Guys, is there any app for the yale lock with fingerprint that I can identify the user via digital printing?
Haven’t played with the Yale locks, but suspect the information, if available, may be in the event description; i.e. unlocked by userName [digital] or something similar.
Which lock? AFAIK, there are no Yale biometric locks that also support either their z-wave or zigbee module.
The model is Yale YMF 40
From what I saw, in the smartlife app you have the option of recognizing either via password or via fingerprint, so I believe it is possible in hubitat too, but it seems that no one has still developed this
Looks to be BT or WiFi, no Zigbee or ZWave so will require a 3rd party integration - may be possible using Alexa or GH as an intermediary also.
My lock (YMF 40), this one is integrated into the hubitat via zigbee module
Interesting, don’t see that option, but if you have it connected to HE already then you’re half way there. What driver are you using?
Edit: found the module as an addon from Yale
So back to my earlier statement, what does the event description show when you unlock via fingerprint?
The event description show when i unlock via fingerprint is this:
| id: | 147417 |
| Date: | 2021-04-28 17:44:29.000 |
| Name: | lock |
| descriptionText: | Fechadura Porta Sala was unlocked via unknown [physical] |
| isStateChange: | true |
| source: | DEVICE |
| type: | physical |
| value: | unlocked |
Looks like your current driver doesn’t recognize the fingerprint action directly. Looking at the old ST DTH to see if it handles it; if it does we may be able to port it over.
Edit: It contains code that looks like it might work and compiles (after a small change), but not sure if it works any better.
Zigbee Lock Driver Code
* ZigBee Lock
* Copyright 2015 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
import hubitat.zigbee.zcl.DataType
metadata {
definition (name: "ZigBee Lock ST", namespace: "smartthings", author: "SmartThings", genericHandler: "Zigbee") {
capability "Actuator"
capability "Lock"
capability "Polling"
capability "Refresh"
capability "Sensor"
capability "Lock Codes"
capability "Battery"
capability "Configuration"
capability "Health Check"
fingerprint profileId: "0104", inClusters: "0000,0001,0009,000A,0101,0020", outClusters: "000A,0019", manufacturer: "Yale", model: "YRD220/240 TSDB", deviceJoinName: "Yale Door Lock" //Yale Touch Screen Deadbolt Lock
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0009,000A,0101,0020", outClusters: "000A,0019", manufacturer: "Yale", model: "YRL220 TS LL", deviceJoinName: "Yale Door Lock" //Yale Touch Screen Lever Lock
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0009,000A,0101,0020", outClusters: "000A,0019", manufacturer: "Yale", model: "YRD210 PB DB", deviceJoinName: "Yale Door Lock" //Yale Push Button Deadbolt Lock
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0009,000A,0101,0020", outClusters: "000A,0019", manufacturer: "Yale", model: "YRD220/240 TSDB", deviceJoinName: "Yale Door Lock" //Yale Touch Screen Deadbolt Lock
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0009,000A,0101,0020", outClusters: "000A,0019", manufacturer: "Yale", model: "YRL210 PB LL", deviceJoinName: "Yale Door Lock" //Yale Push Button Lever Lock
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0009,000A,0101,0020", outClusters: "000A,0019", manufacturer: "Yale", model: "YRD226/246 TSDB", deviceJoinName: "Yale Door Lock" //Yale Assure Lock
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0009,000A,0101,0020,0B05", outClusters: "000A,0019", manufacturer: "Yale", model: "YRD226 TSDB", deviceJoinName: "Yale Door Lock" //Yale Assure Lock
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0009,000A,0101,0020,0B05", outClusters: "000A,0019", manufacturer: "Yale", model: "YRD446 BLE TSDB", deviceJoinName: "Yale Door Lock" //Yale Assure Lock
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0009,000A,0101,0020", outClusters: "000A,0019", manufacturer: "Yale", model: "YRD216 PBDB", deviceJoinName: "Yale Door Lock" //Yale Push Button Deadbolt Lock
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0009,000A,0101,0020", outClusters: "000A,0019", manufacturer: "Yale", model: "YRL226 TSLL", deviceJoinName: "Yale Door Lock" //Yale Assure Touch Screen Lever Lock
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0009,000A,0101,0020,0B05", outClusters: "000A,0019", manufacturer: "Yale", model: "YRL216 PB", deviceJoinName: "Yale Door Lock" //Yale Assure Keypad Lever Lock
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0004,0005,0009,0020,0101,0402,0B05,FDBD", outClusters: "000A,0019", manufacturer: "Kwikset", model: "SMARTCODE_DEADBOLT_5", deviceJoinName: "Kwikset Door Lock" //Kwikset 5-Button Deadbolt
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0004,0005,0009,0020,0101,0402,0B05,FDBD", outClusters: "000A,0019", manufacturer: "Kwikset", model: "SMARTCODE_LEVER_5", deviceJoinName: "Kwikset Door Lock" //Kwikset 5-Button Lever
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0004,0005,0009,0020,0101,0402,0B05,FDBD", outClusters: "000A,0019", manufacturer: "Kwikset", model: "SMARTCODE_DEADBOLT_10", deviceJoinName: "Kwikset Door Lock" //Kwikset 10-Button Deadbolt
