This is generally dependent on the app/service developer’s inclination to add support for Pushover’s API, as Hubitat did.
kflick:
Huh... cool. I do see the retry interval on mine, but in the "Default Message Priority" box, I only see Low, Normal, and High, with no Emergency selection.
The easiest way to set the priority of a Pushover notification is to embed it with in the actual message text as a prefix, as described below. This works for both the Hubitat driver, as well as mine.
Prefixes
[L] - Low
[N] - Normal
[H] - High
E.g.. Message "[H]This is a test" will send "This is a test" with High Priority to your mobile app.
[E] prefix is now used for emergency notifications and requires the following parameters
retry - how often to resend notification until it is acknowledged (in seconds with a minimum of 30 seconds)
expire - timeout for resending notifications if they are never acknowledged (in seconds with a maximum of 10800)
