Zigbee Devices which are not working for me
@SmartHomePrimer i had the same feeling, my initial goal was to install z2m and use it HE, but after installing driver and app. I added a virtual device but i am not what to do next. the devices which were shown in the Z2M portal was not showing HE I followed this guide
but i was unable to go further
You don't select the drivers manually if that's what you're doing. You simply add them to the Home Assistant Device Bridge if they are not part of the base installation. They will be selected automatically if appropriate for that device.
In the case of your siren, I only see one "Switch", but it looks like there should be two entities. Make sure you have not missed it in the list. I suggest you change the device names on Home Assistant and let it rename the entities so it's not so confusing to look at a list of very similar names. It would be much easier to identify in the list on your Hubitat hub.
The Z2M routing driver for Hubitat and the Z2M integration on Home Assistant are not the same. The Z2M integration for Home Assistant is highly developed by hundreds of contributors and allows two-way communication. The Z2M routing driver currently only maps the device state to Hubitat.
You can check if your devices are supported by Zigbee2MQTT here. It's not impossible, but quite rare that a device in supported by the Zigbee HA integration on Home Assistant, but not by the Z2M integration on Home Assistant.
it works with Z2M but i want to know how i can i control using HE using routing driver
At the present time, you cannot control any device using the Z2M routing driver by @birdslikewires. You can only see the device state (i.e. Open/Close, ON/OFF, etc.)
@renovatio The MQTT routing driver and the Home Assistant Device bridge (HADB) are 2 different things. If you use HADB you DO NOT choose a driver for your imported devices: HADB will install the correct driver for you. If you change the driver, the device will stop working (in HE).
For your TZ3000, you get 5 entities in HA so you will get 5 different devices on HE (if you selected all 5 devices in the HADB app). You will get 2 switches and 3 sensors.
Thank you all for your help.I will try to work this weekend again to see if i can get it working.
