Z-Wave Multi Channel (PE653)
In my soon to be never-ending quest to get my pool controls over to Hubitat, my first task is to convert the ST Multichannel Driver over to Hubitat. The purpose of the Driver is to take the single Device discovered on the network (Z-Wave Device) and convert it over to the 10 devices occupied by the pool controls (10 switches).
 *  Copyright 2015 SmartThings
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
metadata {
	definition (name: "Z-Wave Device Multichannel", namespace: "smartthings", author: "SmartThings") {
		capability "Actuator"
		capability "Switch"
		capability "Switch Level"
		capability "Refresh"
		capability "Configuration"
		capability "Sensor"
		capability "Zw Multichannel" // deprecated
		fingerprint inClusters: "0x60"
		fingerprint inClusters: "0x60, 0x25"
		fingerprint inClusters: "0x60, 0x26"
		fingerprint inClusters: "0x5E, 0x59, 0x60, 0x8E"
	simulator {
		status "on":  "command: 2003, payload: FF"
		status "off": "command: 2003, payload: 00"
		reply "8E010101,delay 800,6007": "command: 6008, payload: 4004"
		reply "8505": "command: 8506, payload: 02"
		reply "59034002": "command: 5904, payload: 8102003101000000"
		reply "6007":  "command: 6008, payload: 0002"
		reply "600901": "command: 600A, payload: 10002532"
		reply "600902": "command: 600A, payload: 210031"
	tiles(scale: 2) {
		multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
			tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
				attributeState "on", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#00a0dc", nextState:"turningOff"
				attributeState "off", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
				attributeState "turningOn", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#00a0dc", nextState:"turningOff"
				attributeState "turningOff", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
			tileAttribute ("device.level", key: "SLIDER_CONTROL") {
				attributeState "level", action:"switch level.setLevel"
		childDeviceTiles("endpoints")
		/*standardTile("refresh", "device.switch", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
			state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
def installed() {
	def queryCmds = []
	def delay = 200
	def zwInfo = getZwaveInfo()
	def endpointCount = zwInfo.epc as Integer
	def endpointDescList = zwInfo.ep ?: []
	// This is needed until getZwaveInfo() parses the 'ep' field
	if (endpointCount && !zwInfo.ep && device.hasProperty("rawDescription")) {
		try {
			def matcher = (device.rawDescription =~ /ep:(\[.*?\])/)  // extract 'ep' field
			endpointDescList = util.parseJson(matcher[0][1].replaceAll("'", '"'))
		} catch (Exception e) {
			log.warn "couldn't extract ep from rawDescription"
	if (zwInfo.zw.contains("s")) {
		// device was included securely
		state.sec = true
	if (endpointCount > 1 && endpointDescList.size() == 1) {
		// This means all endpoints are identical
		endpointDescList *= endpointCount
	endpointDescList.eachWithIndex { desc, i ->
		def num = i + 1
		if (desc instanceof String && desc.size() >= 4) {
			// desc is in format "1001 AA,BB,CC" where 1001 is the device class and AA etc are the command classes
			// supported by this endpoint
			def parts = desc.split(' ')
			def deviceClass = parts[0]
			def cmdClasses = parts.size() > 1 ? parts[1].split(',') : []
			def typeName = typeNameForDeviceClass(deviceClass)
			def componentLabel = "${typeName} ${num}"
			log.debug "EP #$num d:$deviceClass, cc:$cmdClasses, t:$typeName"
			if (typeName) {
				try {
					String dni = "${device.deviceNetworkId}-ep${num}"
					addChildDevice(typeName, dni, device.hub.id,
							[completedSetup: true, label: "${device.displayName} ${componentLabel}",
							 isComponent: true, componentName: "ch${num}", componentLabel: "${componentLabel}"])
					// enabledEndpoints << num.toString()
					log.debug "Endpoint $num ($desc) added as $componentLabel"
				} catch (e) {
					log.warn "Failed to add endpoint $num ($desc) as $typeName - $e"
			} else {
				log.debug "Endpoint $num ($desc) ignored"
			def cmds = cmdClasses.collect { cc -> queryCommandForCC(cc) }.findAll()
			if (cmds) {
				queryCmds += encapWithDelay(cmds, num) + ["delay 200"]
	response(queryCmds)
private typeNameForDeviceClass(String deviceClass) {
	def typeName = null
	switch (deviceClass[0..1]) {
		case "10":
		case "31":
			typeName = "Switch Endpoint"
			break
		case "11":
			typeName = "Dimmer Endpoint"
			break
		case "08":
			//typeName = "Thermostat Endpoint"
			//break
		case "21":
			typeName = "Multi Sensor Endpoint"
			break
		case "20":
		case "A1":
			typeName = "Sensor Endpoint"
			break
	return typeName
private queryCommandForCC(cc) {
	switch (cc) {
		case "30":
			return zwave.sensorBinaryV2.sensorBinaryGet(sensorType: 0xFF).format()
		case "71":
			return zwave.notificationV3.notificationSupportedGet().format()
		case "31":
			return zwave.sensorMultilevelV4.sensorMultilevelGet().format()
		case "32":
			return zwave.meterV1.meterGet().format()
		case "8E":
			return zwave.multiChannelAssociationV2.multiChannelAssociationGroupingsGet().format()
		case "85":
			return zwave.associationV2.associationGroupingsGet().format()
		default:
			return null
	def result = null
	if (description.startsWith("Err")) {
	    result = createEvent(descriptionText:description, isStateChange:true)
	} else if (description != "updated") {
		def cmd = zwave.parse(description, [0x20: 1, 0x84: 1, 0x98: 1, 0x56: 1, 0x60: 3])
		if (cmd) {
			result = zwaveEvent(cmd)
	log.debug("'$description' parsed to $result")
	return result
def uninstalled() {
	sendEvent(name: "epEvent", value: "delete all", isStateChange: true, displayed: false, descriptionText: "Delete endpoint devices")
def zwaveEvent(hubitat.zwave.commands.wakeupv1.WakeUpNotification cmd) {
	[ createEvent(descriptionText: "${device.displayName} woke up", isStateChange:true),
	  response(["delay 2000", zwave.wakeUpV1.wakeUpNoMoreInformation().format()]) ]
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd) {
	if (cmd.value == 0) {
		createEvent(name: "switch", value: "off")
	} else if (cmd.value == 255) {
		createEvent(name: "switch", value: "on")
	} else {
		[ createEvent(name: "switch", value: "on"), createEvent(name: "switchLevel", value: cmd.value) ]
private List loadEndpointInfo() {
	if (state.endpointInfo) {
		state.endpointInfo
	} else if (device.currentValue("epInfo")) {
		util.parseJson((device.currentValue("epInfo")))
	} else {
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelEndPointReport cmd) {
	updateDataValue("endpoints", cmd.endPoints.toString())
	if (!state.endpointInfo) {
		state.endpointInfo = loadEndpointInfo()
	if (state.endpointInfo.size() > cmd.endPoints) {
		cmd.endpointInfo
	state.endpointInfo = [null] * cmd.endPoints
	//response(zwave.associationV2.associationGroupingsGet())
	[ createEvent(name: "epInfo", value: util.toJson(state.endpointInfo), displayed: false, descriptionText:""),
	  response(zwave.multiChannelV3.multiChannelCapabilityGet(endPoint: 1)) ]
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCapabilityReport cmd) {
	def result = []
	def cmds = []
	if(!state.endpointInfo) state.endpointInfo = []
	state.endpointInfo[cmd.endPoint - 1] = cmd.format()[6..-1]
	if (cmd.endPoint < getDataValue("endpoints").toInteger()) {
		cmds = zwave.multiChannelV3.multiChannelCapabilityGet(endPoint: cmd.endPoint + 1).format()
	} else {
		log.debug "endpointInfo: ${state.endpointInfo.inspect()}"
	result << createEvent(name: "epInfo", value: util.toJson(state.endpointInfo), displayed: false, descriptionText:"")
	if(cmds) result << response(cmds)
	result
def zwaveEvent(hubitat.zwave.commands.associationv2.AssociationGroupingsReport cmd) {
	state.groups = cmd.supportedGroupings
	if (cmd.supportedGroupings > 1) {
		[response(zwave.associationGrpInfoV1.associationGroupInfoGet(groupingIdentifier:2, listMode:1))]
def zwaveEvent(hubitat.zwave.commands.associationgrpinfov1.AssociationGroupInfoReport cmd) {
	def cmds = []
	/*for (def i = 0; i < cmd.groupCount; i++) {
		def prof = cmd.payload[5 + (i * 7)]
		def num = cmd.payload[3 + (i * 7)]
		if (prof == 0x20 || prof == 0x31 || prof == 0x71) {
			updateDataValue("agi$num", String.format("%02X%02X", *(cmd.payload[(7*i+5)..(7*i+6)])))
			cmds << response(zwave.multiChannelAssociationV2.multiChannelAssociationSet(groupingIdentifier:num, nodeId:zwaveHubNodeId))
	for (def i = 2; i <= state.groups; i++) {
		cmds << response(zwave.multiChannelAssociationV2.multiChannelAssociationSet(groupingIdentifier:i, nodeId:zwaveHubNodeId))
	cmds
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
	def encapsulatedCommand = cmd.encapsulatedCommand([0x32: 3, 0x25: 1, 0x20: 1])
	if (encapsulatedCommand) {
		def formatCmd = ([cmd.commandClass, cmd.command] + cmd.parameter).collect{ String.format("%02X", it) }.join()
		if (state.enabledEndpoints.find { it == cmd.sourceEndPoint }) {
			createEvent(name: "epEvent", value: "$cmd.sourceEndPoint:$formatCmd", isStateChange: true, displayed: false, descriptionText: "(fwd to ep $cmd.sourceEndPoint)")
		def childDevice = getChildDeviceForEndpoint(cmd.sourceEndPoint)
		if (childDevice) {
			log.debug "Got $formatCmd for ${childDevice.name}"
			childDevice.handleEvent(formatCmd)
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
	def encapsulatedCommand = cmd.encapsulatedCommand([0x20: 1, 0x84: 1])
		state.sec = 1
		def result = zwaveEvent(encapsulatedCommand)
		result = result.collect {
			if (it instanceof hubitat.device.HubAction && !it.toString().startsWith("9881")) {
				response(cmd.CMD + "00" + it.toString())
			} else {
				it
		result
def zwaveEvent(hubitat.zwave.commands.crc16encapv1.Crc16Encap cmd) {
	def versions = [0x31: 2, 0x30: 1, 0x84: 1, 0x9C: 1, 0x70: 2]
	// def encapsulatedCommand = cmd.encapsulatedCommand(versions)
	def version = versions[cmd.commandClass as Integer]
	def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
	def encapsulatedCommand = ccObj?.command(cmd.command)?.parse(cmd.data)
def zwaveEvent(hubitat.zwave.Command cmd) {
	createEvent(descriptionText: "$device.displayName: $cmd", isStateChange: true)
def on() {
	commands([zwave.basicV1.basicSet(value: 0xFF), zwave.basicV1.basicGet()])
def off() {
	commands([zwave.basicV1.basicSet(value: 0x00), zwave.basicV1.basicGet()])
def refresh() {
	command(zwave.basicV1.basicGet())
def setLevel(value) {
	commands([zwave.basicV1.basicSet(value: value as Integer), zwave.basicV1.basicGet()], 4000)
def configure() {
	commands([
		zwave.multiChannelV3.multiChannelEndPointGet()
	], 800)
// epCmd is part of the deprecated Zw Multichannel capability
