Zigbee with gen4 Shelly work?
I've seen that some folks have gen4 Shelly devices in the wild that support zigbee. Has anyone tried them with Hubitat yet?
I'm super hopeful about gen4 zigbee support and am waiting to make a big device swap if they work.
@kkossev has tested a Shelly 1PM Gen4 and the switch works with the native driver. I'm not sure about the power monitoring feature.
I'll buy a Shelly 1 Gen4 (without power monitoring) today, but it will probably take more than a month to arrive.
Actually, my tests were not much successful.... :frowning:
I managed to pair Shelly Gen4 1PM just once :
Manufacturer: Shelly
Endpoint 01 endpointId: 01
Endpoint 01 idAsInt: 1
Endpoint 01 inClusters: 0000,0003,0004,0005,0006,0B04,0702
Endpoint 01 initialized: true
Endpoint 01 manufacturer: Shelly
Endpoint 01 model: 1PM
Endpoint 01 profileId: 0104
Endpoint 01 stage: 4
Endpoint EF application: unknown
Endpoint EF endpointId: EF
Endpoint EF idAsInt: 239
Endpoint EF inClusters: FC01,FC02
Endpoint EF initialized: true
Endpoint EF manufacturer: unknown
Endpoint EF model: unknown
Endpoint EF profileId: C001
Endpoint EF stage: 4
A minute later, the Zigbee connection was lost, and I could not pair it again (C-8 Pro).
Shelly Gen4 are using the standard ZCL clusters for reporting the power and energy, so I suppose it will work with the inbuilt HE drivers, providing if it pairs and stays connected. I don't know why I can not pair it anymore, tried with all my HE hubs (C8 Pro, C8, C7 ), tried to use all my pairing workarounds - no success. Update: a link to a complex and tricky pairing sequence post on the Shelly forum.
Switching between Matter and Zigbee interface is working (5 quick presses of the device button), but starting the Zigbee pairing (3 quick presses) worked just once. I will try again after a few days.
The good news is that Shelly Gen4 Matter mode is working well! - Power, Voltage, Amperage, Frequency, and PowerFactor readings are correct and not spammy. There is a problem with the accumulated energy readings, however.
I have just updated the Matter Advanced Bridge .
Thanks. Looks like we will need a wait a bit for them to get the firmware right for Zigbee. The US site either hasn't released them yet or is just out of stock.
I thought I picked up from the videos or help docs that you could have Zigbee and Wifi running at the same time. That would be an advantage for me if it's eventually true.
Secondarily, it's a shame that the X2 display is getting bad reviews. I was hopeful.
Yes, still seems too early, but this note from the QA team maybe helps. You can have Wifi and Zigbee at the same time as long we the wifi AP is not enabled.
After many tries, I managed to pair it to my C-8 Pro.
Using the Generic Zigbee Outlet driver, the power readings are off by a factor of 10.
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006,0B04,0702",
Using the ThirdReality Power Meter Plug community driver :
So it works, but was really challenging to pair.
Maybe their docs would be useful for understanding the Zigbee clusters. The RPC cluster is interesting.
Shelly Gen 4 works simultaneously via Zigbee (Tuya driver) and WiFi (tnx @dmitry.rozovik )!
Nice! thanks for confirming! Over time I'm sure we will see some full Zigbee drivers with RPC functionality.
Which Tuya driver is this? Is it built in or a download? I've just purchased some Gen4 Shelly 1 devices (non-pm) and I'm having some issues getting them working. They're detected okay (Device data IDs them as Shelly Mini1) but the driver it defaults to is Zemismart ZigBee Wall Switch Multi-Gang...have tried generic Zigbee switch and ShellyPlus Generic but neither seem to work.
@dmitry.rozovik , the gen4 devices are not listed under "Currently driver is expected to support...." , Is the list incomplete or is it an coincident the driver is working?
@dmitry.rozovik, or mayby your driver is working for Gen 2,3 an 4? :slight_smile:
Comparison of Shelly Gen 1, Gen 2, Gen 3 and Gen 4 Devices :
The list is mainly consists of devices used as a base for the implemenation. The driver is not focusing on specific devices but on device components. Gen2+ devices expose a set of component instances responsible for some subset of features. As long as component is supported, the related fetures will work. Gen4 devices follow the same Gen2+ API and thus are supported.
Some new specific componnets might be required to add (for more new featuers). But the total set does not seem to be changed at the moment. Components that are currently WIP (I'm waiting for a device to get at hand to test and finilize) are 'cct', 'rgb', 'rgbw'
All the documented componets can be fount here Welcome! | Shelly Technical Documentation
Not all of them are implemented by driver as not all of them have practical use.
Thanks for your feedback. Wouldn't it be useful to add a note in the description of the driver at the top, indicating that Gen3 and Gen4 are also supported, as I was initially unaware of this?
