Hey taysnet, tbh I haven't been tinkering with the hubitat for a while now, so I don't remember the state I left this driver in
looks like I just changed some ids from the driver from Muxa, I'll need some time to check later if it actually works as intended ^^
import hubitat.zigbee.clusters.iaszone.ZoneStatus
import com.hubitat.zigbee.DataType
metadata {
definition (name: "PIR ZigBee Motion Sensor2", namespace: "muxa", author: "Mikhail Diatchenko") {
capability "MotionSensor"
capability "Battery"
capability "PushableButton"
capability "Configuration"
capability "Refresh"
fingerprint endpointId: "01", profileId: "0104", inClusters: "0000,0001,0003,0402,0500", outClusters: "0003,0019", manufacturer: "_TYZB01_jytabjkb", model: "TS0202" , deviceJoinName: "PIR Motion Sensor"
preferences {
input "motionreset", "number", title: "After motion is detected, wait ___ second(s) until resetting to inactive state. Default = 16 seconds (Hardware resets at 15 seconds)", description: "", range: "1..7200", defaultValue: 16
input "batteryReportingHours", "number", title: "Report battery every ___ hours. Default = 12h (Minimum 2 h)", description: "", range: "2..12", defaultValue: 12
input name: "infoLogging", type: "bool", title: "Enable info message logging", description: ""
input name: "debugLogging", type: "bool", title: "Enable debug message logging", description: ""
// Parse incoming device messages to generate events
Map map = [:]
// logDebug("Parsing: $description")
if (description?.startsWith('zone status')) {
// logDebug("Zone status: $description")
def zs = zigbee.parseZoneStatus(description)
map = parseIasMessage(zs)
else if (description?.startsWith("catchall") || description?.startsWith("read attr"))
Map descMap = zigbee.parseDescriptionAsMap(description)
if (descMap.clusterInt == zigbee.POWER_CONFIGURATION_CLUSTER && descMap.attrInt == 0x0020) {
map = parseBattery(descMap.value)
} else if (descMap.command == "07") {
// Process "Configure Reporting" response
if (descMap.data[0] == "00") {
switch (descMap.clusterInt) {
case zigbee.POWER_CONFIGURATION_CLUSTER:
logInfo("Battery reporting configured");
break
default:
log.warn("Unknown reporting configured: ${descMap}");
break
} else {
log.warn "Reporting configuration failed: ${descMap}"
} else if (descMap.clusterInt == 0x0500 && descMap.attrInt == 0x0002) {
logDebug("Zone status repoted: $descMap")
def zs = new ZoneStatus(Integer.parseInt(descMap.value, 16))
} else if (descMap.clusterInt == 0x0500 && descMap.attrInt == 0x0011) {
logInfo("IAS Zone ID: ${descMap.value}")
} else if (descMap.profileId == "0000") {
// ignore routing table messages
} else {
log.warn ("Description map not parsed: $descMap")
//------IAS Zone Enroll request------//
else if (description?.startsWith('enroll request')) {
logInfo "Sending IAS enroll response..."
return zigbee.enrollResponse()
else {
log.warn "Description not parsed: $description"
if (map != [:]) {
logInfo(map.descriptionText)
return createEvent(map)
} else
return [:]
// helpers -------------------
def parseIasMessage(ZoneStatus zs) {
if ((zs.alarm1 || zs.alarm2) && zs.battery == 0 && zs.trouble == 0) {
// Motion detected
return handleMotion(true)
else if (zs.tamper == 1 && zs.battery == 1 && zs.trouble == 1 && zs.ac == 1) {
logDebug "Device button pressed"
map = [
value: 1,
isStateChange: true,
descriptionText: "Device button pushed"
else {
log.warn "Zone status message not parsed"
if (debugLogging) {
logDebug "zs.alarm1 = $zs.alarm1"
logDebug "zs.alarm2 = $zs.alarm2"
logDebug "zs.tamper = $zs.tamper"
logDebug "zs.battery = $zs.battery"
logDebug "zs.supervisionReports = $zs.supervisionReports"
logDebug "zs.restoreReports = $zs.restoreReports"
logDebug "zs.trouble = $zs.trouble"
logDebug "zs.ac = $zs.ac"
logDebug "zs.test = $zs.test"
logDebug "zs.batteryDefect = $zs.batteryDefect"
private handleMotion(motionActive) {
if (motionActive) {
def timeout = motionreset ?: 16
// The sensor only sends a motion detected message so reset to motion inactive is performed in code
runIn(timeout, resetToMotionInactive)
if (device.currentState('motion')?.value != "active") {
state.motionStarted = now()
return getMotionResult(motionActive)
def getMotionResult(motionActive) {
def descriptionText = "Detected motion"
if (!motionActive) {
descriptionText = "Motion reset to inactive after ${getSecondsInactive()}s"
return [
value : motionActive ? 'active' : 'inactive',
descriptionText : descriptionText
def resetToMotionInactive() {
if (device.currentState('motion')?.value == "active") {
def descText = "Motion reset to inactive after ${getSecondsInactive()}s"
sendEvent(
value:'inactive',
// isStateChange: true,
descriptionText: descText
logInfo(descText)
def getSecondsInactive() {
if (state.motionStarted) {
return Math.round((now() - state.motionStarted)/1000)
} else {
return motionreset ?: 16
// Convert 2-byte hex string to voltage
// 0x0020 BatteryVoltage - The BatteryVoltage attribute is 8 bits in length and specifies the current actual (measured) battery voltage, in units of 100mV.
private parseBattery(valueHex) {
//logDebug("Battery parse string = ${valueHex}")
def rawVolts = Integer.parseInt(valueHex, 16) / 10 // hexStrToSignedInt(valueHex)/10
def minVolts = voltsmin ? voltsmin : 2.5
def maxVolts = voltsmax ? voltsmax : 3.0
def pct = (rawVolts - minVolts) / (maxVolts - minVolts)
def roundedPct = Math.min(100, Math.round(pct * 100))
def descText = "Battery level is ${roundedPct}% (${rawVolts} Volts)"
//logInfo(descText)
// sendEvent(name: "batteryLevelLastReceived", value: new Date())
def result = [
value: roundedPct,
unit: "%",
//isStateChange: true,
return result
// lifecycle methods -------------
// installed() runs just after a sensor is paired
def installed() {
logInfo("Installing")
sendEvent(name: "numberOfButtons", value: 1, descriptionText: "Device installed")
return refresh()
// configure() runs after installed() when a sensor is paired or reconnected
def configure() {
logInfo("Configuring")
return configureReporting()
def refresh() {
logInfo("Refreshing")
return zigbee.readAttribute(zigbee.POWER_CONFIGURATION_CLUSTER, 0x0020) // battery voltage
// updated() runs every time user saves preferences
def updated() {
logInfo("Updating preference settings")
private def configureReporting() {
def seconds = Math.round((batteryReportingHours ?: 12)*3600)
logInfo("Battery reporting frequency: ${seconds/3600}h")
return zigbee.configureReporting(zigbee.POWER_CONFIGURATION_CLUSTER, 0x0020, DataType.UINT8, seconds, seconds, 0x01)
+ zigbee.readAttribute(zigbee.POWER_CONFIGURATION_CLUSTER, 0x20)
private def logDebug(message) {
if (debugLogging) log.debug "${device.displayName}: ${message}"
private def logInfo(message) {
if (infoLogging)
log.info "${device.displayName}: ${message}"