def epCmd(Integer ep, String cmds) {
	def result
	if (cmds) {
		def header = state.sec ? "988100600D00" : "600D00"
		result = cmds.split(",").collect { cmd -> (cmd.startsWith("delay")) ? cmd : String.format("%s%02X%s", header, ep, cmd) }
	result
// enableEpEvents is part of the deprecated Zw Multichannel capability
def enableEpEvents(enabledEndpoints) {
	state.enabledEndpoints = enabledEndpoints.split(",").findAll()*.toInteger()
	null
// sendCommand is called by endpoint child device handlers
def sendCommand(endpointDevice, commands) {
	def result
	if (commands instanceof String) {
		commands = commands.split(',') as List
	def endpoint = deviceEndpointNumber(endpointDevice)
	if (endpoint) {
		log.debug "${endpointDevice.deviceNetworkId} cmd: ${commands}"
		result = commands.collect { cmd ->
			if (cmd.startsWith("delay")) {
				new hubitat.device.HubAction(cmd)
			} else {
				new hubitat.device.HubAction(encap(cmd, endpoint))
		sendHubCommand(result, 0)
private deviceEndpointNumber(device) {
	String dni = device.deviceNetworkId
	if (dni.size() >= 5 && dni[2..3] == "ep") {
		// Old format: 01ep2
		return device.deviceNetworkId[4..-1].toInteger()
	} else if (dni.size() >= 6 && dni[2..4] == "-ep") {
		// New format: 01-ep2
		return device.deviceNetworkId[5..-1].toInteger()
	} else {
		log.warn "deviceEndpointNumber() expected 'XX-epN' format for dni of $device"
private getChildDeviceForEndpoint(Integer endpoint) {
	def children = childDevices
	if (children && endpoint) {
		return children.find{ it.deviceNetworkId.endsWith("ep$endpoint") }
private command(hubitat.zwave.Command cmd) {
	if (state.sec) {
		zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
	} else {
		cmd.format()
private commands(commands, delay=200) {
	delayBetween(commands.collect{ command(it) }, delay)
private encap(cmd, endpoint) {
	if (endpoint) {
		if (cmd instanceof hubitat.zwave.Command) {
			command(zwave.multiChannelV3.multiChannelCmdEncap(destinationEndPoint:endpoint).encapsulate(cmd))
		} else {
			// If command is already formatted, we can't use the multiChannelCmdEncap class
			String.format("%s%02X%s", header, endpoint, cmd)
	} else {
		command(cmd)
private encapWithDelay(commands, endpoint, delay=200) {
	delayBetween(commands.collect{ encap(it, endpoint) }, delay)
When I find replace physical graph out of the code, I receive the following message upon trying to save.
No signature of method: Script1.childDeviceTiles() is applicable for argument types: (java.lang.String) values: [endpoints]
Any ideas?
The ST Composite Device Handler (aka Paraent/Child Device Handler) feature does not yet exist on Hubitat. I faced the same issue with my HubDuino (ST_Anything) code.
So, I broke the Parent Device Handler code into what I call a HubDuino Bridge Driver + a HubDuino Service Manager App. The Srv Mgr app is repsonsible for creating the Child Devices and keeping them up to date. I was able to move most of my code from the original Parent DTH to my Service Manager App without too much trouble,
Take a look at my code at GitHub - DanielOgorchock/ST_Anything: ST_Anything is an Arduino library, sketch, and Device Type that works with your SmartThings ThingShield to create an all-in-one SmartThings device. as an example. Specifically, look in the /HubDuino folder for the Bridge Driver and Service Manager App. I was able to reuse all of my Child Device Handlers as Hubitat Drivers. YMMV…
So... the PE653 setup from ST seems to go a bit differently (but you tell me).
I converted an app called Multi-Channel which takes a Z-Wave device and breaks it apart into child devices. Converting that app was fairly simple.
However, the PE653 app runs into errors when converting when referencing z-wave commands with multichannel.
The code below is attached and the error message is as follows:
 *  Intermatic PE653 Pool Control System
 *  Original Copyright 2014 bigpunk6
 *  Updated 2017 KeithR26
 *  Don't use Cooper Lee's code (vTile_ms, ms_w_vts) he was working on a different implementation than me.
 *  Install my device type then use the Multi-Channel Controll App by SmartThings from the Marketplace under the More section.
metadata {
	definition (name: "Intermatic PE653 Pool Control System", author: "KeithR26", namespace:  "KeithR26") {
		capability "Switch"
		capability "Polling"
		capability "Temperature Measurement"
		capability "Sensor"
        capability "Thermostat"
        attribute "operationMode", "string"
        attribute "firemanTimeout", "string"
        attribute "temperature", "string"
        attribute "temperatureOffsets", "string"
        attribute "poolspaConfig", "string"
        attribute "poolSetpoint", "string"
        attribute "spaSetpoint", "string"
        attribute "poolSpaMode", "string"
        attribute "pumpSpeed", "string"
        attribute "lightColor", "string"
        attribute "lightCircuits", "string"
		attribute "ccVersions", "string"
		attribute "VersionInfo", "string"
		attribute "ManufacturerInfo", "string"
		attribute "groups", "string"
		attribute "debugLevel", "string"
		attribute "switch1", "string"
		attribute "switch2", "string"
		attribute "switch3", "string"
		attribute "switch4", "string"
		attribute "switch5", "string"
		attribute "swVSP1", "string"
		attribute "swVSP2", "string"
		attribute "swVSP3", "string"
		attribute "swVSP4", "string"
        command "quickSetPool"
        command "quickSetSpa"
		command "quickGetWaterTemp"
		command "setPoolMode"
		command "setSpaMode"
		command "togglePoolSpaMode"
		command "onMulti"
		command "offMulti"
        command "on1"
		command "off1"
        command "on2"
		command "off2"
        command "on3"
		command "off3"
        command "on4"
		command "off4"
        command "on5"
		command "off5"
		command "setVSPSpeed"
		command "setVSPSpeed0"
		command "setVSPSpeed1"
		command "setVSPSpeed2"
		command "setVSPSpeed3"
		command "setVSPSpeed4"
        command "setMode1"
        command "setMode2"
        command "setMode3"
        command "setMode4"
        command "setLightColor"
        command "setColor"
//		command "epCmd"
//		command "enableEpEvents"
		fingerprint deviceId: "0x1001", inClusters: "0x91,0x73,0x72,0x86,0x81,0x60,0x70,0x85,0x25,0x27,0x43,0x31", outClusters: "0x82"
    preferences {
        input "operationMode1", "enum", title: "Boster/Cleaner Pump",
            options:[1:"No",
                     2:"Uses Circuit-1",
                     3:"Variable Speed pump Speed-1",
                     4:"Variable Speed pump Speed-2",
                     5:"Variable Speed pump Speed-3",
                     6:"Variable Speed pump Speed-4"]
        input "operationMode2", "enum", title: "Pump Type",
            options:[0:"1 Speed Pump without Booster/Cleaner",
                     1:"1 Speed Pump with Booster/Cleaner",
                     2:"2 Speed Pump without Booster/Cleaner",
                     3:"2 Speed Pump with Booster/Cleaner",
                     4:"Variable Speed Pump without Booster/Cleaner",
                     5:"Variable Speed Pump with Booster/Cleaner",
                     6:"Reserved 6",
                     7:"Reserved 7"]
        input "poolSpa1", "enum", title: "Pool or Spa",
        	options:[0:"Pool",
            		 1:"Spa",
                     2:"Both"]
	    input "fireman", "enum", title: "Fireman Timeout",
            options:["255":"No heater installed",
                     "0":"No cool down period",
                     "1":"1 minute",
                     "2":"2 minute",
                     "3":"3 minute",
                     "4":"4 minute",
                     "5":"5 minute",
                     "6":"6 minute",
                     "7":"7 minute",
                     "8":"8 minute",
                     "9":"9 minute",
                     "10":"10 minute",
                     "11":"11 minute",
                     "12":"12 minute",
                     "13":"13 minute",
                     "14":"14 minute",
                     "15":"15 minute"]
        input "tempOffsetwater", "number", title: "Water temperature offset", defaultValue: 0, required: true
        input "tempOffsetair", "number",
            title: "Air temperature offset - Sets the Offset of the air temerature for the add-on Thermometer in degrees Fahrenheit -20F to +20F", defaultValue: 0, required: true
        input "debugLevel", "enum", title: "Debug Level", multiple: "true",
        	options:[0:"Off",
            		 1:"Low",
                     2:"High"], defaultvalue: 0
        input "ZWdelay", "number",
            title: "Delay between Z-Wave commands sent (milliseconds). Suggest 1000.", defaultValue: 1000, required: true
//        input "M1On", "enum", title: "M1: Turn these circuits On:", multiple: "true",
//        	options:[1:"Sw1",
//            		 2:"Sw2",
//            		 3:"Sw3",
//            		 4:"Sw4",
//                   5:"Sw5"], defaultValue: 0
//Mode 1
        input "M1Label", "text", title: "M1: Display Name:", defaultValue: ""
        input "M1Sw1", "enum", title: "M1: Circuit 1 action:", defaultValue: 0,
        	options:[0:"No Change",
            		 1:"On",
            		 2:"Off"]
        input "M1Sw2", "enum", title: "M1: Circuit 2 action:", defaultValue: 0,
            		 1:"On",
            		 2:"Off"]
        input "M1Sw3", "enum", title: "M1: Circuit 3 action:", defaultValue: 0,
            		 1:"On",
            		 2:"Off"]
        input "M1Sw4", "enum", title: "M1: Circuit 4 action:", defaultValue: 0,
            		 1:"On",
            		 2:"Off"]
        input "M1Sw5", "enum", title: "M1: Circuit 5 action:", defaultValue: 0,
            		 1:"On",
            		 2:"Off"]
        input "M1Mode", "enum", title: "M1: Mode to change to:", defaultValue: 0,
        	options:[0:"No change",
            		 1:"Pool",
                     2:"Pool & Set Temperature",
            		 3:"Spa",
                     4:"Spa & Set Temperature"]
        input "M1Temp", "number", title: "M1: Set Temperature to:", range: "40..104", defaultValue: 40
        input "M1VSP", "enum", title: "M1: Set VSP Speed to:", defaultValue: 0,
        	options:[5:"No change",
            		 1:"Speed 1",
            		 2:"Speed 2",
            		 3:"Speed 3",
                     4:"Speed 4",
                     0:"Turn off"]
//Mode 2
        input "M2Label", "text", title: "M2: Display Name:", defaultValue: ""
		input "M2Sw1", "enum", title: "M2: Circuit 1 action:", defaultValue: 0,
            		 1:"On",
            		 2:"Off"]
        input "M2Sw2", "enum", title: "M2: Circuit 2 action:", defaultValue: 0,
