Have you tried shutting down the hub (from the menu), removing power for ~30 seconds, booting up again, and then trying the z-wave radio firmware update?
Are you able to choose the device and firmware target? If this error happens immediately when opening the app, remove the app (red button at the bottom, or on the App Status page if you can't even get that far) and then try again.
If this all happens after a "normal" experience in the app UI, it may be helpful to share what device (manufacturer and model) this is and whether you have it securely included (some users have reported problems with S2 devices and the updater app).
EDIT: Nevermind, you're doing the radio, not a device.
I'm on the z-wave details page under settings and selecting 'Firmware Update' button on the right. I don't see where there's an option to select a device.
Yeah, sorry, I assumed it was the other way around.
So, other question: what is the output of http://hubitat.local/hub/zwaveVersion? (Replace hubitat.local with your hub IP address or, if you know, actual mDNS name.) Maybe it's not lying to you and there isn't a firmware update, though it shouldn't display if not. This will tell you for sure.
I think 7.18.1 should be available for the C-7. so it looks like the "Firmware Update" button is there for a reason (your output shows you are indeed older). I'm not sure why it's erroring out for you. Probably one for @bcopeland to look at.
Even though it says to ensure the old hub is running the latest z-wave firmware before migration, the hardware upgrade was smooth and the new hub is running fine. The new hub doesn't indicate a need for a firmware update.
Same issue here. I just finally migrated to a C7 from ST one week ago after it sat in my closet since Christmas 2022. After building a perfect z wave network with 90 wired devices, no ghost devices, and perfectly clean repair reports, I seem to wake up every morning to an empty z wave device table. Following the post on here to update the z wave firmware, I stumbled upon this firmware issue.
A bit of a disappointment that even with a perfectly set up z wave network, I have to unplug my C7 every morning to restore the z wave device table -and- I can’t upgrade the z wave firmware. I’d say it’s an even trade at this point - ST sucked, but I only had to soft restart homebridge from time to time. Kinda sucks worse to have to go down to the basement every morning and unplug, wait 2 minutes and plug back in. I might be at a net loss between that 2 minutes and the amount of time I’d otherwise spend getting up to turn on/off lights throughout the day.
Hope they figure this out soon. I don’t get much time to work on this stuff, and I want to get it done and behind me. Have a lot of automation to rewrite, but want to make sure the hardware/firmware is good before I start that massive effort.
I think if you downgrade the hub itself to 2.3.6 firmware it may work. I am guessing something with the update button got botched up with the new UI. On 2.3.7 that button was missing and they added it back in 2.3.8, possibly is broken.
Use this URL to download the last 2.3.6 release: http://HUB.IP/hub/advanced/downloadPlatform/236
It will spin for a while just let it go.
thanks but my hubs that need updating are in a remote location,, seems a little risky to start going back that far in f/w.. think i will wait for a real fix..
