I see in the logs where it didn't work, then when I went in to command it, it then did work.
Red circle is working, blue is not.
Is there a way to sniff if the zigbee command was sent and the thermostat ignored or any other way to try to figure out why this happens sporadically?
I reported this problem a while back and was never able to find a resolution. I've since switched my thermostat for another (this problem didn't help but I had other oddities too). You can read more here and maybe something will work for you or you could add your findings:
Funny thing is I had the same issue with a pearl... I cycle my fan every hour if I haven't done a heat or cool, so I know it is an intermittent issue. I can go days without it happening.
