I assume this would apply to any Zooz switch, but for the Zen74 specifically, I want to use Double Tap to turn on another Zen74 switch without turning on the switch I'm double tapping. I'm using the Zooz Advanced Switch drivers to assign buttons 3/4 to double tap actions.
Currently when I set up a button rule for double tap UP (button 3), the light connected to the switch turns on (if off) before turning on the separate switch I actually want to control. Oddly enough, double tap DOWN (button 4) only turns off the separate switch and not the light connected to the switch.
Ideally if I double tap, I don't want the switch I'm performing this action on to change its own state. Is this possible?
