Switched from iris, now at about 50 devices, nearly all zwave plus with 3 repeaters covering house, one of the devices at end of house - zooz power strip is flooding logs with 10 on/off messages a second.
Resetting it, power cycling, and s3nding refresh/reconfigure commands not helping.
Zwave issue or likely defective device? What do you guys think? Has worked fine for a week.
I have a Zooz ZEN25 (double plug with USB) that does the same. I also have both generations of the ZEN20 power strip and am afraid to put the v2.0 one on the network for the same reason--I'm afraid I'll see what you're seeing. I'm not sure if the device is excessively chatty or if that's just the driver logging for no reason (though that seems unlikely). I'm assuming you also have the 2.0 revision (the older one didn't have power monitoring and seems to be working fine for me)?
EDIT: I see you said a repair helped. Perhaps I could try the same, though my device didn't constantly do this, so I'd keep an eye on yours to see if the problem comes back and it was just coincidence.
Maybe, I'll need to be careful about zooz devices going forward. I have 5 of the power strips, 4 of the normal plugs, and 6 of the heavy appliance plugs all installed in the last month. So far, I'm only seeing issues for one of the power strips. Not sure what firmware it is running.
I was always looking at the zooz stuff, but now may not consider it anymore. Also so them talking about the chattiness in this thread. Not a good look.
Drivers only create events when they receive messages from the device so it's not the driver.
While removing a plug from the ZEN20 I think I accidentally loosened the USB cable I was using to power another device and it started sending multiple reports per second and continued doing that until I unplugged the USB cable and plugged it back in. I have 3 of the ZEN20s and I've only run into that once...
When it comes to the actual outlets you can change the settings to reduce the frequency that it sends reports.
[quote="krlaframboise, post:6, topic:11685"]so it's not the driver.
[/quote]
I must have a defective device then. Here are a fraction of my settings, most of which were previously at the default and many of which I changed to report less, but once in a while, the logs still get flooded multiple times per second.
> [dev:18](#dev18)2019-03-08 09:08:18.981 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:18.648 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:18.368 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:16.844 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:08:16.544 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:16.242 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:15.943 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:08:15.246 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:14.942 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:14.666 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:08:14.506 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:08:14.453 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:14.287 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:14.249 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:08:14.216 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:13.036 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:12.968 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:12.905 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:12.333 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:12.304 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:10.867 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:09.756 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:08.097 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:07.800 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:07.580 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:06.364 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:06.321 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:06.273 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:06.242 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:06.158 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:04.722 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:04.641 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:04.617 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:04.540 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:04.504 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:04.443 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:04.366 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:03.425 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:03.107 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:01.861 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:01.139 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:01.035 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:08:00.536 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:08:00.236 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:59.937 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:59.672 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:59.361 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:59.078 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:58.737 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:58.438 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:58.135 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:57.837 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:57.326 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:55.453 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:55.422 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:55.308 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:55.089 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:54.173 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:54.131 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:54.116 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:54.070 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:54.045 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:54.013 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:53.572 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:53.491 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:53.428 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:52.629 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:52.475 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:52.310 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:50.707 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:50.581 am [info](/device/edit/18)Science Room Power switch is on
> [dev:3](#dev3)2019-03-08 09:07:50.147 am[info](/device/edit/3)Hallway Motion: motion is active
> [dev:18](#dev18)2019-03-08 09:07:49.249 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:45.683 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:45.243 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:45.156 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:45.068 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:45.001 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:44.684 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:44.606 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:44.560 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:44.525 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:43.353 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:43.205 am [info](/device/edit/18)Science Room Power switch is off
> [dev:3](#dev3)2019-03-08 09:07:42.355 am[info](/device/edit/3)Hallway Motion: motion is active
> [dev:18](#dev18)2019-03-08 09:07:42.160 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:41.212 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:40.652 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:36.457 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:36.138 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:36.078 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:36.044 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:35.609 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:35.567 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:35.534 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:35.463 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:35.445 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:33.940 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:33.770 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:32.537 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:32.439 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:31.563 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:31.229 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:30.954 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:30.398 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:30.154 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:29.874 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:29.093 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:29.037 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:28.962 am [info](/device/edit/18)Science Room Power switch is off
> [dev:3](#dev3)2019-03-08 09:07:28.864 am[info](/device/edit/3)Hallway Motion: motion is active
> [dev:18](#dev18)2019-03-08 09:07:28.770 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:28.553 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:28.452 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:28.357 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:28.249 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:28.152 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:28.055 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:27.954 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:27.899 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:22.951 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:22.914 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:22.808 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:22.746 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:22.722 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:21.142 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:20.780 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:18.478 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:18.381 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:17.054 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:16.971 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:16.912 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:16.614 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:16.539 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:16.515 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:16.412 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:16.393 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:16.347 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:16.120 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:16.086 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:16.073 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:15.578 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:14.014 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:13.109 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:08.386 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:08.312 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:08.276 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:07.119 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:05.521 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:04.576 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:04.388 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:04.014 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:03.715 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:03.313 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:03.027 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:02.716 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:02.419 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:02.122 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:01.814 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:01.516 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:01.220 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:00.915 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:07:00.636 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:07:00.053 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:55.956 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:55.802 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:55.659 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:55.658 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:55.530 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:55.505 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:54.722 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:54.219 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:53.493 am [info](/device/edit/18)Science Room Power switch is off
