So for the past week I keep having to unplug my hubitat elevation once a day in order to get z-wave to start working again. It works fine for about a day then. Just stops working... all devices..
Any suggestions on where to start troubleshooting this? Clicking on/off shows the event in the logs but no z-wave device can be reached until I do a power cycle (unplug device, then plug back in).
Do you have any power metering devices or multi-sensors? Some of those have been known to be very chatty and overwhelm the zwave radion on the C7, which then causes the symptoms you describe.
Might try unplugging or pulling the batteries on them temporarily to see if it helps.
I was running my zwave net fine until this version for months now. Today after upgrade on C7 I had to unplug and I’m trying to see if it works again…
I did a quick investigation… looks like it was somehow related to my Aeotec Nano Dimmer which I changed yesterday it’s setting to send the full report… now it’s reporting only power (default) and zwave started working again (it seems)
I'd also throw out a couple of things... You're unplugging a lot. This leads to database corruption. You should download your latest backup, do a soft reset and apply the backup you downloaded to your pc. This will ensure a healthy database. Also how does your z-wave table look?