Seems like an edgy comment to people that are contributing their personal time. While what you are asking is logical it's maybe unfriendly. Perhaps it's a language issue.
Gen4 devices are brand new. It's OK to assume things will get documented and supported in good time.
It does make sense to update a device list comment in a more generic way as it might confuse people. I'll edit it alongside with other changes. Due to the driver implementation approach and the same API Gen3 and Gen4 were supported right from their release (though few new components had to be added)
Of course this thread or topic is about Zigbee control.
The Shelly switches Gen4 (and now also Gen3 with the latest Shelly firmware) should work via Zigbee in HE using the inbuilt stock 'Generic Zigbee Switch' drivers. I am using this custom driver because of the power and energy scale adjustments.
With Debug logging turned on, do you see anything in the live logs when you turn the Shelly switch module on and off from the physical switch? Most probably, your device has left the Zigbee network ... Try pairing it again.
I am unable to pair the Shelly 1 Mini Gen4 with C-7, using the Zigbee firmware (1.6.0-beta).
Did a little bit of sniffing, and looks like it joins the network, but immediately after receiving the transport key, it sends the "Leave" command, then the join process starts again.
Had no problem joining it with Z2MQTT though.
Probably Shelly does not like the old ZCL version (non-ZIgbee 3.0) reported from C-7 ? :thinking:
Knockturn Alley
Node Descriptor
▸ Logical Type = Zigbee Router
▸ Complex Descriptor Available = No
▸ User Descriptor Available = No
▸ Fragmentation Supported (R23) = No
▸ Frequency Band = Reserved
▸ Alternate PAN Coordinator = No
▸ Device Type = Full Function Device (FFD)
▸ Mains Power Source = Yes
▸ Receiver On When Idle = Yes (always on)
▸ Security Capability = No
▸ Allocate Address = Yes
▸ Manufacturer Code = 0x1490
▸ Maximum Buffer Size = 108 bytes
▸ Maximum Incoming Transfer Size = 1613 bytes
▸ Primary Trust Center = No
▸ Backup Trust Center = No
▸ Primary Binding Table Cache = Yes
▸ Backup Binding Table Cache = No
▸ Primary Discovery Cache = Yes
▸ Backup Discovery Cache = Yes
▸ Network Manager = Yes
▸ Maximum Outgoing Transfer Size = 1613 bytes
▸ Extended Active Endpoint List Available = No
▸ Extended Simple Descriptor List Available = No
Power Descriptor
▸ Current Power Mode = Same as "Receiver On When Idle" from "Node Descriptor" section above
▸ Available Power Sources =
▸ Current Power Sources =
▸ Current Power Source Level = Critical
Endpoint 0x01
In Cluster: 0x0000 (Basic Cluster)
▸ 0x0000 | ZCL Version | req | r-- | uint8 | 08 = 8 | --
▸ 0x0004 | Manufacturer Name | opt | r-- | string | Shelly | --
▸ 0x0005 | Model Identifier | opt | r-- | string | 1PM | --
▸ 0x0007 | Power Source | opt | r-- | enum8 | 00 = Unknown | --
▸ 0x00 | Reset to Factory Defaults | opt
In Cluster: 0x0003 (Identify Cluster)
▸ 0x0000 | Identify Time | req | rw- | uint16 | 0000 = 0 seconds | --
▸ 0x00 | Identify | req
▸ 0x01 | Identify Query | req
▸ 0x40 | Trigger Effect | opt
In Cluster: 0x0004 (Groups Cluster)
▸ 0x0000 | Name Support | req | r-- | map8 | 00 = 00000000 | --
▸ 0x00 | Add Group | req
▸ 0x01 | View Group | req
▸ 0x02 | Get Group Membership | req
▸ 0x03 | Remove Group | req
▸ 0x04 | Remove All Groups | req
▸ 0x05 | Add Group If Identifying | req
In Cluster: 0x0005 (Scenes Cluster)
▸ 0x0000 | Scene Count | req | r-- | uint8 | 00 = 0 | --
▸ 0x0001 | Current Scene | req | r-- | uint8 | 00 = 0 | --
▸ 0x0002 | Current Group | req | r-- | uint16 | 0000 = 0 | --