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0004,0005,0009,0020,0101,0402,0B05,FDBD", outClusters: "000A,0019", manufacturer: "Kwikset", model: "SMARTCODE_DEADBOLT_10T", deviceJoinName: "Kwikset Door Lock" //Kwikset 10-Button Touch Deadbolt
fingerprint profileId: "0104", inClusters: "0000, 0003, 0101", manufacturer:"Kwikset", model:"Smartcode", deviceJoinName: "Kwikset Door Lock" //Kwikset Smartcode Lock
fingerprint profileId: "0104", inClusters: "0000, 0001, 0003, 0009, 0020, 0101, 0B05, FC00", outClusters: "000A, 0019", manufacturer: "Schlage", model: "BE468", deviceJoinName: "Schlage Door Lock" //Schlage Connect Smart Deadbolt
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0009,000A,0101,0020,0B05", outClusters: "000A,0019", manufacturer: "Yale", model: "YDD-D4F0 TSDB", deviceJoinName: "Lockwood Door Lock" //Lockwood Smart Lock
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0004,0005,0009,000A,0020,0101", outClusters: "000A,0019", manufacturer: "ASSA ABLOY iRevo", model: "iZBModule01", deviceJoinName: "Yale Door Lock" //Yale Locks (YDF30/40, YMF30/40) with old firmware (v.9.0)
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0004,0005,0009,000A,0020,0101", outClusters: "000A,0019", manufacturer: "ASSA ABLOY iRevo", model: "c700000202", deviceJoinName: "Yale Door Lock" //Yale Fingerprint Lock YDF40
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0004,0005,0009,000A,0020,0101", outClusters: "000A,0019", manufacturer: "ASSA ABLOY iRevo", model: "0700000001", deviceJoinName: "Yale Door Lock" //Yale Fingerprint Lock YMF40
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0101", outClusters: "0000,0001,0003,0101", manufacturer: "Datek", model: "ID Lock 150", deviceJoinName: "ID Lock Door Lock" //ID Lock 150 Zigbee Module by Datek
// Globals - Cluster IDs
private getCLUSTER_POWER() { 0x0001 }
private getCLUSTER_DOORLOCK() { 0x0101 }
private getCLUSTER_ALARM() { 0x0009 }
// Globals - Command IDs
private getDOORLOCK_CMD_LOCK_DOOR() { 0x00 }
private getDOORLOCK_CMD_UNLOCK_DOOR() { 0x01 }
private getDOORLOCK_CMD_USER_CODE_SET() { 0x05 }
private getDOORLOCK_CMD_USER_CODE_GET() { 0x06 }
private getDOORLOCK_CMD_CLEAR_USER_CODE() { 0x07 }
private getDOORLOCK_RESPONSE_OPERATION_EVENT() { 0x20 }
private getDOORLOCK_RESPONSE_PROGRAMMING_EVENT() { 0x21 }
private getPOWER_ATTR_BATTERY_PERCENTAGE_REMAINING() { 0x0021 }
private getDOORLOCK_ATTR_LOCKSTATE() { 0x0000 }
private getDOORLOCK_ATTR_NUM_PIN_USERS() { 0x0012 }
private getDOORLOCK_ATTR_MAX_PIN_LENGTH() { 0x0017 }
private getDOORLOCK_ATTR_MIN_PIN_LENGTH() { 0x0018 }
private getDOORLOCK_ATTR_SEND_PIN_OTA() { 0x0032 }
private getALARM_ATTR_ALARM_COUNT() { 0x0000 }
private getALARM_CMD_ALARM() { 0x00 }
private getYALE_FINGERPRINT_MAX_CODES() { 0x1E }
* Called on app installed
def installed() {
log.trace "ZigBee DTH - Executing installed() for device ${device.displayName}"
* Called on app uninstalled
def uninstalled() {
def deviceName = device.displayName
log.trace "ZigBee DTH - Executing uninstalled() for device $deviceName"
sendEvent(name: "lockRemoved", value: device.id, isStateChange: true, displayed: false)
* Executed when the user taps on the 'Done' button on the device settings screen. Sends the values to lock.
* @return The list of commands to be executed
def updated() {
try {
if (!state.init || !state.configured) {
// Executed when the lock is being paired
state.init = true
log.trace "ZigBee DTH - Returning commands for lock operation get and battery get"
def cmds = []
if (!state.configured) {
cmds << doConfigure()
cmds << zigbee.readAttribute(CLUSTER_DOORLOCK, DOORLOCK_ATTR_LOCKSTATE)
cmds << zigbee.readAttribute(CLUSTER_POWER, POWER_ATTR_BATTERY_PERCENTAGE_REMAINING)
cmds = cmds.flatten()
log.info "ZigBee DTH - updated() returning with cmds:- $cmds"
return response(cmds)
} catch (e) {
log.warn "ZigBee DTH - updated() threw exception:- $e"
return null
* Ping is used by Device-Watch in attempt to reach the device
def ping() {
log.trace "ZigBee DTH - Executing ping() for device ${device.displayName}"
refresh()
* Called by the Smart Things platform in case Polling capability is added to the device type
def poll() {
log.trace "ZigBee DTH - Executing poll() for device ${device.displayName}"
def cmds = []
def latest = device.currentState("lock")?.date?.time
if (!latest || !secondsPast(latest, 6 * 60) || secondsPast(state.lastPoll, 55 * 60)) {
state.lastPoll = now()
} else if (!state.lastbatt || now() - state.lastbatt > 53*60*60*1000) {
state.lastbatt = now()
if (cmds) {
log.info "ZigBee DTH - poll() returning with cmds:- $cmds"
return cmds
} else {
// workaround to keep polling from stopping due to lack of activity
sendEvent(descriptionText: "skipping poll", isStateChange: true, displayed: false)
return null
* Called when the user taps on the refresh button
def refresh() {
log.trace "ZigBee DTH - Executing refresh() for device ${device.displayName}"
def cmds =
zigbee.readAttribute(CLUSTER_DOORLOCK, DOORLOCK_ATTR_LOCKSTATE) +
log.info "ZigBee DTH - refresh() returning with cmds:- $cmds"
return cmds
* Configures the device to settings needed by SmarthThings at device discovery time
