", switchVal, true)
	sendEventIfNew("primaryStatus", statusVal, (lastAction == "chime"))
def soundSwitchEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
	logDebug "soundSwitchEvent: ${cmd}"
	switch (cmd.command) {
		case 7:
			handleSoundSwitchConfigurationReport(cmd)
			break
		case 10:
			// handleSoundSwitchTonePlayReport(cmd)
			break
		default:
			logDebug "Unknown Sound Switch Command: ${cmd}"
	return []
private handleSoundSwitchConfigurationReport(cmd) {
	if (cmd.parameter?.size() == 2) {
		def volume = cmd.parameter[0]
		def tone = cmd.parameter[1]
		if (cmd.sourceEndPoint == TAMPER_ASSOC.endpoint) {
			logDebug "Tamper - Volume:${volume}, Tone:${tone}"
			state.tamperVolume = volume
def zwaveEvent(hubitat.zwave.Command cmd, endpoint=null) {
	logTrace "Ignored zwaveEvent: ${cmd}" + (endpoint ? " (endpoint: ${endpoint})" : "")
	return []
private getConfigParams() {
	def params = [
		tamperGroupParam,
		manualSilenceParam
	params += lightEffectParams
	return params
private getAllConfigParams() {
	def params = [
		tamperGroupParam,
		// button1GroupParam,
		// button2GroupParam,
		// button3GroupParam,
		siren1GroupParam,
		// siren2GroupParam,
		// siren3GroupParam,
		// basicSetGroup2Param,
		// basicSetGroup3Param,
		// basicSetGroup4Param,
		// basicSetGroup5Param,
		// basicSetGroup6Param,
		// basicSetGroup7Param,
		// basicSetGroup8Param,
		// basicSetGroup9Param,
		// triggerUnpairingModeParam,
		// triggerPairingModeParam
		activePairingButtonParam,
		pairingResultsParam,
		// button1InfoParam,
		// button2InfoParam,
		// button3InfoParam,
		manualSilenceParam
	return params
private getLightEffectParams() {
	return [
		lightEffect1Param,
		lightEffect2Param,
		lightEffect3Param,
		lightEffect4Param,
		lightEffect5Param,
		lightEffect6Param,
		lightEffect7Param
private getTamperGroupParam() {
	return getParam(2, "Tamper Group", 4, 0x20030001)
// private getButton1GroupParam() {
	// return getParam(3, "Button 1 Group", 4, 0x02000001)
// private getButton2GroupParam() {
	// return getParam(4, "Button 2 Group", 4, 0x02000001)
// private getButton3GroupParam() {
	// return getParam(5, "Button 3 Group", 4, 0x02000001)
private getSiren1GroupParam() {
	return getParam(6, "Siren 1 Group", 4, 0x04000000)
// private getSiren2GroupParam() {
	// return getParam(7, "Siren 2 Group", 4, 0x04000000)
// private getSiren3GroupParam() {
	// return getParam(8, "Siren 3 Group", 4, 0x04000000)
private getLightEffect1Param() {
	return getParam(16, "Off", 4, 0x0000000A)
	// brighten: 0-127 (unit=20ms)
	// dim: 0-127 (unit=20ms)
	// on: 0-255 (unit=100ms)
	// off: 0-255 (unit=100ms)
private getLightEffect2Param() {
	return getParam(17, "On", 4, 0x00007F00)
private getLightEffect3Param() {
	return getParam(18, "Slow Pulse", 4, 0x7F7F1414)
private getLightEffect4Param() {
	return getParam(19, "Pulse", 4, 0x64640808)
private getLightEffect5Param() {
	return getParam(20, "Fast Pulse", 4, 0x64640000)
private getLightEffect6Param() {
	return getParam(21, "Flash", 4, 0x00000A0A)
private getLightEffect7Param() {
	return getParam(22, "Strobe", 4, 0x00000101)
// private getBasicSetGroup2Param() {
	// return getParam(32, "Send Basic Set to Group 2", 1, 3)
	// // 0: start-nothing, stop-nothing
	// // 1: start-0xFF, stop-nothing
	// // 2: start-0x00, stop-nothing
	// // 3: start-0xFF, stop-0x00
	// // 4: start-0x00, stop-0xFF
// private getBasicSetGroup3Param() {
	// return getParam(33, "Send Basic Set to Group 3", 1, 3)
// private getBasicSetGroup4Param() {
	// return getParam(34, "Send Basic Set to Group 4", 1, 3)
// private getBasicSetGroup5Param() {
	// return getParam(35, "Send Basic Set to Group 5", 1, 3)
// private getBasicSetGroup6Param() {
	// return getParam(36, "Send Basic Set to Group 5", 1, 3)
// private getBasicSetGroup7Param() {
	// return getParam(37, "Send Basic Set to Group 7", 1, 3)
// private getBasicSetGroup8Param() {
	// return getParam(38, "Send Basic Set to Group 8", 1, 3)
// private getBasicSetGroup9Param() {
	// return getParam(39, "Send Basic Set to Group 9", 1, 3)
// private getTriggerUnpairingModeParam() {
	// return getParam(48, "Trigger Unpairing Mode", 1)  // write only
// private getTriggerPairingModeParam() {
	// return getParam(49, "Trigger Pairing Mode", 1)  // write only
private getActivePairingButtonParam() {
	return getParam(50, "Active Pairing Button", 1)  // read only (automatically sent)
private getPairingResultsParam() {
	return getParam(51, "Pairing Results", 1)  // read only (automatically sent)
// private getButton1InfoParam() {
	// return getParam(52, "Button 1 Information", 4) (read only)
// private getButton2InfoParam() {
	// return getParam(53, "Button 2 Information", 4) (read only)
// private getButton3InfoParam() {
	// return getParam(54, "Button 3 Information", 4) (read only)
private getManualSilenceParam() {
	return getParam(96, "Silence Alarm with Action Button", 1, 0, [0:"Disabled", 1:"Enabled"])
private getParam(num, name, size, defaultVal=null, options=null) {
	def val = safeToInt((settings ? settings["configParam${num}"] : null), defaultVal)
	def map = [num: num, name: name, size: size, value: val]
	if (options) {
		map.valueName = options?.find { k, v -> "${k}" == "${val}" }?.value