> [dev:3](#dev3)2019-03-08 09:06:52.382 am[info](/device/edit/3)Hallway Motion: motion is active
> [dev:18](#dev18)2019-03-08 09:06:52.372 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:51.469 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:51.280 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:51.171 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:50.507 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:49.820 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:49.131 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:47.755 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:47.637 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:47.507 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:42.119 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:42.067 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:39.520 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:39.381 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:39.258 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:39.050 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:37.888 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:37.817 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:37.200 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:37.040 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:36.966 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:35.839 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:34.920 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:34.846 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:34.842 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:34.438 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:34.418 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:33.432 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:33.177 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:33.103 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:30.701 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:30.386 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:29.545 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:29.526 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:29.473 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:29.436 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:29.399 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:29.390 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:27.713 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:27.654 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:24.580 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:22.034 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:21.949 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:21.744 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:16.643 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:15.444 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:15.367 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:15.356 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:15.101 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:15.038 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:15.003 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:13.740 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:13.298 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:13.102 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:11.908 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:10.695 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:10.663 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:10.656 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:10.615 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:10.611 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:09.813 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:09.767 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:09.687 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:09.435 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:09.413 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:09.369 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:09.366 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:08.850 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:08.771 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:08.722 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:07.235 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:06:04.567 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:04.554 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:02.968 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:02.929 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:02.923 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:01.970 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:01.964 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:01.161 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:06:00.589 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:05:59.587 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:05:58.696 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:58.626 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:58.555 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:58.397 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:57.558 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:57.513 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:57.454 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:55.675 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:54.737 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:54.597 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:53.572 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:52.420 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:52.389 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:52.139 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:52.105 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:51.830 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:51.433 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:51.218 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:51.210 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:50.801 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:50.774 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:50.756 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:49.200 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:48.881 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:48.663 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:47.625 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:46.844 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:46.532 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:46.002 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:05:45.746 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:45.002 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:05:44.706 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:05:44.472 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:05:44.195 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:41.781 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:41.474 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:41.358 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:40.873 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:40.846 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:39.263 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:39.205 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:39.173 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:38.260 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:37.787 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:37.746 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:37.701 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:35.568 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:35.341 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:35.053 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:34.726 am [info](/device/edit/18)Science Room Power switch is on
> [dev:3](#dev3)2019-03-08 09:05:34.599 am[info](/device/edit/3)Hallway Motion: motion is active
> [dev:18](#dev18)2019-03-08 09:05:34.346 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:05:33.997 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:33.696 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:33.399 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:33.136 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:05:32.809 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:32.304 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:27.307 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:27.302 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:26.247 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:25.893 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:25.728 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:25.585 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:24.793 am [info](/device/edit/18)Science Room Power switch is on
> [dev:40](#dev40)2019-03-08 09:05:17.915 am[info](/device/edit/40)Entryway Motion motion is active
> [dev:40](#dev40)2019-03-08 09:05:17.887 am[info](/device/edit/40)Entryway Motion motion is active
> [dev:40](#dev40)2019-03-08 09:05:16.824 am[info](/device/edit/40)Entryway Motion motion is active
> [dev:40](#dev40)2019-03-08 09:05:16.738 am[info](/device/edit/40)Entryway Motion motion is active
> [dev:12](#dev12)2019-03-08 09:05:14.889 am[info](/device/edit/12)Hallway Light 2 was turned on
> [dev:13](#dev13)2019-03-08 09:05:14.889 am[info](/device/edit/13)Hallway Light 3 was turned on
> [dev:11](#dev11)2019-03-08 09:05:14.858 am[info](/device/edit/11)Hallway Light 1 was turned on
> [dev:18](#dev18)2019-03-08 09:05:14.588 am [info](/device/edit/18)Science Room Power switch is on
> [app:19](#app19)2019-03-08 09:05:14.471 am[info](/installedapp/configure/19)Turn On Hallway Light 1, Hallway Light 2, Hallway Light 3 when Hallway Motion active Turn On
> [dev:18](#dev18)2019-03-08 09:05:14.416 am [info](/device/edit/18)Science Room Power switch is on
> [dev:3](#dev3)2019-03-08 09:05:14.389 am[info](/device/edit/3)Hallway Motion: motion is active
> [dev:18](#dev18)2019-03-08 09:05:14.202 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:13.875 am [info](/device/edit/18)Science Room Power switch is off
> [dev:10](#dev10)2019-03-08 09:05:12.655 am[info](/device/edit/10)Front Closet Light was turned on
> [dev:9](#dev9)2019-03-08 09:05:12.621 am[info](/device/edit/9)Entryway Light was turned on
> [app:23](#app23)2019-03-08 09:05:12.231 am[info](/installedapp/configure/23)Turn On Entryway Light, Front Closet Light when Entryway Motion active Turn On
> [dev:40](#dev40)2019-03-08 09:05:12.170 am[info](/device/edit/40)Entryway Motion motion is active
