EDIT: For those asking how I get the images for my cameras, they are Hikvision cameras and they have URL's which render an immediate jpg image. I use the Image tile and set the background image to each URL. I don't go directly to the cameras, instead I proxy those through a PHP script which is on the internet and is authenticated by a get request and tells the script which camera to pull an image from. Here is the script: Hikvision Camera Snapshot Auth Proxy Β· GitHub
is it correct that it shows just a clear or blank box for the color prior to setting it to something else? shouldn't it show the existing setting which is mustard?
So far, so good. I like the new look. Mostly just been playing with dashboard. Was playing with labels and had IOS lock up, but it was self inflicted and came back right away.
Do you have a dashboard tile of type attribute and what youβre trying to display in that tile is greater than 1024. Reduce the number of characters to 1024 or less to solve your problem(s).
Do you have any custom drivers installed? This is dashboard warning you that something is sending a larger than 1024 characters attribute to dashboard. This can lead to other problems so it warns you.
I do have custom drivers installed but none of the tiles points to a custom driver, they are all switches, dimmers, bulbs, or fans, all from built-in DTHs.
