Turned on logging, waited to logs to clear. Did not create the child instances...
dev:12020-05-15 08:46:40.068 am infoBookcase Lamps power is 0W
dev:12020-05-15 08:46:18.665 am warndescription logging is: true
dev:12020-05-15 08:46:18.664 am warndebug logging is: true
dev:12020-05-15 08:46:18.663 am infoupdated...
dev:12020-05-15 08:46:10.079 am infoBookcase Lamps power is 0W
dev:12020-05-15 08:46:07.322 am warndescription logging is: true
dev:12020-05-15 08:46:07.321 am warndebug logging is: true
dev:12020-05-15 08:46:07.320 am infoupdated...
dev:12020-05-15 08:45:40.066 am infoBookcase Lamps power is 0W
dev:12020-05-15 08:45:10.759 am infoBookcase Lamps energyDuration is 6.76 Days
dev:12020-05-15 08:45:10.751 am infoBookcase Lamps energy is 3.87kWh
dev:12020-05-15 08:45:10.664 am infoBookcase Lamps power is 0W
dev:12020-05-15 08:45:10.356 am infoBookcase Lamps current is 0A
dev:12020-05-15 08:45:09.901 am infoBookcase Lamps voltage is 0V
dev:12020-05-15 08:44:40.052 am infoBookcase Lamps power is 0W
dev:12020-05-15 08:44:30.553 am infoBookcase Lamps power is 0W
dev:12020-05-15 08:44:30.251 am infoBookcase Lamps current is 0A
dev:12020-05-15 08:44:29.747 am infoBookcase Lamps voltage is 0V
dev:12020-05-15 08:44:29.640 am debugSwitchBinaryReport(value:0, targetValue:0, duration:0) (right)
dev:12020-05-15 08:44:29.617 am debugSwitchBinaryReport(value:0, targetValue:0, duration:0) (left)
dev:12020-05-15 08:44:29.537 am debugSwitchBinaryReport(value:0, targetValue:0, duration:0) (left)
dev:12020-05-15 08:44:29.435 am debugSwitchBinaryReport(value:0) ()
dev:12020-05-15 08:44:29.341 am debugoff()...
dev:12020-05-15 08:44:10.054 am infoBookcase Lamps power is 0W
dev:12020-05-15 08:43:52.455 am warndescription logging is: true
dev:12020-05-15 08:43:52.454 am warndebug logging is: true
dev:12020-05-15 08:43:52.453 am infoupdated...
dev:12020-05-15 08:43:51.000 am debugEnergy Reporting(#18) = 4
dev:12020-05-15 08:43:50.478 am debugRight Outlet Auto Turn-On After(#15) = 60
dev:12020-05-15 08:43:49.980 am debugRight Outlet Auto Turn-On Timer Enabled(#14) = 0
dev:12020-05-15 08:43:49.445 am debugLeft Outlet Auto Turn-On After(#11) = 60
dev:12020-05-15 08:43:48.929 am debugLeft Outlet Auto Turn-On Timer Enabled(#10) = 0
dev:12020-05-15 08:43:48.420 am debugRight Outlet Auto Turn-Off After(#13) = 60
dev:12020-05-15 08:43:47.904 am debugRight Outlet Auto Turn-Off Timer Enabled(#12) = 0
dev:12020-05-15 08:43:47.389 am debugLeft Outlet Auto Turn-Off After(#9) = 60
dev:12020-05-15 08:43:46.881 am debugLeft Outlet Auto Turn-Off Timer Enabled(#8) = 0
dev:12020-05-15 08:43:46.368 am debugElectrical Current Reporting Frequency(#6) = 300
dev:12020-05-15 08:43:45.860 am debugVoltage Reporting Frequency(#5) = 300
dev:12020-05-15 08:43:45.324 am debugEnergy Reporting Frequency(#4) = 300
dev:12020-05-15 08:43:44.831 am debugPower Reporting Frequency(#3) = 30
dev:12020-05-15 08:43:44.323 am debugPower Reporting Threshold(#2) = 0
dev:12020-05-15 08:43:43.822 am debugLED Indicator Mode(#17) = 1
dev:12020-05-15 08:43:43.275 am debugManual Control(#16) = 1
dev:12020-05-15 08:43:42.758 am debugOverload Protection(#7) = 10
