As I have just one blinds motor (for now), I haven't tried this app yet. Will give it a try in the next days and will comment here.
@s1godfrey , this one seems to be the same motor I use. I´ll post its fingerprint and if it is really the same you may try the driver I posted. Mine uses battery, and its only problem is the battery not being reported, differently of yours that uses AC.
The fingerprint:
- endpointId: 01
- application: 44
- softwareBuild:
- inClusters: 0000,0004,0005,EF00
- outClusters: 0019,000A
- model: TS0601
- manufacturer: _TZE200_5sbebbzs
If it don´t work, you will know its a hardware problem...
So this is the weirdest occurrence. I have an automation to open all of the 6 roller blind motor driven shades in the house each morning and to close them all at night. As the previous post show, one of these has been problematic and strays away from the pack, so to speak.
But this morning, all of my shades, except the problem one decided to not work. And the logs show that they all reported as open (100%) and executed the TUYA command. Yet, physical all, except for the supposedly 'bad' one failed to physically respond.
It's like a bad practical joke...
I'm in the same boat, but not as bad.
I have 5 motors all the same model, from the same supplier. Some report their position correctly. Others work properly but only ever report a state of opening or closing.
How strange, being the same model, that some inform you and others don't, have you seen that you have a good curtain? I'm sorry to hear that
It is not uncommon for Tuya products suppliers to ship different models/modifications, even in one and the same purchase order. So for me it is possible that this may be yours and (less likely) @s1godfrey cases.
Can you double-check again if there are any differences in the 'Manufacturer' and 'Application' values between your blinds/motors?
The 'Manufacturer' is what explicitly identifies a Tuya product. The 'application' is the firmware version.
As an example, saying 'my Zemismart blinds model is AM43' doesn't uniquely identify the device. There are at least 3 different AM43 models with different Tuya commands implementation.
The identified different models (manufacturers) of Zemismart Rollers/Blinds/Shade Motors is now increased from 20 to 24, each of these may have potentially slightly different commands set and respectively slightly different behavior. There are also about a dozen modifications of the "ZemiSmart Zigbee Blind" driver for HE, every mod patched to work fine for just one of the models, but not properly working for the other models.
I've been working recently on an attempt to improve this driver to support all of the different types of Tuya/Zemismart blinds. If this activity is successful, the final goal is to merge these changes into Amos Yuen's driver, which seems to be the most popular and available in HPM.
The temporary link to the work-in-progress driver mod is here. If you have time, you can test it and please let me know if it works for your model(s) ( 'Manufacturer' )
Nice!!!!
Not so much here. I changed to the new driver and then trouble started. Now it only moves up 2 or 3 steps or down 2 or 3 steps. I switched back to old driver, no change. I did wipe device using cleaner, nothing. I unpaired the device and repaired, same results.
Can anyone please tell me how to completely wipe the zemismart zigbee tubular motor model: ZM25TQ back to factory defaults.
I tried press 5x quickly, still paired. I tried hold for several seconds, still paired. I tried unplug AC, hold on plug-in, still paired. By still paired, I mean that it will move motor upon command, not correctly, but it still responds from hubitat. So, its definitely not reset to factory defaults.
- endpointId: 01
- application: 52
- softwareBuild:
- inClusters: 0000,000A,0004,0005,EF00
- outClusters: 0019
- model: TS0601
- manufacturer: _TZE200_fzo2pocs
Yes, thank you and sorry I missed the answer you gave me some days before...
I will need some time to check what info is available for your device.
Before I would always press 5x quickly on red set button located on the motor side.
Now, even when I do that, it still shows up in the zigbee logs:
[blind] 2022-05-13 15:34:58.472 profileId:0x104, clusterId:0x0, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:255, lastHopRssi:-60
[blind] 2022-05-13 15:32:31.423 profileId:0x104, clusterId:0x0, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:240, lastHopRssi:-53
That is what I'm trying to do by starting all over again. When the motor stopped working, the limits somehow because only a short rotation in either direction. So, I sucked it up and decided to reset the whole system and start over... Only now I'm unable to clear the upper and lower limits or even factory refresh the whole unit.
Without the upper and lower limits set, all motors/shades will usually not accept commands from the Zigbee channel, and will accept only local keys controls or RF remote controls.
You can check this video My Budget-Friendly DIY Homekit Solution for Smart Shades - YouTube. I think it is exactly your model :
Thank you.. But it will not erase. I can pair it with one of my other 5 remotes and it will do the same.
The action is not acting like roller motor, its now acting like it has some sort of jog function. I can press up over and over and it will turn once in forward direction over and over again with each up arrow (button) press. Same for down, it just turns once per button press.
I wonder if somehow it got flashed to become function of another type of device, but how is this possible.?
It acts like its stuck in tilt motor configuration instead of lift. But I assure you I never changed that setting.
You can try changing between tilt and lift configuration from the driver. Is there any change?
Then test SetPosition command (any number between 0 and 100). Make sure the debug logs option is turned on and please copy and paste the logs.
Or it is better to wait one more day for the _TZE200_fzo2pocs ZM25TQ Tubular motor specific to be added into the driver. Your device fingerprint was not into the driver, it differs from all other 24 models.
I will ping you when ready, hopefully tomorrow.
Strange, if I hold the up or down button long enough it will start rotating continuously
Like in the original driver description?