		map.options = setDefaultOption(options, defaultVal)
	return map
private setDefaultOption(options, defaultVal) {
	return options?.collect { k, v ->
		if ("${k}" == "${defaultVal}") {
			v = "${v} [DEFAULT]"
		["$k": "$v"]
private getVolumeOptions() {
	def options = ["0":"Mute", "1":"1%"]
	(1..20).each {
		options["${it * 5}"] = "${it * 5}%"
	return options
private getToneOptions() {
	def options = [:]
	(1..30).each {
		options["${it}"] = "Tone #${it}"
	return options
private getLightEffectOptions() {
	def options = [1:lightEffectParams[0].name]
	def val = 1
	(1..6).each {
		val = (val * 2)
		options["${val}"] = lightEffectParams[it].name
	return options
private getRepeatOptions(includeUnlimited) {
	def options = [:]
	if (includeUnlimited) {
		options["0"] = "Unlimited"
	(1..15).each {
		options["${it}"] = "${it}"
	(4..50).each {
		options["${it * 5}"] = "${it * 5}"
	return options
private getRepeatDelayOptions() {
	def options = [
		0:"No Delay"
	options += durationOptions
	return options
private getToneInterceptOptions() {
	def options = [
		0:"Play Entire Tone"
	return options
private getDurationOptions() {
	def options = [
		1:"1 Second"
	(2..15).each {
		options["${it}"] = "${it} Seconds"
	(4..50).each {
		options["${it * 5}"] = "${it * 5} Seconds"
	return options
private getSwitchOnActionOptions() {
	def options = [
		"0":"Do Nothing",
		"chime": "Play Default Chime",
		"led": "Turn On LED",
		"siren": "Turn On Siren",
		"strobe": "Turn On Strobe",
		"both": "Turn On Siren/Strobe"
	(1..30).each {
		options["${it}"] = "Play Tone #${it}"
	return options
private sendEventIfNew(attr, newValue, displayed=false, unit=null) {
	if (device.currentValue("${attr}") != newValue) {
		sendEvent(getEventMap("${attr}", newValue, displayed, unit))
private getEventMap(name, value, displayed=false, unit=null) {
	def eventMap = [
		value: value,
		displayed: displayed,
		isStateChange: true,
		descriptionText: "${device.displayName} - ${value}"
	if (unit) {
		eventMap.unit = unit
		eventMap.descriptionText = "${eventMap.descriptionText} ${unit}"
	if (displayed) {
		logDebug "${name} is ${value}"
	return eventMap
private convertToHex(num) {
	return Integer.toHexString(num).padLeft(2, "0").toUpperCase()
private safeToInt(val, defaultVal=0) {
	return "${val}"?.isInteger() ? "${val}".toInteger() : defaultVal
private convertToLocalTimeString(dt) {
	def timeZoneId = location?.timeZone?.ID
	if (timeZoneId) {
		return dt.format("MM/dd/yyyy hh:mm:ss a", TimeZone.getTimeZone(timeZoneId))
	else {
		return "$dt"
private isDuplicateCommand(lastExecuted, allowedMil) {
	!lastExecuted ? false : (lastExecuted + allowedMil > new Date().time)
private logDebug(msg) {
	if (settings?.debugOutput != false) {
		log.debug "$msg"
private logTrace(msg) {
	// log.trace "$msg"
Even if you had the device you wouldn't be able to test it because Hubitat's inclusion doesn't work with this device yet...
I also just posted the handler for the Aeotec Doorbell 6, but I doubt that one will be as simple to port...
It was actually. For the Doorbell just the physicalgraph to hubitat and for the button, just changing the capability from Button to Pushable Button worked. Both saved.
Just because it saves, doesn't mean it works...
The "response" wrapper isn't needed in the updated method so the settings won't save, the button implementation in Hubitat is different (not just the capability name), I don't believe the multichannel encapsulation will work the same way as ST for the unsupported capability sound switch, I believe the hub action implementation is slightly different so I don't believe the child commands with get executed, etc...
Right back at ya.
Kevin, as usual a great job. Just connected the siren6 (with frimware 1.4), and it works perfect on ST.
Kudos, your drivers are always very well done, so much so, your list of devices you've coded drivers for are a first stop for me when buying new devices.
Thank You
Does anyone know how to tell when the siren is powered by the 5 volt input, vs. being on the internal battery?
I rigged up a 5 volt transformer and gutted my old doorbell box and used it's existing wire, instead of the supplied ugly power in wire to the siren.
So now my siren 6 is hidden inside my old doorbell box and don't want to find out via dead battery, that my rigged up power supply jack isn't making contact somewhere. I used a spare plug from my supply box, and it was a 99% match. I didn't want to hack up the OEM supply jack, in case I return the item.
The device doesn't report that so there's no way to do it from the handler...
Would be good to feed back to Aeotec for a future firmware release I guess. Knowing the power source would be very useful.
Okay, so it's the "dead battery test".
Thank you for replying Kevin, much appreciated.
After spending half my weekend rewriting these handlers because of all the changes they made in the 1.4 firmware, I'm praying they don't screw with the firmware again...
Just got mine today and tried to set it up but hit the inclusion problem. Checked my hub for updates and I saw that an update was released just hours ago that supports this siren. Applied and it included and works great. Yay!