dev:12020-05-15 08:43:42.341 am debugOn/Off Status Recovery After Power Failure(#1) = 0
dev:12020-05-15 08:43:41.568 am debugCHANGING Energy Reporting(#18) from 4 to 4
dev:12020-05-15 08:43:41.564 am debugCHANGING Right Outlet Auto Turn-On After(#15) from 60 to 60
dev:12020-05-15 08:43:41.552 am debugCHANGING Right Outlet Auto Turn-On Timer Enabled(#14) from 0 to 0
dev:12020-05-15 08:43:41.546 am debugCHANGING Left Outlet Auto Turn-On After(#11) from 60 to 60
dev:12020-05-15 08:43:41.542 am debugCHANGING Left Outlet Auto Turn-On Timer Enabled(#10) from 0 to 0
dev:12020-05-15 08:43:41.537 am debugCHANGING Right Outlet Auto Turn-Off After(#13) from 60 to 60
dev:12020-05-15 08:43:41.532 am debugCHANGING Right Outlet Auto Turn-Off Timer Enabled(#12) from 0 to 0
dev:12020-05-15 08:43:41.528 am debugCHANGING Left Outlet Auto Turn-Off After(#9) from 60 to 60
dev:12020-05-15 08:43:41.523 am debugCHANGING Left Outlet Auto Turn-Off Timer Enabled(#8) from 0 to 0
dev:12020-05-15 08:43:41.518 am debugCHANGING Electrical Current Reporting Frequency(#6) from 300 to 300
dev:12020-05-15 08:43:41.514 am debugCHANGING Voltage Reporting Frequency(#5) from 300 to 300
dev:12020-05-15 08:43:41.508 am debugCHANGING Energy Reporting Frequency(#4) from 300 to 300
dev:12020-05-15 08:43:41.504 am debugCHANGING Power Reporting Frequency(#3) from 30 to 30
dev:12020-05-15 08:43:41.500 am debugCHANGING Power Reporting Threshold(#2) from 0 to 0
dev:12020-05-15 08:43:41.496 am debugCHANGING LED Indicator Mode(#17) from 1 to 1
dev:12020-05-15 08:43:41.491 am debugCHANGING Manual Control(#16) from 1 to 1
dev:12020-05-15 08:43:41.487 am debugCHANGING Overload Protection(#7) from 10 to 10
dev:12020-05-15 08:43:41.450 am debugCHANGING On/Off Status Recovery After Power Failure(#1) from 0 to 0
dev:12020-05-15 08:43:40.031 am infoBookcase Lamps power is 0W
dev:12020-05-15 08:43:30.519 am infoBookcase Lamps power is 0W
dev:12020-05-15 08:43:30.219 am infoBookcase Lamps current is 0A
dev:12020-05-15 08:43:29.720 am infoBookcase Lamps voltage is 0V
dev:12020-05-15 08:43:29.605 am debugSwitchBinaryReport(value:0, targetValue:0, duration:0) (right)
dev:12020-05-15 08:43:29.506 am debugSwitchBinaryReport(value:0, targetValue:0, duration:0) (left)dev:12020-05-15 08:43:29.409 am debugSwitchBinaryReport(value:0) ()
dev:12020-05-15 08:43:29.288 am debugoff()...
dev:12020-05-15 08:43:10.024 am infoBookcase Lamps power is 0W
dev:12020-05-15 08:42:40.019 am infoBookcase Lamps power is 0W
dev:12020-05-15 08:42:30.517 am infoBookcase Lamps power is 0W
dev:12020-05-15 08:42:30.218 am infoBookcase Lamps current is 0A
dev:12020-05-15 08:42:29.714 am infoBookcase Lamps voltage is 0V
dev:12020-05-15 08:42:29.606 am debugSwitchBinaryReport(value:0, targetValue:0, duration:0) (right)dev:12020-05-15 08:42:29.517 am debugSwitchBinaryReport(value:0, targetValue:0, duration:0) (left)
dev:12020-05-15 08:42:29.407 am debugSwitchBinaryReport(value:0) ()
dev:12020-05-15 08:42:29.292 am debugoff()...
dev:12020-05-15 08:42:15.525 am warndescription logging is: truedev:12020-05-15 08:42:15.524 am warndebug logging is: true
dev:12020-05-15 08:42:15.523 am infoupdated...
