I installed a Zooz Zen30 today for my front porch lights, with the lights connected to the dimmer switch. As I expand my zwave network, I will also eventually have my back porch light and outside garage lights on smart switches. So I figured I'd go ahead and make a group, and call it Outdoor Lights. Right now, there is just this single dimmer switch added. It looks like this. Side questions, how does "use group device to indicate of any members are on?" work exactly? It would be nice if some of these options had tooltips or something. What I assume it means, is lets say there are 4 switches in the group, if any of the switches are on, the "Outside Lights" group will report as being on. Is this correct?
I created a simple automation rule to turn this group on at 50% brightness 30 minutes after sunset. There are no restrictions.
The light did not come on. As far as I can tell, there was no log entry created for it either. I'm on platform version 2.2.2.129 (I will probably skip 2.2.3 after seeing all the problems posted. Here is what I see under System Events for the sunset time. So the light should have turned on at 8:08pm.
sunsetTime | 2020-09-13T23:36:00.000Z | API | 2020-09-12 07:38:00.221 PM EDT
I'm not even sure where to start troubleshooting this.