> [dev:18](#dev18)2019-03-08 09:05:11.801 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:11.700 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:11.348 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:02.333 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:02.237 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:05:02.183 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:58.795 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:58.748 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:58.654 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:58.644 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:57.663 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:57.639 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:57.482 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:57.312 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:57.292 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:57.146 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:55.596 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:55.457 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:55.294 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:54.912 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:54.480 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:53.435 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:53.110 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:53.066 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:53.003 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:52.956 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:52.876 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:52.843 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:50.750 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:50.417 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:50.128 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:49.245 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:49.167 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:49.127 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:45.796 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:45.661 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:45.556 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:45.543 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:44.116 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:44.027 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:43.106 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:43.070 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:43.026 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:42.893 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:42.790 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:42.664 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:42.654 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:42.298 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:41.745 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:41.596 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:41.310 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:40.926 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:40.167 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:39.374 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:39.088 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:36.431 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:36.197 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:34.128 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:34.063 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:34.061 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:32.616 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:32.546 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:32.274 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:32.228 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:31.770 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:31.735 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:31.730 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:30.762 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:29.162 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:29.142 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:25.831 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:25.719 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:25.613 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:25.177 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:23.682 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:23.673 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:23.623 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:23.566 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:23.536 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:23.429 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:23.116 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:23.113 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:23.068 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:23.038 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:23.016 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:21.384 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:21.164 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:20.897 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:20.766 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:20.491 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:20.489 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:17.206 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:17.148 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:16.844 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:16.796 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:15.919 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:15.888 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:15.746 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:15.695 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:15.666 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:15.325 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:15.290 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:15.287 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:14.150 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:13.479 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:13.146 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:12.339 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:04:12.116 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:12.092 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:07.955 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:07.934 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:07.436 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:07.398 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:07.380 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:06.544 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:06.202 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:06.168 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:06.125 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:06.082 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:05.219 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:04.342 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:04.213 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:03.537 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:03.080 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:01.792 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:04:00.810 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:59.958 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:59.933 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:59.163 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:58.014 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:57.773 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:57.764 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:57.602 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:57.040 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:55.106 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:55.064 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:55.024 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:55.019 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:54.970 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:54.966 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:53.260 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:53.084 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:52.978 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:52.082 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:51.278 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:47.970 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:47.534 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:46.396 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:45.347 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:45.328 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:43.390 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:42.483 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:38.796 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:38.783 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:37.885 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:37.806 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:37.436 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:37.332 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:37.287 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:35.706 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:35.395 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:35.381 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:34.454 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:34.224 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:34.069 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:32.557 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:31.114 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:31.082 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:30.073 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:30.010 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:29.975 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:29.936 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:29.865 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:28.255 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:27.994 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:26.433 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:26.292 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:26.164 am [info](/device/edit/18)Science Room Power switch is on
> [dev:1](#dev1)2019-03-08 09:03:25.077 am[info](/device/edit/1)Laundry Motion: illuminance is 680lux
> [dev:18](#dev18)2019-03-08 09:03:24.988 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:23.899 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:23.741 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:23.458 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:19.544 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:19.198 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:18.494 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:18.416 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:18.374 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:17.934 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:17.869 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:17.802 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:17.768 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:17.745 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:17.693 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:17.614 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:17.587 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:16.045 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:15.932 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:15.781 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:12.679 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:12.544 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:12.216 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:11.887 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:10.867 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:10.844 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:09.688 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:09.360 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:09.323 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:08.370 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:08.293 am [info](/device/edit/18)Science Room Power switch is off
> [dev:18](#dev18)2019-03-08 09:03:08.174 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:08.131 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:06.182 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:06.178 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:04.458 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:04.383 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:04.320 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:03.233 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:02.465 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:02.383 am [info](/device/edit/18)Science Room Power switch is on
> [dev:18](#dev18)2019-03-08 09:03:01.371 am [info](/device/edit/18)Science Room Power switch is on
We're testing the issue reported by @bertabcd1234 for the Double Plug and should have some results early next week.
