dJOS
April 6, 2025, 11:14pm
1
@bcopeland I’ve found that my Fibaro Smart Implant‘s don’t fully work via ZWJS.
The main issue I found is the digital outputs / relays not working. The digital inputs did work. I also saw reports of the internal temp sensor not working, but I didn’t test that.
PS I couldn’t get either the community driver or HE driver to work.
As an additional data point, I have a C8 running JWJS with a Fibaro. They internal temperature works as does an external temperature sensor. However, I don't have any digital devices to contribute to that data.
dJOS
April 7, 2025, 10:38am
3
I was able to sense my garage door open / close state, I just couldn’t trigger the digital out relays.
I don’t use the temp sensor for anything, so it never occurred to me to check it.
dJOS
April 22, 2025, 1:16am
4
@bcopeland has this issue been looked at?
dJOS
May 13, 2025, 11:47pm
5
@bcopeland can you please let us know if this Fibaro issue been fixed in .170?
Release 2.4.1.170 Available
Changes from 2.4.1.167
Platform Changes
EZ dashboards: added one click/tap push for button controller tiles.
New Devices
Apple WeatherKit (paid Apple Developer account required)
dJOS
June 23, 2025, 11:00pm
6
@bobbyD has this been fixed in 2.4.2?
Release 2.4.2.119 Available
Changes from 2.4.1.177
New Devices
frient Zigbee Keypad (KEPZB-110).
Generic Matter lock.
Sensurance Water Leak Sensor.
Platform Changes
Added HomeKit controller app to connect HomeKit compatible accessories directly to the Hubitat hubs - requires C8 pro hub.
Added network device discovery and suggested integrations section to the home page.
Implemented automatic switch to ZWaveJS stack when onboarding a new C8 Pro hub (if ZWaveJS installation is successful).
A…
dJOS
September 26, 2025, 12:29am
7
@gopher.ny unfortunately 2.4.3.x has not fixed this issue, as I can’t open my garage door after switching to it.
It’s infuriating, because ZWJS is so much more responsive than the legacy stack.
Release 2.4.3.122 Available
Changes from 2.4.2.160
Platform Changes
Added Shelly device integration app, with support of:
v1 switches, relays, lights, natural gas and leak sensors.
v2+ switches, relays, dimmers, lights, power meters, temperature, and humidity sensors.
Completely re-wrote ZWave-JS value parsing to fix missing reports from some devices.
Added the ability to navigate between dashboards for EZ cloud dashboards.
Added ability to publish user apps, drivers, and libraries to all …
