I have an app that should be executing (the trigger appears in the log), but it's not running (although the trigger appears in the log, I don't see the app actually firing).
Namely, in this case, it's an RM4.0 app that is triggered when my Ring devices switch arming states.
The (user) Ring part is working, as I see those devices changing state and I see the app's trigger.
However, none of the actions in the RM4.0 app are happening--nothing is in the logs.
I rebooted the hub. My "Arm Home" stuff seemed to work and things ran (and the HSM re-set itself properly). But, the routine simply isn't running properly on a "disarm".
This had been working fine. I rebooted, etc. No luck.
The triggering event is noted in the log--but the RM app isn't actually being invoked.
I had a couple of 4.0 apps not fire today but it was around the time I uploaded the last hotfix.
As they were small rules I just re-did them in 4.1.
Should have investigated further I suppose.
Just spotted this.
I've already re-written them (2 hrs I won't get back ) in 4.1 so they no longer exist in 4.0.
All were timed rules.
Curtains closing.
Un-pausing various rules at specific times/conditions.
RM 4.0 mode manager rule not changing modes.
Before the last hotfix the rules were painfully slow to edit but worked. Latest update and some rules did not trigger.
I had rebooted the hub after the first rule failed to make sure all was OK. Looks like that didn't work.
I am having a very similar problem. I have a couple rules that have been working for > 1 year, no change to the rules.
I have global variables that get changed in one rule and these globals are then used as a trigger to another rule. What I noticed is that a change in the global variable no longer causes the other rule to trigger.
As a work around I added one of these to the bottom of the 1st rule and now the 2nd rule is triggering.
Run Actions: Bathroom Kids - Master Controller
I pretty convince there was a regression in one of the recent updates, I'm currently running: 2.2.6.134
