Can someone explain to me why we can't use a variable within a dashboard image url field?
or any other dashboard field for that matter???
all I want to do is to be able to dynamically change the image based on a variable...
yes, I tried the conditional image server... that doesn't work.. ugh..
HELP!!!!!!
I have never tried to do this myself, but wonder if something in here might help?
DISCLAIMER: I'm no web designer and my knowledge of and interest in CSS is pretty low.
Everything I've put together in this post is through searching, inferring and experimenting and if there are omissions, mistakes or things that can be done better (which there will be plenty of I'm sure) I'd be happy to be corrected. Everything here is basic 101 stuff for people versed in html/CSS but probably might as well be Greek to everyone else.
I won't have time to put everything down initially so willโฆ
Thanks Sebastien,
however I don't see anything relating to css style Sheets supporting Hubitat variables.
CAZ
September 2, 2022, 12:24pm
4
I'm not sure exactly what you're trying to display but there are 5 variable templates in the dashboard. Boolean, decimal, number, string and time.
