I'm not sure if it will work if you manually change it. It does work when the volume changes when the mode changes to night. I think it requires the mini to report a volume. Perhaps when you manually change it, it does not report a volume back.
I would suggest just waiting and seeing if it changes and then sets back in the evening when the volume usually changes to 45% and not try to test it the way you did.
I can assure you it's not a hubitat problem, it does it using home assistant too. It's a google issue. (unless home assistant and hubitat have been copying each others code and copied a bug unknowingly haha)
The annoying thing is it can be set at 80%, you send it a command to say something and it changes to 45% and then says it.
Seems to happen more often on the newer Nest mini than the Google home mini too.
I found that most of the time this works:
Set volume to 80%
Play a 0.5 second wav/MP3 of silence
Wait 0.5 seconds
Set volume to 80%
Play your announcement
Even then, it STILL occasionally changes the volume back to 45% and plays the announcement at 45% by itself.
I tried putting an extra set of :
Set volume to 80%
Wait 0.5 seconds
At the start (so it does it twice) but then I find it occasionally doesn't play the announcement at all (think it trips some sort of anti command spam measure?)
I just watched it. With my simple rule, I saw it changing to 45 and then right back to 80 during the announcement of "system arming night." . No playing of .wav or .mp3 needed.
Digging up an oldie but goodie here. New to Hubitat, and am seeing this same 45% issue. Ive created the RM that watches for the volume change and brings it back up - but has anyone figured out the root cause of this?
