I believe you said you have a Zooz 4-in-1 as well? Can you check the device page for the firmware version being reported, that will tell me which one you have.
Do you have any other sensor or power metering zwave devices? Those are what typically can be configured poorly and overwhelm the radio causing a crash.
Also, might be helpful if you post the entire zwave details page (multiple screenshots are fine).
That does not show the firmware but it looks like you are using my driver and have the new 700 series device, so FW should be 32.32 or 1.10 which are the same thing.
What is the Garage Motion 2 device?
Here is an example of my settings for the ZSE40
You just want it to be set so you are not getting constant, unnecessary, reports from it.
So I plugged those xmas devices in , and removed the motion two from the Garage it was stuck on Active so it gone now, And I made those changes you suggested on the ZSE40. Let see what happens after those changes. Strange stuff at times. Thanks for the help. Hopefully this works.
You can adjust the motion clear delay down if you want but having it higher will create less reports so not a bad idea for testing. Did you wake the device so the changes would apply right away?
Other than those two motion sensors I don't really see anything that should normally be sending a lot of updates to the hub.
You could also Check the logs > Device stats tab. See if any of the other devices are high on the list, might be an indication of excessing reporting. Sometimes a device will go bad and start spamming stuff out, has been known to cause issues for other people in the past.
