I'm gonna copy this that I posted over on ST earlier. Hope no one minds:
Hey all,
So, it seems that somewhere along the way, the development for this driver (which I absolutely love) has made full use of, taken advantage of, and has flourished because of some enhancements in the 3.4 firmware. --And as such, those of us still on 3.3 are operating less-than optimally.
SIMPLY STATED: I want to upgrade my firmware. Iām familiar with the process. But the stick thatās required to do it is discontinued, and it looks like itās expensive and rare if you can even find one online. So Iām wondering: since this is a device that you presumably will have to use ONCE for just a few minutes everā¦could we possibly work out a borrow situation, or does someone have one lying around that theyād let go for cheap?
Apparently, Frank Pomeroy has retired, and Intermatic no longer will perform the flash for you (not that I want to ship my whole setup in to them anyway). In my years in such communities as these, Iāve found it common that one person who has āthe thingā (like an almond router that can flash everyoneās peanut plugs to get power consumption readouts in ST, or an intermatic ZWave stick that is the only thing that can flash the firmware on a PE653/953) wants to help other fellow members out. I donāt want to beg or be presumptuous, but it never hurts to ask.
Now that Iāve asked: Iāll elaborate on my issue, for anyone who cares to continue reading: At some point, an update or two back, my internal timers on all but circuit 1 have ceased to operate the system. In my setup, I have a single speed pump on 1, a booster pump for a cleaner on 3, and a light on 4. Nothing else.
I should note that I can control all these 3 channels just fine with the remote, the buttons on the 653, and through the app. No problem. But even though I have schedules set internally in the 653 on all 3 of those circuits, only the pump on 1 will actually switch as scheduled. So, my vacuum wonāt run in the mornings, and my light, which I have a rule set up to turn on every day at sunset, but which I have a 653 schedule set to turn off at 9:30, never turns off.
INTERESTINGLY: I have recently moved my PE653 over to Hubitat, and I was hoping that the fresh start, including a full reset of everything, would inspire the 653 to start working reliably again. IN FACT, after fully resetting and getting everything running right on Hubitat, I set new schedules for all 3 circuits that nightā¦and THEY WORKED THE NEXT DAY! My pump turned on at 7 am (internal timer), my booster turned on at 8 am (internal timer), they both turned off at 11 am (internal timer), my pump turned on at 6 pm (internal timer), my light turned on at sunset (Hubitat), my light turned off at 9:30 (internal timer), and my pump turned off at 10 pm (internal timer). SUCCESS!!!..untilā¦it has never worked again. Itās as if once the internal timers have turned off a timer on 3 and 4, it can never turn it back on again.
āAnd this is exactly the same behavior I have had with both ST and Hubitat (both of which were amazingly developed by our good friend @KeithR ). As I mentioned, Iāve suspected that it has something to do with a bug in 3.3 that doesnāt much care for the way our automation controllers are doing things.
THANKS FOR THE READ, and hopefully someone wants to help a stranded 3.3er off the lonely island.
My next move with my pool is to install a variable speed pump, and I really want to make sure Iām well up to date as I add features.
