I can't seem to get this zigbee plug to pair.
It to initialize. Tried both options, avoiding repeaters and exchange keys.
States device found but that's it.
C-8 or C-7 ?
It's a C8
Have you tried this sequence?
The pre-requirement is to bring the problematic device close to the C-8 hub
That worked like a charm. Now, I need a little more help.
This is a power monitor outlet. I'm using the zigbee generic outlet. When the TV power is on THE OUTLET power reads 1. I have to hit refresh to update the reading (4 after refresh) then the outlet reads power increase and a light turns on. The same with off, have to refresh to achieve the correct reading of 1.
The ‘Double Luck’ workaround efficiency score so far is 5:0 ! ![]()
For Tuya devices I recommend Tuya drivers.
Thank you
this worked for me as well to pair linptech presence sensors.
