Zooz dimmer as button controller?
Not sure how to do this but I would like to be able to turn off a smart bulb in another room by double tapping the "off" switch on the zooz dimmer
What driver are you using? If not this one, I recommend moving to it -- it will expose all available parameters to set.
[DRIVER] Zooz ZEN Switches Advanced (and Dimmers) - :gear: Custom Apps and Drivers / Custom Drivers - Hubitat
Then once you switch over to my driver I would check out the built in Button Controller app. It is the easiest way to create button based rules. The normal app uses the Rule Machine engine, but if you like the "Basic Rules" engine better then you can use the "Basic" button controller.
Docs:
Here is the button number mappings from the bottom of my driver post.
I think I have added "doubleTapped" events also for 2x so you can use the special button number or buttons 1/2 with doubleTapped
Thanks!
Dumb question... how do I switch to the new driver? I was able to install the HPM and I clicked on the download of your driver from the list... what is the next step? Thanks!
Just to save myself from explaining it, here are the docs for that topic: How to Change the Driver Used by a Device | Hubitat Documentation
Thanks again!
