In the event log, what differentiates the 'type' column for the message?
The repeat messages are virtually at the same instant, but only one of them is tagged as type = digital.
The Kwiksets zigbee locks issue multiple events, but I'll have a fix for this in platform 2.3.1...
Hi I recently installed a kwikset 914 zigbee lock and Iβm having the same problem described here. When I lock or unlock the door, there are two events logged in events and I get two notifications. I get one that says front door has been locked and I get one that says front door has been locked manually. While The lock is working the way it should, itβs kind of annoying to get two of the basically same notifications. Does anyone have anything new on this?
@mike.maxwell hi mike it seems that the double events that the zigbee locks are creating is still a problem. Am I missing something I should be doing to stop it?
can you enable debug logging, open the live logs, then lock or unlock the lock or whatever you're doing that's generating these double events?
Then post a screen shot of the logs, thanks.
@mike.maxwell
Sure, I hope copy and paste will do. These are from today, each time I unlock or lock the door lock, no matter how I do it (manually, digitally, with keypad, with code) it always will send a notification that says door was locked or unlocked and will also send one saying the door was locked or unlocked and also which method was used.
dev:1162022-09-07 11:57:26.761 aminfoFront Door Lock was locked by digital command
dev:1162022-09-07 11:57:26.756 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 20 01 0101FFFF00FFFFFFFF00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[01, 01, FF, FF, 00, FF, FF, FF, FF, 00]]
dev:1162022-09-07 11:57:26.738 aminfoFront Door Lock was locked
dev:1162022-09-07 11:57:26.736 amdebugparseAttributeResponse: [raw:E6200201010800003001, dni:E620, endpoint:02, cluster:0101, size:08, attrId:0000, encoding:30, command:0A, value:01, clusterInt:257, attrInt:0]
dev:1162022-09-07 11:57:24.266 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
dev:1162022-09-07 11:57:24.220 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
dev:1162022-09-07 11:57:22.122 amdebuglock()
dev:1162022-09-07 11:49:27.722 aminfoFront Door Lock was unlocked by digital command
dev:1162022-09-07 11:49:27.719 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 20 01 0102FFFF00FFFFFFFF00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[01, 02, FF, FF, 00, FF, FF, FF, FF, 00]]
dev:1162022-09-07 11:49:27.716 aminfoFront Door Lock was unlocked
dev:1162022-09-07 11:49:27.714 amdebugparseAttributeResponse: [raw:E6200201010800003002, dni:E620, endpoint:02, cluster:0101, size:08, attrId:0000, encoding:30, command:0A, value:02, clusterInt:257, attrInt:0]
dev:1162022-09-07 11:49:25.059 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 01 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00]]
dev:1162022-09-07 11:49:24.326 amdebugunlock()
dev:1162022-09-07 11:48:44.308 aminfoFront Door Lock was locked by digital command
dev:1162022-09-07 11:48:44.305 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 20 01 0101FFFF00FFFFFFFF00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[01, 01, FF, FF, 00, FF, FF, FF, FF, 00]]
dev:1162022-09-07 11:48:44.285 aminfoFront Door Lock was locked
dev:1162022-09-07 11:48:44.283 amdebugparseAttributeResponse: [raw:E6200201010800003001, dni:E620, endpoint:02, cluster:0101, size:08, attrId:0000, encoding:30, command:0A, value:01, clusterInt:257, attrInt:0]
dev:1162022-09-07 11:48:41.760 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
dev:1162022-09-07 11:48:41.477 amdebuglock()
dev:1162022-09-07 11:48:06.200 aminfoFront Door Lock was unlocked by digital command
dev:1162022-09-07 11:48:06.197 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 20 01 0102FFFF00FFFFFFFF00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[01, 02, FF, FF, 00, FF, FF, FF, FF, 00]]
dev:1162022-09-07 11:48:06.175 aminfoFront Door Lock was unlocked
dev:1162022-09-07 11:48:06.173 amdebugparseAttributeResponse: [raw:E6200201010800003002, dni:E620, endpoint:02, cluster:0101, size:08, attrId:0000, encoding:30, command:0A, value:02, clusterInt:257, attrInt:0]
