Also, @mike.maxwell, I can reliably reproduce a series of 100->200->100 battery reporting flurries by clicking Configure on the device page. Happy to pull any info or more detailed logging that would be helpful.
what does the device report steady state for battery?, meaning when you don't hit configure?
I'm going to be pissed if the firmware breaks battery reporting, as the changes I made to correct it were given to my by Third Reality in the first place...
I also have a ThirdReality Smart Button connected to Hubitat; no firmware update available on it and it's reporting 88% which sounds about right for that specific one.
My contact sensor and motion sensor are both showing 200% now.
Prior to the firmware update, the motion sensor was reporting 76%, contact sensor was 69%
@mike.maxwell I have another TR Motion Sensor fresh out of the box with an older firmware version (not showing in the data, SmartThings CLI couldn't get it either) that is reporting 88% currently. I won't update that one.
If you'd like, I can test out any driver updates your team comes up with (willing to join the beta group if required) and do some A/B testing with a device on older and latest firmware.
Zigbee updates are handled by the hub after the given file has been published by Hubitat.
Its not possible for a user to use a local file for this.
What is the device and where did you get the update from?