            		 1:"On",
            		 2:"Off"]
        input "M2Sw3", "enum", title: "M2: Circuit 3 action:", defaultValue: 0,
            		 1:"On",
            		 2:"Off"]
        input "M2Sw4", "enum", title: "M2: Circuit 4 action:", defaultValue: 0,
            		 1:"On",
            		 2:"Off"]
        input "M2Sw5", "enum", title: "M2: Circuit 5 action:", defaultValue: 0,
            		 1:"On",
            		 2:"Off"]
        input "M2Mode", "enum", title: "M2: Mode to change to:", defaultValue: 0,
            		 1:"Pool",
            		 3:"Spa",
        input "M2Temp", "number", title: "M2: Set Temperature to:", range: "40..104", defaultValue: 40
        input "M2VSP", "enum", title: "M2: Set VSP Speed to:", defaultValue: 0,
            		 1:"Speed 1",
            		 2:"Speed 2",
            		 3:"Speed 3",
                     4:"Speed 4",
                     0:"Turn off"]
//Mode 3
        input "M3Label", "text", title: "M3: Display Name:", defaultValue: ""
        input "M3Sw1", "enum", title: "M3: Circuit 1 action:", defaultValue: 0,
            		 1:"On",
            		 2:"Off"]
        input "M3Sw2", "enum", title: "M3: Circuit 2 action:", defaultValue: 0,
            		 1:"On",
            		 2:"Off"]
        input "M3Sw3", "enum", title: "M3: Circuit 3 action:", defaultValue: 0,
            		 1:"On",
            		 2:"Off"]
        input "M3Sw4", "enum", title: "M3: Circuit 4 action:", defaultValue: 0,
            		 1:"On",
            		 2:"Off"]
        input "M3Sw5", "enum", title: "M3: Circuit 5 action:", defaultValue: 0,
            		 1:"On",
            		 2:"Off"]
        input "M3Mode", "enum", title: "M3: Mode to change to:", defaultValue: 0,
            		 1:"Pool",
            		 3:"Spa",
        input "M3Temp", "number", title: "M3: Set Temperature to:", range: "40..104", defaultValue: 40
        input "M3VSP", "enum", title: "M3: Set VSP Speed to:", defaultValue: 0,
            		 1:"Speed 1",
            		 2:"Speed 2",
            		 3:"Speed 3",
                     4:"Speed 4",
                     0:"Turn off"]
//Mode 4
        input "M4Label", "text", title: "M4: Display Name:", defaultValue: ""
        input "M4Sw1", "enum", title: "M4: Circuit 1 action:", defaultValue: 0,
            		 1:"On",
            		 2:"Off"]
        input "M4Sw2", "enum", title: "M4: Circuit 2 action:", defaultValue: 0,
            		 1:"On",
            		 2:"Off"]
        input "M4Sw3", "enum", title: "M4: Circuit 3 action:", defaultValue: 0,
            		 1:"On",
            		 2:"Off"]
        input "M4Sw4", "enum", title: "M4: Circuit 4 action:", defaultValue: 0,
            		 1:"On",
            		 2:"Off"]
        input "M4Sw5", "enum", title: "M4: Circuit 5 action:", defaultValue: 0,
            		 1:"On",
            		 2:"Off"]
        input "M4Mode", "enum", title: "M4: Mode to change to:", defaultValue: 0,
            		 1:"Pool",
            		 3:"Spa",
        input "M4Temp", "number", title: "M4: Set Temperature to:", range: "40..104", defaultValue: 40
        input "M4VSP", "enum", title: "M4: Set VSP Speed to:", defaultValue: 0,
            		 1:"Speed 1",
            		 2:"Speed 2",
            		 3:"Speed 3",
                     4:"Speed 4",
                     0:"Turn off"]
        input "C1ColorEnabled", "enum", title: "Circuit 1 Color Light Enable:", defaultValue: 0,
        	options:[0:"off",
            		 1:"On"]
        input "C2ColorEnabled", "enum", title: "Circuit 2 Color Light Enable:", defaultValue: 0,
        	options:[0:"off",
            		 1:"On"]
        input "C3ColorEnabled", "enum", title: "Circuit 3 Color Light Enable:", defaultValue: 0,
        	options:[0:"off",
            		 1:"On"]
        input "C4ColorEnabled", "enum", title: "Circuit 4 Color Light Enable:", defaultValue: 0,
        	options:[0:"off",
            		 1:"On"]
        input "C5ColorEnabled", "enum", title: "Circuit 5 Color Light Enable:", defaultValue: 0,
        	options:[0:"off",
            		 1:"On"]
	simulator {
	// tile definitions
	tiles(scale: 2) {
		standardTile("mainTile", "device.poolSpaMode", width: 1, height: 1, canChangeIcon: true, canChangeBackground: true) {
			state "spa",        label: "spa",        action: "setPoolMode", icon: "st.Health & Wellness.health2",  backgroundColor: "#79b821", nextState: "turningOff"
			state "pool",       label: "pool",       action: "setSpaMode",  icon: "st.Health & Wellness.health2", backgroundColor: "#ffffff", nextState: "turningOn"
			state "turningOn",  label:'Turning on',  action: "pool",        icon: "st.Health & Wellness.health2",  backgroundColor: "#79b821", nextState: "turningOff"
			state "turningOff", label:'Turning off', action: "spa",         icon: "st.Health & Wellness.health2", backgroundColor: "#ffffff", nextState: "turningOn"
			state "disabled",   label:'',            icon: "st.Health & Wellness.health2", backgroundColor: "#bc2323"  //"#ffffff"
		valueTile("temperatureTile", "device.temperature", width: 2, height: 2, inactiveLabel: true, decoration: "flat" ) {
			state "temperature", label:'${currentValue}°', action: "quickGetWaterTemp",
					backgroundColors:[
						[value: 32, color: "#153591"],
					    [value: 54, color: "#1e9cbb"],
				    	[value: 64, color: "#90d2a7"],
				    	[value: 74, color: "#44b621"],
				    	[value: 90, color: "#f1d801"],
				    	[value: 98, color: "#d04e00"],
				    	[value: 110, color: "#bc2323"]
        controlTile("poolSliderControl", "device.poolSetpoint", "slider", width: 4, height: 1, inactiveLabel: false, range:"(40..104)") {
			state "PoolSetpoint", action:"quickSetPool", backgroundColor:"#d04e00"
		valueTile("poolSetpoint", "device.poolSetpoint", width: 2, height: 1, inactiveLabel: false, decoration: "flat") {
			state "pool", label:'pool ${currentValue}°', backgroundColor:"#ffffff"
		controlTile("spaSliderControl", "device.spaSetpoint", "slider", width: 4, height: 1, inactiveLabel: false, range:"(40..104)") {
			state "SpaSetpoint", action:"quickSetSpa", backgroundColor: "#1e9cbb"
		valueTile("spaSetpoint", "device.spaSetpoint", width: 2, height: 1, inactiveLabel: false, decoration: "flat") {
			state "spa", label:'spa  ${currentValue}°', backgroundColor:"#ffffff"
        controlTile("pumpSpeedSliderControl", "device.pumpSpeed", "slider", width: 4, height: 1, inactiveLabel: false, range:"(0..4)") {
			state "pumpSpeed", action:"setVSPSpeed", backgroundColor:"#d04e00"
		valueTile("pumpSpeed", "device.pumpSpeed", width: 2, height: 1, inactiveLabel: false, decoration: "flat") {
			state "pumpSpeed", label:'speed ${currentValue}', backgroundColor:"#ffffff"
        controlTile("lightColorSliderControl", "device.lightColor", "slider", width: 4, height: 1, inactiveLabel: false, range:"(1..14)") {
			state "color", action:"setLightColor", backgroundColor:"#d04e00"
//		valueTile("temperatureTile", "device.temperature", width: 2, height: 2, inactiveLabel: true) {
		valueTile("lightColor", "device.lightColor", width: 2, height: 1, inactiveLabel: true, decoration: "flat") {
			state "color", action:"setColor", label:'color ${currentValue}', backgroundColor:"#ffffff"
//		standardTile("lightColor", "device.lightColor", width: 2, height: 1, inactiveLabel: false, decoration: "flat") {
//			state "color", action:"setColor", label:'color ${currentValue}', backgroundColor:"#ffffff", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/Pool.png"
		standardTile("poolSpaMode", "device.poolSpaMode", width: 2, height: 2, decoration: "flat") {
			state "spa",        label: "",           action: "setPoolMode", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/spa.png",  backgroundColor: "#79b821", nextState: "turningOff"
			state "pool",       label: "",           action: "setSpaMode",  icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/Pool.png", backgroundColor: "#ffffff", nextState: "turningOn"
			state "turningOn",  label: 'changing',   action: "pool",        icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/spa.png",  backgroundColor: "#79b821", nextState: "turningOff"
			state "turningOff", label: 'changing',   action: "spa",         icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/Pool.png", backgroundColor: "#ffffff", nextState: "turningOn"
			state "disabled",   label:'',            icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/all-white.png", backgroundColor: "#ffffff"
		standardTile("switch1", "device.switch1", width: 1, height: 1, decoration: "flat") {
			state "on",         label: "on",         action: "off1", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/sw1-on.png",  backgroundColor: "#79b821", nextState: "turningOff"
			state "off",        label: "off",        action: "on1",  icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/sw1-off.png", backgroundColor: "#ffffff", nextState: "turningOn"
			state "turningOn",  label:'Turning on',  action: "off1", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/sw1-on.png",  backgroundColor: "#79b821", nextState: "turningOff"
			state "turningOff", label:'Turning off', action: "on1",  icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/sw1-off.png", backgroundColor: "#ffffff", nextState: "turningOn"
        standardTile("switch2", "device.switch2", width: 1, height: 1, decoration: "flat") {
			state "on",         label: "on",         action: "off2", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/sw2-on.png",  backgroundColor: "#79b821", nextState: "turningOff"
			state "off",        label: "off",        action: "on2",  icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/sw2-off.png", backgroundColor: "#ffffff", nextState: "turningOn"
			state "turningOn",  label:'Turning on',  action: "off2", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/sw2-on.png",  backgroundColor: "#79b821", nextState: "turningOff"
			state "turningOff", label:'Turning off', action: "on2",  icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/sw2-off.png", backgroundColor: "#ffffff", nextState: "turningOn"
        standardTile("switch3", "device.switch3", width: 1, height: 1, decoration: "flat") {
			state "on",         label: "on",         action: "off3", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/sw3-on.png",  backgroundColor: "#79b821", nextState: "turningOff"
			state "off",        label: "off",        action: "on3",  icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/sw3-off.png", backgroundColor: "#ffffff", nextState: "turningOn"
			state "turningOn",  label:'Turning on',  action: "off3", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/sw3-on.png",  backgroundColor: "#79b821", nextState: "turningOff"