def configure() {
log.trace "ZigBee DTH - Executing configure() for device ${device.displayName}"
def cmds = doConfigure()
log.info "ZigBee DTH - configure() returning with cmds:- $cmds"
cmds
* Returns the list of commands to be executed when the device is being configured/paired
def doConfigure() {
log.trace "ZigBee DTH - Executing doConfigure() for device ${device.displayName}"
state.configured = true
// Device-Watch allows 2 check-in misses from device + ping (plus 2 min lag time)
sendEvent(name: "checkInterval", value: 2 * 60 * 60 + 2 * 60, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID, offlinePingable: "1"])
def cmds =
zigbee.configureReporting(CLUSTER_DOORLOCK, DOORLOCK_ATTR_LOCKSTATE,
DataType.ENUM8, 0, 3600, null) +
zigbee.configureReporting(CLUSTER_POWER, POWER_ATTR_BATTERY_PERCENTAGE_REMAINING,
DataType.UINT8, 600, 21600, 0x01) +
zigbee.configureReporting(CLUSTER_ALARM, ALARM_ATTR_ALARM_COUNT,
DataType.UINT16, 0, 21600, null)
def allCmds = refresh() + cmds + reloadAllCodes()
log.info "ZigBee DTH - doConfigure() returning with cmds:- $allCmds"
allCmds // send refresh and reloadAllCodes cmds as part of configureDevice
* Executes lock command on a Zigbee lock
def lock() {
log.trace "ZigBee DTH - Executing lock() for device ${device.displayName}"
def cmds = zigbee.command(CLUSTER_DOORLOCK, DOORLOCK_CMD_LOCK_DOOR)
log.info "ZigBee DTH - lock() returning with cmds:- $cmds"
return cmds
* Executes unlock command on a Zigbee lock
def unlock() {
log.trace "ZigBee DTH - Executing unlock() for device ${device.displayName}"
def cmds = zigbee.command(CLUSTER_DOORLOCK, DOORLOCK_CMD_UNLOCK_DOOR)
log.info "ZigBee DTH - unlock() returning with cmds:- $cmds"
return cmds
* API endpoint for server smart app to scan the lock and populate the attributes. Called only when the attributes are not populated.
* @return cmds: The command(s) fired for reading attributes
def reloadAllCodes() {
log.trace "ZigBee DTH - Executing reloadAllCodes() for device ${device.displayName}"
sendEvent(name: "scanCodes", value: "Scanning", descriptionText: "Code scan in progress", displayed: false)
def lockCodes = loadLockCodes()
sendEvent(lockCodesEvent(lockCodes))
def cmds = validateAttributes()
if (isYaleLock()) {
state.checkCode = state.checkCode ?: 1
} else {
state.checkCode = state.checkCode ?: 0
cmds += requestCode(state.checkCode)
log.info "ZigBee DTH - reloadAllCodes() returning with cmds:- $cmds"
return cmds
* API endpoint for setting a user code on a Zigbee lock
* @param codeID: The code slot number
* @param code: The code PIN
* @param codeName: The name of the code
* @returns cmds: The commands fired for creation and checking of a lock code
def setCode(codeID, code, codeName = null) {
if (!code) {
log.trace "ZigBee DTH - Executing nameSlot() for device ${device.displayName}"
nameSlot(codeID, codeName)
return
log.trace "ZigBee DTH - Executing setCode() for device ${device.displayName}"
if (isValidCodeID(codeID) && isValidCode(code)) {
log.debug "Zigbee DTH - setting code in slot number $codeID"
def cmds = []
def attrCmds = validateAttributes()
def setPayload = getPayloadToSetCode(codeID, code)
if (isYaleLock()) {
// Executing both user code set and get commands as Yale lock do not generate programming event while creating
// a user code from the SmartApp
cmds << zigbee.command(CLUSTER_DOORLOCK, DOORLOCK_CMD_USER_CODE_SET, setPayload).first()
cmds << requestCode(codeID).first()
state["setcode$codeID"] = encrypt(code.toString())
cmds = delayBetween(cmds, 4200)
} else {
def strname = (codeName ?: "Code $codeID")
state["setname$codeID"] = strname
if(attrCmds) {
cmds = attrCmds + cmds
return cmds
} else {
log.warn "Zigbee DTH - Invalid input: Unable to set code in slot number $codeID"
return null
* Validates attributes and if attributes are not populated, adds the command maps to list of commands
* @return List of command maps or empty list
def validateAttributes() {
def cmds = []
if (!state.attrAlarmCountSet) {
state.attrAlarmCountSet = true
cmds += zigbee.configureReporting(CLUSTER_ALARM, ALARM_ATTR_ALARM_COUNT,
// DOORLOCK_ATTR_SEND_PIN_OTA is sometimes getting reset to 0. Hence, writing it explicitly to 1.
cmds += zigbee.writeAttribute(CLUSTER_DOORLOCK, DOORLOCK_ATTR_SEND_PIN_OTA, DataType.BOOLEAN, 1)
if(!device.currentValue("maxCodes")) {
cmds += zigbee.readAttribute(CLUSTER_DOORLOCK, DOORLOCK_ATTR_NUM_PIN_USERS)
if(!device.currentValue("minCodeLength")) {
cmds += zigbee.readAttribute(CLUSTER_DOORLOCK, DOORLOCK_ATTR_MIN_PIN_LENGTH)
if(!device.currentValue("maxCodeLength")) {
cmds += zigbee.readAttribute(CLUSTER_DOORLOCK, DOORLOCK_ATTR_MAX_PIN_LENGTH)
log.trace "validateAttributes returning commands list: " + cmds
cmds
* API endpoint for deleting a user code on a Zigbee lock
* @returns cmds: The command fired for deletion of a lock code
def deleteCode(codeID) {
log.trace "ZigBee DTH - Executing deleteCode() for device ${device.displayName}"
def cmds = []
if (isValidCodeID(codeID)) {
log.debug "Zigbee DTH - deleting code slot number $codeID"
// Calling user code get when deleting a code because some Kwikset locks do not generate
// programming event when a code is deleted manually on the lock.
