Hello All, new to Hubitat and first post. I did read the many posts on Zen17, but I dont see anyone running into this issue so far.
I have two garage door openers with the purple button, these do not have the security protocols of newer models, and should be straight forward to wire.
I wired from the zen17 directly to the garage door opener in parallel with the wall switch.
I wired in magnetic sensors for the closed state of the door.
I have had a number of logic issues. Hubitat shows the door open when it is closed, or the opposite. In this state I cannot control the door through Hubitat, and I havent found the sequence of events to sync it back up...but have tried manual operation, Refresh in the device in Hubitat, etc.
To rule out the magnetic sensors I switched from the ones i installed to the zen17 to the ones that tie into the alarm system, which is integrated into Hubitat with Envisalink. However, I did experience a similar logic issue is the incorrect door state.
Today i went to open the garage door with the wall button, it would not operate, in fact both did not work. I'm not sure what the zen17 could do to prevent the wall buttons from working - only perhaps keeping it in the 'on' state as if the button was held down.
The hub is the closest zwave device, and is maybe 30 feet away, but there is HVAC and the foam insulated garage wall in-between.
I'm thinking the most likely cause is spotty connectivity...but hoping someone has seen similar issues or can offer some advice. Outside of relocating the hub or getting an extender, is there specific logging that would show me if connectivity to this device was dropping. I did turn on debug for the zen17 parent device, but just now.
Thanks!!
