I think I may have found the issue. It seems that maybe hubitat is somehow not respecting the "night mode" settings in the google home app...so even if you have night mode disabled, enable it and go in and adjust the volume up to 80 or 90 under the night mode settings . and then go ahead and disable night mode again. I haven't had an issue since i made this change and it's the only setting I noticed was different on my mini's vs my wifi points. I think 45% volume might be the default for night mode and would explain why we are seeing the same level being set.