			state "turningOff", label:'Turning off', action: "on3",  icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/sw3-off.png", backgroundColor: "#ffffff", nextState: "turningOn"
        standardTile("switch4", "device.switch4", width: 1, height: 1, decoration: "flat") {
			state "on",         label: "on",         action: "off4", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/sw4-on.png",  backgroundColor: "#79b821", nextState: "turningOff"
			state "off",        label: "off",        action: "on4",  icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/sw4-off.png", backgroundColor: "#ffffff", nextState: "turningOn"
			state "turningOn",  label:'Turning on',  action: "off4", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/sw4-on.png",  backgroundColor: "#79b821", nextState: "turningOff"
			state "turningOff", label:'Turning off', action: "on4",  icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/sw4-off.png", backgroundColor: "#ffffff", nextState: "turningOn"
        standardTile("switch5", "device.switch5", width: 1, height: 1, decoration: "flat") {
			state "on",         label: "on",         action: "off5", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/sw5-on.png",  backgroundColor: "#79b821", nextState: "turningOff"
			state "off",        label: "off",        action: "on5",  icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/sw5-off.png", backgroundColor: "#ffffff", nextState: "turningOn"
			state "turningOn",  label:'Turning on',  action: "off5", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/sw5-on.png",  backgroundColor: "#79b821", nextState: "turningOff"
			state "turningOff", label:'Turning off', action: "on5",  icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/sw5-off.png", backgroundColor: "#ffffff", nextState: "turningOn"
        standardTile("swVSP1", "device.swVSP1", width: 1, height: 1, decoration: "flat") {
			state "off",        label: "off",        action: "setVSPSpeed1", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/vsp1-off.png", backgroundColor: "#ffffff", nextState: "turningOn"
			state "on",         label: "on",         action: "setVSPSpeed0", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/vsp1-on.png",  backgroundColor: "#79b821", nextState: "turningOff"
			state "turningOn",  label:'Turning on',  action: "setVSPSpeed0", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/vsp1-on.png",  backgroundColor: "#79b821", nextState: "turningOff"
			state "turningOff", label:'Turning off', action: "setVSPSpeed1", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/vsp1-off.png", backgroundColor: "#ffffff", nextState: "turningOn"
			state "disabled",   label:'',                                    icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/all-white.png",backgroundColor: "#ffffff"
        standardTile("swVSP2", "device.swVSP2", width: 1, height: 1, decoration: "flat") {
			state "off",        label: "off",        action: "setVSPSpeed2", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/vsp2-off.png", backgroundColor: "#ffffff", nextState: "turningOn"
			state "on",         label: "on",         action: "setVSPSpeed0", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/vsp2-on.png",  backgroundColor: "#79b821", nextState: "turningOff"
			state "turningOn",  label:'Turning on',  action: "setVSPSpeed0", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/vsp2-on.png",  backgroundColor: "#79b821", nextState: "turningOff"
			state "turningOff", label:'Turning off', action: "setVSPSpeed2", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/vsp2-off.png", backgroundColor: "#ffffff", nextState: "turningOn"
        standardTile("swVSP3", "device.swVSP3", width: 1, height: 1, decoration: "flat") {
			state "off",        label: "off",        action: "setVSPSpeed3", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/vsp3-off.png", backgroundColor: "#ffffff", nextState: "turningOn"
			state "on",         label: "on",         action: "setVSPSpeed0", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/vsp3-on.png",  backgroundColor: "#79b821", nextState: "turningOff"
			state "turningOn",  label:'Turning on',  action: "setVSPSpeed0", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/vsp3-on.png",  backgroundColor: "#79b821", nextState: "turningOff"
			state "turningOff", label:'Turning off', action: "setVSPSpeed3", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/vsp3-off.png", backgroundColor: "#ffffff", nextState: "turningOn"
        standardTile("swVSP4", "device.swVSP4", width: 1, height: 1, decoration: "flat") {
			state "off",        label: "off",        action: "setVSPSpeed4", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/vsp4-off.png", backgroundColor: "#ffffff", nextState: "turningOn"
			state "on",         label: "on",         action: "setVSPSpeed0", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/vsp4-on.png",  backgroundColor: "#79b821", nextState: "turningOff"
			state "turningOn",  label:'Turning on',  action: "setVSPSpeed0", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/vsp4-on.png",  backgroundColor: "#79b821", nextState: "turningOff"
			state "turningOff", label:'Turning off', action: "setVSPSpeed4", icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/vsp4-off.png", backgroundColor: "#ffffff", nextState: "turningOn"
        standardTile("swM1", "device.swM1", width: 1, height: 1, decoration: "flat") {
			state "disabled",   label:'',            action: "setMode1",     icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/M1-off.png",backgroundColor: "#ffffff", nextState: "disabled"
        standardTile("swM2", "device.swM2", width: 1, height: 1, decoration: "flat") {
			state "disabled",   label:'',            action: "setMode2",     icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/M2-off.png",backgroundColor: "#ffffff", nextState: "disabled"
        standardTile("swM3", "device.swM3", width: 1, height: 1, decoration: "flat") {
			state "disabled",   label:'',            action: "setMode3",     icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/M3-off.png",backgroundColor: "#ffffff", nextState: "disabled"
        standardTile("swM4", "device.swM4", width: 1, height: 1, decoration: "flat") {
			state "disabled",   label:'',            action: "setMode4",     icon: "https://raw.githubusercontent.com/KeithR26/Intermatic-PE653/master/M4-off.png", backgroundColor:"#ffffff", nextState: "disabled"
		valueTile("M1Name", "device.M1Name", width: 2, height: 1, inactiveLabel: false, decoration: "flat") {
			state "M1Name", label:'${currentValue}', backgroundColor:"#ffffff", action: "setMode1"
		valueTile("M2Name", "device.M2Name", width: 2, height: 1, inactiveLabel: false, decoration: "flat") {
			state "M2Name", label:'${currentValue}', backgroundColor:"#ffffff", action: "setMode2"
		valueTile("M3Name", "device.M3Name", width: 2, height: 1, inactiveLabel: false, decoration: "flat") {
			state "M3Name", label:'${currentValue}', backgroundColor:"#ffffff", action: "setMode3"
		valueTile("M4Name", "device.M4Name", width: 2, height: 1, inactiveLabel: false, decoration: "flat") {
			state "M4Name", label:'${currentValue}', backgroundColor:"#ffffff", action: "setMode4"
        standardTile("blank1", "device.blank", width: 1, height: 1, decoration: "flat") {
			state "on",         icon: "st.Health & Wellness.health2",  backgroundColor: "#ffffff"
        standardTile("configure", "device.configure", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
			state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
        standardTile("blank2", "device.blank", width: 2, height: 2, decoration: "flat") {
			state "on",         label: "", icon: "st.Health & Wellness.health2",  backgroundColor: "#ffffff"
	main "mainTile"
        details([
            "blank1",
            "switch1","switch2","switch3","switch4","switch5",
            "poolSpaMode",
        	"temperatureTile",
            "swVSP1","swVSP2","swVSP3","swVSP4",
            "swM1", "M1Name", "swM2", "M2Name", "swM3", "M3Name", "swM4", "M4Name",
			"poolSliderControl", "poolSetpoint", "spaSliderControl", "spaSetpoint",
//            "pumpSpeedSliderControl", "pumpSpeed",
            "configure","refresh", "blank2",
            "lightColorSliderControl","lightColor"])
//	Version History
//	Ver		Date		Author		Changes
//	1.00	06/15/2016	bigpunk6	Latest version from the original author
//	2.00	07/14/2016	KeithR26	Updates to make this work with Intermatic firmware v3.4
//									Added Pool/Spa mode and initial VSP support
//	2.01	08/10/2016	KeithR26	Major UI redesign
//									Added 4 switches to set VSP speeds and off
//									Added 4 "Multi-channel" endpoints for ST VSP control
//									Added configurable Z-Wave delay
//									Added PE653 configuration diagnostics in Debug level = High
//									Added Version Info in IDE and logs
//									Allow changing icon
//	2.02	04/26/2017	KeithR26	Fix Thermostat set for v3.4 firmware (force scale = 0)
//  								Prototype Pool Light Color Control
//									Implement simple "Macros"
//	2.03	05/01/2017	KeithR26	Refresh water temp when UI temp is tapped
// Constants for PE653 configuration parameter locations
def getDELAY () {ZWdelay}								// How long to delay between commands to device (configured)
def getMIN_DELAY () {"800"}								// Minimum delay between commands to device (configured)
def getVERSION () {"Ver 2.03"}							// Keep track of handler version
def getPOOL_SPA_SCHED_PARAM () { 21 }					// Pool/Spa mode Schedule #3 - 0x15
def getVSP_SCHED_NO (int spd) { (35 + (spd * 3)) }		// VSP Speed 1 Schedule #3 - 0x26
def getVSP_SPEED (int sched) { ((sched - 35) / 3) }		// Convert from sched to speed
def getVSP_ENABLED () { (operationMode2 >= "4") ? 1 : 0 }	// True if a Variable Speed Pump Configured
def getPOOL_SPA_COMBO () { (poolSpa1 == "2") ? 1 : 0 }	// True if both Pool and Spa
def getSWITCH_NAME (int instance) {
	def swNames = ["switch1","switch2","switch3","switch4","switch5","poolSpaMode","swVSP1","swVSP2","swVSP3","swVSP4"]
    return swNames[instance - 1]
// Return the list supported command classes by PE653. The following are the versions for firmware v3.4
// ccVersions: {"20":1,"25":1,"27":1,"31":1,"43":1,"60":2,"70":1,"72":1,"73":1,"81":1,"85":1,"86":1,"91":1}
def getSupportedCmdClasses () {[
	0x20,	//	Basic
	0x25,	//	Switch Binary
	0x27,	//	Switch All
	0x31,	//	Sensor Multilevel
	0x43,	//	Thermostat setpoint
	0x60,	//	Multi Instance
	0x70,	//	Configuration
