I just installed a half dozen of these, so I'm trying to get some traction. The latest device firmware release back in March of 2023 added a few additional parameter configurations. The one I'm most interested in is the LED behavior update.
I'd be glad to assist with the update, but would prefer to start with the existing drive code rather than from scratch.
Yeah... I think I meant to make a special version for this device but never did. We might need one for a new Leviton 800 Dimmer as well. Seems Z-Wave is getting some more traction back in the market. This may be a good test case for an idea I have been cooking up in my head for a more universal driver (which could support all the settings for any device).
Looking into adding this now. Can you (or anyone with this device) scroll down to the "Device Details" table at the bottom of the device detail page and see what is listed for firmwareVersion in the Data row? (Hopefully it's there...)
Not really sure I'll need this for the LED parameter (#83) updates, but I see they also added parameter 120. If anyone is interested in that one, it would be nice to filter that one to the appropriate version. That being said, the document is not really clear on what it does, and the Basic Z-Wave Tool shouldn't have any problem with this parameter (the driver won't overwrite it if you switch back). And I'm not sure anyone has asked for this particular one, so...
Thanks! That does look like the right information. Parameter 83 was added to the switch and dimmer drivers one the 2.3.9 hotfixes about a month ago, and I think I got the right firmware version for those, but it will be displayed on any version with a note that it should only be used on the firmware versions equal to or newer than the ones listed (been a while, but I think I found that in their docs/changelog? but if that's wrong, I can modify the note...but you should be able to use it if your firmware supports it, regardless).