// This will also help in resolving the failure cases during deletion of a lock code.
cmds = zigbee.writeAttribute(CLUSTER_DOORLOCK, DOORLOCK_ATTR_SEND_PIN_OTA, DataType.BOOLEAN, 1)
cmds += zigbee.command(CLUSTER_DOORLOCK, DOORLOCK_CMD_CLEAR_USER_CODE, getLittleEndianHexString(codeID))
cmds += requestCode(codeID)
} else {
log.warn "Zigbee DTH - Invalid input: Unable to delete slot number $codeID"
log.info "ZigBee DTH - deleteCode() returning with cmds:- $cmds"
return cmds
* API endpoint for setting/deleting multiple user codes on a lock
* @param codeSettings: The map with code slot numbers and code pins (in case of update)
* @returns The commands fired for creation and deletion of lock codes
def updateCodes(codeSettings) {
log.trace "ZigBee DTH - Executing updateCodes() for device ${device.displayName}"
if(codeSettings instanceof String) codeSettings = util.parseJson(codeSettings)
def set_cmds = []
def get_cmds = []
codeSettings.each { name, updated ->
if (name.startsWith("code")) {
def n = name[4..-1].toInteger()
if (updated && updated.size() >= 4 && updated.size() <= 8) {
log.debug "Setting code number $n"
def setPayload = getPayloadToSetCode(n, updated)
set_cmds << zigbee.command(CLUSTER_DOORLOCK, DOORLOCK_CMD_USER_CODE_SET, setPayload).first()
if (isYaleLock()) {
get_cmds << requestCode(n).first()
} else if (updated == null || updated == "" || updated == "0") {
log.debug "Deleting code number $n"
set_cmds << zigbee.command(CLUSTER_DOORLOCK, DOORLOCK_CMD_CLEAR_USER_CODE, getLittleEndianHexString(n)).first()
} else log.warn("unexpected entry $name: $updated")
if (set_cmds && get_cmds) {
def allCmds = []
allCmds = delayBetween(set_cmds, 2200) + ["delay 2200"] + delayBetween(get_cmds, 4200)
return response(allCmds)
} else if (set_cmds) {
return response(delayBetween(set_cmds, 4200))
return null
* Renames an existing lock code slot
* @param codeSlot: The code slot number
* @param codeName The new name of the code
def nameSlot(codeSlot, codeName) {
codeSlot = codeSlot.toString()
if (lockCodes[codeSlot]) {
log.trace "ZigBee DTH - Executing nameSlot() for device $deviceName"
def oldCodeName = getCodeName(lockCodes, codeSlot)
def newCodeName = codeName ?: "Code $codeSlot"
lockCodes[codeSlot] = newCodeName
sendEvent(name: "codeChanged", value: "$codeSlot renamed", data: [ lockName: deviceName, notify: false, notificationText: "Renamed \"$oldCodeName\" to \"$newCodeName\" in $deviceName at ${location.name}" ],
descriptionText: "Renamed \"$oldCodeName\" to \"$newCodeName\"", displayed: true, isStateChange: true)
* Constructs the ZigBee command for user code get
* @return The command for user code get
def requestCode(codeID) {
return zigbee.command(CLUSTER_DOORLOCK, DOORLOCK_CMD_USER_CODE_GET, getLittleEndianHexString(codeID))
* Responsible for parsing incoming device messages to generate events
* @param description The incoming description from the device
* @return result: The list of events to be sent out
log.trace "ZigBee DTH - Executing parse() for device ${device.displayName}"
def result = null
if (description) {
if (description.startsWith('read attr -')) {
result = parseAttributeResponse(description)
} else {
result = parseCommandResponse(description)
return result
* Responsible for handling attribute responses
* @param description The description to be parsed
private def parseAttributeResponse(String description) {
Map descMap = zigbee.parseDescriptionAsMap(description)
log.trace "ZigBee DTH - Executing parseAttributeResponse() for device ${device.displayName} with description map:- $descMap"
def result = []
Map responseMap = [:]
def clusterInt = descMap.clusterInt
def attrInt = descMap.attrInt
if (clusterInt == CLUSTER_POWER && attrInt == POWER_ATTR_BATTERY_PERCENTAGE_REMAINING) {
responseMap.name = "battery"
responseMap.value = Math.round(Integer.parseInt(descMap.value, 16) / 2)
// Handling Yale locks incorrect battery reporting issue
if (reportsBatteryIncorrectly()) {
responseMap.value = Integer.parseInt(descMap.value, 16)
responseMap.descriptionText = "Battery is at ${responseMap.value}%"
} else if (clusterInt == CLUSTER_DOORLOCK && attrInt == DOORLOCK_ATTR_LOCKSTATE) {
def value = Integer.parseInt(descMap.value, 16)
responseMap.name = "lock"
if (value == 0) {
responseMap.value = "unknown"
responseMap.descriptionText = "Unknown state"
} else if (value == 1) {
responseMap.value = "locked"
responseMap.descriptionText = "Locked"
} else if (value == 2) {
responseMap.value = "unlocked"
responseMap.descriptionText = "Unlocked"
} else {
if (responseMap.value) {
/* delay this event for a second in the hopes that we get the operation event (which has more info).