	0x72,	//	Manufacturer Specific
	0x73,	//	Powerlevel
	0x81,	//	Clock
	0x85,	//	Association
	0x86,	//	Version
	0x91	//	Manufacturer Proprietary
// Main entry point for messages from the device
	def result = null
        log.warn "Error in Parse"
	} else {
//		def cmd = zwave.parse(description, [0x20: 1, 0x25:1, 0x27:1, 0x31:1, 0x43:1, 0x60:3, 0x70:2, 0x81:1, 0x85:1, 0x86: 1, 0x73:1])
		def cmd = zwave.parse(description, [0x20: 1, 0x25:1, 0x27:1, 0x31:1, 0x43:1, 0x60:3, 0x70:2, 0x81:1, 0x85:2, 0x86: 1, 0x73:1])
		if (debugLevel > "0") {
			log.debug(">>>>> ${cmd} - description:$description ")
		if (cmd) {
        } else {
			log.debug("----- Parse() parsed to NULL:  description:$description")
	delayResponseLog(result)
private List setPoolSetpointInternal(Double degrees) {
	log.debug "setPoolSetpointInternal degrees=${degrees}"
    def cmds = []
	def deviceScale = state.scale ?: 1
	def deviceScaleString = deviceScale == 2 ? "C" : "F"
    def locationScale = getTemperatureScale()
	def p = (state.precision == null) ? 1 : state.precision
    def convertedDegrees
    if (locationScale == "C" && deviceScaleString == "F") {
    	convertedDegrees = celsiusToFahrenheit(degrees)
    } else if (locationScale == "F" && deviceScaleString == "C") {
    	convertedDegrees = fahrenheitToCelsius(degrees)
    } else {
    	convertedDegrees = degrees
    deviceScale = 0			// Cannot send scale = 1 to PE653 or it will ignore the request
//    log.trace "setPoolSetpoint: setpointType: 1  scale: $deviceScale  precision: $p  scaledValue: $convertedDegrees"
	cmds << zwave.thermostatSetpointV1.thermostatSetpointSet(setpointType: 1, scale: deviceScale, precision: p, scaledValue: convertedDegrees)
	cmds << zwave.thermostatSetpointV1.thermostatSetpointGet(setpointType: 1)
//    cmds
private List setSpaSetpointInternal(Double degrees) {
    log.debug "setSpaSetpointInternal degrees=${degrees}"
    def cmds = []
    } else {
    deviceScale = 0			// Cannot send scale = 1 to PE653 ver 3.4 or it will ignore the request
//    log.trace "setSpaSetpoint: setpointType: 7  scale: $deviceScale  precision: $p  scaledValue: $convertedDegrees"
	cmds << zwave.thermostatSetpointV1.thermostatSetpointSet(setpointType: 7, scale: deviceScale, precision: p,  scaledValue: convertedDegrees)
	cmds << zwave.thermostatSetpointV1.thermostatSetpointGet(setpointType: 7)
//    cmds
// Ask the controller for the water temperature
private List getWaterTemp() {
    log.debug "getWaterTemp()"
    [zwave.sensorMultilevelV1.sensorMultilevelGet()]
//Reports
def zwaveEvent(hubitat.zwave.commands.versionv1.VersionReport cmd) {
	state.VersionInfo = "Versions: Firmware v${cmd.applicationVersion}.${cmd.applicationSubVersion}   DTH: ${VERSION}   zWaveLibraryType: ${cmd.zWaveLibraryType}    zWaveProtocol: v${cmd.zWaveProtocolVersion}.${cmd.zWaveProtocolSubVersion}"
	createEvent(name: "VersionInfo", value: state.VersionInfo, displayed: false, descriptionText: state.VersionInfo)
def zwaveEvent(hubitat.zwave.commands.versionv1.VersionCommandClassReport cmd) {
	if (cmd.commandClassVersion) {
    	def cls = String.format("%02X", cmd.requestedCommandClass)
        state.ccVersions[cls] = cmd.commandClassVersion
		createEvent(name: "ccVersions", value: util.toJson(state.ccVersions), displayed: false, descriptionText:"")
	} else {
def zwaveEvent(hubitat.zwave.commands.thermostatsetpointv1.ThermostatSetpointSupportedReport cmd) {
//	log.debug "thermostatSetpointSupportedReport !!!"
	def cmds = []
    state.cnfSendParmOne = 1		// Resend the request for "Guarenteed response"
    state.cnfParallelGets = 0		// Reset for unresponsive parm numbers
    if (debugLevel > "1") {
        cmds.addAll(nextConfig())
	cmds
// ManufacturerSpecificReport(manufacturerId: 5, manufacturerName: Intermatic, productId: 1619, productTypeId: 20549)
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv1.ManufacturerSpecificReport cmd) {
	log.debug "ManufacturerSpecificReport !!!"
	state.ManufacturerInfo = "ManufacturerInfo:  manufacturerId: $manufacturerId, manufacturerName: $manufacturerName, productId: $productId, productTypeId: $productTypeId"
	createEvent(name: "ManufacturerInfo", value: state.ManufacturerInfo, displayed: true, descriptionText: state.ManufacturerInfo)
def zwaveEvent(hubitat.zwave.commands.configurationv2.ConfigurationReport cmd) {
    def map = [:]
	def cmds = []
    def myValue = ""
    def externalValue = ""
    def paramNum = cmd.parameterNumber
	map.value = cmd.configurationValue[0]
    map.name = ""
	map.displayed = true
    switch (paramNum) {
        case 1:
			map.name = "operationMode"
			cmds << createEvent(map)
			break;
        case 2:
			map.name = "firemanTimeout"
			break;
        case 3:
			map.name = "temperatureOffsets"
			break;
		case POOL_SPA_SCHED_PARAM:
			def instance = 6
			if ((cmd.size != 4) || (cmd.configurationValue[0] != 0xFF) || (cmd.configurationValue[1] != 0xFF) || (cmd.configurationValue[2] != 0xFF) || (cmd.configurationValue[3] != 0xFF)) {
            	myValue = "spa"
                externalValue = 0xFF
            } else {
            	myValue = "pool"
                externalValue = 0x00
			cmds.addAll(createMultipleEvents (instance, 0x25, 0x03, externalValue, myValue))
			break;
		case getVSP_SCHED_NO(1):
		case getVSP_SCHED_NO(2):
		case getVSP_SCHED_NO(3):
		case getVSP_SCHED_NO(4):
            def int instance = getVSP_SPEED(paramNum) + 6
                state.pumpSpeed = getVSP_SPEED(paramNum).toString()
                map.value = state.pumpSpeed.toInteger()
				map.name = "pumpSpeed"
            	myValue = "on"
			} else {
            	if (paramNum == getVSP_SCHED_NO(4)) {
            	myValue = "off"
                externalValue = 0
			break;
//		log.trace " map:$map map.name.length():${map.name.length()}"
        def lst = [cmd.size]
	    state.cnfAttemptsLeft[paramNum] = 0
		state.cnfParallelGets = state.cnfParallelGets - 1
        for (def i=0;i<cmd.size;i++) {
            lst << cmd.configurationValue[i]
        state.cnfData[paramNum] = lst
	cmds
// Display the previous and current configuration data and the differences
private List compareConfig() {
//	log.trace "cnfData1:${state.cnfData}"
//	log.trace "cnfData2:${state.cnfData2}"
    def dif1 = state.cnfData - state.cnfData2
    def dif2 = state.cnfData2 - state.cnfData
	log.trace "dif1:$dif1"
	log.trace "dif2:$dif2"
// Save any previous configuration data, then initiializes and initiates a fresh set of queries
private List startConfig() {
	if (state.cnfData) {
		state.cnfData2 = state.cnfData
    } else {
		state.cnfData2 = [:]
	state.cnfData = [:]
    state.cnfAttemptsLeft = []
    state.cnfGetGoal = 10
	def cmds = []
    for (def i=0;i<=75;i++) {
    	state.cnfAttemptsLeft[i] = 3
	state.cnfAttemptsLeft[0] = 2
	nextConfig()
// Prepare the next batch of configuration queries
private List nextConfig() {
	def cmds = []
	while ((state.cnfGetGoal > 0) && (state.cnfParallelGets < state.cnfGetGoal)) {
        def nextInx = -1
	    def maxAttemptsLeft = 0
        state.cnfAttemptsLeft.eachWithIndex {itm, i ->
            if (i > 1 && itm > maxAttemptsLeft) {
                nextInx = i
                maxAttemptsLeft = itm
		if (nextInx >= 0) {
            state.cnfParallelGets = state.cnfParallelGets + 1
			state.cnfAttemptsLeft[nextInx] = state.cnfAttemptsLeft[nextInx] - 1
//			log.debug "nextConfig() nextInx:$nextInx  maxAttemptsLeft:$maxAttemptsLeft cnfParallelGets:${state.cnfParallelGets}"
            cmds << zwave.configurationV2.configurationGet(parameterNumber: nextInx)
        } else {
            state.cnfGetGoal = 0
	        state.cnfSendParmOne = 0
            log.trace "Config Get Complete: cnfData:${state.cnfData}"
            compareConfig()
	if (state.cnfSendParmOne == 1) {
	    cmds << zwave.thermostatSetpointV1.thermostatSetpointSupportedGet()
	if (state.cnfGetGoal) {
//		runIn(5, timerConfig)
	cmds
// Called from runIn timer
def List timerConfig() {
	delayResponseLog(restartConfig())
// Push out the next batch of configuration queries
private List restartConfig() {
	nextConfig()
def zwaveEvent(hubitat.zwave.commands.sensormultilevelv1.SensorMultilevelReport cmd) {
    def map = [:]
    map.value = cmd.scaledSensorValue.toString()
    map.unit = cmd.scale == 1 ? "F" : "C"
    map.name = "temperature"
    createEvent(map)
def zwaveEvent(hubitat.zwave.commands.thermostatsetpointv1.ThermostatSetpointReport cmd) {
	def map = [:]
	map.value = cmd.scaledValue.toString()
	switch (cmd.setpointType) {
		case 1:
			map.name = "poolSetpoint"
			break;
		case 7:
			map.name = "spaSetpoint"
			break;
		default:
			return [:]
	// So we can respond with same format
	state.size = cmd.size
	state.scale = cmd.scale
	state.precision = cmd.precision
	createEvent(map)
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd) {
    def result = []
		result = createEvent(name: "switch", value: "off")
		result = createEvent(name: "switch", value: "on")
    result
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicGet cmd) {
    def cmds = []
	int val = device.currentValue("switch1").equals("on") ? 0xFF : 0
    cmds << zwave.basicV1.basicReport(value: val)
	delayBetweenLog(cmds)
//Fabricate endpoint info based on the number of real endpoints in the device, plus extras for virtual switches
private List createEndpointInfo(int endPoints) {
	def eps = []
	def int endpointCnt = endPoints + 1 + 4		// 1 for Pool/Spa + 4 for VSP speed
	for (def i=1;i<=endpointCnt;i++) {
		if (i==1) {
        	eps << "10012527"
//		} else if (i == 7) {
//        	eps << "110025"
        } else {
        	eps << "100025"
    log.trace "createEndpointInfo(${endPoints}) endpointCnt=${endpointCnt} eps=${eps}"
	eps
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiInstanceReport cmd) {
	state.endpointInfo = createEndpointInfo(cmd.instances)
	[ createEvent(name: "epInfo", value: util.toJson(state.endpointInfo), displayed: true, descriptionText:"")]
	state.endpointInfo = createEndpointInfo(cmd.endpoints)
def zwaveEvent(hubitat.zwave.commands.associationv2.AssociationReport cmd) {
	log.debug "got here - chan"
	log.debug "encapsulatedCommand: $encapsulatedCommand"
        } else {
			zwaveEvent(encapsulatedCommand, cmd.sourceEndPoint as Integer)
// Multi-channel event from the device
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiInstanceCmdEncap cmd) {
	def rslt = []
    def String myStr = (cmd.parameter[0] == 0) ? "off": "on"
		rslt.addAll(createMultipleEvents(cmd.instance, cmd.commandClass, cmd.command, cmd.parameter[0], myStr))
	} else {
		log.warn "MultiInstanceCmdEncap: Could not de-encapsulate!!!"