▸ 0x0003 | Scene Valid | req | r-- | bool | 00 = False | --
▸ 0x0004 | Name Support | req | r-- | map8 | 00 = 00000000 | --
▸ 0x00 | Add Scene | req
▸ 0x01 | View Scene | req
▸ 0x02 | Remove Scene | req
▸ 0x03 | Remove All Scenes | req
▸ 0x04 | Store Scene | req
▸ 0x05 | Recall Scene | req
▸ 0x06 | Get Scene Membership | req
In Cluster: 0x0006 (On/Off Cluster)
▸ 0x0000 | On Off | req | r-p | bool | 00 = Off | 5..0
▸ 0x00 | Off | req
▸ 0x01 | On | req
▸ 0x02 | Toggle | req
▸ 0x40 | Off With Effect | opt
▸ 0x41 | On With Recall Global Scene | opt
▸ 0x42 | On With Timed Off | opt
In Cluster: 0x0702 (Metering (Smart Energy) Cluster)
▸ 0x0000 | Current Summation Delivered | req | r-- | uint48 | 000000000FA0 = 4000 | --
▸ 0x0001 | Current Summation Received | opt | r-- | uint48 | 000000000000 = 0 | --
▸ 0x0200 | -- | -- | r-- | map8 | 00 = 00000000 | --
▸ 0x0300 | Unit of Measure | req | r-- | enum8 | 00 = kWh & kW | --
▸ 0x0301 | Multiplier | opt | r-- | uint48 | 000000000001 = 1 | --
▸ 0x0302 | Divisor | opt | r-- | uint48 | 0000000F4240 = 1000000 | --
▸ 0x0303 | Summation Formatting | req | r-- | map8 | 1B = 00011011 | --
▸ 0x0306 | Metering Device Type | req | r-- | map8 | 00 = Electric Metering | --
▸ 0x00 | Zone Enroll Response | req
▸ 0x03 | -- | --
▸ 0x06 | -- | --
▸ 0x08 | -- | --
In Cluster: 0x0B04 (Electrical Measurement Cluster)
▸ 0x0000 | Measurement Type | req | r-- | map32 | 00000001 = 00000000000000000000000000000001 | --
▸ 0x0300 | ACFrequency | opt | r-- | uint16 | 1382 = 4994 | --
▸ 0x0400 | AC Frequency Multiplier | opt | r-- | uint16 | 0001 = 1 | --
▸ 0x0401 | AC Frequency Divisor | opt | r-- | uint16 | 0064 = 100 | --
▸ 0x0505 | RMS Voltage | opt | r-- | uint16 | 5516 = 21782 | --
▸ 0x0508 | RMS Current | opt | r-- | uint16 | 0000 = 0 | --
▸ 0x050B | Active Power | opt | r-- | int16 | 0000 = Infinity | --
▸ 0x0600 | AC Voltage Multiplier | opt | r-- | uint16 | 0001 = 1 | --
▸ 0x0601 | AC Voltage Divisor | opt | r-- | uint16 | 0064 = 100 | --
▸ 0x0602 | AC Current Multiplier | opt | r-- | uint16 | 0001 = 1 | --
▸ 0x0603 | AC Current Divisor | opt | r-- | uint16 | 0064 = 100 | --
▸ 0x0604 | AC Power Multiplier | opt | r-- | uint16 | 0001 = 1 | --
▸ 0x0605 | AC Power Divisor | opt | r-- | uint16 | 0064 = 100 | --
▸ No received commands
Endpoint 0xEF
In Cluster: 0xFC01 (Unknown Cluster)
▸ No attributes
In Cluster: 0xFC02 (Unknown Cluster)
▸ No attributes
Endpoint 0xF2
Out Cluster: 0x0021 (Green Power Cluster)
▸ No generated commands
Bindings Table
▸ Could not retrieve data
Neighbors Table
▸ Addr:4661 | Type:Zigbee Router | RxOnWhenIdle:Yes | Rel:Sibling | Permit Joining:No | Depth:1
▸ Addr:E03B | Type:Zigbee Router | RxOnWhenIdle:Yes | Rel:Sibling | Permit Joining:No | Depth:1
▸ Addr:2BD1 | Type:Zigbee Router | RxOnWhenIdle:Yes | Rel:Sibling | Permit Joining:No | Depth:3
▸ Addr:9CDF | Type:Zigbee Router | RxOnWhenIdle:Yes | Rel:Sibling | Permit Joining:No | Depth:1
▸ Addr:B450 | Type:Zigbee Router | RxOnWhenIdle:Yes | Rel:Sibling | Permit Joining:No | Depth:1
▸ Addr:2763 | Type:Zigbee Router | RxOnWhenIdle:Yes | Rel:Sibling | Permit Joining:No | Depth:1
▸ Addr:0000 | Type:Zigbee Coordinator | RxOnWhenIdle:Yes | Rel:Sibling | Permit Joining:No | Depth:0
▸ Addr:AE74 | Type:Unknown | RxOnWhenIdle:Yes | Rel:Unknown | Permit Joining:No | Depth:0
Routing Table
▸ Destination:0000 | Next Hop:2BD1 | Route Status:Active
▸ Destination:0000 | Next Hop:0000 | Route Status:Acti
Pairing to C-8 via Zigbee 3.0 repeaters was also not possible. I had to use the Double Luck Voodoo to clean up the C-8 Zigbee routing table, and only then it will pair directly to the hub.