If we don't get one, then it's okay to send. If we send the event with more info first, the event
with less info will be marked as not displayed
log.debug "Lock attribute report received: ${responseMap.value}. Delaying event."
runIn(1, "delayLockEvent", [data : [map : responseMap]])
return [:]
} else if (clusterInt == CLUSTER_DOORLOCK && attrInt == DOORLOCK_ATTR_MIN_PIN_LENGTH && descMap.value) {
def minCodeLength = Integer.parseInt(descMap.value, 16)
responseMap = [name: "minCodeLength", value: minCodeLength, descriptionText: "Minimum PIN length is ${minCodeLength}", displayed: false]
} else if (clusterInt == CLUSTER_DOORLOCK && attrInt == DOORLOCK_ATTR_MAX_PIN_LENGTH && descMap.value) {
def maxCodeLength = Integer.parseInt(descMap.value, 16)
responseMap = [name: "maxCodeLength", value: maxCodeLength, descriptionText: "Maximum PIN length is ${maxCodeLength}", displayed: false]
} else if (clusterInt == CLUSTER_DOORLOCK && attrInt == DOORLOCK_ATTR_NUM_PIN_USERS && descMap.value) {
def maxCodes = isYaleFingerprintLock() ? YALE_FINGERPRINT_MAX_CODES : Integer.parseInt(descMap.value, 16)
responseMap = [name: "maxCodes", value: maxCodes, descriptionText: "Maximum Number of user codes supported is ${maxCodes}", displayed: false]
} else {
log.trace "ZigBee DTH - parseAttributeResponse() - ignoring attribute response"
return null
if (responseMap.data) {
responseMap.data.lockName = deviceName
} else {
responseMap.data = [ lockName: deviceName ]
result << createEvent(responseMap)
log.info "ZigBee DTH - parseAttributeResponse() returning with result:- $result"
return result
def delayLockEvent(data) {
log.debug "Sending cached lock operation: ${data.map}"
sendEvent(data.map)
* Responsible for handling command responses
private def parseCommandResponse(String description) {
log.trace "ZigBee DTH - Executing parseCommandResponse() for device ${deviceName}"
def result = []
def data = descMap.data
def cmd = descMap.commandInt
if (clusterInt == CLUSTER_DOORLOCK && (cmd == DOORLOCK_CMD_LOCK_DOOR || cmd == DOORLOCK_CMD_UNLOCK_DOOR)) {
log.trace "ZigBee DTH - Executing DOOR LOCK/UNLOCK SUCCESS for device ${deviceName} with description map:- $descMap"
// Reading lock state with a delay of 4200 as some locks do not report their state change
def cmdList = []
cmdList << "delay 4200"
cmdList << zigbee.readAttribute(CLUSTER_DOORLOCK, DOORLOCK_ATTR_LOCKSTATE).first()
result << response(cmdList)
} else if (clusterInt == CLUSTER_DOORLOCK && cmd == DOORLOCK_RESPONSE_OPERATION_EVENT) {
log.trace "ZigBee DTH - Executing DOORLOCK_RESPONSE_OPERATION_EVENT for device ${deviceName} with description map:- $descMap"
def eventSource = Integer.parseInt(data[0], 16)
def eventCode = Integer.parseInt(data[1], 16)
responseMap.displayed = true
responseMap.isStateChange = true
def desc = ""
def codeName = ""
if (eventSource == 0) {
def codeID = Integer.parseInt(data[3] + data[2], 16)
if (!isValidCodeID(codeID, true)) {
// invalid code slot number reported by lock
log.debug "Invalid slot number := $codeID"
return null
codeName = getCodeName(lockCodes, codeID)
responseMap.data = [ codeId: codeID as String, usedCode: codeID, codeName: codeName, method: "keypad" ]
} else if (eventSource == 1) {
responseMap.data = [ method: "command" ]
} else if (eventSource == 2) {
desc = "manually"
responseMap.data = [ method: "manual" ]
switch (eventCode) {
case 1:
if(codeName) {
responseMap.descriptionText = "Locked by \"$codeName\""
} else {
responseMap.descriptionText = "Locked ${desc}"
break
case 2:
if(codeName) {
responseMap.descriptionText = "Unlocked by \"$codeName\""
} else {
responseMap.descriptionText = "Unlocked ${desc}"
break
case 3: //Lock Failure Invalid Pin
break
case 4: //Lock Failure Invalid Schedule
break
case 5: //Unlock Invalid PIN
break
case 6: //Unlock Invalid Schedule
break
case 7: // locked by touching the keypad
case 8: // locked using the key
case 13: // locked using the Thumbturn
break
case 9: // unlocked using the key
case 14: // unlocked using the Thumbturn
break
case 10: //Auto lock
responseMap.descriptionText = "Auto locked"
responseMap.data = [ method: "auto" ]
break
default:
break
} else if (clusterInt == CLUSTER_DOORLOCK && cmd == DOORLOCK_CMD_USER_CODE_SET) {
log.trace "ZigBee DTH - Executing DOORLOCK_CMD_USER_CODE_SET for device ${deviceName} with description map:- $descMap"
def status = Integer.parseInt(data[0], 16)
switch (status) {
case 0:
log.debug "Lock code creation successful"
// Lock code creation is successful but we do not have the codeID/code number here.
// Hence, code creation success event will be sent from DOORLOCK_RESPONSE_PROGRAMMING_EVENT response.
break
case 1:
log.debug "Lock code creation failed - General failure"
break
case 2:
log.debug "Lock code creation failed - Memory full"
break
case 3:
log.debug "Lock code creation failed - Duplicate Code error"
break
default:
break
} else if (clusterInt == CLUSTER_DOORLOCK && cmd == DOORLOCK_RESPONSE_PROGRAMMING_EVENT) {
log.trace "ZigBee DTH - Executing DOORLOCK_RESPONSE_PROGRAMMING_EVENT for device ${deviceName} with description map:- $descMap"
// Programming event is generated when the user creates/updates/deletes a code manually on the lock.