    rslt
// Used to update our own switches state as well as the exposed Multi-channel switches
private List sendMultipleEvents (Integer instance, Integer cmdClass, Integer cmdVal, Integer externalParm, String myParm) {
        log.debug "..... sendMultipleEvents( instance:$instance, cmdClass:$cmdClass, cmdVal:$cmdVal, externalParm:$externalParm, myParm:$myParm)"
	def rslt = createMultipleEvents(instance, cmdClass, cmdVal, externalParm, myParm)
	rslt.each {e ->
			log.debug "<<<<< Event: $e"
		sendEvent(e)
	null
private List createMultipleEvents (Integer instance, Integer cmdClass, Integer cmdVal, Integer externalParm, String myParm) {
	def rslt = []
        log.debug "..... createMultipleEvents( instance:$instance, cmdClass:$cmdClass, cmdVal:$cmdVal, externalParm:$externalParm, myParm:$myParm)"
    if (state.enabledEndpoints.find { it == instance }) {
        def formatCmd = ([cmdClass, cmdVal] + externalParm).collect{ String.format("%02X", it) }.join()
        rslt << createEvent(name: "epEvent", value: "$instance:$formatCmd", isStateChange: true, displayed: true, descriptionText: "(fwd to ep $instance)")
    } else {
    	log.trace "CME: CANT'T FIND INSTANCE: $instance  enabledEndpoints:${state.enabledEndpoints}"
    if (cmdClass == 0x25 && cmdVal == 3) {
        def sw = getSWITCH_NAME(instance)
        rslt << createEvent(name: "$sw", value: "$myParm", isStateChange: true, displayed: true, descriptionText: "($sw set to $myParm)")
    rslt
    log.warn "Captured zwave command $cmd"
//Commands
// Called from the Multi-command SmartApp with a command string separated by commas
def List epCmd(Integer ep, String cmds) {
	def rslt = []
	    log.debug "+++++ epCmd: ep:$ep cmds:$cmds"
    cmds.tokenize(",").each {tok ->
        def op = null
        def val = 0
        if (tok.contains('delay')){
        } else if (tok.contains('2001FF')){
            op = "Set"
            val = 0xFF
        } else if (tok.contains('200100')) {
            op = "Set"
        } else if (tok.contains('2001')) {
			val = tok[4..5].toInteger()
            op = "Set"
			log.debug "contained 2001 and parm=${val}"
        } else if (tok.contains('2002')) {
            op = "Get"
        } else if (tok.contains('2502')) {
            op = "Get"
        } else if (tok.contains('2602')) {
            op = "Get"
            log.debug "contained 2602  Switch Multi-level Get"
        } else {
            log.warn "ep Cmd not recognized: $tok"
		if (op) {
			switch (ep) {
                case 1:
                case 2:
                case 3:
                case 4:
                case 5:
                    rslt.addAll(epSendToDevice(ep, op, val))
                    break
                case 6:
					if (op.equals("Set")) {
                    	rslt.addAll(setPoolSpaMode(val))
                    } else {
                    	rslt.addAll(getPoolSpaMode())
                    break
                case 7:
                case 8:
                case 9:
                case 10:
                	// Convert switch endpoint to a VSP speed
                        if (val > 0) {
                            val = ep - 6
                        rslt.addAll(setVSPSpeedInternal( val ))
                    } else {
                    	rslt.addAll(getVSPSpeed())
                    break
	delayBetweenLog(rslt)
// Forward on the Get or Set to the physical devicce as a Multi-channel encapsulated command
private List epSendToDevice(Integer ep, String op, Integer val) {
	def rslt = []
		rslt << encap(zwave.switchBinaryV1.switchBinarySet(switchValue: val), ep)
    } else {
		rslt << encap(zwave.switchBinaryV1.switchBinaryGet(), ep)
		log.debug "..... encap() cmd:$cmd endpoint:$endpoint"
	if (endpoint) {
//		zwave.multiChannelV3.multiChannelCmdEncap(destinationEndPoint:endpoint, sourceEndPoint: endpoint).encapsulate(cmd)
		zwave.multiChannelV3.multiInstanceCmdEncap(instance: endpoint).encapsulate(cmd)
	} else {
		cmd
		log.debug "+++++ enableEpEvents() enabledEndpoints: $enabledEndpoints"
	log.debug "state: $state"
	null
def List poll() {
	log.debug "+++++ poll()"
//	refreshLight()
	getWaterTemp()
def List updated() {
	log.debug "+++++ updated()  ${state.VersionInfo}"
	initUILabels()
	def lightCircuits = []
	if (C1ColorEnabled == "1") {lightCircuits << 1}
	if (C2ColorEnabled == "1") {lightCircuits << 2}
	if (C3ColorEnabled == "1") {lightCircuits << 3}
	if (C4ColorEnabled == "1") {lightCircuits << 4}
	if (C5ColorEnabled == "1") {lightCircuits << 5}
    state.lightCircuitsList = lightCircuits
log.trace("lightCircuits=${lightCircuits}  C3ColorEnabled=${C3ColorEnabled}")
	configure()
private initUILabels() {
	sendEvent(name: "M1Name", value: (M1Label ? "${M1Label}" : ""), isStateChange: true, displayed: true, descriptionText: "init M1 Label to ${M1Label}")
	sendEvent(name: "M2Name", value: (M2Label ? "${M2Label}" : ""), isStateChange: true, displayed: true, descriptionText: "init M2 Label to ${M2Label}")
	sendEvent(name: "M3Name", value: (M3Label ? "${M3Label}" : ""), isStateChange: true, displayed: true, descriptionText: "init M3 Label to ${M3Label}")
	sendEvent(name: "M4Name", value: (M4Label ? "${M4Label}" : ""), isStateChange: true, displayed: true, descriptionText: "init M4 Label to ${M4Label}")
def List refresh() {
	log.debug "+++++ refresh()  ${state.VersionInfo}"
    def cmds = []
    	compareConfig()
        state.ccVersions = [:]
        getSupportedCmdClasses().each {cc ->
            cmds << zwave.versionV1.versionCommandClassGet(requestedCommandClass: cc)
    cmds.addAll(refreshLight())
 	if (0 || debugLevel <= "1") {
        cmds << zwave.configurationV2.configurationGet(parameterNumber: 1)
        cmds << zwave.configurationV2.configurationGet(parameterNumber: 2)
        cmds << zwave.configurationV2.configurationGet(parameterNumber: 3)
        cmds << zwave.configurationV2.configurationGet(parameterNumber: 19)
	cmds << zwave.versionV1.versionGet()
	cmds << zwave.manufacturerSpecificV1.manufacturerSpecificGet()
//	cmds << zwave.associationV2.associationGroupingsGet()
//	cmds << zwave.multiInstanceV1.multiInstanceGet(commandClass:37)
// Used by the refresh() command and also by poll()
private List refreshLight() {
    def cmds = []
	cmds.addAll(getWaterTemp())
    cmds.addAll(getPoolSpaMode())
    cmds.addAll(getVSPSpeed())
	for (int i=1;i<=5;i++) {
//		cmds << zwave.multiChannelV3.multiChannelCmdEncap(destinationEndPoint:i, sourceEndPoint: i).encapsulate(zwave.switchBinaryV1.switchBinaryGet())
	    cmds << zwave.multiInstanceV1.multiInstanceCmdEncap(instance:i).encapsulate(zwave.switchBinaryV1.switchBinaryGet())
	    cmds.addAll( restartConfig() )
    cmds
def List configure() {
	log.debug "+++++ configure()  ${state.VersionInfo}"
    def opMode2 = operationMode2.toInteger() & 0x03
	def cmds = []
//    cmds << zwave.associationV2.associationSet(groupingIdentifier:1, nodeId:zwaveHubNodeId)
//    cmds << zwave.associationV2.associationGet(groupingIdentifier:1)
    cmds << zwave.configurationV2.configurationSet(parameterNumber: 1,  size: 2, configurationValue: [operationMode1.toInteger(), opMode2.toInteger()])
    cmds << zwave.configurationV2.configurationSet(parameterNumber: 3,  size: 4, configurationValue: [tempOffsetwater.toInteger(), tempOffsetair.toInteger(), 0, 0])
    cmds << zwave.configurationV2.configurationSet(parameterNumber: 19, size: 1, configurationValue: [poolSpa1.toInteger()])
    cmds << zwave.configurationV2.configurationSet(parameterNumber: 2,  size: 1, configurationValue: [fireman.toInteger()])
	if (debugLevel <= "1") {
	} else {
		cmds.addAll(startConfig())
		log.trace "state=$state"
log.trace "VSP_ENABLED:${VSP_ENABLED}"
    if ( !VSP_ENABLED ) {
    	cmds << createEvent(name: "swVSP1", value: "disabled", displayed: true, descriptionText:"")
    	cmds << createEvent(name: "swVSP2", value: "disabled", displayed: true, descriptionText:"")
    	cmds << createEvent(name: "swVSP3", value: "disabled", displayed: true, descriptionText:"")
    	cmds << createEvent(name: "swVSP4", value: "disabled", displayed: true, descriptionText:"")
    } else {
log.trace "POOL_SPA_COMBO:${POOL_SPA_COMBO}"
	if ( !POOL_SPA_COMBO ) {
    	cmds << createEvent(name: "poolSpaMode", value: "disabled", displayed: true, descriptionText:"poolSpaMode is disabled")
    } else {
// Query the four VSP scheduled to determine which speed is enabled
private List getVSPSpeed() {
	def cmds = []
	log.debug "+++++ getVSPSpeed()"
    if ( VSP_ENABLED ) {
        state.pumpSpeed = '0'		// Assume off unless a schedule is returned on
        for (int sp=1;sp<=4;sp++) {
            cmds << zwave.configurationV2.configurationGet(parameterNumber: getVSP_SCHED_NO(sp))
	cmds
// Select a VSP speed by forcing the appropriate schedule to always on. speed is from 1-4
// Called from the slider tile in the app
private List setVSPSpeedAndGet(Integer speed) {
	log.debug "+++++ setVSPSpeedAndGet()  speed=${speed}"
	def cmds = []
//	def l = setVSPSpeedInternal(speed)
//	log.trace("l = $l")
//	cmds.addAll(l)
	cmds.addAll(setVSPSpeedInternal(speed))
	cmds
// A speed of zero will disable all 4 speeds (off).
