After you finish changing settings you need to click save. Then you need to use the paperclip to wake the device up.
Sometimes you have to use the paperclip more than once to wake it up so if it still shows pending changes after 15 seconds you need to wake it up again.
the device is now stuck in the active state. heres the logs:
2018-04-20 19:49:51.209:debugDevice Checked In
2018-04-20 19:34:45.999:debugMotion is active
2018-04-20 19:34:35.089:debugDevice Checked In
2018-04-20 19:32:52.576:debugDevice Checked In
2018-04-20 19:14:08.053:debugDevice Checked In
2018-04-20 19:14:08.038:debugUnable to parse description: zw device: 07, command: D840, payload:
2018-04-20 19:11:04.945:debugDevice Checked In
2018-04-20 18:58:09.480:debugMotion is inactive
sigh ... this didnt look so good so bugging you again. this is my first zwave device on hubitat. however not sure why the device status is DEAD. doesnt seem like the device is healthy.
I'm having an issue with this sensor as well. It seems to be reporting everything except motion. Motion is set as the primary status and no matter how many times I wake up the device (and save before), it won't show the motion value.
When waking, I see a yellow flash of the LED and the check-in value does seem to update.
I'm having the same problem with the same sensor, but not with Hubitat. I was doing some testing of this sensor with a Vera Plus and I'm having the exact same issue. Odd thing is I know Vera did a firmware upgrade recently.
I also had this issue with a Homeseer setup. I fixed it with HomeSeer by pairing in unsecure mode.
Currently the Zooz is still reporting: primaryStatus : Save Settings and Wake Up Device.
No matter how many times I poke it with a paperclip, it doesn't seem to update the primary status. I can even change the primary status to report temperature instead of motion and it still doesn't work.
So it's been a few days, I did some more troubleshooting, and I think I found a solution to my problem.
For whatever reason, pairing the device in Firefox (Dev Edition) seemed to cause the no motion problem.
I switched to Chrome for pairing and the device was reporting motion immediately. Since I don't know the ins-and-outs of the pairing process, I'm not sure why it would be reliant on my browser vendor, but I'm not complaining too much.
Here is what I did to finally get this device working:
Open Hubitat in Google Chrome. 1 tab for adding device & 1 tab for logging
Remove back cover of sensor
Press reset button w/ paperclip 10 times. The sensor LED should blink a bunch afterwards for a second or two
Replace back cover
Start device pairing in Hubitat (Discover Devices button)
Press reset button w/ paperclip 2 times
Sensor LED will blink a couple times
Click Save when the device is detected by Hubitat
Navigate to device settings in Hubitat
Make any modifications (motion threshold, temp settings, etc) then click Save button
Press reset button w/ paperclip 1 time
Wait for device to accept to new changes. Verify in Hubitat log.
Hopefully this helps someone who may have issues in the future. Big thanks to @krlaframboise for helping me with some DMs and also I want to give a shoutout to the support staff at Zooz (The Smartest House). Initially when I thought it might be a hardware issue, they sent out a replacement no questions asked. Great folks over there!
The device takes light/temperature/humidity measurements about every 3 minutes and if any of those values exceed the thresholds specified in the settings then the device reports all 3 values to the hub.
