So here is a problem I haven't experienced before. Years ago I bought some Stelpro Maestros (SPM). At first I was using them with the Maestro controller, then I switched over to Hubitat. I have two SPMs in the house. One in the washroom on he main floor, and one in the garage (the floor below). I had both connected to Hubitat without a problem until recently. The one on the main floor is still connected. The one in the garage lost its connection (for a while now unbeknownst to me). Tried to re-connect through resents both hard and soft to no affect, Tries to re-pair the device and it initially connects (even gets the manufacturer info) and then the device suddenly turns off its radio. I tried with a spare SPM I have lying around and I get the same behaviour. Now we recently renovated the garage, ao there is more drywall etc in the way, but it pairs immediately, so I'm not sure it's a range issue. Anyone have a similar experience?
Here are the logs from the Pairing;
dev:18152023-11-21 11:49:40.885warnconfigure...
dev:18152023-11-21 11:47:22.181debuggetting info for unknown Zigbee device...
dev:18152023-11-21 11:47:17.315infoZigbee parsed:[raw:catchall: 0104 0402 19 01 0040 00 DB96 00 00 0000 00 00 0000, profileId:0104, clusterId:0402, clusterInt:1026, sourceEndpoint:19, destinationEndpoint:01, options:0040, messageType:00, dni:DB96, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[00, 00]]
dev:18152023-11-21 11:47:17.309infoZigbee parsed:[raw:catchall: 0104 0402 19 14 0040 00 DB96 00 00 0000 00 00 0000, profileId:0104, clusterId:0402, clusterInt:1026, sourceEndpoint:19, destinationEndpoint:14, options:0040, messageType:00, dni:DB96, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[00, 00]]
dev:18152023-11-21 11:47:12.158debuggetting device info in 10 seconds...
