I have many Zooz 77 dimmers. I like to have them set up so that a single tap turns to full brightness, and a double tap turns to a pre-set brightness. I've done this by adjusting parameters 12, 18, 25 with the Advanced Driver (v1.5):
The issue I'm having is that when I double tap, the light first goes to full brightness, then dims to the set level, instead of turning on directly to the set dimmed level. This is really annoying at night, since I use the double tap to go into rooms where I don't want to turn the light to full brightness.
When I change over to the built in Zen77 driver, it behaves as it should (single tap to full brightness, double tap to pre-set dimming level). Contrasted with the Advanced driver behaviour on double tap that first turns it to full brightness, then dims to the pre-set dimming level.
Is there something I should change, or is this a driver issue?