// Called based on commands from the Multi-channel SmartApp
private List setVSPSpeedInternal(Integer speed) {
//	log.debug "+++++ setVSPSpeedInternal()  speed=${speed}"
	def cmds = []
    	if (sp == speed) {
			cmds.addAll(setSched(getVSP_SCHED_NO(sp), 0xFF))
		} else {
			cmds.addAll(setSched(getVSP_SCHED_NO(sp), 0))
	    // The following should not be necessary except I don't consistently get replies to the ConfigurationGet
//		sendMultipleEvents ((sp + 6), 0x25, 0x03, speed, "$speed")
	cmds
def List getPoolSpaMode() {
	def cmds = []
	if ( POOL_SPA_COMBO ) {
		cmds = [zwave.configurationV2.configurationGet(parameterNumber: POOL_SPA_SCHED_PARAM)]
    cmds
private List setPoolSpaMode(Integer val) {
	def cmds = []
	def myValue = ""
	cmds.addAll(setSched(POOL_SPA_SCHED_PARAM, val))
	if (val == 0xFF) {
        myValue = "spa"
    } else {
        myValue = "pool"
	sendMultipleEvents (6, 0x25, 0x03, val, myValue)
    cmds
private List setSpaModeInternal() {
	log.debug "+++++ setSpaMode"
	def cmds = []
	cmds.addAll(setPoolSpaMode(0xFF))
	cmds
private List setPoolModeInternal() {
	log.debug "+++++ setPoolMode"
	def cmds = []
	cmds.addAll(setPoolSpaMode(0))
	cmds
private def List togglePoolSpaModeInternal() {
	log.debug "+++++ togglePoolSpaMode: poolSpaMode:${device.currentValue("poolSpaMode")}"
	def cmds = []
    if (device.currentValue("poolSpaMode").equals("spa")) {
    } else {
	cmds
// General purpose function to set a schedule to "Always off" or "Always on"
private List setSched(int paramNum, Integer val) {
//		log.debug "+++++ setSched(paramNum:${paramNum}, val:$val)"
	def cmds = []
	if (val == 0) {
        cmds << zwave.configurationV2.configurationSet(configurationValue: [0xFF, 0xFF, 0xFF, 0xFF], size: 4, parameterNumber: paramNum)
    } else {
        cmds << zwave.configurationV2.configurationSet(configurationValue: [0x01, 0x00, 0x9F, 0x05], size: 4, parameterNumber: paramNum)
	cmds
def setPowerLevel(int pwrLvl) {
	log.debug "+++++ setPowerLevel(${pwrLvl})"
    delayBetweenLog([
		zwave.powerlevelV1.powerlevelSet(powerLevel: pwrLvl),
		zwave.powerlevelV1.powerlevelGet()
def setLightColor(int col) {
	log.debug "+++++ setColor ${col}"
	def cmds = []
	cmds = createEvent(name: "lightColor", value: "${col}", isStateChange: true, displayed: true, descriptionText: "Color set to ${col}")
def setColor() {
	def cmds = []
	int blinkCnt = device.currentValue("lightColor").toInteger()
	if (blinkCnt > 14) blinkCnt = 14;
    if (state.lightCircuitsList) {
		cmds.addAll(blink(state.lightCircuitsList, blinkCnt))
// Alternately turn a switch off then on a fixed number of times. Used to control the color of Pentair pool lights.
private def blink(List switches, int cnt) {
	log.debug "+++++ blink switches=${switches} cnt=${cnt}"
    def cmds = []
    def dly = MIN_DELAY
	for (int i=1; i<=cnt; i++) {
    	switches.each { sw ->
			if (cmds) {
				cmds << "delay ${dly}"
            cmds << zwave.multiInstanceV1.multiInstanceCmdEncap(instance: sw, commandClass:37, command:1, parameter:[0])
		    dly = MIN_DELAY
        dly = "${DELAY}"
            cmds << zwave.multiInstanceV1.multiInstanceCmdEncap(instance: sw, commandClass:37, command:1, parameter:[255])
		    dly = MIN_DELAY
        dly = "${DELAY}"
		cmds <<	zwave.multiInstanceV1.multiInstanceCmdEncap(instance: sw, commandClass:37, command:2)
//log.trace "blink() cmds=${cmds}"
	cmds
// Called by a button press for one of the "Mode" selections  (eg: M1, M2, M3, M4)
def setMode(int mode) {
	def cmds = []
	List MxSw
	String MxMode, MxTemp, MxVSP
//log.trace "M1Sw1=${M1Sw1} M1Sw2=${M1Sw2} M1Sw3=${M1Sw3} M1Sw4=${M1Sw4} M1Sw5=${M1Sw5} M1Mode=${M1Mode} M1Temp=${M1Temp} M1VSP=${M1VSP}"
	switch(mode) {
    case 1:
    	MxSw = [M1Sw1, M1Sw2, M1Sw3, M1Sw4, M1Sw5]; MxMode = M1Mode; MxTemp = M1Temp; MxVSP = M1VSP; break
    case 2:
    	MxSw = [M2Sw1, M2Sw2, M2Sw3, M2Sw4, M2Sw5]; MxMode = M2Mode; MxTemp = M2Temp; MxVSP = M2VSP; break
    case 3:
    	MxSw = [M3Sw1, M3Sw2, M3Sw3, M3Sw4, M3Sw5]; MxMode = M3Mode; MxTemp = M3Temp; MxVSP = M3VSP; break
    case 4:
    	MxSw = [M4Sw1, M4Sw2, M4Sw3, M4Sw4, M4Sw5]; MxMode = M4Mode; MxTemp = M4Temp; MxVSP = M4VSP; break
	log.debug "+++++ setMode ${mode} MxSw=${MxSw} MxMode=${MxMode} MxTemp=${MxTemp} MxVSP=${MxVSP}"
    if (MxMode == "1") {
        cmds.addAll(setPoolModeInternal())
    } else if (MxMode == "2") {
        cmds.addAll(setPoolSetpointInternal(MxTemp.toDouble()))
    } else if (MxMode == "3") {
        cmds.addAll(setSpaModeInternal())
    } else if (MxMode == "4") {
        cmds.addAll(setSpaSetpointInternal(MxTemp.toDouble()))
	MxSw.eachWithIndex {action, idx ->
    	if (action == "1") {
        	cmds.addAll(onMulti(idx+1))
        } else if (action == "2") {
        	cmds.addAll(offMulti(idx+1))
    if (VSP_ENABLED && MxVSP != "5") {
    	cmds.addAll(setVSPSpeedAndGet(MxVSP.toInteger()))
//log.trace "setMode: cmds(before)=${cmds}"
	cmds
def on() {
	log.debug "+++++ on()"
    delayBetweenLog([
//		zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint: 1, destinationEndPoint: 1, commandClass:37, command:1, parameter:[255]),
//		zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint: 1, destinationEndPoint: 1, commandClass:37, command:2)
def off() {
	log.debug "+++++ off()"
    delayBetweenLog([
//		zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint: 1, destinationEndPoint: 1, commandClass:37, command:1, parameter:[0]),
//switch instance
private List onMulti(value) {
	log.debug "+++++ onMulti($value)"
	def cmds =[
		zwave.multiInstanceV1.multiInstanceCmdEncap(instance: value, commandClass:37, command:1, parameter:[255]),
		zwave.multiInstanceV1.multiInstanceCmdEncap(instance: value, commandClass:37, command:2)
private List offMulti(value) {
	log.debug "+++++ offMulti($value)"
	def cmds =[
		zwave.multiInstanceV1.multiInstanceCmdEncap(instance: value, commandClass:37, command:1, parameter:[0]),
// Called by switch presses on the circuit buttons.
def List on1()  { delayBetweenLog(onMulti(1)) }
def List on2()  { delayBetweenLog(onMulti(2)) }
def List on3()  { delayBetweenLog(onMulti(3)) }
def List on4()  { delayBetweenLog(onMulti(4)) }
def List on5()  { delayBetweenLog(onMulti(5)) }
def List off1() { delayBetweenLog(offMulti(1)) }
def List off2() { delayBetweenLog(offMulti(2)) }
def List off3() { delayBetweenLog(offMulti(3)) }
def List off4() { delayBetweenLog(offMulti(4)) }
def List off5() { delayBetweenLog(offMulti(5)) }
// Called by slider control.
def List setVSPSpeed(sp) { delayBetweenLog(setVSPSpeedAndGet(sp)) }
// Called by switch presses on the VSP buttons.