dev:1162022-09-07 11:48:03.458 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 01 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00]]
dev:1162022-09-07 11:48:02.763 amdebugunlock()
dev:1162022-09-07 11:46:42.721 aminfoFront Door Lock was locked by digital command
dev:1162022-09-07 11:46:42.718 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 20 01 0101FFFF00FFFFFFFF00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[01, 01, FF, FF, 00, FF, FF, FF, FF, 00]]
dev:1162022-09-07 11:46:42.707 aminfoFront Door Lock was locked
dev:1162022-09-07 11:46:42.706 amdebugparseAttributeResponse: [raw:E6200201010800003001, dni:E620, endpoint:02, cluster:0101, size:08, attrId:0000, encoding:30, command:0A, value:01, clusterInt:257, attrInt:0]
dev:1162022-09-07 11:46:39.876 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
dev:1162022-09-07 11:46:39.867 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
dev:1162022-09-07 11:46:39.823 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
dev:1162022-09-07 11:46:36.543 amdebuglock()
dev:1162022-09-07 11:44:03.939 aminfoFront Door Lock was unlocked by digital command
dev:1162022-09-07 11:44:03.936 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 20 01 0102FFFF00FFFFFFFF00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[01, 02, FF, FF, 00, FF, FF, FF, FF, 00]]
dev:1162022-09-07 11:44:03.914 aminfoFront Door Lock was unlocked
dev:1162022-09-07 11:44:03.912 amdebugparseAttributeResponse: [raw:E6200201010800003002, dni:E620, endpoint:02, cluster:0101, size:08, attrId:0000, encoding:30, command:0A, value:02, clusterInt:257, attrInt:0]
dev:1162022-09-07 11:44:01.017 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 01 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00]]
dev:1162022-09-07 11:44:00.987 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 01 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00]]
dev:1162022-09-07 11:44:00.942 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 01 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00]]
dev:1162022-09-07 11:43:55.936 amdebugunlock()
dev:1162022-09-07 11:43:10.193 aminfoFront Door Lock was locked by digital command
dev:1162022-09-07 11:43:10.190 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 20 01 0101FFFF00FFFFFFFF00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[01, 01, FF, FF, 00, FF, FF, FF, FF, 00]]
dev:1162022-09-07 11:43:10.169 aminfoFront Door Lock was locked
dev:1162022-09-07 11:43:10.167 amdebugparseAttributeResponse: [raw:E6200201010800003001, dni:E620, endpoint:02, cluster:0101, size:08, attrId:0000, encoding:30, command:0A, value:01, clusterInt:257, attrInt:0]
dev:1162022-09-07 11:43:07.703 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
dev:1162022-09-07 11:43:07.359 amdebuglock()
dev:1162022-09-07 11:41:06.939 aminfoFront Door Lock was unlocked by digital command
dev:1162022-09-07 11:41:06.936 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 20 01 0102FFFF00FFFFFFFF00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[01, 02, FF, FF, 00, FF, FF, FF, FF, 00]]
dev:1162022-09-07 11:41:06.926 aminfoFront Door Lock was unlocked
dev:1162022-09-07 11:41:06.924 amdebugparseAttributeResponse: [raw:E6200201010800003002, dni:E620, endpoint:02, cluster:0101, size:08, attrId:0000, encoding:30, command:0A, value:02, clusterInt:257, attrInt:0]
dev:1162022-09-07 11:41:03.917 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 01 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00]]
dev:1162022-09-07 11:41:03.882 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 01 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00]]
dev:1162022-09-07 11:41:03.828 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 01 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00]]
dev:1162022-09-07 11:40:59.461 amdebugunlock()
dev:1162022-09-07 11:39:02.976 aminfoFront Door Lock was locked by digital command
dev:1162022-09-07 11:39:02.973 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 20 01 0101FFFF00FFFFFFFF00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[01, 01, FF, FF, 00, FF, FF, FF, FF, 00]]
dev:1162022-09-07 11:39:02.957 aminfoFront Door Lock was locked
dev:1162022-09-07 11:39:02.955 amdebugparseAttributeResponse: [raw:E6200201010800003001, dni:E620, endpoint:02, cluster:0101, size:08, attrId:0000, encoding:30, command:0A, value:01, clusterInt:257, attrInt:0]
