Hello. I'm trying to boot up my PC but seems that WakeOnLan v1.01
its not working.
Does it exist new/working app that could send WOL packets and preferably also shut down windows pc?
its not working.
How did you verify that the WakeOnLan app is not working? Did you do a network capture with wireshark ?
Is your computer configured for WOL and have you ensured it is not going into S4/S5 sleep state where WOL is generally not available.
The hub doesn’t have a built-in wake-on-lan app, can you clarify which developer’s code you were using?
Most likely this one and it's better to post for help in there.
Hi. I use "WAKE ON LAN" mentioned by Navat604. I can't add link to my post.
however its not waking up pc. When I'm sending wol command from my mac it works so PC is ok:
sh-3.2# wakeonlan 40:16:3b:e:be:7e
Sending magic packet to 255.255.255.255:9 with payload 40:16:3b:e:be:7e
Hardware addresses: <total=1, valid=1, invalid=0>
Magic packets: <sent=1>
With the PC on, have you run wireshark in the two scenarios? Compared the network traffic?
Do you have VLANs or other advanced network features enabled?
Is your Mac wired or wireless? What about your Hubitat ?
Join the Owners group and that will elevate your community privileges allowing you to add links, etc:
https://community.hubitat.com/g/owners