def List setVSPSpeed0() { delayBetweenLog(setVSPSpeed(0)) }
def List setVSPSpeed1() { delayBetweenLog(setVSPSpeed(1)) }
def List setVSPSpeed2() { delayBetweenLog(setVSPSpeed(2)) }
def List setVSPSpeed3() { delayBetweenLog(setVSPSpeed(3)) }
def List setVSPSpeed4() { delayBetweenLog(setVSPSpeed(4)) }
def List setMode1() { delayBetweenLog(setMode(1)) }
def List setMode2() { delayBetweenLog(setMode(2)) }
def List setMode3() { delayBetweenLog(setMode(3)) }
def List setMode4() { delayBetweenLog(setMode(4)) }
def List setSpaMode() {delayBetweenLog(setSpaModeInternal()) }
def List setPoolMode() {delayBetweenLog(setPoolModeInternal()) }
def List togglePoolSpaMode() {delayBetweenLog(togglePoolSpaModeInternal()) }
def List quickSetSpa(degrees) {delayBetweenLog(setSpaSetpointInternal(degrees), 3000)}
def List quickSetPool(degrees) {delayBetweenLog(setPoolSetpointInternal(degrees), 3000)}
def List quickGetWaterTemp()  {delayBetweenLog(getWaterTemp()) }
// Called from all commands
def delayBetweenLog(parm, dly=DELAY) {
	def lst = parm
	def cmds =[]
	def evts =[]
	def devStr = ""
    def evtStr = ""
    if (!(parm in List)) {
    	lst = [parm]
    lst.each {l ->
//log.trace "l -> ${l}"
		if (l instanceof hubitat.device.HubAction) {log.trace "instanceof hubitat.device.HubAction"}
//        if (l instanceof hubitat.zwave.commands.associationv2.AssociationGroupingsGet) {log.trace "$l instanceof hubitat.zwave.commands.associationv2.AssociationGroupingsGet"}
		//if (l instanceof hubitat.HubAction) {log.trace "delay instanceof hubitat.zwave.commands.associationv2.AssociationGroupingsGet"}
        if (l instanceof String || l instanceof GString) {
            cmds << l
            devStr = devStr.concat(", ${l}")
//            log.trace "## String: $l"
        } else if (l instanceof List) {
            cmds << l
//            log.trace "#### LIST: $l"
        } else if (l instanceof Map) {
//          evts << l
			sendEvent(l)
			evtStr = evtStr.concat("\n<<<<< Event: $l")
//            log.trace "## Map: $l"
        } else {
            def fmt = l.format()
            if (cmds) {
				def c = cmds.last()			//check if there is already a delay prior to this
//log.trace "cmds=${cmds} c=${c}"
//	            if (c instanceof String) { log.trace "c is String take(6)=${c.take(6)}" }
//	            if (c instanceof GString) { log.trace "c is GString take(6)=${c.take(6)}" }
//	            if ((c instanceof String || c instanceof GString) && c.take(6) != "delay ") { log.trace "not = delay" }
//	            if ((c instanceof String || c instanceof GString) && c.take(6) == "delay ") { log.trace "= delay" }
	            if (!(c instanceof String || c instanceof GString) || c.take(6) != "delay ") {
	                cmds << "delay $dly"
    	            devStr = devStr.concat(", delay $dly")
            devStr = devStr.concat("\n<<<<< Dev cmd: $l  --> $fmt")
            cmds << fmt
//			log.trace "## HubAction: $l,   format()=$fmt"
    evts.addAll(cmds)
	if (evts) {
            log.debug "<<<<< dly:$dly/${DELAY}${evtStr}${devStr}"
		evts
    } else {
            log.debug "<<<<< dly:$dly/${DELAY} No Commands or Events"
    	null
// Only called from parse().
def delayResponseLog(parm, dly=DELAY) {
	def lst = parm
	def cmds =[]
	def evts =[]
	def devStr = ""
    def evtStr = ""
    	lst = [parm]
    lst.each {l ->
//		if (l instanceof hubitat.HubAction) {log.trace "delay instanceof hubitat.zwave.commands.associationv2.AssociationGroupingsGet"}
        if (l instanceof String) {
            cmds << l
            cmds << l
            evts << l
        } else {
            def fmt = response(l)
            if (cmds) {
            	c = cmds.last()			//check if there is already a delay priot to this
	            if (c.take(6) != "delay ") {
            devStr = devStr.concat("\n<<<<< Dev resp: $l  --> $fmt")
            cmds << fmt
//			log.trace "## HubAction: $l,   response()=$fmt"
    evts.addAll(cmds)
	if (evts) {
		evts
    } else {
    	null
I’ll have a look at this, looks like we’re short a command or two here.
OK, I found a couple of issues with that driver.
the MultiInstanceReport command on line 873 is implemented in the multiinstancev1 class, not multichannelv3
same goes for MultiInstanceCmdEncap on line 909, it’s implemented in multiinstancev1
This isn’t some bizarre hubitat implementation, this is per Z-Wave command class spec.
Getting my translation book . . .
sorry, replace multichannelv3 with multiinstancev1 on lines 873 and 909
there may be other issues, but lets get through both of these first.
Took your advice and did a find replace for multichannelv3 to multiinstancev1.
New error.
thanks, I’ll poke at this shortly…
Hi… with the more recent updates I am able to port over an app that will take this driver and create 10 switches… however, I am still stuck on the driver itself.
Any ideas?
So, I managed to get the device up and running by commenting out the lines with the error message.
Two things:
  1. When running the multi-channel app on the device, the app seems to complete by letting me select ā€˜Done’ but no new devices are created whereas on ST 10 devices were created;
  2. The only buttons that appear to work are on/off and pool/spa.
I will post screenshots when I am back on the LAN.
your options are:
hubitat.zwave.commands.multiinstancev1.MultiInstanceReport
or
hubitat.zwave.commands.multichannelv3.MultiChannelEndPointReport
it looks like you have a mashup of both.
Will try that when I get on the LAN…
Thanks!
So got the driver installed. It now shows a mish-mosh of information that would need to be broken apart into child devices by way of the ST Multi-Channel App… also installed (but I don’t think working correctly).
When I go to install the ST Multi-Channel App, I run through the template and all appears to ā€œinstallā€ however no child devices are created.
This is the log:
2018-03-11 16:04:02.325:errorDevice type 'vTile_ms' in namespace 'ms_w_vts' not found on line 169
[app:269](http://192.168.7.201/logs#app269)2018-03-11 16:04:02.310:debugLabel Filter Pump
[app:269](http://192.168.7.201/logs#app269)2018-03-11 16:04:00.636:errorDevice type 'vTile_ms' in namespace 'ms_w_vts' not found on line 169
[app:269](http://192.168.7.201/logs#app269)2018-03-11 16:04:00.618:debugLabel Filter Pump
I believe this causes the other errors when I try to use the device.
For instance, if I select the button for VSP1, nothing happens and I receive the following log:
2018-03-11 16:05:29.900:warnNo signature of method: java.util.LinkedHashMap.putAll() is applicable for argument types: (java.util.LinkedHashMap$Entry) values: [1=No] Possible solutions: putAll(java.util.Map), putAll(java.util.Map), putAll(java.util.Collection), putAt(java.lang.Object, java.lang.Object), putAt(java.lang.String, java.lang.Object), findAll()
[dev:257](http://192.168.7.201/logs#dev257)2018-03-11 16:05:29.082:debug+++++ getVSPSpeed()
[dev:257](http://192.168.7.201/logs#dev257)2018-03-11 16:05:29.060:debug+++++ setVSPSpeedAndGet() speed=1
[dev:257](http://192.168.7.201/logs#dev257)2018-03-11 16:05:20.186:warnNo signature of method: java.util.LinkedHashMap.putAll() is applicable for argument types: (java.util.LinkedHashMap$Entry) values: [1=No] Possible solutions: putAll(java.util.Map), putAll(java.util.Map), putAll(java.util.Collection), putAt(java.lang.Object, java.lang.Object), putAt(java.lang.String, java.lang.Object), findAll()
The device, DOES however appear to work in very limited capacity as On/Off works (turns on/off the pool light) and spa/pool will actually switch the actuator.
I simply think the error within the ST Multi Channel app is holding me back.
Any assistance would be greatly appreciated.
Thank You,
This error
vTile_ms’ in namespace ā€˜ms_w_vts’ not found…
Is telling you it can’t create the device.
In order for an app to create a child device, the specified driver (noted above) must exist in the drivers code page, or within the drivers provided on the hub.
So, unlike ST, I must first create the driver code for the device (ie. VSP1)?
Lets assume VSP1 is nothing more than a virtual on/off switch.
What sort of naming convention would I use so that my app knows/understands that my virtual switch corresponds because as far as I can tell the app should create 10 on/off switches.__
Read up on creating child devices at you know where, it will all make sense after that.
So I am really close on this one and would appreciate help.
I have installed a working driver for the Intermatic PE653 and the app ST Multi Channel
However when I run the ST Multichannel app I receive an error ****
This error means the App will not create the device because no driver for the device exists.
The driver, in this case would be an on/off switch.
I can use your github and see you have a child switch device type for hubitat but my question is how do I tell my ST Multichannel app to associate the switch child device?
It would see from reading what you have done, you created the virtual device (ie. virtual switch) and your app ?somehow? connected to that child device.
That is the part I do not understand.
My HubDuino/ST_Anything Child Devices are specifically written to work with my Service Manager App, but they are a good starting point.
One thing that was not obvious to me originally, is that you will need to change the following line in the Child Device Driver so the Parent App can successfully find the Child Driver code.
definition (name: "Child Switch", namespace: "ogiewon", author: "Dan Ogorchock") {
In the above line, the ā€œnamespaceā€ field will need to be changed to the same ā€œnamespaceā€ of your Parent App’s definition. Otherwise, if the two do not match, the Parent won’t be able to create the Child Device.
This namespace is also referenced when Adding the Child Device to the Parent App. Make sure they match. Read through my HubDuino Service Manager App to see how everything is done. It is the Glue that ties everything together.
My Architectural flow for HubDuino is:
Physical Device
Device Driver (physical)
Parent App
Child Devices (virtual)
So, the Parent needs a reference to the physical device, as it will perform all of the communications with the real-world physical device.
The Parent creates virtual Child Devices and keeps them up to date with any physical device updates.
The Child Devices implement the correct capabilities to allow other Apps to subscribe to their events AND to send commands if appropriate. If a command is received from an App, the Child needs to make a call into the Parent App, who will then call the Physical Device’s appropriate function to communicate with the real-world device.
Hope this helps.
Note: Some of my code is a little unique, especially in how my Parent App updates its children through a custom command. This was done to allow the Child device code an opportunity to tweak the incoming data per user defined preferences (e.g. converting temperatures from F to C.)