dev:1162022-09-07 11:39:00.412 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
dev:1162022-09-07 11:38:59.971 amdebuglock()
dev:1162022-09-07 11:37:19.601 aminfoFront Door Lock was unlocked by digital command
dev:1162022-09-07 11:37:19.598 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 20 01 0102FFFF00FFFFFFFF00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[01, 02, FF, FF, 00, FF, FF, FF, FF, 00]]
dev:1162022-09-07 11:37:19.582 aminfoFront Door Lock was unlocked
dev:1162022-09-07 11:37:19.580 amdebugparseAttributeResponse: [raw:E6200201010800003002, dni:E620, endpoint:02, cluster:0101, size:08, attrId:0000, encoding:30, command:0A, value:02, clusterInt:257, attrInt:0]
dev:1162022-09-07 11:37:16.907 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 01 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00]]
dev:1162022-09-07 11:37:15.823 amdebugunlock()
dev:1162022-09-07 11:36:36.209 aminfoFront Door Lock was locked by digital command
dev:1162022-09-07 11:36:36.206 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 20 01 0101FFFF00FFFFFFFF00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[01, 01, FF, FF, 00, FF, FF, FF, FF, 00]]
dev:1162022-09-07 11:36:36.181 aminfoFront Door Lock was locked
dev:1162022-09-07 11:36:36.179 amdebugparseAttributeResponse: [raw:E6200201010800003001, dni:E620, endpoint:02, cluster:0101, size:08, attrId:0000, encoding:30, command:0A, value:01, clusterInt:257, attrInt:0]
dev:1162022-09-07 11:36:33.593 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
dev:1162022-09-07 11:36:33.195 amdebuglock()
dev:1162022-09-07 11:35:52.888 aminfoFront Door Lock was unlocked by digital command
dev:1162022-09-07 11:35:52.885 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 20 01 0102FFFF00FFFFFFFF00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[01, 02, FF, FF, 00, FF, FF, FF, FF, 00]]
dev:1162022-09-07 11:35:52.865 aminfoFront Door Lock was unlocked
dev:1162022-09-07 11:35:52.863 amdebugparseAttributeResponse: [raw:E6200201010800003002, dni:E620, endpoint:02, cluster:0101, size:08, attrId:0000, encoding:30, command:0A, value:02, clusterInt:257, attrInt:0]
dev:1162022-09-07 11:35:50.057 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 01 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00]]
dev:1162022-09-07 11:35:48.864 amdebugunlock()
dev:1162022-09-07 11:35:09.368 amdebugparseAttributeResponse: [raw:E6200201010800003001, dni:E620, endpoint:02, cluster:0101, size:08, attrId:0000, encoding:30, command:0A, value:01, clusterInt:257, attrInt:0]
dev:1162022-09-07 11:35:09.351 aminfoFront Door Lock was locked by digital command
dev:1162022-09-07 11:35:09.348 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 20 01 0101FFFF00FFFFFFFF00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[01, 01, FF, FF, 00, FF, FF, FF, FF, 00]]
dev:1162022-09-07 11:35:06.512 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
dev:1162022-09-07 11:35:06.481 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
dev:1162022-09-07 11:35:06.416 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
dev:1162022-09-07 11:35:02.063 amdebuglock()
dev:1162022-09-07 11:33:50.744 aminfoFront Door Lock was unlocked by digital command
dev:1162022-09-07 11:33:50.740 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 20 01 0102FFFF00FFFFFFFF00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[01, 02, FF, FF, 00, FF, FF, FF, FF, 00]]
dev:1162022-09-07 11:33:50.739 aminfoFront Door Lock was unlocked
dev:1162022-09-07 11:33:50.737 amdebugparseAttributeResponse: [raw:E6200201010800003002, dni:E620, endpoint:02, cluster:0101, size:08, attrId:0000, encoding:30, command:0A, value:02, clusterInt:257, attrInt:0]
dev:1162022-09-07 11:33:48.044 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 01 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00]]
dev:1162022-09-07 11:33:47.508 amdebugunlock()
dev:1162022-09-07 11:32:57.440 aminfoFront Door Lock was locked by digital command
dev:1162022-09-07 11:32:57.437 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 20 01 0101FFFF00FFFFFFFF00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[01, 01, FF, FF, 00, FF, FF, FF, FF, 00]]
dev:1162022-09-07 11:32:57.419 aminfoFront Door Lock was locked