The ZEN27 dimmer described as too chatty, was basically sending live reports for brightness during manual dimming, it wouldn't send any additional reports without action taken, just to clear that one up. As mentioned before, we have provided Hubitat with the updated firmware which doesn't feature the dimming reports, this firmware will also be applied to all future production runs.
Z-Wave has restrictions on the amount reporting and they test that part of the device during certification as well so any certified Z-Wave product shouldn't be chatty to an extent when it would affect network reliability.
We will keep testing all multichannel devices to see if we can replicate the issues described and see if they're related to the power monitor and/or USB reporting.
@marlowefamily do you have anything connected to the USB ports?
Agnes,
Thanks for the response. There were usb chargers that were inactive attached. This power strip is in a utility room with various equipment attached, however all ports were not in use at the time. I'lldetach the usb ports and see if it helps.
The way the USB reporting works is if it detects current, it reports ON to the hub. So if a device is on and charging it will say ON, then when it's fully charged, it will send OFF to the hub but once it starts charging again (which can be right away if it's an older battery and if the device is on and using power) it will say ON. Depending on what's plugged into the USB outlets, it could technically send a lot of reports in a short period of time but we haven't seen anything like this yet to be honest. We will also explore a way to limit the amount of reports sent to the hub if they're all being sent from the device.
I had a similar seeming problem, but was able to get it resolved by clicking "configure" on the offending devices. I had reached out to Zooz support about possible firmware upgrades and they were great and didn't even make me feel dumb when I fixed my own problem with "configure"
Once that configure was committed by the devices that were being excessively chatty, the repeated notifications stopped.
Also fine tune the reporting options, I have some fish tank heaters on outlets that use 50w, so I changed the reporting threshold to 20w, so smaller changes in power don't get reported. I also changed it to 10m reporting frequency and turned down the energy reporting frequency (24 hours for now, but might lower it once I get influxDB setup).
On the Zooz Power switch you can also change "power report percentage change" which can trigger LOTS of reporting at small load changes if the total load is small (10% of 10w is 1w change in power).
While I had tried that before, I just tried it again--and even increased the threshold to 10W--and I'd say it didn't help:
(I'm also not sure if the 10W applies to the whole strip or individual outlets, but I'm not sure that's working right, either.) I also keep getting messages like 2019-03-11 16:28:45.106 warnThere are 1 pending changes, please click the Save button again, despite having clicked Save (under both preferences and the device itself) before doing the Configure, several times.
Logging with the Zen20 2.0 seems to be working as expected for me. I have all preferences set to defaults (Power reporting threshold 5W) except Power reporting set to 1 minute and Energy Reporting Frequency set to 24 hours. My logs look like this:
Isn't that still quite a lot? that's multiple events per second every second. I assumed that with the 10 W threshold I set it to, it would take that much of a change to log one (or is that just the minimum needed at all for it to count anything?), and if not, I thought surely my 10 minute interval would eliminate the "every second" thing. Maybe I just don't understand what the parameters actually do, but both mine and yours look like quite a bit more events than I'd like to see on a Z-Wave network.
Well it is a lot, but it is respecting the interval I've selected-- I'm seeing one power event for every attached device every minute; nothing more frequent that what I would expect. The other posted logs are seeing multiple power reports for the same device within a one minute interval, which definitely doesn't seem correct.