// Ideally it should be generated even when the user tries to create/update a code through the
// SmartApp as well, but that is not the case with Yale locks.
responseMap.name = "codeChanged"
def codeName
case 1: // MasterCodeChanged
codeName = "Master Code"
responseMap.value = "0 set"
responseMap.descriptionText = "${getStatusForDescription('set')} \"Master Code\""
responseMap.data = [ codeName: codeName, notify: true, notificationText: "${getStatusForDescription('set')} \"$codeName\" in $deviceName at ${location.name}" ]
break
case 3: // PINCodeDeleted
if (codeID == 255) {
result = allCodesDeletedEvent()
responseMap.value = "all deleted"
responseMap.descriptionText = "Deleted all user codes"
responseMap.data = [notify: true, notificationText: "Deleted all user codes in $deviceName at ${location.name}"]
result << createEvent(name: "lockCodes", value: util.toJson([:]), displayed: false, descriptionText: "'lockCodes' attribute updated")
} else {
if (lockCodes[codeID.toString()]) {
responseMap.value = "$codeID deleted"
responseMap.descriptionText = "Deleted \"$codeName\""
responseMap.data = [ codeName: codeName, notify: true, notificationText: "Deleted \"$codeName\" in $deviceName at ${location.name}" ]
result << codeDeletedEvent(lockCodes, codeID)
break
case 2: // PINCodeAdded
case 4: // PINCodeChanged
codeName = getCodeNameFromState(lockCodes, codeID)
def changeType = getChangeType(lockCodes, codeID)
responseMap.value = "$codeID $changeType"
responseMap.descriptionText = "${getStatusForDescription(changeType)} \"$codeName\""
responseMap.data = [ codeName: codeName, notify: true, notificationText: "${getStatusForDescription(changeType)} \"$codeName\" in $deviceName at ${location.name}" ]
result << codeSetEvent(lockCodes, codeID, codeName)
} else {
break
default:
break
} else if (clusterInt == CLUSTER_DOORLOCK && cmd == DOORLOCK_CMD_USER_CODE_GET) {
log.trace "ZigBee DTH - Executing DOORLOCK_CMD_USER_CODE_GET for device ${deviceName}"
// This is called only when the user creates/updates a code using the SmartApp (in case of Yale locks)
// or when the user tries to scan the lock by calling reloadAllCodes()
def userStatus = Integer.parseInt(data[2], 16)
def codeID = Integer.parseInt(data[1] + data[0], 16)
def codeName = getCodeNameFromState(lockCodes, codeID)
// PIN code saved in the state - it will be non null only in case of Yale locks
def localCode = decrypt(state["setcode$codeID"])
// userStatus = 1 indicates that the code slot is occupied
if (userStatus == 1) {
if (localCode && isYaleLock()) {
// This will be applicable for Yale locks - both create and update through the SmartApp
// PIN code fetched from the lock
def serverCode = getCodeFromOctet(data)
if (localCode == serverCode) {
// Code set successfully
log.debug "Code matches - lock code creation successful"
} else {
// Code update failed
log.debug "Code update failed"
responseMap.value = "$codeID failed"
responseMap.descriptionText = "Failed to update code '$codeName'"
//It should be OK to mark this as duplicate pin code error because in case lock batteries are down,
// or lock is out of range, or there is wireless interference, the Lock will not be able to respond
// back with user code get response.
responseMap.data = [isCodeDuplicate: true]
} else {
// This will be applicable when a slot is found occupied during scanning of lock
// Populating the 'lockCodes' attribute after scanning a code slot
log.debug "Scanning lock - code $codeID is occupied"
responseMap.data = [ codeName: codeName ]
if ("set" == changeType) {
} else {
responseMap.displayed = false
} else {
// Code slot is empty - can happen when code creation fails or a slot is empty while scanning the lock
if (localCode != null && isYaleLock()) {
// Code slot found empty during creation of a user code
log.debug "Code creation failed"
responseMap.descriptionText = "Failed to set code '$codeName'"
def codeReportMap = [ name: "codeReport", value: codeID, data: [ code: "" ], isStateChange: true, displayed: false ]
codeReportMap.descriptionText = "Code $codeID is not set"
result << createEvent(codeReportMap)
} else if (lockCodes[codeID.toString()]) {
} else {
// Code slot is empty - can happen when a slot is found empty while scanning the lock
responseMap.value = "$codeID unset"
responseMap.descriptionText = "Code slot $codeID found empty during scanning"
clearStateForSlot(codeID)
if (codeID == state.checkCode) {
log.debug "Code scanning in progress..."
def defaultMaxCodes = isYaleLock() ? 8 : 7
def maxCodes = device.currentValue("maxCodes") ?: defaultMaxCodes
// Hard coding it to defaultMaxCodes as we do not want to scan all the codes.
maxCodes = defaultMaxCodes
if (state.checkCode >= maxCodes) {
log.debug "Code scanning complete"
state["checkCode"] = null
sendEvent(name: "scanCodes", value: "Complete", descriptionText: "Code scan completed", displayed: false)
} else {
log.debug "More codes to scan..."