dev:1162022-09-07 11:32:57.417 amdebugparseAttributeResponse: [raw:E6200201010800003001, dni:E620, endpoint:02, cluster:0101, size:08, attrId:0000, encoding:30, command:0A, value:01, clusterInt:257, attrInt:0]
dev:1162022-09-07 11:32:54.890 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
dev:1162022-09-07 11:32:54.680 amdebuglock()
dev:1162022-09-07 11:30:48.500 aminfoFront Door Lock was unlocked by digital command
dev:1162022-09-07 11:30:48.497 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 20 01 0102FFFF00FFFFFFFF00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[01, 02, FF, FF, 00, FF, FF, FF, FF, 00]]
dev:1162022-09-07 11:30:48.484 aminfoFront Door Lock was unlocked
dev:1162022-09-07 11:30:48.482 amdebugparseAttributeResponse: [raw:E6200201010800003002, dni:E620, endpoint:02, cluster:0101, size:08, attrId:0000, encoding:30, command:0A, value:02, clusterInt:257, attrInt:0]
dev:1162022-09-07 11:30:45.834 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 01 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00]]
dev:1162022-09-07 11:30:45.772 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 01 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00]]
dev:1162022-09-07 11:30:42.991 amdebugunlock()
dev:1162022-09-07 11:29:25.138 aminfoFront Door Lock was locked by digital command
dev:1162022-09-07 11:29:25.135 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 20 01 0101FFFF00FFFFFFFF00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[01, 01, FF, FF, 00, FF, FF, FF, FF, 00]]
dev:1162022-09-07 11:29:25.108 aminfoFront Door Lock was locked
dev:1162022-09-07 11:29:25.106 amdebugparseAttributeResponse: [raw:E6200201010800003001, dni:E620, endpoint:02, cluster:0101, size:08, attrId:0000, encoding:30, command:0A, value:01, clusterInt:257, attrInt:0]
dev:1162022-09-07 11:29:22.584 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
dev:1162022-09-07 11:29:22.535 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
dev:1162022-09-07 11:29:20.016 amdebuglock()
dev:1162022-09-07 11:27:41.740 aminfoFront Door Lock was unlocked by digital command
dev:1162022-09-07 11:27:41.737 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 20 01 0102FFFF00FFFFFFFF00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[01, 02, FF, FF, 00, FF, FF, FF, FF, 00]]
dev:1162022-09-07 11:27:41.716 aminfoFront Door Lock was unlocked
dev:1162022-09-07 11:27:41.715 amdebugparseAttributeResponse: [raw:E6200201010800003002, dni:E620, endpoint:02, cluster:0101, size:08, attrId:0000, encoding:30, command:0A, value:02, clusterInt:257, attrInt:0]
dev:1162022-09-07 11:27:38.832 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 01 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00]]
dev:1162022-09-07 11:27:38.825 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 01 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00]]
dev:1162022-09-07 11:27:38.792 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 01 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00]]
dev:1162022-09-07 11:27:34.740 amdebugunlock()
dev:1162022-09-07 11:24:32.834 aminfoFront Door Lock was locked by manual
dev:1162022-09-07 11:24:32.831 amdebugparseCommandResponse: [raw:catchall: 0104 0101 02 01 0040 00 E620 01 00 0000 20 01 020DFFFF00FFFFFFFF00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:E620, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[02, 0D, FF, FF, 00, FF, FF, FF, FF, 00]]
dev:1162022-09-07 11:24:32.820 aminfoFront Door Lock was locked
dev:1162022-09-07 11:24:32.818 amdebugparseAttributeResponse: [raw:E6200201010800003001, dni:E620, endpoint:02, cluster:0101, size:08, attrId:0000, encoding:30, command:0A, value:01, clusterInt:257, attrInt:0]
can you also post a screen shot of the data section of the driver details?, thanks
will be fixed in the next platform release.
@mike.maxwell
Thanks Mike, I appreciate the work. Iβm learning hubitat one day at a time. Itβs going well so far. Will hubitat automatically update to the next platform release or will it notify me that there is an update?
Thanks again!
You will be notified by an alert on the hub's main web-page. You can also keep up to date with news about Hub updates by "watching" the category "News and Update"/"Release Notes" on the community forum.
