@agnes.zooz and all. I purchased 3 ZSE44s. 2 of them gave me fits when paired to my C-7 (temperature and humidity readings were just not even close to accurate - like 20-30 degrees off on temperature and same on humidity and they were not reporting to the hub correctly). I paired them to my C-5 instead and 1 is working completely normally, the other was a crazy chatterbox for a few days but seems to have calmed down now after having burned the battery down to 60%.
The 3rd one is my big problem - it was briefly paired with my C-7, but I was having the same problems with inaccurate measurements, so I Excluded it and attempted to pair to my C-5 like I had done for the other 2, but it appears to have somehow bricked itself. It excluded fine, but now it won't include on either hub no matter what I try (I've tried re-excluding a zillion times, battery pulls, hard resets, battery replacements, resetting hubs, using a Z-Stick to pair it etc.). Still can't get it to pair again.
The odd thing is that when you triple tap the button, the LED flashes as you would normally think for pairing, but it literally never stops flashing - no time outs, which I thought was odd when comparing to other Zooz products that typically give up after 30/60/90 seconds.
Also, and this may or may not be key, but the Factory Reset procedure in the booklet seems to not be correct. If I do the triple tap and hold on the third, the led will flash quickly as stated, then I double tap at the end of 10 seconds as instructed, but the LED only flashes twice, not 3 times as the manual states. Also, at this point, unless you do a battery pull, pushing the button any number of times does nothing, so it seems that pulling the battery needs to be added as the last step of the reset procedure (then again, if my unit is just defective and behaving oddly, that's a whole other issue.).
Long story short, Seeing lots of odd behavior out of these sensors. Thankfully the 2 that are paired to my C-5 seem to be working ok (though battery drain seems awfully high), but really would appreciate some assistance with the 3rd one that is just a very light-weight paperweight at the moment.
Editing to say that I was incorrect about the 1 sensor - it is still reporting like crazy. Not sure what the right solution is - and guidance would be appreciated. It is set to report Temp and humidity both hourly. 2F threshold for Temp and 1% for humidity and I have 535 log entries and counting in the last 1hr 36min.