state.checkCode = state.checkCode + 1
result << response(requestCode(state.checkCode))
} else if (clusterInt == CLUSTER_ALARM && cmd == ALARM_CMD_ALARM) {
log.trace "ZigBee DTH - Executing ALARM_CMD_ALARM for device ${deviceName} with description map:- $descMap"
def alarmCode = Integer.parseInt(data[0], 16)
switch (alarmCode) {
case 0: // Deadbolt Jammed
responseMap = [ name: "lock", value: "unknown", descriptionText: "Was in unknown state" ]
break
case 1: // Lock Reset to Factory Defaults
responseMap = [ name: "lock", value: "unknown", descriptionText: "Has been reset to factory defaults" ]
break
case 2: // Reserved
break
case 3: // RF Module Power Cycled
responseMap = [ descriptionText: "Batteries replaced", isStateChange: true ]
break
case 4: // Tamper Alarm - wrong code entry limit
responseMap = [ name: "tamper", value: "detected", descriptionText: "Keypad attempts exceed code entry limit", isStateChange: true ]
break
case 5: // Tamper Alarm - front escutcheon removed from main
responseMap = [ name: "tamper", value: "detected", descriptionText: "Front escutcheon removed", isStateChange: true ]
break
case 6: // Forced Door Open under Door Locked Condition
responseMap = [ name: "tamper", value: "detected", descriptionText: "Door forced open under door locked condition", isStateChange: true ]
break
case 16: // Battery too low to operate
responseMap = [ name: "battery", value: device.currentValue("battery"), descriptionText: "Battery too low to operate lock", isStateChange: true ]
break
case 17: // Battery level critical
responseMap = [ name: "battery", value: device.currentValue("battery"), descriptionText: "Battery level critical", isStateChange: true ]
break
case 18: // Battery very low
responseMap = [ name: "battery", value: device.currentValue("battery"), descriptionText: "Battery very low", isStateChange: true ]
break
case 19: // Battery low
responseMap = [ name: "battery", value: device.currentValue("battery"), descriptionText: "Battery low", isStateChange: true ]
break
default:
break
} else {
log.trace "ZigBee DTH - parseCommandResponse() - ignoring command response"
if(responseMap["value"]) {
} else {
if (result) {
result = result.flatten()
} else {
result = null
log.debug "ZigBee DTH - parseCommandResponse() returning with result:- $result"
return result
* Creates the event map for user code creation
* @param lockCodes: The user codes in a lock
* @param codeName: The name of the user code
* @return The list of events to be sent out
private def codeSetEvent(lockCodes, codeID, codeName) {
lockCodes[codeID.toString()] = (codeName ?: "Code $codeID")
def result = []
result << lockCodesEvent(lockCodes)
codeReportMap.descriptionText = "${device.displayName} code $codeID is set"
result
* Creates the event map for user code deletion
private def codeDeletedEvent(lockCodes, codeID) {
lockCodes.remove("$codeID".toString())
def result = []
codeReportMap.descriptionText = "${device.displayName} code $codeID was deleted"
result
* Creates the event map for all user code deletion
* @return The List of events to be sent out
private def allCodesDeletedEvent() {
def result = []
lockCodes.each { id, code ->
result << createEvent(name: "codeReport", value: id, data: [ code: "" ], descriptionText: "code $id was deleted",
displayed: false, isStateChange: true)
def codeName = code
result << createEvent(name: "codeChanged", value: "$id deleted",
data: [ codeName: codeName, lockName: deviceName, notify: true,
notificationText: "Deleted \"$codeName\" in $deviceName at ${location.name}" ],
descriptionText: "Deleted \"$codeName\"",
clearStateForSlot(id)
result
* Populates the 'lockCodes' attribute by calling send event
* @param lockCodes The codes in a lock
private Map lockCodesEvent(lockCodes) {
createEvent(name: "lockCodes", value: util.toJson(lockCodes), displayed: false, descriptionText: "'lockCodes' attribute updated")
* Reads the 'lockCodes' attribute and parses the same
* @returns Map: The lockCodes map
private Map loadLockCodes() {
parseJson(device.currentValue("lockCodes") ?: "{}") ?: [:]
* Converts the code octet to code PIN
* @param data The data map returned in case of user code get
* @return code: The code string
private def getCodeFromOctet(data) {
def code = ""
def codeLength = Integer.parseInt(data[4], 16)
if (codeLength >= device.currentValue("minCodeLength") && codeLength <= device.currentValue("maxCodeLength")) {
for (def i = 5; i < (5 + codeLength); i++) {
code += (char) (zigbee.convertHexToInt(data[i]))
return code
* Checks if the slot number is within the allowed limits
* @param codeID The code slot number
* @param allowMasterCode Flag to indicate if master code slot should be allowed as a valid slot
* @return true if valid, false if not
private boolean isValidCodeID(codeID, allowMasterCode = false) {
def defaultMaxCodes = isYaleLock() ? 250 : 30
def minCodeId = isYaleLock() ? 1 : 0
if (allowMasterCode) {
minCodeId = 0
if (codeID.toInteger() >= minCodeId && codeID.toInteger() <= maxCodes) {
return true
return false
* Checks if the code PIN is valid
* @param code The code PIN
private boolean isValidCode(code) {
def minCodeLength = device.currentValue("minCodeLength") ?: 4
def maxCodeLength = device.currentValue("maxCodeLength") ?: 8
if (code.toString().size() <= maxCodeLength && code.toString().size() >= minCodeLength && code.isNumber()) {
return true
return false
* Checks if a change type is set or update
* @return "set" or "update" basis the presence of the code id in the lockCodes map
private def getChangeType(lockCodes, codeID) {
def changeType = "set"
changeType = "changed"
changeType
* Method to obtain status for descriptuion based on change type
* @param changeType: Either "set" or "changed"
* @return "Added" for "set", "Updated" for "changed", "" otherwise
private def getStatusForDescription(changeType) {
if("set" == changeType) {
return "Added"
