For shits and giggles, can you arm the keypad between attempts? Memory says I had to do this for an Iris keypad that I think is very similar to the one you’ve used.
I'm just using the "Keypad codes" trigger which lets me select specific people.
The Security Keypad -> Disarmed does not let me select specific codes... and it's not clear if this would only trigger if it were previously armed or not.
@mike.maxwell Not sure if this is helpful - but I noticed an issue with this tonight with an existing integration through Maker API.
From what I am seeing, the event history shows the event:
Oh this is great news! I have a lot of guests, and I cannot trigger anything from my keypad currently, regardless of using lastCodeName. I guess the system uses that internally when utilizing the trigger function for keypads. Thanks for the update.
When I punch my code into he keypad, the logs show that it is toggling between armed and disarmed. Neither triggers the rule, but since the rule is "keypad code entered", it should be subscribed to both armed & disarmed events I'd think...
