Yes natively, make sure your using the dedicated driver though. What driver did it select?
@BorrisTheCat, thanks for your reply. As is often the case, the problem lay with the mouse, keyboard and screen driver
I'm new to Hubitat and thought the device setting 'Enable automatic power reporting' was exception reporting. I now see the power sensors just fine but the associated energy sensors report as 'unknown'. Maybe I need to wait a while for these to populate but failing that a Riemann sum integral sensors should do the trick.