} else if("changed" == changeType) {
return "Updated"
//Don't return null as it cause trouble
return ""
* Checks if the time elapsed from the provided timestamp is greater than the number of senconds provided
* @param timestamp: The timestamp
* @param seconds: The number of seconds
* @returns true if elapsed time is greater than number of seconds provided, else false
private Boolean secondsPast(timestamp, seconds) {
if (!(timestamp instanceof Number)) {
if (timestamp instanceof Date) {
timestamp = timestamp.time
} else if ((timestamp instanceof String) && timestamp.isNumber()) {
timestamp = timestamp.toLong()
} else {
return true
return (now() - timestamp) > (seconds * 1000)
* Clears the code name and pin from the state basis the code slot number
def clearStateForSlot(codeID) {
state.remove("setname$codeID")
state["setname$codeID"] = null
if (isYaleLock()) {
state.remove("setcode$codeID")
state["setcode$codeID"] = null
* Constructs the payload for setting a code
* @returns payload: The payload for setting a code
def getPayloadToSetCode(codeID, code) {
def payload = "" + getLittleEndianHexString(codeID)
payload += " " + getUserStatusForOccupied() + " " + getDefaultUserType()
payload += " " + getOctetStringForCode(code)
payload
* Returns the value 1 (Occupied/Enabled) for user status
def getUserStatusForOccupied() {
return "01"
* Returns the value 0 (Unrestricted User - default) for user type
def getDefaultUserType() {
return "00"
* Converts the code PIN to octet string
* @return octetCode: The code equivalent in octet string
def getOctetStringForCode(code) {
def octetStr = "" + zigbee.convertToHexString(code.length(), 2)
for(int i = 0; i < code.length(); i++) {
octetStr += " " + zigbee.convertToHexString((int) code.charAt(i), 2)
octetStr
* Returns hex string in little endian format
def getLittleEndianHexString(numStr) {
return zigbee.swapEndianHex(zigbee.convertToHexString(numStr.toInteger(), 4))
* Utility function to check if the lock manufacturer is Yale
* @return true if the lock manufacturer is Yale, else false
def isYaleLock() {
return "Yale" == device.getDataValue("manufacturer")
def isYaleFingerprintLock() {
return "ASSA ABLOY iRevo" == device.getDataValue("manufacturer") && ("iZBModule01" || "c700000202" || "0700000001" == device.getDataValue("model"))
* Utility function to check for specific models of Yale Lock that don't report battery correctly
* @return true if the lock has the bug
def reportsBatteryIncorrectly() {
def badModels = [
"YRD220/240 TSDB",
"YRL220 TS LL",
"YRD210 PB DB",
"YRD220/240 TSDB",
"YRL210 PB LL",
return (isYaleLock() && device.getDataValue("model") in badModels)
* Reads the code name from the device state
* @param lockCodes: map with lock code names
* @returns The code name
private String getCodeNameFromState(lockCodes, codeID) {
if (isMasterCode(codeID) && isYaleLock()) {
return "Master Code"
def nameFromLockCodes = lockCodes[codeID.toString()]
def nameFromState = state["setname$codeID"]
if(nameFromLockCodes) {
if(nameFromState) {
//Updated from smart app
return nameFromState
} else {
//Updated from lock
return nameFromLockCodes
} else if(nameFromState) {
//Set from smart app
//Set from lock
return "Code $codeID"
* Reads the code name from the 'lockCodes' map
private String getCodeName(lockCodes, codeID) {
lockCodes[codeID.toString()] ?: "Code $codeID"
* Utility function to figure out if code id pertains to master code or not
* @param codeID - The slot number in which code is set
* @return - true if slot is for master code, false otherwise
private boolean isMasterCode(codeID) {
if(codeID instanceof String) {
codeID = codeID.toInteger()
(codeID == 0) ? true : false
The tiles section is unnecessary on Hubitat and can be removed.
I usually catch that...gone now.
Thank you for your support. I tried this drive, but it didn't work, so I changed the Yale lock drive to the Generic zigbee lock and he gave me this feedback here:
| d: | 148003 |
| Date: | 2021-04-28 21:27:32.000 |
| Name: | lastCodeName |
| descriptionText: | Fechadura Porta Sala was unlocked by unknown codeNumber: 1 |
| source: | DEVICE |
| value: | unknown codeNumber: 1 |
That’s actually progress. Wouldn’t take much to pull together a small app to take the codeNumber, and issue a getCodes to pull back the name value from the lockCodes map. Should also be able to do the same thing in Rule Machine or webCoRE for that matter.
Guess the next question is what format are you envisioning the name return to be in, i,e. do you just want to be able to see a list of who unlocked it with time and date, or are you wanting a push notification of some sort, or???
I'd like to see a list of who unlocked it with time, date and push notification, I tried with rule machine but don't work!
Definitely sounds doable. Might take a couple of days to throw together a prototype given my schedule, but the highlevel plan would be to have the notifications triggered from a subscription to the unlock event, and to have the display use the statesSince() method on the device to pull all of the unlocked statuses of the lock attribute from a given date forward.
Edit: Just noticed that you are getting a lastCodeName event, will be easier to check that state and use the value for look up.
I tried it also via Lock code manager, but when I register the user and add the position of the digital code it is "pending" and then "failed"
My guess is that the fingerprint storage will need to be done via the Yale app, but once stored pulling the data back out shouldn’t be a herculean task.
By the lock code manager I think it would be the easiest way, but unfortunately he asks to associate the pin registered in the lock, however the digital registration does not have the option of associating a pin. So whenever I try, I make a mistake. Only solution would be for the app developer to edit the app to accept fingerprint
