'Aeon HEM V1 Laundry Driver' is NOW working on Hubitat
I have two rules that do the job. Probably a better way to accomplish this (would be glad to learn), but this is what I could wrap my head around.
I finally realized I was focusing on when the washer itself indicated it had turned off, but really it was better to have a second rule that is triggered when a virtual switch is no longer kept alive by the pauses in the machine. When the pauses cease for a period of time, the notification is sent (for me at the moment, notifications are done by triggering a second virtual switch, which then triggers ST to alert me).
I went with a five minute pause. My washer will often spend a long time starting and stopping to try and redistribute an unbalanced load before it will go into a high speed spin. I may need to increase it, but if it's long enough and the wash sits for a few minutes before I'm notified, that is quite alright by me.
57%20PM
I have updated the driver code to try to use the custom attributes instead of the state variables to try and avoid the duplicate button pushed events. So far, so good in my limited testing this evening.
Would it be possible to add a third button push to allow cancellation? Basically I’ve been turning on a virtual switch with a button push, and that then turns on a second virtual switch to send notifications, but delaying the second switch still sends the notification after delay, even if the current load rises above the threshold, because the button has already been pushed.
So if there were a button 3 push when the washer current rises above the threshold, that would turn the first virtual switch off again before a timeout has occurred, thus cancelling the action that turns on my second switch to send notification.
First - Sorry for the slow response. I was traveling for work all last week, and I am still trying to catch back up on everything.
Second, you've completely lost me... :slight_smile: Ever since I made my most recent changes, I do not believe we've had any more double/triple notifications. I did just upgrade my hub from 707 to 710 this evening, so only time will tell for sure.
You should be able to keep all of the logic within the custom Driver code, and hopefully not need to add extra virtual devices and logic elsewhere. What problem are you trying to resolve?
No problem at all on the response time of course. I’ve been on a project the last week myself too. The issue I’m still having is my washer never drops below 7 watts, even when it’s “off” and the run wattage is sometimes as low as 10 watts toward the end of the cycle where it’s going into a rinse.
I’ve played with the threshold and can’t seem to find a happy medium. So I’ll get several notifications toward the end of the cycle. However, based on what you’ve said, I should strip out that added logic and try again.
Unfortunately, the operating wattage range of my washer is so low, it results in frequent fluctuations between ON and OFF during a cycle and the changes you made could not compensate for this. I was able to finally resolve the issue by modifying the code to add a button 3 push when the washer is ON. I'm using this to cancel a rule actions if the washer has not stopped for 2 minutes, thus preventing false notifications.
I had to create two virtual switches, two RM triggers and one RM rule to accomplish what I needed. Maybe there's an easier way, but I couldn't figure it out.
How it works:
When the washer starts, the Aeon HEM pushes button 3. This turns on the virtual switches "Washer is running" and "Washer is done". When the washer pauses during the cycle and creates an OFF status, the rule "Send Washer Notification" becomes [TRUE] and begins a two minute countdown before it turns OFF the "Washer is done" virtual switch. If, before the two minute countdown has completed, the washer cycles ON, and therefore pushes button 3 again, then the rule becomes [FALSE] and the "Washer is done" virtual switch is turned ON, thus cancelling the countdown to OFF.
When the washer finally no longer cycles ON in a two minute period, then the virtual switch "Washer is done" turns OFF. This triggers an IFTTT notification that "The Washer has Finished".
Here's the modified code, and my RM triggers/rule if anyone finds it helpful.
21%20AM
10%20AM
[Edit] I've done a second adaptation to @ogiewon 's original port of @mike.maxwell 's Aeon HEM V1 Laundry DTH, this time adding a button 4 push to indicate the dryer is running. This can now be used in conjunction with RM and Google Assistant Relay to check the status (running or finished) of a washer and dryer.
Using IFTTT integration, you can ask Google Assistant or a Google Home for the status of your laundry and get a spoken response based on what is currently running or if nothing is running.
Please note: I have modified the original port of the code, because Dan's second revision to the code did not work for my washer and actually caused a greater number of false alarms. Your experience may be completely different. I have a very difficult washer to determine the running, versus off amperage.
Glad you found a workaround. I guess I am lucky that my washer and dryer are 'well behaved' when it comes to power usage.
One thought... I wonder if you could have implemented all of the logic within the Driver code itself? Instead of immediately sending the button pushed event for washer is done, you could schedule an function to run in two minutes. If another off to on transition occurs, you could unschedule the timer. Essentially, implement the delay with cancel inside the driver. It would definitely be cleaner. A user preference could be added for 'How long OFF before sending event'. Thoughts?
That’s a great idea, but not one I have the skill to accomplish. I was happy just to have figured out how to modify the existing code enough to accomplish a third button that does what I expected! :grimacing:
@ogiewon I have the same problem that @SmartHomePrimer has and would love to see your idea come to life? It's beyond my skill level also.
I'll take a look at adding some more intelligence to the driver to help reduce false/duplicate notifications. Hopefully I'll find some time this weekend.
@oglewon I know that you very busy. Did you ever look at changing this to add more intelligence to the driver? Thanks for all your hard work.
Hopefully, with the long Holiday Weekend, I will find some time to get back to looking at this.
Sorry for the delay, but life always seems to get in the way! :wink:
Since I put those three rules into effect, the false “done” indications on the washer are gone
I am interested in doing this as well. Do you guys know if the newer version of the energy meter will work, or do I need to get a V1?
Looks like there is a newer Aeotec Home Energy Meter Gen5 available on amazon. I believe the V1 is Zwave, not Zwave plus correct?
Could be. Mine is v1 and I don’t find the Z-Wave Plus logo on it or anywhere, in the box or instructions. If you’re concerned about compatibility, I only bought mine a few months ago on eBay. Probably still available.
The device driver posted in this thread is specifically for a 1st gen Aeotec HEM, as far as I know.
@SmartHomePrimer could you share what you did cause I'm still getting false reading? Thanks
This post. You need the code I modified to give a button 3
You'll need to play with the running wattage of your washer to fine tune. I just raised it a watt at a time (for my washer anyway) until I hit the right value. Took some weeks to find it.
@leeonestop I have updated the driver to add a required parameter which allows you to determine how many seconds the washer/dryer must be below the wattage threshold before the button pushed events are triggered.
Please note that the Aeon HEM v1 transmits data every 30 seconds. I would recommend that you use a 'Debounce Time" of at least 45 seconds so that it takes at least two updates in a row, below the wattage threshold, before any messages will be sent. You can make this much larger if desired. If the wattage jumps back up above the threshold during this time period, the delay is reset.
Please give this version a try and let me know if it resolves the false positives/multiples events you've been seeing.
https://raw.githubusercontent.com/ogiewon/Hubitat/master/Drivers/aeon-hem-v1-laundry.src/aeon-hem-v1-laundry.groovy
@oglewon thanks for the code. I will do laundry tomorrow and will try the code. Thanks for all you have done for us in the Smart Things and now the Hubitat community. Thanks so much.
